IE092705-1
IE092705-1
    DBUNLIMITED
    MIC-2P_D9.6X5MM_TM
    机电元件 蜂鸣器 指示灯,内部驱动 5 V 25mA 2.73kHz 80dB @ 5V,10cm 通孔 PC 引脚
IE092705-1 数据手册
4 3 2 1 Part Number: DRAWN 6/20/2016 CJ IE092705-1 CHECKED 3/24/2017 P.D. Description: APPROVED Electro-Mechanical Indicator D 3/24/2017 C.E. This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View Bottom View Ø9.60 C 5.5 D C 5 5 2 - Ø0.6 ± 0.05 Epoxy Potting 1.5 Masking Label B A B Items Specifications Conditions Sound Pressure Level 80 dB (@ 10cm) Tone Single Resonant Frequency 2,730 ± 300 Hz Rated Voltage 5 V Voltage Range 3-7 V Max. Rated Current 25 mA Storage Temperature -30 ~ +85 °C Operating Temperature -30 ~ +85 °C REVISION HISTORY REV DESCRIPTION DATE Released from Engineering 10/21/2013 J.S. 1 Update template, specs, add missing washtab 3/23/2017 C.E. 2 Updated storage temperature 4/17/2019 C.E. NOTES Connection Method PC Pins 1) All dimensions are in mm unless otherwise noted Mount Type Thru Hole 2) All tolerances are ± 0.5 mm unless otherwise noted Housing Material PBT Weight 1 4 APPROVED 3) All parts meet RoHS g 3 4) Subject to change or redrawn without notice 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
IE092705-1 价格&库存
很抱歉,暂时无法提供与“IE092705-1”相匹配的价格&库存,您可以联系我们找货
