2BS1T1A1MTQES
2BS1T1A1MTQES
    DAILYWELL(德利威)
    SMD
    钮子开关 单刀双掷 3万次 卧贴 -30℃~+85℃
2BS1T1A1MTQES 数据手册
2B Series Sealed Sub-Miniature Toggle Switches(SMT) MATERIALS CASE & BUSHING: Glass filled nylon 6/6,flame retardant, heat stabilized (UL94v-0). ACTUATOR: Brass,chrome plated,internal O-ring seal. Standard for all actuators. SWITCH SUPPORT: Brass,tin plated. CONTACT / TERMINALS: Copper alloy,with Silver or gold plated. (See Page 37) 2B CONTACT RATING: Dependent upon contact material See Page 37. MECHANICAL LIFE: 30,000 make-and-break cycles. CONTACT RESISTANCE: 20 mȟġmax. initial @ 2-4VDC 100mA for both silver and gold plated contacts. INSULATION RESISTANCE: 1,000 Mȟġmin. DIELECTRIC STRENGTH: 1,000 Vrms min.@sea level. OPERATING TEMPERATURE: -30°C to 85°C. Toggle Switches SPECIFICATIONS HOW TO ORDER MODEL NO. ACTUATOR BUSHING TERMINATIONS TERMINAL PLATING SEAL RoHS SOLDERING E Model NO. 2BS1 SP On-None-On 2BS2 SP On-None-Mom 2BS3 SP On-Off -On 2BS4 SP Mom-Off-Mom 2BS5 SP On-Off-Mom Bushing Seal E EPOXY (std) A1 4.35 high (Std) Actuator T1 10.16 high T2 6.10 high T4 13.97 high TA Plastic,Black,10.16 high TB Plastic,Black,6.10 high Terminal plating Q Gold flash over silver R Gold C Gold over silver Terminations MT (STD) Right angle, surface mount. MZ (STD) RoHS soldering S RoHS & Lead Free We have invented the rules www.dailywell.com.tw 35 2B Series Sealed Sub-Miniature Toggle Switches(SMT) SWITCH FUNCTION SWITCH FUNCTION 2B Toggle Switches NO. POLES SP UL/CSA MODEL MODEL NO. NO. CONNECTED TERMINALS / SCHEMATIC POS.1 POS.2 POS.3 Q22B11 2BS1 ON NONE ON Q22B12 2BS2 ON NONE MOM Q22B13 2BS3 ON OFF ON Q22B14 2BS4 MOM OFF MOM Q22B15 2BS5 ON OFF MOM POS.1 POS.2 POS.3 2-3 N/A 2-1 2 (COMM) 1 2 (COMM) OPEN 3 3 1 MOM=MOMENTARY POLE OPTIONS MT P.C. MOUNTING .171 4.35 .244 6.20 EPOXY SEAL .105 2.67 .124 3.15 .030 0.76 .410 10.41 MAX. .325 8.23 .020 0.51 1 2 .143 3.63 .070 1.78 .346 8.8 .080 2.03 .040 1.02 2 3 .320 8.13 3 .200 5.08 .346 8.8 1 .240 6.10 .030 0.77 .140 3.56 .040 1.02 SPDT .080 2.03 .128 3.25 Part No. Shown : 2BS1T2A1MTRES MZ P.C. MOUNTING .171 4.35 .320 8.13 EPOXY SEAL .059 1.50 .121 3.08 .234 5.94 1 .240 6.10 .354 9.00 .276 7.00 .052 1.30 SPDT .272 6.90 2 .071 1.80 3 .100 2.54 .079 2.00 .354 9.00 .032 0.80 Part No. Shown : 2BS1TBA1MZRES ACTUATOR OPTIONS T1 T2 Ø.100 Ø2.54 TA Ø.100 Ø2.54 Ø.100 Ø2.54 .400 10.16 TB .240 6.10 Ø.100 Ø2.54 .400 10.16 PLASTIC ACTUATOR 36 We have invented the rules www.dailywell.com.tw .240 6.10 .100 2.54 .150 3.81 2B Series Sealed Sub-Miniature Toggle Switches(SMT) PACKAGING Switches available on embossed antistatic tape and reels. Tape and cover strip are conductive for use near statically sensitive components. .079 2.00 .630 16.00 .061 DIA. 1.55 .157 4.00 .260 6.60 .068 1.75 2B .795 20.20 12.992 330.00 Toggle Switches .087 2.20 1.238 31.44 1.476 37.50 .630 16.00 1.260 32.00 .873 22.18 SCALE: 10 : 1 1.118 28.40 .350 8.90 Elongated Sprocket Holes REEL INFORMATION QUANTITY PER REEL 500 / pcs SCALE: 1 : 1 CONTACT MATERIAL OPTIONS CONTACT PLATING Q C R Silver Gold over Silver Gold TERMINAL PLATING RATINGS 3 Amps with resistant load @ 120VAC or 28VDC Q = Gold flash over silver 1 Amps with resistant load @ 250VAC C = Gold over silver R = Gold 0.4 Volt - Amps ( VA ) max. @ 20V max. ( AC or DC ) SOLDERING PROCESSES REFLOW SOLDERING: Temperature Profile Recommended Soldering Temperature: 260 ± 5°C Duration of Solder Immersion: Max 5 sec. (PCB is 1.6mm in thickness) SOLDERING: Vapor phase & IR-reflow soldering can be applied. Zone Room Temperature Pre-heat (A) Time (Sec) 150°C Min 120s Soak (B) 150°C ~ 200°C Min 150s Peak (C) 200°C ~ 235°C Min 30s Peak (D) 235°C ~ 260°C Min 40s Peak (E) 260°C Max 5s Peak : 260°C (°C) 250 200 150 100 50 A B C D E Room Temperature Time (Sec) We have invented the rules www.dailywell.com.tw 37
2BS1T1A1MTQES 价格&库存
很抱歉,暂时无法提供与“2BS1T1A1MTQES”相匹配的价格&库存,您可以联系我们找货
