LT268A
LT268A
    LEVETOP(乐升)
    QFN48_EP
    LT268A 是一款针对小尺寸 MCU 屏所设计的 Uart 串口屏控制芯片。其内部采用32bit MCU 核心架构
LT268A 数据手册
LT268A 小尺寸 TFT 串 口 屏 控 制 芯 片 Small Type Uart TFT Panel Controller 规 格 书 V1.2A www.levetop.cn Levetop Semiconductor Co., Ltd. LT268A 小尺寸 TFT 串口屏控制芯片 目 录 1. 芯片介绍.................................................................................................................... 4 2. 系统应用方块图 ....................................................................................................... 4 3. 内部方块图 ............................................................................................................... 5 4. 功能简介.................................................................................................................... 5 5. 芯片脚位图 ............................................................................................................... 6 6. 引脚信号说明 ........................................................................................................... 6 6.1 Uart 串口信号 ........................................................................................................................... 6 6.2 MCU 屏接口信号 ...................................................................................................................... 7 6.3 SPI Flash 接口信号 .................................................................................................................. 8 6.4 触控屏信号 ................................................................................................................................. 8 6.5 其他控制信号 ............................................................................................................................. 9 6.6 晶振与电源信号 ......................................................................................................................10 7. 电气特性.................................................................................................................. 11 7.1 极限参数 ...................................................................................................................................11 7.2 DC 电气参数 ............................................................................................................................11 8. 硬件接口.................................................................................................................. 13 8.1 上位机 MCU 通讯接口 ..........................................................................................................13 8.2 MCU 屏的控制接口 ...............................................................................................................13 8.3 SPI Flash 控制接口 ................................................................................................................14 8.4 USB 接口 ..................................................................................................................................14 8.5 触控屏接口 ...............................................................................................................................15 8.6 背光控制接口 ...........................................................................................................................15 8.7 声音输出接口 ...........................................................................................................................16 8.8 时钟信号 ...................................................................................................................................16 8.9 复位 ............................................................................................................................................16 9. 显示功能.................................................................................................................. 17 9.1 串口指令 ...................................................................................................................................17 LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -2- LT268A 小尺寸 TFT 串口屏控制芯片 9.2 LT268A 串口屏协议表 ..........................................................................................................18 9.3 RS-232(UART) 通讯协议 ....................................................................................................21 10.参考原理图 ............................................................................................................. 23 11.封装信息.................................................................................................................. 24 12.版本记录.................................................................................................................. 26 13.版权说明.................................................................................................................. 26 LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -3- LT268A 小尺寸串口屏控制芯片 Small Type Uart TFT Panel Controller 1. 芯片介绍 LT268A 是一款针对小尺寸 MCU 屏所设计的 Uart 串口屏控制芯片。其内部采用 乐升半导体 的 32bit MCU 核心架构,主要的功能就是提供 Uart 串口通讯,让上 位机 MCU 透过简易的指令就能轻易的将要显示到 TFT 屏的内容传递给小尺寸 MCU 屏上的 TFT 驱动器(Driver),LT268A 内部硬件及程序提供图形处理功能, 能够提升 TFT 显示效率,及降低主控端 MCU 处理图形显示的时间, LT268A 支持 小尺寸 MCU 接口的 TFT 屏,通常是 3.5”以下、显示分辨率为 320*240(QVGA) 以内,提供 SPI 或 8 位的 MCU 接口。 LT268A 内部的主频可达 72MHz,含有 64K Flash、8Kbytes SRAM,除了提供 Uart 串口通讯,也提供一 SPI Flash 接口,外接的 SPI Flash 可以用来储存图片、动画、字库等信息。LT268A 可以配合 乐升半导体 开发的 PC 上位机软件(UI_Editor / UartTFT_Tool),直接在计算机上进产品的 UI 显示接口开发,除了提升显示效率外, 也大幅缩短 TFT 显示功能的开发周期。LT268A 内建串口指令功能包括图片显示、GIF 动画显示、循环图片显 示、开机画面显示、进度条显示、文字符串显示,及几何图形显示如画线、画圆、画三角形、画矩形等功能。 LT26x8 的显示功能非常适合用在有小尺寸 TFT-LCD 屏的电子产品上,如各式小家电、智能家电、工业控制 板、电子仪器、医疗设备、小型检测设备等产品。 2. 系统应用方块图 图 2-1:LT268A 设置在 LCD 模块上 LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -4- LT268A 小尺寸 TFT 串口屏控制芯片 3. 内部方块图 图 3-1:LT268A 内部方块图 4. 功能简介 ◼ 支持 Uart 串口通讯、Boudrate 达 115,200bps ◼ 内建高效 32Bit MCU 解析串口指令 ◼ 可以支持 SPI 串口 / 8bit 并口的 MCU 屏 ◼ 支持外部 SPI Flash,可储存图片、动画、字库等信息 ◼ 支持图片显示、GIF 动画显示、循环图片显示、开机画面显示、进度条显示、文字符串显示指令功能 ◼ 支持画点、线、圆、三角形、矩形等绘图指令功能 ◼ 支持 UartTFT_Tool 及 UI_Editor 开发软件 ◼ 支持电阻式/电容式触控屏 ◼ 支持 USB 更新程序及更新 SPI Flash 数据功能 ◼ 提供 PWM/GPIO 输出 ◼ 内建时钟信号源 ◼ 工作电压:3.0~3.6V ◼ QFN-48Pin LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -5- LT268A 小尺寸 TFT 串口屏控制芯片 5. 芯片脚位图 图 5-1:LT268A 引脚图(QFN-48Pin) 6. 引脚信号说明 6.1 Uart 串口信号 表 6-1:MCU 串口信号 LT268A 引脚名称 I/O 功 能 说 明 串口通信(Uart) 接收数据输入 7 RXD I 这是 Uart 串行通信接口的数据输入口,用来接收主控端的 TX 送来指令信号。 串口通信(Uart) 发送数据输出 6 TXD O 这是 Uart 串行通信接口的数据输出口,用来传送指令信号到 主控端的 RX。 忙状态输出 22 BUSY O 此脚为串口屏的忙状态输出,主控端可以由此信号了解串口屏 是否为忙状态。 LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -6- LT268A 6.2 小尺寸 TFT 串口屏控制芯片 MCU 屏接口信号 表 6-2:MCU 屏接口信号 LT268A 引脚名称 I/O 38 P_SCS# O 40 P_MISO I 42 P_MOSI O 43 SCK O 26 RS O DB[7:0] IO 25 CS# O 27 WR# O 28 RD# O 功 能 说 明 MCU 屏上的 SPI 芯片选择信号 此信号为 LT268A 对外部 SPI 屏的的片选输出。 MCU 屏上的 SPI 数据输入信号 此信号为 LT268A 由外部 SPI 屏的读取数据输入。 MCU 屏上输出到 SPI 的数据信号 此信号为 LT268A 输出数据到外部 SPI 屏。 MCU 屏上的 SPI 串行时钟信号 此引脚是提供 SPI 屏及 SPI Flash 的时钟信号输出。 输出到 MCU 屏上的的 RS/A0 信号 使用 SPI 屏时,为 LT268A 输出到 SPI 屏的 A0 信号。 5, 23, 30, 11, 34, 33, 8Bit 的 MCU 屏数据信号 这些信号为 LT268A 对外部 8Bit MCU 屏的数据传输信号。 46, 31 8Bit 的 MCU 屏芯片选择信号 这信号为 LT268A 对外部 8Bit MCU 屏的片选信号。 8Bit 的 MCU 屏写入控制信号 这信号为 LT268A 对外部 8Bit MCU 屏的数据写入信号。 8Bit 的 MCU 屏读取控制信号 这信号为 LT268A 对外部 8Bit MCU 屏的数据读取信号。 复位输出信号 32 P_RST# O 此引脚是提供 SPI 屏或是 8Bit MCU 屏的复位信号,当 P_RST# = 0 时,将对 TFT 屏产生复位动作。 LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -7- LT268A 6.3 小尺寸 TFT 串口屏控制芯片 SPI Flash 接口信号 表 6-3:SPI Flash 接口信号 LT268A 引脚名称 I/O 37 F_SCS# O 39 F_MISO I 41 F_MOSI O 43 SCK O 6.4 功 能 说 明 SPI Flash 的芯片选择信号 此信号为 LT268A 对外部 SPI Flash 的片选输出。 接收 SPI Flash 的数据输入信号 此信号为 LT268A 由外部 SPI Flash 的读取数据输入。 输出到 SPI Flash 的数据信号 此信号为 LT268A 输出数据到外部 SPI Flash。 SPI 串行时钟信号 此引脚是提供 SPI 屏及 SPI Flash 的时钟信号输出。 触控屏信号 表 6-4:触控屏信号 LT268A 14 15 16 17 引脚名称 I/O Y-, I I2C_SCL O X-, I I2C_SDA IO Y+, I CTP_INT I X+, I CTP_RST# O 功 能 说 明 电阻屏 Y- 信号 / 电容屏上 I2C 的时钟信号 使用电阻屏时接到 Y- 信号;当使用电容屏时为电容屏上的 I2C 时钟信号。 电阻屏 X- 信号 / 电容屏上 I2C 的数据信号 使用电阻屏时接到 X- 信号;当使用电容屏时为电容屏上的 I2C 数据信号。 电阻屏 Y+ 信号 / 电容屏上 I2C 的中断信号 使用电阻屏时接到 Y+ 信号;当使用电容屏时为电容屏上的 I2C 中断信号。 电阻屏 X+ 信号 / 电容屏上 I2C 的复位信号 使用电阻屏时接到 X- 信号;当使用电容屏时为电容屏上的复 位信号。 LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -8- LT268A 6.5 小尺寸 TFT 串口屏控制芯片 其他控制信号 表 6-5:其他控制信号 LT268A 引脚名称 I/O 功 能 说 明 复位输入信号 8 RST# I 当 RST# = 0 时,将对内部 MCU 产生复位动作,除了少数由 POR 才能复位的寄存器外,大多数由 MCU 控制的寄存器将回 复到默认值。 24 BL O 29 S_OUT O GPIO[0:3] IO 44, 45, 4, 21 背光控制信号 此脚为串口屏的背光控制信号。 声音输出信号 此为一专用的 PWM 输出,做为声音输出信号。 GPIO 信号 此脚位可以透过指令进行读取或是设置。 USB 数据端 (Positive) 1 DP IO 此为 USB 数据端 DP 的信号。LT268A 可以透过 USB 接口更 新内部 MCU 程序及外接 SPI Flash 内的数据。 48 DM IO 9, 10 PWM[0:1] I AIN[0:2] I 18, 19, 20 USB 数据端 (Negative) 此为 USB 数据端 DM 的信号。 PWM 输出 此为 LT268A 内部 PWM 输出,可预留做其他控制信号使用。 模拟输入 此为 LT268A 仿真信号输入,可预留做其他控制信号使用。 LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -9- LT268A 6.6 小尺寸 TFT 串口屏控制芯片 晶振与电源信号 表 6-6:晶振与电源信号 LT268A 引脚名称 I/O 3 VDD_C1 PWR 47 VDD_C2 PWR VDD PWR 3.3V 电源输入 VSS PWR GND 接地 12, 35, 36 2, 13 - Thermal Pad - 功 能 说 明 1.5V 内核电源输出 此引脚必须外接一个 1uF 和一个 0.1uF 滤波电容到地。 3.3V 内核电源输出 此引脚必须外接一个 0.1uF 滤波电容到地。 散热焊盘 IC 的背部散热焊盘直接接地。 LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -10- LT268A 小尺寸 TFT 串口屏控制芯片 7. 电气特性 7.1 极限参数 表 7-1:电气极限参数表 符 号 参 数 描 述 参 数 范 围 单 位 -0.3 ~ 5.5 V VDD 电源电压 VIN 逻辑输入电压 -0.3 ~ VDD+0.3 V VOUT 逻辑输出电压 -0.3 ~ VDD+0.3 V ≦300 mW PD 最大功耗 TOPR 工作温度范围 -20 ~ 80 ℃ TST 储存温度范围 -45 ~ 125 ℃ TSOL 最高焊接温度 260 ℃ 提示:最大极限值是指超出该工作范围时,芯片有可能损坏。推荐工作范围是指在该范围内,器件 功能正常,但并不完全保证满足个别性能指针。电气参数定义了器件在工作范围内并且在保证特定 性能指针的测试条件下的直流和交流电参数规范。对于未给定上下限值的参数,本规范不予保证其 精度,但其典型值合理反映了器件性能。 7.2 DC 电气参数 表 7-2:DC 电气参数表 Parameter Symbol Min Typical Max Unit 电源电压 Vdd 2.8 3.3/5.0 5.5 V 输入高电位 VIH 0.65*Vdd - Vdd V 输入低电位 VIL VSS - 0.35*Vdd V 输出高电位 VOH 0.8*Vdd — — V 输出低电位 VOL — — 0.1*Vdd V 上拉电阻 RPU 20 100 Kohm 下拉电阻 RPU 20 100 Kohm 低电位输出电流 @ VOL=0.1*Vdd IOL 6 mA 高电位输出电流@ VOH=0.8*Vdd IOH 6 mA 主频(Main Clock) FCLK 72 1% MHz (条件:VDD = 3.3V,TA = 25 ℃) LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -11- LT268A 小尺寸 TFT 串口屏控制芯片 表 7-3:功耗参数表 Parameter Min Typical Max Unit ADC, Cache → On -- 20 -- ADC, Cache → Off -- 16 -- USB → On -- 23 -- ADC, Cache → On -- 20 -- ADC, Cache → Off -- 16 -- USB → On -- 18 -- Sleep Mode (Ext. Interrupt Enable) -- 5 -- uA Sleep Mode (WDT1 Interrupt Enable) -- 7 -- uA ADC, Cache → On -- 21 -- ADC, Cache → Off -- 17 -- USB → On -- 24 -- ADC, Cache → On -- 21 -- ADC, Cache → Off -- 17 -- USB → On -- 19 -- Sleep Mode (Ext. Interrupt Enable) -- 6 -- uA Sleep Mode (WDT1 Interrupt Enable) -- 12 -- uA VDD = 3.3V, System Clock = 72MHZ 3.3V LDO Enable 3.3V LDO Disable mA mA VDD = 5.0V,System Clock = 72MHZ 3.3V LDO Enable 3.3V LDO Disable mA mA LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -12- LT268A 小尺寸 TFT 串口屏控制芯片 8. 硬件接口 8.1 上位机 MCU 通讯接口 LT268A 与上位机 MCU 通信的模式是透过 UART 接口,相关的软件设置及通讯协议可以参考本公 司的上下位机软件使用说明书。 图 8-1:与上位机 MCU 的通信模式 8.2 MCU 屏的控制接口 LT268A 与 MCU 型式的 TFT 屏可以透过 SPI 串口或是 8 位并口模式连接。 图 8-2:LT268A 与 SPI 接口的 MCU 模块连接 图 8-3:LT268A 与 8 位并口的 MCU 模块连接 LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -13- LT268A 8.3 小尺寸 TFT 串口屏控制芯片 SPI Flash 控制接口 LT268A 内部有 2 组 SPI Master 接口,一组如上图所示,可以接到 SPI 的 MCU 屏,另一组则是 接到外部 SPI Flash,外接的 SPI Flash 用来储存图片、动画、字库等信息,当 LT268A 收到主控端透 过 Uart 送来的串口指令后,会依据指令要求的动作到 SPI Flash 内提取图片等信息,然后将数据传 送至 MCU 屏。而透过 USB 端口可以用专用 PC 软件(参考 LT268 应用手册)更新 SPI Flash 内的数 据。 图 8-4:LT268A 连接到 SPI Flash 的应用电路 8.4 USB 接口 LT268A 提供 USB 接口,透过 USB 接口可以用专用 PC 软件更新内部 MCU 程序及外接 SPI Flash 内的数据,详细操作模式请参考 LT268 应用手册(LT268_UartTFT_AP Note_Vxx_CH.pdf)。 图 8-5:LT268A 连接到 USB 的应用电路 LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -14- LT268A 8.5 小尺寸 TFT 串口屏控制芯片 触控屏接口 LT268A 有仿真信号输入,可以用来连接电阻式触控屏,并且配合内部程序将触控信息传递给主 控端,如下图 8-5,连接电容式触控屏如下图 8-6。 图 8-6:LT268A 连接到电阻式触控屏 图 8-7:LT268A 连接到电容式触控屏 8.6 背光控制接口 LT268A 提供一背光控制接口,可以用来控制 TFT 背光,参考原理图如下: 图 8-8:背光控制参考原理图 LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -15- LT268A 8.7 小尺寸 TFT 串口屏控制芯片 声音输出接口 LT268A 提供一个由 PWM 产生的声音输出接口 S_OUT,可以用来作为声音拨放,参考原理图如 下: 图 8-9:声音输出参考原理图 8.8 时钟信号 LT268A 内部有时钟源,外部不需要使用其他晶振电路,而内部最高运行时钟频率为 72MHz。 8.9 复位 LT268A 的硬件复位来源有 2 种,2 种复位都会经过内部时钟做同步处理: – 电源开启复位(Power on Reset) – 外部复位输入信号(External Reset Pin, RST#) 此外 LT268A 还提供一硬件复位信号 P_RST#,作为给 MCU 屏进行硬件复位用,如图 8-2、8-3。 LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -16- LT268A 小尺寸 TFT 串口屏控制芯片 9. 显示功能 9.1 串口指令 LT268A 支持的 TFT 串口屏指令,包括图片静态显示、图片动态显示、文字显示、几何图形等等,如 下表 9-1 所示。而随着不同硬件与功能需求,会不定期的增加指令让 LT268A TFT 串口屏能有更广的应用。 表 9-1:LT268A 串口屏指令集 主功能 显示图片 显示控件 图片 指标与造图 显示字库 背光亮度 开机指令、 合并指令 电阻屏校验 细项功能 指令码 单张/多张图片 80h, 8Ah, 8Fh 循环播放 81h, 84h GIF 动画 88h, 89h 弹出图片 D8h 循环卷动 D9h, DBh 数字图片 90h 显示单一控件图片 A0h 取消单一控件图片 A1h 虚拟控件 A2h 取消虚拟控件 A3h 进度条指标图 B0h 环形指标图 DCh 字库-1 C0h 字库-2 C1h 字库-3 C2h 字库-4 C3h 设置亮度 BAh On/Off BCh 开机指令 9Ah 电阻屏校验指令 8Bh 主功能 几何图形 串口屏侦测 细项功能 指令码 画点 DFh 直线 E0h 空心圆形 E1h 实心圆形 E2h 带框实心圆形 E3h 空心椭圆 E4h 实心椭圆形 E5h 带框实心椭圆 E6h 空心矩形 E7h 实心矩形 E8h 带框矩形 E9h 空心圆角矩形 EAh 实心圆角矩形 EBh 带框圆角矩形 ECh 空心三角形 EDh 实心三角形 EEh 带框三角形 EFh 圆柱体 F4h 表格视窗 F6h 联机检查 BEh 版本侦测 BFh 在 使 用 TFT 串 口 屏 之 前 必 须 要 用 上 位 机 软 件 做 开 发 , 乐 升 半 导 体 提 供 了 图 文 整 合 编 译 器 (UartTFT_Tool.exe)及 图文 UI 编辑器(UI_Editor.exe)两种上位机软件,两者都可以单独对 LT268A 的 TFT 串口屏进行设置及显示功能的开发,上位机软件开发时会将使用到的图片、文字、动画等信息产生 Bin 檔,开发者可以透过 USB 及使用 LT268A_ISP_Vxx.exe 程序、或是专用的 SPI Flash 烧录器将 Bin 檔 烧录到 SPI Flash 内,然后透过 USB 转 RS232 的控制线对 TFT 串口屏进行模拟,也就是做 TFT 屏显示画 面的前期验证,详细的操作请参考 LT268 应用手册(LT268A_UartTFT_AP Note_Vxx_CH.pdf)。 LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -17- LT268A 9.2 小尺寸 TFT 串口屏控制芯片 LT268A 串口屏协议表 表 9-2:主控端与 LT268A 串口屏协议表 主 功 能 细项 功能 起始码 指令码 主 控 端 发 送 主 控 端 接 收 (TFT 串口屏接收) (TFT 串口屏发送) 序号 (1Bytes) (1Byte) (1Byte) 单张/ 指令参数 CRC 码 结束码 起始码 (2Bytes) (4Bytes) (1Bytes) 指令码 序号 1Byte) (1Byte) 信息码/ 反馈码 (1Bytes) CRC 码 结束码 (2Bytes) (4Bytes) Start 80h nn CRC End Start 80h nn 信 息 码 CRC End Start 8Ah nn CRC End Start 8Ah nn 信 息 码 CRC End 单张图片 Start 8Fh nn CRC End Start 8Fh nn 信 息 码 CRC End 循环播放 Start 81h nn CRC End Start 81h nn 信 息 码 CRC End 示 取消循环 播放 Start 84h nn CRC End Start 84h nn 信 息 码 CRC End 图 GIF 动画 Start 88h nn CRC End Start 88h nn 信 息 码 CRC End 片 取消 GIF 动 Start 89h nn CRC End Start 89h nn 信 息 码 CRC End 弹出图片 Start D8h nn CRC End Start D8h nn 信 息 码 CRC End 循环卷动 Start D9h nn CRC End Start D9h nn 信 息 码 CRC End 取消循环卷 动 Start DBh nn CRC End Start DBh nn 信 息 码 CRC End 数字图片 Start 90h nn CRC End Start 90h nn 信 息 码 CRC End Start A0h nn CRC End Start A0h nn 信 息 码 CRC End 按下控件图片时 Start A0h nn 31h CRC End 放开控件图片时 Start A0h nn 30h CRC End 多张图片 单张/ 多张图片 显 画 显示单一控 件图片 显 示 控 件 图 取消单一控 件图片 片 指 标 进度条 指标图 环形指标图 ddd.d A1h nn CRC End Start A1h nn 信 息 码 CRC End Start A2h nn CRC End Start A2h nn 信 息 码 CRC End 按下控件图片时 Start A2h nn 31h CRC End 放开控件图片时 Start A2h nn 30h CRC End Start A3h nn Start B0h nn Start DCh nn 与 造 Pnn Start 虚拟控件 取消虚拟控 件 X, Y, PNG, 图 Value (2 Bytes) S_Angle, A_Angle CRC End Start A3h nn 信 息 码 CRC End CRC End Start B0h nn 信 息 码 CRC End CRC End Start DCh nn 信 息 码 CRC End LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -18- LT268A 小尺寸 TFT 串口屏控制芯片 表 9-2:主控端与 LT268A 串口屏协议表(续) 主 功 能 细项 功能 起始码 指令码 主 控 端 发 送 主 控 端 接 收 (TFT 串口屏接收) (TFT 串口屏发送) 序号 (1Bytes) (1Byte) (1Byte) 指令参数 CRC 码 结束码 起始码 指令码 (2Bytes) (4Bytes) (1Bytes) 1Byte) 序号 (1Byte) 信息码/ 反馈码 (1Bytes) CRC 码 结束码 (2Bytes) (4Bytes) 显 字库-1 Start C0h nn 字符串 CRC End Start C0h nn 信 息 码 CRC End 示 字库-2 Start C1h nn 字符串 CRC End Start C1h nn 信 息 码 CRC End 字库-3 Start C2h nn 字符串 CRC End Start C2h nn 信 息 码 CRC End 字库-4 Start C3h nn 字符串 CRC End Start C3h nn 信 息 码 CRC End 设置亮度 Start BAh CRC End Start BAh BL (00~0Fh) 信 息 码 CRC End On/Off Start BCh CRC End Start BCh 00 或 01 信 息 码 CRC End 开机指令 开机指令 Start 9Ah 00 CRC End Start 9Ah 00 信 息 码 CRC End 合并指令 合并指令 Start 9Ah nn CRC End Start 9Ah nn 信 息 码 CRC End 电阻屏 校验 Start 8Bh CRC End Start 8Bh 00 信 息 码 CRC End 画点 Start DFh nn CRC End Start DFh nn 信 息 码 CRC End 直线 Start E0h nn CRC End Start E0h nn 信 息 码 CRC End 空心圆形 Start E1h nn CRC End Start E1h nn 信 息 码 CRC End 实心圆形 Start E2h nn CRC End Start E2h nn 信 息 码 CRC End 带框实心圆 形 Start E3h nn CRC End Start E3h nn 信 息 码 CRC End 空心椭圆 Start E4h nn CRC End Start E4h nn 信 息 码 CRC End 实心椭圆形 Start E5h nn CRC End Start E5h nn 信 息 码 CRC End 带框实心 椭圆 Start E6h nn CRC End Start E6h nn 信 息 码 CRC End 几 空心矩形 Start E7h nn CRC End Start E7h nn 信 息 码 CRC End 何 实心矩形 Start E8h nn CRC End Start E8h nn 信 息 码 CRC End 带框矩形 Start E9h nn CRC End Start E9h nn 信 息 码 CRC End 空心圆角 矩形 Start EAh nn CRC End Start EAh nn 信 息 码 CRC End Start EBh nn CRC End Start EBh nn 信 息 码 CRC End 带框圆角 矩形 Start ECh nn CRC End Start ECh nn 信 息 码 CRC End 空心三角形 Start EDh nn CRC End Start EDh nn 信 息 码 CRC End 实心三角形 Start EEh nn CRC End Start EEh nn 信 息 码 CRC End 带框三角形 Start EFh nn CRC End Start EFh nn 信 息 码 CRC End 圆柱体 Start F4h nn CRC End Start F4h nn 信 息 码 CRC End 表格视窗 Start F6h nn CRC End Start F6h nn 信 息 码 CRC End 字 串 背光 亮度 电阻屏 校验 图 形 实心圆角 矩形 BL (00~0Fh) 00 或 01 LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -19- LT268A 小尺寸 TFT 串口屏控制芯片 表 9-2:主控端与 TFT 串口屏协议表(续) 主 功 能 细项 功能 起始码 指令码 主 控 端 发 送 主 控 端 接 收 (TFT 串口屏接收) (TFT 串口屏发送) 序号 (1Bytes) (1Byte) (1Byte) 联机检查 Start BEh 指令参数 CRC 码 结束码 起始码 指令码 (2Bytes) (4Bytes) (1Bytes) 1Byte) CRC End Start BEh (1Byte) 00 信息码/ 反馈码 (1Bytes) 5Ah, or 55h CRC 码 结束码 (2Bytes) (4Bytes) CRC End CRC End MCU 串口屏 侦测 序号 Code(5Byte 版本检查 Start BFh CRC End Start BFh s) + Module 信 息 码 Info. (42Bytes) LT268A_DS_CH / V1.2A © Levetop Semiconductor Co., Ltd. Page -20- LT268A 9.3 小尺寸 TFT 串口屏控制芯片 RS-232(UART) 通讯协议 主控端的系统或是主板透过 UART 串口传递显示命令给 LT268A TFT 串口屏时,除了 指令码、序号、 指令参数 外还要加上 1 个 Byte 的 起始码(固定为 0xAA)、2 个 Byte 的 CRC 码、4 个 Byte 的 结束码 (固定为 0x E4、0x 1B、0x 11、0x EE),指令信息如下表: 表 9-3:串口屏接收的指令信息 起始码 0xAA (1 Byte) 指令码 序号 1 Byte 1 Byte 指令参数 CRC 码 n Bytes 2 Bytes 结束码 0xE4、0x1B、0x11、0xEE (4 Bytes) CRC 码协议如下: chkSum = Rx_CRC_CCITT(txBuf,txLen); txBuf[txLen++] = (chkSum>>8)&0xFF; txBuf[txLen++] = chkSum&0xFF; unsigned int Rx_CRC_CCITT(unsigned char *puchMsg, unsigned int usDataLen) { unsigned char i = 0; unsigned short wCRCin = 0x0000; unsigned short wCPoly = 0x1021; unsigned char wChar = 0; } while (usDataLen--) { wChar = *(puchMsg++); wCRCin ^= (wChar
LT268A 价格&库存
很抱歉,暂时无法提供与“LT268A”相匹配的价格&库存,您可以联系我们找货
