NSIP8821W1-DSWR
NSIP8821W1-DSWR
    NOVOSENSE(纳芯微)
    SOICW16_300MIL
    数字隔离器 2-Ch 4.5KVrms SOICW16
NSIP8821W1-DSWR 数据手册
NSiP8820/NSiP8821/NSiP8822 Dual-Channel Digital Isolators with Integrated DC to DC Converter Datasheet (EN) 1.1 Product Overview The NSiP882x devices are dual-channel digital isolators with integrated isolated DC-DC converter. The isolated DC-DC converter provides up to 500mW output power using on chip transformer. The feedback PWM signal is sent to primary side by a digital isolator based on Novosense capacity isolation technology. The high integrated solution can help to simplify system design and improve reliability. The NSiP882x device is safety certified by UL1577 support 4.5kVrms withstand voltages, while providing high electromagnetic immunity and low emissions. The data rate of the NSiP882x is up to 150Mbps, and the common-mode transient immunity (CMTI) is up to 150kV/us. The NSiP882x devices provide 5V to 5V, 5V to 3.3V, 3.3V to 3.3V conversion mode, the output voltage can be set by SEL pin.The logical level of digital isolators on left side can be set by VDDL pin which can support the application when the supply voltage and I/O voltage level are different. Key Features Safety Regulatory Approvals  UL recognition: up to 4500Vrms for 1 minute per UL1577  CQC certification per GB4943.1-2011  CSA component notice 5A  DIN VDE V 0884-11:2017-01 Applications  Industrial automation system  Isolated SPI, CAN, RS485  General-purpose multichannel isolation Device Information Part Number NSiP882x-DSWR Package SOW16 Body Size 10.30mm × 7.50mm  Up to 4500Vrms Insulation voltage  Power supply voltage: 3.3V to 5.5V Functional Block Diagrams  5V to 5V, 5V to 3.3V, support 100mA load current  3.3V to 3.3V, support 60mA load current VDD  Over current and over temperature protection  Date rate: DC to 150Mbps 16 VISO GND 1 2 15 GND2 INA 3 14 OUTA OUTB 4  High CMTI: 150kV/us  Propagation delay: 400 V DIN EN 60112 (VDE 0303-11); IEC 60112 Ⅱ 6.2. DIN VDE V 0884-11(VDE V 0884-11):2017-01 INSULATION CHARATERISTICS Description Test Condition Symbol Value Unit Installation Classification per DIN VDE 0110 For Rated Mains Voltage ≤ 150Vrms Ⅰto Ⅳ For Rated Mains Voltage ≤ 300Vrms Ⅰto Ⅲ For Rated Mains Voltage ≤ 400Vrms Ⅰto Ⅲ Climatic Classification 10/105/21 Pollution Degree per DIN VDE 0110, 2 Table 1 Maximum repetitive isolation voltage VIORM 565 Vpeak VIOWM 400 VRMS 565 VDC V pd (m) 847 Vpeak VIORM × 1.2=Vpd (m), tini = 60 sec, tm=10 sec, qpd < 5 pC V pd (m) 678 Vpeak V IORM × 1.2= V pd (m) , t ini = 60 sec, t m = 10 sec, partial discharge < 5 pC V pd (m) 678 Vpeak t = 60 sec VIOTM 5300 Vpeak VTEST= VISO, t = 60 s (qualification); VTEST= 1.2 × VISO, t = 1 s (100%production) VISO 4500 VRMS Maximum Surge Isolation Voltage Test method per IEC60065,1.2/50us waveform, VTEST=VIOSM×1.3 VIOSM 5384 Vpeak Isolation resistance VIO =500V at Tamb=TS RIO >109 Ω >1011 Ω 0.6 pF Maximum Working Isolation Voltage AC voltage DC voltage Input to Output Test Voltage, Method B1 VIORM × 1.5 = Vpd(m), 100% production test, tini = tm = 1 sec, qpd < 5 pC After Environmental Tests Subgroup 1 After Input and /or Safety Test Subgroup 2 and Subgroup 3 Maximum transient isolation voltage Maximum withstanding isolation voltage VIO =500V at 100℃≤Tamb≤125℃ Isolation capacitance Copyright © 2020, NOVOSENSE f = 1MHz CIO Page 11 NSiP8820/NSiP8821/NSiP8822 Datasheet (EN) 1.1 Input capacitance CI 2 Total Power Dissipation at 25℃ Ps 2201 mW 400 mA 150 ℃ θJA = 56.8 °C/W, VI = 5.5 V, Safety input, output, or supply current Is TJ = 150 °C, TA = 25 °C Ts Safty Limiting Current(mA) Case Temperature pF 450 400 350 300 250 200 150 100 50 0 0 50 100 150 200 250 Ambient Temperature(°C) Figure 6.1 NSiP882x Thermal Derating Curve, Dependence of Safety Limiting Values with Case Temperature per DIN VDE V 0884-11 6.3. Regulatory Information The NSiP882x are approved by the organizations listed in table. CUL UL 1577 Component Recognition Program1 VDE Approved under CSA Component Acceptance Notice 5A DIN VDE V 088411:2017-012 CQC Certified by CQC11471543-2012 GB4943.1-2011 Single Protection,4500Vrms Isolation voltage Single Protection, 4500Vrms Isolation voltage Basic Insulation 565Vpeak, VIOSM=5384Vpeak File (pending) File (pending) File (pending) Basic insulation at 400Vrms (565Vpeak) File (pending) 7. Function Description 7.1. Overview The NSiP882x devices are dual-channel digital isolators with integrated isolated DC-DC converter. The digital isolators are based on Novosense capacity isolation barrier technique.The isolated DC-DC converter provides up to 500mW output power using on chip transformer. The feedback PWM signal is sent to primary side by a digital isolator based on capacity isolation technology. The NSiP882x device are safety certified by UL1577 support 4.5kVrms insulation withstand voltages, while providing high electromagnetic immunity and low emissions. The data rate of the NSiP882x is up to 150Mbps, and the common-mode transient immunity (CMTI) is up to 150kV/us. The logical level of digital isolators on left side can be set by VDDL pin which can support the application when the supply voltage and I/O voltage level are different. Copyright © 2020, NOVOSENSE Page 12 NSiP8820/NSiP8821/NSiP8822 Datasheet (EN) 1.1 The high integrated solution can help to simplify system design and improve reliability. The NSiP882x devices are suitable for the limited PCB space applications. The devices are also suitable for wide temperature application which the most the power module can not support. 7.2. Device Functional Modes The NSiP882x devices provide 5V to 5V, 5V to 3.3V, 3.3V to 3.3V conversion mode, the output voltage can be set by SEL pin. Supply configuration table showed below. SEL PIN VDD VISO Shorted to VISO 5V 5V Shorted to GND2 or floating 5V 3.3V Shorted to GND2 or floating 3.3V 3.3V The NSiP882x devices provide four channel digital isolators. The digital isolators have default weak pull up or pull down input status when input is floating as shown in below table. Input VDD1 status VDDOUT status Output Comment H Ready Ready H Normal operation L Ready Ready L floating Ready Ready L(NSiP882xW0) Floating input status H(NSiP882xW1) 7.3. Emi Considerations The NSiP882x devices are using on chip transformer, so the power transfer must operate at high frequency allow higher efficiency transfer using the small transformer. This will cause emissions which need to pay attention to PCB layout if the application allow low emission. Please see the application note if needed. 7.4. Output Short And Over Temperature Protection The NSiP882x devices are protected against output short. When the devices detect the output is short, the device will be in Hiccup mode and the transfer power will be limited. So the temperature of the device will be low, and the device is protected. The NSiP882x devices are also protected against over temperature. When the devices detect the chip is over 165℃, the device will be shut down until the temperature of the device is below 145℃. 8. Application Note 8.1. Typical Application The NSiP882x requires a 0.1 µF and 10uF bypass capacitors between VDD and GND1, VISO and GND2. The capacitor should be placed as close as possible to the package. This is very important for the performance of the device. The figure 8.1 is the basic schematic of NSiP882x and the figure 8.2 is the typical isolated CAN schematic using NSiP8821. Copyright © 2020, NOVOSENSE Page 13 NSiP8820/NSiP8821/NSiP8822 Datasheet (EN) 1.1 VDD VISO 1 16 10uF 100nF 2 GND1 15 INA 3 14 OUTA OUTB 4 13 INB NC 5 11 SEL VDDL 7 GND1 8 10uF 12 NC NC 6 VDD 100nF GND2 10 NC NSiP8821 9 GND 2 Figure 8.1 Basic schematic of NSiP88xx VDD=5V VISO 1 16 100nF 2 GND1 15 3 14 4 13 5 12 NC NC 6 VDDL 7 VDD 11 SEL 10uF TXD MCU RXD NC 8 GND1 10uF 100nF GND2 VCC CANH TXD RXD CAN CANL 10 NC NSiP8821 9 GND2 Figure 8.2 Isolated CAN schematic using NSiP8821 8.2. Pcb Layout The recommended PCB layout shown below. The low ESR capacitor C1 should be closed to PIN1 and PIN2, the distance should be less than 1mm. The low ESR capacitor C3 should be closed to PIN15 and PIN16, the distance should be less than 1mm. Figure 8.3 Recommended PCB Layout — Top Layer Copyright © 2020, NOVOSENSE Figure 8.4 Recommended PCB Layout — Bottom Layer Page 14 NSiP8820/NSiP8821/NSiP8822 Datasheet (EN) 1.1 9. Package Information Figure 9.1 SOW16 Package Shape and Dimension in millimeters Copyright © 2020, NOVOSENSE Page 15 NSiP8820/NSiP8821/NSiP8822 Datasheet (EN) 1.1 10. Order Information Part Number NSIP8820W0 -DSWR NSIP8820W1 -DSWR NSIP8821W0 -DSWR NSIP8821W1 -DSWR NSIP8822W0 -DSWR NSIP8822W1 -DSWR Isolation Rating (kV) 4.5 Number of side 1 inputs 2 Number of side 2 inputs 0 Max Data Rate (Mbps) 150 Default intput logic Low Temperature MSL Package Type Package Drawing SPQ -40 to 125℃ 3 SOW16 1000 4.5 2 0 150 High -40 to 125℃ 3 SOW16 1000 4.5 2 0 150 Low -40 to 125℃ 3 SOW16 1000 4.5 1 1 150 High -40 to 125℃ 3 SOW16 1000 4.5 2 0 150 Low -40 to 125℃ 3 SOW16 1000 4.5 1 1 150 High -40 to 125℃ 3 SOP16 (300mil) SOP16 (300mil) SOP16 (300mil) SOP16 (300mil) SOP16 (300mil) SOP16 (300mil) SOW16 1000 Part Number Rule: NSiP(88)(4)(0)(W)(0)-DSWR Power D = Industrial Q1 = Auto Power addition fountion: 89:power disable 88:VDDL Defult input logic: 0 = Logic Low 1 = Logic High Total Channel Amount: N=N Channels N=1,2,4 Reverse Channel Amount: N=N Channels N=0,1,2 Package Type: W= SOW16 11. Documentation Support Part Number Product Folder Datasheet Technical Documents Isolator selection guide NSiP882x Click here Click here Click here Click here Copyright © 2020, NOVOSENSE Page 16 NSiP8820/NSiP8821/NSiP8822 Datasheet (EN) 1.1 12. Tape And Reel Information Copyright © 2020, NOVOSENSE Page 17 NSiP8820/NSiP8821/NSiP8822 Datasheet (EN) 1.1 Figure 12.1 Tape and Reel Information of SOW16 13. Revision History Revision 1.0 1.1 Description Initial version Updating relative figures Copyright © 2020, NOVOSENSE Date 2021/3/28 2022/5/9 Page 18
NSIP8821W1-DSWR 价格&库存
很抱歉,暂时无法提供与“NSIP8821W1-DSWR”相匹配的价格&库存,您可以联系我们找货
