K5B S5HQ 5x4.6x5.5-2.5Ts-M-T
    KINGCORE(钧宝)
    SMD
    铁氧体 SMD
K5B S5HQ 5x4.6x5.5-2.5Ts-M-T 数据手册
寶 號 CUSTOMER 科普倫-駱駝集團 承 認 SPECIFICATION FOR 書 APPROVAL 品名 PRODUCT NAME K5B S5HQ 5x4.6x5.5-2.5Ts-M-T 客戶料號 CUSTOMER PART NO. 日期 DATE. 批號 SAMPLE NO. 2023/06/29 Customer Approved Status 客戶承認範圍 FULLY APPROVED (全部承認) PARTILLY APPROVED (部份承認) REVISE APPROVED (修訂承認) Drawn by Checked by Approved by KING CORE ELECTRONICS INC. NO 269,Nanfong Rd.,Pingjhen City,Taoyuan County Taiwan Tel: 886-3-4698855 Fax: 886-4691395 Website:http:// www.kingcore.com.tw E-mail: kc@mail.kingcore.com.tw 修訂履歷 REVISION RESUME 日期 版次 修訂目的 修訂內容概述 備註 DATE VERSION PURPOSE REVISION DESCRIPTION REMARK 2023/06/29 A 首次送承認書 INITIAL RELEASE 製作 DRAWN BY: 確認 CHECKED BY: 承認 APPROVED BY: 鈞寶電子工業股份有限公司 KING CORE ELECTRONICS INC SPECIFICATION FOR APPROVAL CUSTOMER: 科普倫-駱駝集團 CUST.P/N ORDERING CODE: K5B S5HQ 5x4.6x5.5-2.5Ts-M-T K.C.P/N: (1) SHAPE : (2)ELECTRICAL REQUIREMENTS: Z1= 266 TYP. OHM AT 25 MHz Z2= 405 ±25% OHM AT A 4.6±0.5 mm B 5.0±0.5 mm C 5.5±0.5 mm D 2.0 max mm E 8.0 max mm I 2 REF mm J 6.5 REF mm K 2.5 REF mm (3) TEST CONDITIONS: 1 IMPEDANCE ANALYZER: Agilent E4991A 100 MHz TEST FIXTURE: HP16092A 2.WIRE:Φ 0.5 T.C.Wx2.5Ts IDC:△T 40℃:5A(max) (5) APPEARANCE (4)PACKING INSERTION VACUUM IN BULK PCS/BAG* BAGS/INNER BOX* BOXES/CARTON = PCS/PLATE* PLATES/CARTON= PCS PCS/TRAY* TRAYS/CARTON= PCS REELS/INNER BOX* 4 BOXES/CARTON = 8000 1000 PCS/REEL (6)REMARK: 2 PCS : <1 mm2 (2)SUM OF BREAKING AREA :<2 mm2 (1)AREA OF BREAK (3)DEPTH OF BREAK :<0.8 mm I  t is considered as a normal condition that the PCS surface of core covers with ferrite powder. Approved by Checked by Drawn by DWG.NO. 2023/6/29 20236002A ER011C KING CORE ELECTRONICS INC. TEST DATA FOR PREPRODUCTION SAMPLES CUSTOMER 科普倫-駱駝集團 CUST. P/N ORDERING CODE K5B S5HQ 5x4.6x5.5-2.5Ts-M-T K.C. P/N TEMP. 21 ℃ WIRE 0.5 T.C.W RH 65 % DWG.NO. WINDING 2.5 Ts Q'TY 20236001A 5PCS Test Instruments Meas. Item. Z (OHM) Z (OHM) A mm B mm C mm Specification 266 TYP. 405±25% 4.6±0.5 5.0±0.5 5.5±0.5 Test Freq. 25 MHz 100 MHz sample#1 283 416 4.71 4.82 5.50 sample#2 265 404 4.74 4.83 5.49 sample#3 271 404 4.68 4.80 5.45 sample#4 268 412 4.76 4.82 5.48 sample#5 268 407 4.75 4.82 5.53 X 270.9 408.6 4.728 4.818 5.490 R 18.5 12 0.08 0.03 0.08 sample#6 sample#7 sample#8 sample#9 sample#10 REMARK: Approved by: Checked by: Drawn by: KING CORE ELECTRONICS INC. TEST DATA 客戶/料號 品 名 測試儀器 繞線條件 溫 度℃ 科普倫-駱駝集團 K5B S5HQ 5x4.6x5.5-2.5Ts-M-T Agilent E4991A Φ0.5 T.C.Wx2.5Ts 21 濕 度% 66% 鈞寶料號 生產批號 粉料批號 出貨數量/總數 Z(Ω ) 項目 25MHz 100MHz 10 2023/6/29 / / 出貨日期/檢驗代號 A 尺 B 寸 (單位:m/m) C D E Spec 266 405 4.6 5 5.5 2 8 公差 1 2 3 4 5 6 7 8 9 10 X R SPEC. 判定 Cpk TYP. 283.0 264.5 271.0 268.2 267.6 272.5 265.9 263.9 260.7 270.0 268.7 22 ±25% 377.8 404.0 404.4 411.6 407.0 416.1 408.4 405.9 399.7 395.5 403.0 38 ±0.5 4.71 4.74 4.68 4.76 4.75 4.73 4.75 4.66 4.72 4.83 4.73 0.17 ±0.5 4.82 4.83 4.80 4.82 4.82 4.83 4.85 4.83 4.84 4.85 4.83 0.05 ±0.5 5.50 5.49 5.45 5.48 5.53 5.46 5.45 5.41 5.46 5.46 5.47 0.12 max 1.59 1.57 1.28 1.27 1.48 1.51 1.31 1.29 1.45 1.44 1.42 0.32 max 7.59 7.43 7.37 7.26 7.22 7.15 7.35 7.25 7.12 7.40 7.31 0.47 OK OK 3.133 OK OK OK OK OK 抽樣數: 尺寸 特性 AC= HSF 檢測 備 □合格 尺寸.特性 抽樣標準依據:MIL-STD-105E-S3 AQL=0.4 外觀 抽樣標準依據:MIL-STD-105E-I AQL=0.25 R無粉末沾附 判 抽樣數: R無刮痕破損 外觀 R無組件髒污 RE= AC= RE= R此系列當月第一批檢測合格 □不合格 過量元素: 定 OK 含量: 註 承認 檢驗 陳雯欣2023/6/29 KING CORE ELECTRONICS INC. QR004K Reliability Test No Item Specification Test Method 1 High Temperature Exposure MIL-STD202 Method 108 Temperature: 105°C/Relative Humidity: 0% (Storage) Time: 1000hrs Measured after exposure in the room condition for 24hrs 2 Temperature Cycling JESD22 Method JA-104 3 Humidity MIL-STD-202 Method 103 Temperature: 85±2°C Relative Humidity/Time: 85%RH./1000hrs Measured after exposure in the room condition for 24hrs 4 Low Temperature Specification: Appearance: Ferrite shall not be damaged. Impedance : Within ±30% of the initial value. Total cycles: 1000 cycles Temperature Cycling Test Conditions: -40 to +105°C -40°C Soak Mode Condition: 30minutes 105°C Soak Mode Condition: 30minutes Measured after exposure in the room condition for 24hrs Temperature: -40°C Time: 1000hrs Measured after exposure in the room condition for 24hrs % DSUnknown q 1G 1g 0.1 0 0 0.1 9 0 cm 0 J 0 j 4 M []0 d 1i 0g 313 292 m 313 404 325 453 432 529 c 478 561 504 597 504 645 c 504 736 440 760 391 760 c 286 760 271 681 265 626 c 265 625 l 100 625 l 100 828 253 898 381 898 c 451 898 679 878 679 650 c 679 555 628 499 538 435 c 488 399 467 376 467 292 c 313 292 l h 308 214 170 -164 re f 0.44 G 1.2 w 1 1 0.4 rg 287 318 m 287 430 299 479 406 555 c 451 587 478 623 478 671 c 478 762 414 786 365 786 c 260 786 245 707 239 652 c 239 651 l 74 651 l 74 854 227 924 355 924 c 425 924 653 904 653 676 c 653 581 602 525 512 461 c 462 425 441 402 441 318 c 287 318 l h 282 240 170 -164 re B Q 測試報告 Test Report 號碼(No.): ETR23205217   日期(Date): 24-Feb-2023 頁數(Page): 1 of 12 鈞寶電子工業股份有限公司 (KING CORE ELECTRONICS INC.) 桃園市平鎮區南豐路269號(平鎮工業區) (NO. 269, NANFONG RD., PINGJHEN DIST., TAOYUAN CITY 324, TAIWAN) 以下測試樣品係由申請廠商所提供及確認 (The following sample(s) was/were submitted and identified by the applicant as): 送樣廠商(Sample Submitted By) : 鈞寶電子工業股份有限公司 (KING CORE ELECTRONICS INC.) 樣品名稱(Sample Name) : FERRITE CORE 樣品型號(Style/Item No.) : K5B =============================================================================== 收件日(Sample Receiving Date) : 18-Feb-2023 測試期間(Testing Period) : 18-Feb-2023 to 24-Feb-2023 測試需求(Test Requested) 測試結果(Test Results) : (1) 依據客戶指定,參考RoHS 2011/65/EU Annex II及其修訂指令(EU) 2015/863測 試鎘、鉛、汞、六價鉻、多溴聯苯、多溴聯苯醚, DBP, BBP, DEHP, DIBP。 (As specified by client, with reference to RoHS 2011/65/EU Annex II and amending Directive (EU) 2015/863 to determine Cadmium, Lead, Mercury, Cr(VI), PBBs, PBDEs, DBP, BBP, DEHP, DIBP contents in the submitted sample(s).) (2) 其他測試項目請見下一頁。 (Please refer to next pages for the other item(s).) 請參閱下一頁 (Please refer to following pages.) : PIN CODE: C04EC4A4 This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 2 of 12 號碼(No.): ETR23205217   日期(Date): 24-Feb-2023 鈞寶電子工業股份有限公司 (KING CORE ELECTRONICS INC.) 桃園市平鎮區南豐路269號(平鎮工業區) (NO. 269, NANFONG RD., PINGJHEN DIST., TAOYUAN CITY 324, TAIWAN) 測試部位敘述 (Test Part Description) No.1 : FERRITE CORE 測試結果 (Test Results) 測試項目 (Test Items) 單位 (Unit) MDL mg/kg 2 結果 (Result) No.1 n.d. mg/kg 2 n.d. 汞 (Hg) (Mercury (Hg)) 參考IEC 62321-4: 2013+ AMD1: 2017,以感應耦 mg/kg 合電漿發射光譜儀分析。(With reference to IEC 62321-4: 2013+ AMD1: 2017, analysis was performed by ICP-OES.) 2 n.d. 六價鉻 Cr(VI) (Hexavalent Chromium Cr(VI)) 參考IEC 62321-7-2: 2017,以紫外光-可見光分光 光度計分析。(With reference to IEC 62321-7-2: 2017, analysis was performed by UV-VIS.) mg/kg 8 n.d. mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg 5 5 5 5 5 5 5 5 5 5 - n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. 鎘 (Cd) (Cadmium (Cd)) 鉛 (Pb) (Lead (Pb)) 測試方法 (Method) 參考IEC 62321-5: 2013,以感應耦合電漿發射光 譜儀分析。(With reference to IEC 62321-5: 2013, analysis was performed by ICP-OES.) 一溴聯苯 (Monobromobiphenyl) 二溴聯苯 (Dibromobiphenyl) 三溴聯苯 (Tribromobiphenyl) 四溴聯苯 (Tetrabromobiphenyl) 五溴聯苯 (Pentabromobiphenyl) 六溴聯苯 (Hexabromobiphenyl) 七溴聯苯 (Heptabromobiphenyl) 八溴聯苯 (Octabromobiphenyl) 九溴聯苯 (Nonabromobiphenyl) 十溴聯苯 (Decabromobiphenyl) 多溴聯苯總和 (Sum of PBBs) 參考IEC 62321-6: 2015,以氣相層析儀/質譜儀分 析。(With reference to IEC 62321-6: 2015, analysis was performed by GC/MS.) This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 3 of 12 號碼(No.): ETR23205217   日期(Date): 24-Feb-2023 鈞寶電子工業股份有限公司 (KING CORE ELECTRONICS INC.) 桃園市平鎮區南豐路269號(平鎮工業區) (NO. 269, NANFONG RD., PINGJHEN DIST., TAOYUAN CITY 324, TAIWAN) 測試項目 (Test Items) 測試方法 (Method) 5 5 5 5 5 5 5 5 5 5 50 mg/kg 50 n.d. mg/kg 50 n.d. mg/kg 50 n.d. 參考IEC 62321: 2008,以氣相層析儀/質譜儀分 mg/kg 析。(With reference to IEC 62321: 2008, analysis was performed by GC/MS.) 5 n.d. 三溴聯苯醚 (Tribromodiphenyl ether) 四溴聯苯醚 (Tetrabromodiphenyl ether) 七溴聯苯醚 (Heptabromodiphenyl ether) 參考IEC 62321-6: 2015,以氣相層析儀/質譜儀分 析。(With reference to IEC 62321-6: 2015, analysis was performed by GC/MS.) 八溴聯苯醚 (Octabromodiphenyl ether) 九溴聯苯醚 (Nonabromodiphenyl ether) 十溴聯苯醚 (Decabromodiphenyl ether) 多溴聯苯醚總和 (Sum of PBDEs) 鄰苯二甲酸丁苯甲酯 (BBP) (Butyl benzyl phthalate (BBP)) 鄰苯二甲酸二丁酯 (DBP) (Dibutyl phthalate (DBP)) 鄰苯二甲酸二(2-乙基己基)酯 (DEHP) (Di(2-ethylhexyl) phthalate (DEHP)) 鄰苯二甲酸二異丁酯 (DIBP) (Diisobutyl phthalate (DIBP)) 六溴環十二烷及所有主要被辨別出的異構 物(HBCDD) (α- HBCDD, β- HBCDD, γHBCDD) (Hexabromocyclododecane (HBCDD) and all major diastereoisomers identified (α- HBCDD, β- HBCDD, γ- HBCDD)) (CAS No.: 25637-99-4, 3194-55-6 (134237-51-7, 134237-50-6, 134237-52-8)) 結果 (Result) mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg 二溴聯苯醚 (Dibromodiphenyl ether) 六溴聯苯醚 (Hexabromodiphenyl ether) MDL No.1 n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. 一溴聯苯醚 (Monobromodiphenyl ether) 五溴聯苯醚 (Pentabromodiphenyl ether) 單位 (Unit) 參考IEC 62321-8: 2017,以氣相層析儀/質譜儀分 析。(With reference to IEC 62321-8: 2017, analysis was performed by GC/MS.) This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 4 of 12 號碼(No.): ETR23205217   日期(Date): 24-Feb-2023 鈞寶電子工業股份有限公司 (KING CORE ELECTRONICS INC.) 桃園市平鎮區南豐路269號(平鎮工業區) (NO. 269, NANFONG RD., PINGJHEN DIST., TAOYUAN CITY 324, TAIWAN) 測試項目 (Test Items) 測試方法 (Method) 單位 (Unit) MDL 結果 (Result) 氟 (F) (Fluorine (F)) (CAS No.: 14762-948) 氯 (Cl) (Chlorine (Cl)) (CAS No.: 22537參考BS EN 14582: 2016,以離子層析儀分析。 15-1) (With reference to BS EN 14582: 2016, analysis 溴 (Br) (Bromine (Br)) (CAS No.: 10097was performed by IC.) 32-2) 碘 (I) (Iodine (I)) (CAS No.: 14362-44-8) mg/kg 50 No.1 n.d. mg/kg 50 n.d. mg/kg 50 n.d. mg/kg 50 n.d. 全氟辛烷磺酸及其鹽類 (PFOS and its salts) (CAS No.: 1763-23-1 and its salts) 全氟辛酸及其鹽類 (PFOA and its salts) (CAS No.: 335-67-1 and its salts) 銻 (Sb) (Antimony (Sb)) (CAS No.: 744036-0) 砷 (As) (Arsenic (As)) (CAS No.: 744038-2) 鈹 (Be) (Beryllium (Be)) (CAS No.: 744041-7) mg/kg 10 n.d. mg/kg 10 n.d. mg/kg 2 n.d. mg/kg 2 n.d. mg/kg 2 n.d. 參考US EPA 3550C: 2007,以液相層析串聯質譜 儀分析。(With reference to US EPA 3550C: 2007, analysis was performed by LC/MS/MS.) 參考US EPA 3052: 1996,以感應耦合電漿發射光 譜儀分析。(With reference to US EPA 3052: 1996, analysis was performed by ICP-OES.) 備註(Note): 1. mg/kg = ppm;0.1wt% = 0.1% = 1000ppm 2. MDL = Method Detection Limit (方法偵測極限值) 3. n.d. = Not Detected (未檢出) ; 小於MDL / Less than MDL 4. "-" = Not Regulated (無規格值) 5. 全氟辛烷磺酸及其鹽類包含等物質 (PFOS and its salts including) : CAS No.: 1763-23-1, 2795-39-3, 29457-72-5, 29081-56-9, 70225-14-8, 56773-42-3, 251099-16-8, 307-35-7, 91036-71-4, 4021-47-0 and others. 6. 全氟辛酸及其鹽類包含等物質 (PFOA and its salts including) : CAS No.: 335-67-1, 335-95-5, 2395-00-8, 335-93-3, 335-66-0, 3825-26-1 and others. This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 5 of 12 號碼(No.): ETR23205217   日期(Date): 24-Feb-2023 鈞寶電子工業股份有限公司 (KING CORE ELECTRONICS INC.) 桃園市平鎮區南豐路269號(平鎮工業區) (NO. 269, NANFONG RD., PINGJHEN DIST., TAOYUAN CITY 324, TAIWAN) #FLOW 重金屬流程圖 / Analytical flow chart of heavy metal 根據以下的流程圖之條件,樣品已完全溶解。(六價鉻測試方法除外) These samples were dissolved totally by pre-conditioning method according to below flow chart. (Cr6+ test method excluded) 剪裁、製備樣品 / Cutting、Preparation 測試樣品重量 / Sample measurement 六價鉻 Cr(VI) 鉛 Pb/鎘 Cd/汞 Hg 用微波消解儀/電熱板進行酸消解 Acid digestion with microwave / hot plate 過濾 / Filtration 溶液 / Solution 殘渣 / Residue 1) 2) 鹼熔融法 / Alkali fusion 鹽酸溶解 / HCl to dissolve 非金屬 / Non-metal ABS / PC / PVC 超音波溶解 / Dissolving by ultrasonication 在 150~160℃下 消化 / Digesting at 150~160℃ 在60℃條件下超音波 消化 / Digesting at 60℃ by ultrasonication 取水層 / Separating to get aqueous phase 調整 pH / pH adjustment 加入發色劑顯色 / Add diphenylcarbazide for color development 以感應耦合電漿發射光譜儀分析/ Analysis was performed by ICP-OES 金屬 / Metal 其他材質/Others 以紫外光-可見光光譜儀,量測樣品溶 液在 540 nm 的吸收度 / Measure the absorbance at 540 nm by UV-Vis spectrophotometer 沸水萃取 / Boiling water extraction 冷卻後過濾樣品 / Cool, filter digestate through filter 加入發色劑顯色 / Add diphenylcarbazide for color development 以紫外光-可見光光譜 儀,量測樣品溶液在 540 nm 的吸收度 / Measure the absorbance at 540 nm by UV-Vis spectrophotometer This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 號碼(No.): ETR23205217   日期(Date): 24-Feb-2023 頁數(Page): 6 of 12 鈞寶電子工業股份有限公司 (KING CORE ELECTRONICS INC.) 桃園市平鎮區南豐路269號(平鎮工業區) (NO. 269, NANFONG RD., PINGJHEN DIST., TAOYUAN CITY 324, TAIWAN) 多溴聯苯/多溴聯苯醚分析流程圖 / Analytical flow chart - PBBs/PBDEs 初次測試程序 / First testing process 選擇性篩檢程序 / Optional screen process 確認程序 / Confirmation process 樣品前處理 / Sample pretreatment 初篩分析/ Screen analysis 樣品萃取 / Sample extraction 索式萃取法 / Soxhlet method 萃取液濃縮/稀釋 Concentrate/Dilute extracted solution Fu 萃取液過濾 / Filter 氣相層析質譜儀 / GC/MS This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 號碼(No.): ETR23205217   日期(Date): 24-Feb-2023 頁數(Page): 7 of 12 鈞寶電子工業股份有限公司 (KING CORE ELECTRONICS INC.) 桃園市平鎮區南豐路269號(平鎮工業區) (NO. 269, NANFONG RD., PINGJHEN DIST., TAOYUAN CITY 324, TAIWAN) 可塑劑分析流程圖 / Analytical flow chart - Phthalate 【測試方法/Test method: IEC 62321-8】 樣品前處理/分樣 / Sample pretreatment/separation 樣品以 THF 四氫呋喃溶解萃取 / Sample dissolved/extracted by THF 萃取液稀釋 / Dilute extracted solution 氣相層析質譜儀分析 / Analysis was performed by GC/MS This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 號碼(No.): ETR23205217   日期(Date): 24-Feb-2023 頁數(Page): 8 of 12 鈞寶電子工業股份有限公司 (KING CORE ELECTRONICS INC.) 桃園市平鎮區南豐路269號(平鎮工業區) (NO. 269, NANFONG RD., PINGJHEN DIST., TAOYUAN CITY 324, TAIWAN) 六溴環十二烷分析流程圖 / Analytical flow chart - HBCDD 樣品前處理 / Sample pretreatment 樣品萃取 Sample extraction / 超音波萃取法 Ultrasonic method 萃取液濃縮/稀釋 / Concentrate/Dilute extracted solution 萃取液過濾 / Filter 以氣相層析/質譜儀分析 / Analysis was performed by GC/MS Fu 數據 / Data This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 號碼(No.): ETR23205217   日期(Date): 24-Feb-2023 頁數(Page): 9 of 12 鈞寶電子工業股份有限公司 (KING CORE ELECTRONICS INC.) 桃園市平鎮區南豐路269號(平鎮工業區) (NO. 269, NANFONG RD., PINGJHEN DIST., TAOYUAN CITY 324, TAIWAN) 鹵素分析流程圖 / Analytical flow chart - Halogen 樣品前處理/分樣 / Sample pretreatment / Separation 秤重及將樣品放入樣品槽中 / Weighting and putting sample in cell 燃燒彈/吸收 / Oxygen bomb combustion / Absorption 稀釋至固定體積 / Dilution to fixed volume 以離子層析儀分析 / Analysis was performed by IC This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 10 of 12 號碼(No.): ETR23205217   日期(Date): 24-Feb-2023 鈞寶電子工業股份有限公司 (KING CORE ELECTRONICS INC.) 桃園市平鎮區南豐路269號(平鎮工業區) (NO. 269, NANFONG RD., PINGJHEN DIST., TAOYUAN CITY 324, TAIWAN) 全氟化合物(包含全氟辛酸/全氟辛烷磺酸/其相關化合物等等)分析流程圖 / Analytical flow chart – PFAS (including PFOA/PFOS/its related compound, etc.) 樣品前處理 / Sample pretreatment 超音波萃取法萃取 / Sample extraction by ultrasonic extraction 萃取液稀釋/濃縮 / Concentrate/Dilute extracted solution 以氣相層析/質譜儀分析或液相層析質譜儀或串聯質譜儀分 析/Analysis was performed by GC/MS or LC/MS or LC/MS/MS 數據 / Data This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 11 of 12 號碼(No.): ETR23205217   日期(Date): 24-Feb-2023 鈞寶電子工業股份有限公司 (KING CORE ELECTRONICS INC.) 桃園市平鎮區南豐路269號(平鎮工業區) (NO. 269, NANFONG RD., PINGJHEN DIST., TAOYUAN CITY 324, TAIWAN) 元素(含重金屬)分析流程圖 / Analytical flow chart of elements (Heavy metal included) 根據以下的流程圖之條件,樣品已完全溶解。 These samples were dissolved totally by pre-conditioning method according to below flow chart. 【參考方法/Reference method:US EPA 3051A、US EPA 3052】 剪裁、製備樣品 / Cutting、Preparation 測試樣品重量 / Sample measurement 硝酸/鹽酸/氫氟酸的微波消化 / Microwave digestion with HNO3/HCl/HF 過濾 / Filtration 殘渣 / Residue 溶液 / Solution 1) 2) 鹼熔融法 / Alkali fusion 鹽酸溶解 / HCl to dissolve 以感應耦合電漿發射光譜儀分析 / Analysis was performed by ICP-OES * US EPA 3051A 方法未添加氫氟酸 / US EPA 3051A method does not add HF. This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 12 of 12 號碼(No.): ETR23205217   日期(Date): 24-Feb-2023 鈞寶電子工業股份有限公司 (KING CORE ELECTRONICS INC.) 桃園市平鎮區南豐路269號(平鎮工業區) (NO. 269, NANFONG RD., PINGJHEN DIST., TAOYUAN CITY 324, TAIWAN) #PIC * 照片中如有箭頭標示,則表示為實際檢測之樣品/部位. * (The tested sample / part is marked by an arrow if it's shown on the photo.) ** 報告結尾 (End of Report) ** This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group % DSUnknown q 1G 1g 0.1 0 0 0.1 9 0 cm 0 J 0 j 4 M []0 d 1i 0g 313 292 m 313 404 325 453 432 529 c 478 561 504 597 504 645 c 504 736 440 760 391 760 c 286 760 271 681 265 626 c 265 625 l 100 625 l 100 828 253 898 381 898 c 451 898 679 878 679 650 c 679 555 628 499 538 435 c 488 399 467 376 467 292 c 313 292 l h 308 214 170 -164 re f 0.44 G 1.2 w 1 1 0.4 rg 287 318 m 287 430 299 479 406 555 c 451 587 478 623 478 671 c 478 762 414 786 365 786 c 260 786 245 707 239 652 c 239 651 l 74 651 l 74 854 227 924 355 924 c 425 924 653 904 653 676 c 653 581 602 525 512 461 c 462 425 441 402 441 318 c 287 318 l h 282 240 170 -164 re B Q 測試報告 Test Report 頁數(Page): 1 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) 以下測試樣品係由申請廠商所提供及確認 (The following sample(s) was/were submitted and identified by the applicant as): 送樣廠商(Sample Submitted By) : 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 樣品名稱(Sample Name) : HOT DIPPED Tin-COATED COPPER WIRE (鍍錫銅線) ================================================================================ 收件日(Sample Receiving Date) : 30-Nov-2022 測試期間(Testing Period) : 30-Nov-2022 to 07-Dec-2022 測試需求(Test Requested) : (1) 依據客戶指定,參考RoHS 2011/65/EU Annex II及其修訂指令(EU) 2015/863測試鎘、 鉛、汞、六價鉻、多溴聯苯、多溴聯苯醚, DBP, BBP, DEHP, DIBP。 (As specified by client, with reference to RoHS 2011/65/EU Annex II and amending Directive (EU) 2015/863 to determine Cadmium, Lead, Mercury, Cr(VI), PBBs, PBDEs, DBP, BBP, DEHP, DIBP contents in the submitted sample(s).) (2) 其他測試項目請見下一頁。 (Please refer to next pages for the other item(s).) 測試結果(Test Results) : 結  論(Conclusion) : 請參閱下一頁 (Please refer to following pages.) (1) 根據客戶所提供的樣品,其鎘、鉛、汞、六價鉻、多溴聯苯、多溴聯苯醚, DBP, BBP, DEHP, DIBP的測試結果符合RoHS 2011/65/EU Annex II暨其修訂指令(EU) 2015/863 之限值要求。 (Based on the performed tests on submitted sample(s), the test results of Cadmium, Lead, Mercury, Cr(VI), PBBs, PBDEs, DBP, BBP, DEHP, DIBP comply with the limits as set by RoHS Directive (EU) 2015/863 amending Annex II to Directive 2011/65/EU.) PIN CODE: 364CBE91 This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 2 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) 測試部位敘述 (Test Part Description) No.1 : 銀色金屬線鍍層 (PLATING LAYER OF SILVER COLORED METAL WIRE) No.2 : 銀色金屬線底材 (BASE MATERIAL OF SILVER COLORED METAL WIRE) No.3 : 銀色金屬線 (含鍍層) (SILVER COLORED METAL WIRE (INCLUDING THE PLATING LAYER)) 測試結果 (Test Results) 測試項目 (Test Items) 鎘 (Cd) (Cadmium (Cd)) (CAS No.: 7440-43-9) 鉛 (Pb) (Lead (Pb)) (CAS No.: 743992-1) 汞 (Hg) (Mercury (Hg)) (CAS No.: 7439-97-6) 鎘 (Cd) (Cadmium (Cd)) (CAS No.: 7440-43-9) 鉛 (Pb) (Lead (Pb)) (CAS No.: 743992-1) 汞 (Hg) (Mercury (Hg)) (CAS No.: 7439-97-6) mg/kg 酸洗脫鍍層,參考IEC 62321-5: 2013,以感應耦合電漿發射光譜儀 分析。(IEC 62321-5: 2013 application of modified mg/kg digestion by surface etching, analysis was performed by ICPOES.) 2 結果 (Result) No.1 No.2 No.3 n.d. ----- 2 67.5 --- --- 1000 酸洗脫鍍層,參考IEC 62321-4: mg/kg 2013+ AMD1: 2017,以感應耦合電 漿發射光譜儀分析。(IEC 62321-4: 2013+AMD1: 2017 application of modified digestion by surface etching, analysis was performed by ICP-OES.) 2 n.d. --- --- 1000 mg/kg 2 --- n.d. --- 100 mg/kg 2 --- n.d. --- 1000 參考IEC 62321-4: 2013+ AMD1: mg/kg 2017,以感應耦合電漿發射光譜儀 分析。(With reference to IEC 62321-4: 2013+ AMD1: 2017, analysis was performed by ICPOES.) 2 --- n.d. --- 1000 測試方法 (Method) 參考IEC 62321-5: 2013,以感應 耦合電漿發射光譜儀分析。(With reference to IEC 62321-5: 2013, analysis was performed by ICPOES.) 單位 (Unit) MDL This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 限值 (Limit) 100 測試報告 Test Report 頁數(Page): 3 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) 測試項目 (Test Items) 六價鉻 (Hexavalent Chromium) Cr(VI) (CAS No.: 18540-29-9) (#2) 測試方法 (Method) 參考IEC 62321-7-1: 2015,以紫 µg/cm² 外光-可見光分光光度計分析。 (With reference to IEC 62321-71: 2015, analysis was performed by UV-VIS.) 一溴聯苯 (Monobromobiphenyl) 二溴聯苯 (Dibromobiphenyl) 三溴聯苯 (Tribromobiphenyl) 四溴聯苯 (Tetrabromobiphenyl) 五溴聯苯 (Pentabromobiphenyl) 六溴聯苯 (Hexabromobiphenyl) 七溴聯苯 (Heptabromobiphenyl) 八溴聯苯 (Octabromobiphenyl) 九溴聯苯 (Nonabromobiphenyl) 十溴聯苯 (Decabromobiphenyl) 多溴聯苯總和 (Sum of PBBs) 一溴聯苯醚 (Monobromodiphenyl ether) 二溴聯苯醚 (Dibromodiphenyl ether) 三溴聯苯醚 (Tribromodiphenyl ether) 單位 (Unit) 參考IEC 62321-6: 2015,以氣相 層析儀/質譜儀分析。(With reference to IEC 62321-6: 2015, analysis was performed by GC/MS.) 四溴聯苯醚 (Tetrabromodiphenyl ether) 五溴聯苯醚 (Pentabromodiphenyl ether) 六溴聯苯醚 (Hexabromodiphenyl ether) 七溴聯苯醚 (Heptabromodiphenyl ether) 八溴聯苯醚 (Octabromodiphenyl ether) 九溴聯苯醚 (Nonabromodiphenyl ether) 十溴聯苯醚 (Decabromodiphenyl ether) 多溴聯苯醚總和 (Sum of PBDEs) mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg 結果 (Result) MDL 限值 (Limit) 0.1 No.1 n.d. No.2 n.d. No.3 --- - 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 - --------------------------------------------- --------------------------------------------- n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. 1000 1000 This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 4 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) 測試項目 (Test Items) 測試方法 (Method) 單位 (Unit) 結果 (Result) MDL 限值 (Limit) 全氟辛烷磺酸及其鹽類 (PFOS and its μg/m² 參考CEN/TS 15968: 2010,以液 salts) (CAS No.: 1763-23-1 and its 相層析串聯質譜儀分析。(With salts) reference to CEN/TS 15968: 全氟辛酸及其鹽類 (PFOA and its μg/m² 2010, analysis was performed by salts) (CAS No.: 335-67-1 and its LC/MS/MS.) salts) 0.5 No.1 n.d. No.2 --- No.3 --- - 0.5 n.d. --- --- - 全氟辛烷磺酸及其鹽類 (PFOS and its mg/kg 參考CEN/TS 15968: 2010,以液 salts) (CAS No.: 1763-23-1 and its 相層析串聯質譜儀分析。(With salts) reference to CEN/TS 15968: 全氟辛酸及其鹽類 (PFOA and its mg/kg 2010, analysis was performed by salts) (CAS No.: 335-67-1 and its LC/MS/MS.) salts) 參考IEC 62321-8: 2017,以氣相 鄰苯二甲酸丁苯甲酯 (BBP) (Butyl mg/kg 層析儀/質譜儀分析。(With benzyl phthalate (BBP)) (CAS No.: reference to IEC 62321-8: 2017, 85-68-7) analysis was performed by GC/MS.) 0.01 --- n.d. --- - 0.01 --- n.d. --- - 50 --- --- n.d. 1000 參考IEC 62321-8: 2017,以氣相 鄰苯二甲酸二丁酯 (DBP) (Dibutyl phthalate (DBP)) (CAS No.: 84-74-2) 層析儀/質譜儀分析。(With reference to IEC 62321-8: 2017, analysis was performed by GC/MS.) mg/kg 50 --- --- n.d. 1000 鄰苯二甲酸二(2-乙基己基)酯 (DEHP) 參考IEC 62321-8: 2017,以氣相 (Di-(2-ethylhexyl) phthalate (DEHP)) 層析儀/質譜儀分析。(With reference to IEC 62321-8: 2017, (CAS No.: 117-81-7) analysis was performed by GC/MS.) mg/kg 50 --- --- n.d. 1000 鄰苯二甲酸二異丁酯 (DIBP) (Diisobutyl phthalate (DIBP)) (CAS No.: 84-69-5) mg/kg 50 --- --- n.d. 1000 參考IEC 62321-8: 2017,以氣相 層析儀/質譜儀分析。(With reference to IEC 62321-8: 2017, analysis was performed by GC/MS.) This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 5 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) 測試項目 (Test Items) 測試方法 (Method) 單位 (Unit) 結果 (Result) MDL 限值 (Limit) 鄰苯二甲酸二異癸酯 (DIDP) (Diisodecyl phthalate (DIDP)) (CAS No.: 26761-40-0, 68515-49-1) 參考IEC 62321-8: 2017,以氣相 層析儀/質譜儀分析。(With reference to IEC 62321-8: 2017, analysis was performed by GC/MS.) mg/kg 50 No.1 --- 鄰苯二甲酸二異壬酯 (DINP) (Diisononyl phthalate (DINP)) (CAS No.: 28553-12-0, 68515-48-0) 參考IEC 62321-8: 2017,以氣相 層析儀/質譜儀分析。(With reference to IEC 62321-8: 2017, analysis was performed by GC/MS.) mg/kg 50 --- --- n.d. - 鄰苯二甲酸二正辛酯 (DNOP) (Di-noctyl phthalate (DNOP)) (CAS No.: 117-84-0) 參考IEC 62321-8: 2017,以氣相 層析儀/質譜儀分析。(With reference to IEC 62321-8: 2017, analysis was performed by GC/MS.) mg/kg 50 --- --- n.d. - mg/kg 50 --- --- n.d. - mg/kg 50 --- --- n.d. - mg/kg 50 --- --- n.d. - mg/kg 50 --- --- n.d. - mg/kg 2 --- --- n.d. - 氟 (F) (Fluorine (F)) (CAS No.: 1476294-8) 氯 (Cl) (Chlorine (Cl)) (CAS No.: 22537-15-1) 溴 (Br) (Bromine (Br)) (CAS No.: 10097-32-2) 碘 (I) (Iodine (I)) (CAS No.: 1436244-8) 鈹 (Be) (Beryllium (Be)) (CAS No.: 7440-41-7) 參考BS EN 14582: 2016,以離子 層析儀分析。(With reference to BS EN 14582: 2016, analysis was performed by IC.) 參考US EPA 3050B: 1996,以感 應耦合電漿發射光譜儀分析。 (With reference to US EPA 3050B: 1996, analysis was performed by ICP-OES.) No.2 --- No.3 n.d. - This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 6 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) 備註(Note): 1. mg/kg = ppm;0.1wt% = 0.1% = 1000ppm 2. MDL = Method Detection Limit (方法偵測極限值) 3. n.d. = Not Detected (未檢出) ; 小於MDL / Less than MDL 4. "-" = Not Regulated (無規格值) 5. "---" = Not Conducted (未測試項目) 6. 全氟辛烷磺酸及其鹽類包含等物質 (PFOS and its salts including) : CAS No.: 1763-23-1, 2795-39-3, 29457-72-5, 29081-56-9, 70225-14-8, 56773-42-3, 251099-16-8, 307-35-7, 91036-71-4, 4021-47-0 and others. 7. 全氟辛酸及其鹽類包含等物質 (PFOA and its salts including) : CAS No.: 335-67-1, 335-95-5, 2395-00-8, 335-93-3, 335-66-0, 3825-26-1 and others. 8. (#2) = a. 當六價鉻結果大於0.13 µg/cm²,表示樣品表層含有六價鉻。(The sample is positive for Cr(VI) if the Cr(VI) concentration is greater than 0.13 µg/cm². The sample coating is considered to contain Cr(VI).) b. 當六價鉻結果為n.d. (濃度小於0.10 µg/cm²),表示表層不含六價鉻。(The sample is negative for Cr(VI) if Cr(VI) is n.d. (concentration less than 0.10 µg/cm²). The coating is considered a non-Cr(VI) based coating) c. 當六價鉻結果介於 0.10 及 0.13 µg/cm² 時,無法確定塗層是否含有六價鉻。(The result between 0.10 µg/cm² and 0.13 µg/cm² is considered to be inconclusive - unavoidable coating variations may influence the determination.) 9. 除非另有說明,參照ILAC-G8:09/2019,採用簡單二元(w=0)允收規則進行符合性判定;根據此規則,符合性結果之判定係 以測試結果與限值做比較。(Unless otherwise stated , the decision rule for conformity reporting is based on Binary Statement for Simple Acceptance Rule (w=0) stated in ILAC-G8:09/2019. According to this rule, the judgement of conformity is based on the comparing test results with limits.) This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 7 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) 鍍層重金屬測試流程圖 / Flow chart of stripping method for metal analysis #FLOW 根據以下的流程圖之條件,樣品之外部鍍層已完全溶解。 (六價鉻測試方法除外) / The plating layer of samples were dissolved totally by pre-conditioning method according to below flow chart. (Cr 6+ test method excluded) 製備樣品 / Preparation 六價鉻 Cr 測試樣品重量 / Sample measurement (weight) 6+ 測試樣品面積 / Sample measurement (area) 鉛 Pb、鎘 Cd、汞 Hg 準備適當的酸溶液 / Prepare suitable acid solution 將樣品放入酸溶液中 / Put sample into acid solution 沸水萃取 / Boiling water extraction 冷卻後過濾樣品 / Cool, filter digestate through filter 溶解鍍材料層 / Dissolve plating layer 加入發色劑顯色 / Add diphenyl-carbazide for color development 溶液 / Solution 以紫外光-可見光光譜儀,量測樣品溶液在 以感應耦合電漿發射光譜儀分析 / Analysis was performed by ICP-OES Measure the absorbance at 540 nm by UV-Vis spectrophotometer 540 nm 的吸收度 / This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 8 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) 重金屬流程圖 / Analytical flow chart of heavy metal 根據以下的流程圖之條件,樣品已完全溶解。(六價鉻測試方法除外) These samples were dissolved totally by pre-conditioning method according to below flow chart. (Cr 6+ test method excluded) 剪裁、製備樣品 / Cutting、Preparation 測試樣品重量 / Sample measurement 六價鉻 Cr(VI) 鉛 Pb/鎘 Cd/汞 Hg 用微波消解儀/電熱板進行酸消解 Acid digestion with microwave / hot plate 過濾 / Filtration 溶液 / Solution 殘渣 / Residue 1) 2) 鹼熔融法 / Alkali fusion 鹽酸溶解 / HCl to dissolve 非金屬 / Non-metal ABS / PC / PVC 超音波溶解 / Dissolving by ultrasonication 在 150~160℃下 消化 / Digesting at 150~160℃ 在60℃條件下超音波 消化 / Digesting at 60℃ by ultrasonication 取水層 / Separating to get aqueous phase 調整 pH / pH adjustment 加入發色劑顯色 / Add diphenylcarbazide for color development 以感應耦合電漿發射光譜儀分析/ Analysis was performed by ICP-OES 金屬 / Metal 其他材質/Others 以紫外光-可見光光譜儀,量測樣品溶 液在 540 nm 的吸收度 / Measure the absorbance at 540 nm by UV-Vis spectrophotometer 沸水萃取 / Boiling water extraction 冷卻後過濾樣品 / Cool, filter digestate through filter 加入發色劑顯色 / Add diphenylcarbazide for color development 以紫外光-可見光光譜 儀,量測樣品溶液在 540 nm 的吸收度 / Measure the absorbance at 540 nm by UV-Vis spectrophotometer This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 9 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) 多溴聯苯/多溴聯苯醚分析流程圖 / Analytical flow chart - PBBs/PBDEs 初次測試程序 / First testing process 選擇性篩檢程序 / Optional screen process 確認程序 / Confirmation process 樣品前處理 / Sample pretreatment 初篩分析/ Screen analysis 樣品萃取 / Sample extraction 索式萃取法 / Soxhlet method 萃取液濃縮/稀釋 Concentrate/Dilute extracted solution Fu 萃取液過濾 / Filter 氣相層析質譜儀 / GC/MS This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 10 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) 全氟化合物(包含全氟辛酸/全氟辛烷磺酸/其相關化合物等等)分析流程圖 / Analytical flow chart – PFAS (including PFOA/PFOS/its related compound, etc.) 樣品前處理 / Sample pretreatment 超音波萃取法萃取 / Sample extraction by ultrasonic extraction 萃取液稀釋/濃縮 / Concentrate/Dilute extracted solution 以氣相層析/質譜儀分析或液相層析質譜儀或串聯質譜儀分 析/Analysis was performed by GC/MS or LC/MS or LC/MS/MS 數據 / Data This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 11 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) 可塑劑分析流程圖 / Analytical flow chart - Phthalate 【測試方法/Test method: IEC 62321-8】 樣品前處理/分樣 / Sample pretreatment/separation 樣品以 THF 四氫呋喃溶解萃取 / Sample dissolved/extracted by THF 萃取液稀釋 / Dilute extracted solution 氣相層析質譜儀分析 / Analysis was performed by GC/MS This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 12 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) 鹵素分析流程圖 / Analytical flow chart - Halogen 樣品前處理/分樣 / Sample pretreatment / Separation 秤重及將樣品放入樣品槽中 / Weighting and putting sample in cell 燃燒彈/吸收 / Oxygen bomb combustion / Absorption 稀釋至固定體積 / Dilution to fixed volume 以離子層析儀分析 / Analysis was performed by IC This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 13 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) 元素以 ICP-OES 分析的消化流程圖 (Flow chart of digestion for the elements analysis performed by ICP-OES) 根據以下的流程圖之條件,樣品已完全溶解。 / These samples were dissolved totally by pre-conditioning method according to below flow chart. 剪裁、製備樣品 / Cutting、Preparation 測試樣品重量 / Sample measurement 依據不同樣品的材質而以適當的酸進行消化(如下表所示) / Acid digestion by suitable acid depended on different sample material (as below table) 過濾 / Filtration 殘渣 / Residue 溶液 / Solution 以感應耦合電漿發射光譜儀分析 / Analysis was performed by ICP-OES 1) 鹼熔融法 / Alkali fusion 2) 鹽酸溶解 / HCl to dissolve 鋼,銅,鋁,焊錫 / Steel, copper, aluminum, solder 王水,硝酸,鹽酸,氫氟酸,雙氧水 / Aqua regia, HNO3, HCl, HF, H2O2 玻璃 / Glass 硝酸,氫氟酸 / HNO3,HF 金,鉑,鈀,陶瓷 / Gold, platinum, palladium, ceramic 王水 / Aqua regia 銀 / Silver 硝酸 / HNO3 塑膠 / Plastic 硫酸,雙氧水,硝酸,鹽酸 / H2SO4, H2O2, HNO3, HCl 其他 / Others 加入適當的試劑至完全溶解 / Added appropriate reagent to total digestion This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 14 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) #PIC * 照片中如有箭頭標示,則表示為實際檢測之樣品/部位. * (The tested sample / part is marked by an arrow if it's shown on the photo.) This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 15 of 15 號碼(No.): ETR22B04781   日期(Date): 07-Dec-2022 惠豐特殊電線股份有限公司 (WELL FORE SPECIAL WIRE CORPORATION) 桃園市中壢區自強七路10號 (NO. 10, ZIQIANG 7TH RD., ZHONGLI DIST., TAOYUAN CITY, TAIWAN) ** 報告結尾 (End of Report) ** This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group % DSUnknown q 1G 1g 0.1 0 0 0.1 9 0 cm 0 J 0 j 4 M []0 d 1i 0g 313 292 m 313 404 325 453 432 529 c 478 561 504 597 504 645 c 504 736 440 760 391 760 c 286 760 271 681 265 626 c 265 625 l 100 625 l 100 828 253 898 381 898 c 451 898 679 878 679 650 c 679 555 628 499 538 435 c 488 399 467 376 467 292 c 313 292 l h 308 214 170 -164 re f 0.44 G 1.2 w 1 1 0.4 rg 287 318 m 287 430 299 479 406 555 c 451 587 478 623 478 671 c 478 762 414 786 365 786 c 260 786 245 707 239 652 c 239 651 l 74 651 l 74 854 227 924 355 924 c 425 924 653 904 653 676 c 653 581 602 525 512 461 c 462 425 441 402 441 318 c 287 318 l h 282 240 170 -164 re B Q 測試報告 Test Report 號碼(No.): ETR22501100   日期(Date): 13-May-2022 頁數(Page): 1 of 12 台灣納美仕股份有限公司 (NAMICS TAIWAN CO., LTD.) 苗栗縣銅鑼鄉銅科一路3號 (NO. 3, TONGKE 1ST RD ., TONGLUO TOWNSHIP, MIAOLI COUNTY 36645, TAIWAN (R.O.C)) 以下測試樣品係由申請廠商所提供及確認 (The following sample(s) was/were submitted and identified by the applicant as): 送樣廠商(Sample Submitted By) : 台灣納美仕股份有限公司 (NAMICS TAIWAN CO., LTD.) 樣品名稱(Sample Name) : DP4303W =============================================================================== 收件日(Sample Receiving Date) : 06-May-2022 測試期間(Testing Period) : 06-May-2022 to 13-May-2022 測試需求(Test Requested) 測試結果(Test Results) : (1) 依據客戶指定,參考RoHS 2011/65/EU Annex II及其修訂指令(EU) 2015/863測 試鎘、鉛、汞、六價鉻、多溴聯苯、多溴聯苯醚, DBP, BBP, DEHP, DIBP。 (As specified by client, with reference to RoHS 2011/65/EU Annex II and amending Directive (EU) 2015/863 to determine Cadmium, Lead, Mercury, Cr(VI), PBBs, PBDEs, DBP, BBP, DEHP, DIBP contents in the submitted sample(s).) (2) 其他測試項目請見下一頁。 (Please refer to next pages for the other item(s).) 請參閱下一頁 (Please refer to following pages.) : PIN CODE: 8CBA7459 This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 2 of 12 號碼(No.): ETR22501100   日期(Date): 13-May-2022 台灣納美仕股份有限公司 (NAMICS TAIWAN CO., LTD.) 苗栗縣銅鑼鄉銅科一路3號 (NO. 3, TONGKE 1ST RD ., TONGLUO TOWNSHIP, MIAOLI COUNTY 36645, TAIWAN (R.O.C)) 測試部位敘述 (Test Part Description) No.1 : 暗綠色膏狀 (DARK GREEN PASTE) 測試結果 (Test Results) 測試項目 (Test Items) 單位 (Unit) MDL 鎘 (Cd) (Cadmium (Cd)) (CAS No.: 7440- 參考IEC 62321-5: 2013,以感應耦合電漿發射光 43-9) 譜儀分析。(With reference to IEC 62321-5: 2013, analysis was performed by ICP-OES.) mg/kg 2 結果 (Result) No.1 n.d. 鉛 (Pb) (Lead (Pb)) (CAS No.: 7439-92-1) 參考IEC 62321-5: 2013,以感應耦合電漿發射光 譜儀分析。(With reference to IEC 62321-5: 2013, analysis was performed by ICP-OES.) mg/kg 2 n.d. 汞 (Hg) (Mercury (Hg)) (CAS No.: 7439- 參考IEC 62321-4: 2013+ AMD1: 2017,以感應耦 mg/kg 97-6) 合電漿發射光譜儀分析。(With reference to IEC 62321-4: 2013+ AMD1: 2017, analysis was performed by ICP-OES.) 2 n.d. 六價鉻 Cr(VI) (Hexavalent Chromium Cr(VI)) (CAS No.: 18540-29-9) mg/kg 8 n.d. mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg 5 5 5 5 5 5 5 5 5 5 - n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. 測試方法 (Method) 參考IEC 62321-7-2: 2017,以紫外光-可見光分光 光度計分析。(With reference to IEC 62321-7-2: 2017, analysis was performed by UV-VIS.) 一溴聯苯 (Monobromobiphenyl) 二溴聯苯 (Dibromobiphenyl) 三溴聯苯 (Tribromobiphenyl) 四溴聯苯 (Tetrabromobiphenyl) 五溴聯苯 (Pentabromobiphenyl) 六溴聯苯 (Hexabromobiphenyl) 七溴聯苯 (Heptabromobiphenyl) 八溴聯苯 (Octabromobiphenyl) 九溴聯苯 (Nonabromobiphenyl) 十溴聯苯 (Decabromobiphenyl) 多溴聯苯總和 (Sum of PBBs) 參考IEC 62321-6: 2015,以氣相層析儀/質譜儀分 析。(With reference to IEC 62321-6: 2015, analysis was performed by GC/MS.) This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 3 of 12 號碼(No.): ETR22501100   日期(Date): 13-May-2022 台灣納美仕股份有限公司 (NAMICS TAIWAN CO., LTD.) 苗栗縣銅鑼鄉銅科一路3號 (NO. 3, TONGKE 1ST RD ., TONGLUO TOWNSHIP, MIAOLI COUNTY 36645, TAIWAN (R.O.C)) 測試項目 (Test Items) 單位 (Unit) MDL mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg mg/kg 5 5 5 5 5 5 5 5 5 5 50 結果 (Result) No.1 n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. n.d. mg/kg 50 n.d. mg/kg 50 n.d. 鄰苯二甲酸二異丁酯 (DIBP) (Diisobutyl phthalate (DIBP)) (CAS No.: 84-69-5) 參考IEC 62321-8: 2017,以氣相層析儀/質譜儀分 鄰苯二甲酸二異癸酯 (DIDP) (Diisodecyl 析。(With reference to IEC 62321-8: 2017, phthalate (DIDP)) (CAS No.: 26761-40analysis was performed by GC/MS.) 0, 68515-49-1) mg/kg 50 n.d. mg/kg 50 n.d. 鄰苯二甲酸二異壬酯 (DINP) (Diisononyl phthalate (DINP)) (CAS No.: 28553-120, 68515-48-0) mg/kg 50 n.d. 鄰苯二甲酸二正戊酯 (DNPP) (Di-npentyl phthalate (DNPP)) (CAS No.: 131-18-0) mg/kg 50 n.d. 鄰苯二甲酸二正己酯 (DNHP) (Di-n-hexyl phthalate (DNHP)) (CAS No.: 84-75-3) mg/kg 50 n.d. 測試方法 (Method) 一溴聯苯醚 (Monobromodiphenyl ether) 二溴聯苯醚 (Dibromodiphenyl ether) 三溴聯苯醚 (Tribromodiphenyl ether) 四溴聯苯醚 (Tetrabromodiphenyl ether) 五溴聯苯醚 (Pentabromodiphenyl ether) 六溴聯苯醚 (Hexabromodiphenyl ether) 七溴聯苯醚 (Heptabromodiphenyl ether) 參考IEC 62321-6: 2015,以氣相層析儀/質譜儀分 析。(With reference to IEC 62321-6: 2015, analysis was performed by GC/MS.) 八溴聯苯醚 (Octabromodiphenyl ether) 九溴聯苯醚 (Nonabromodiphenyl ether) 十溴聯苯醚 (Decabromodiphenyl ether) 多溴聯苯醚總和 (Sum of PBDEs) 鄰苯二甲酸丁苯甲酯 (BBP) (Butyl benzyl phthalate (BBP)) (CAS No.: 85-68-7) 鄰苯二甲酸二丁酯 (DBP) (Dibutyl phthalate (DBP)) (CAS No.: 84-74-2) 鄰苯二甲酸二(2-乙基己基)酯 (DEHP) (Di(2-ethylhexyl) phthalate (DEHP)) (CAS No.: 117-81-7) This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 4 of 12 號碼(No.): ETR22501100   日期(Date): 13-May-2022 台灣納美仕股份有限公司 (NAMICS TAIWAN CO., LTD.) 苗栗縣銅鑼鄉銅科一路3號 (NO. 3, TONGKE 1ST RD ., TONGLUO TOWNSHIP, MIAOLI COUNTY 36645, TAIWAN (R.O.C)) 測試項目 (Test Items) 六溴環十二烷及所有主要被辨別出的異構 參考IEC 62321: 2008,以氣相層析儀/質譜儀分 mg/kg 物(HBCDD) (α- HBCDD, β- HBCDD, γ- 析。(With reference to IEC 62321: 2008, analysis HBCDD) (Hexabromocyclododecane was performed by GC/MS.) (HBCDD) and all major diastereoisomers identified (α- HBCDD, β- HBCDD, γ- HBCDD)) (CAS No.: 25637-99-4, 3194-55-6 (134237-51-7, 134237-50-6, 134237-52-8)) 5 結果 (Result) No.1 n.d. 氟 (F) (Fluorine (F)) (CAS No.: 14762-948) 氯 (Cl) (Chlorine (Cl)) (CAS No.: 22537參考BS EN 14582: 2016,以離子層析儀分析。 15-1) (With reference to BS EN 14582: 2016, analysis 溴 (Br) (Bromine (Br)) (CAS No.: 10097was performed by IC.) 32-2) 碘 (I) (Iodine (I)) (CAS No.: 14362-44-8) mg/kg 50 n.d. mg/kg 50 n.d. mg/kg 50 n.d. mg/kg 50 n.d. 銻 (Sb) (Antimony (Sb)) (CAS No.: 7440- 參考US EPA 3052: 1996,以感應耦合電漿發射光 36-0) 譜儀分析。(With reference to US EPA 3052: 1996, analysis was performed by ICP-OES.) mg/kg 2 n.d. 鈹 (Be) (Beryllium (Be)) (CAS No.: 7440- 參考US EPA 3050B: 1996,以感應耦合電漿發射 41-7) 光譜儀分析。(With reference to US EPA 3050B: 1996, analysis was performed by ICP-OES.) mg/kg 2 n.d. 測試方法 (Method) 單位 (Unit) MDL 備註(Note): 1. mg/kg = ppm;0.1wt% = 0.1% = 1000ppm 2. MDL = Method Detection Limit (方法偵測極限值) 3. n.d. = Not Detected (未檢出) ; 小於MDL / Less than MDL 4. "-" = Not Regulated (無規格值) 5. 氟、氯、溴、碘:丙酮萃取前處理。 Fluorine, Chlorine、Bromine, Iodine : Pretreatment by acetone extraction. This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 5 of 12 號碼(No.): ETR22501100   日期(Date): 13-May-2022 台灣納美仕股份有限公司 (NAMICS TAIWAN CO., LTD.) 苗栗縣銅鑼鄉銅科一路3號 (NO. 3, TONGKE 1ST RD ., TONGLUO TOWNSHIP, MIAOLI COUNTY 36645, TAIWAN (R.O.C)) #FLOW 重金屬流程圖 / Analytical flow chart of Heavy Metal 根據以下的流程圖之條件,樣品已完全溶解。(六價鉻測試方法除外) These samples were dissolved totally by pre-conditioning method according to below flow chart. (Cr6+ test method excluded) 剪裁、製備樣品 / Cutting、Preparation 測試樣品重量 / Sample measurement 六價鉻 Cr(VI) 鉛 Pb/鎘 Cd/汞 Hg 用微波消解儀/電熱板進行酸消解 Acid digestion with microwave / hot plate 過濾 / Filtration 溶液 / Solution 殘渣 / Residue 1) 2) 鹼熔融法 / Alkali fusion 鹽酸溶解 / HCl to dissolve 非金屬 / Non-metal ABS / PC / PVC 金屬 / Metal 其他材質/Others 超音波溶解 / Dissolving by ultrasonication 在 150~160℃下 消化 / Digesting at 150~160℃ 在60℃條件下超音波 消化 / Digesting at 60℃ by ultrasonication 取水層 / Separating to get aqueous phase 調整 pH / pH adjustment 加入發色劑顯色 / Add diphenylcarbazide for color development 感應耦合電漿發射光譜儀 / ICP-OES 以 UV-VIS 量測樣品溶液在 540 nm 的吸 收度 / Measure the absorbance at 540 nm by UV-VIS 沸水萃取 / Boiling water extraction 冷卻後過濾樣品 / Cool, filter digestate through filter 加入發色劑顯色 / Add diphenylcarbazide for color development 以 UV-VIS 量測樣品 溶液在 540 nm 的吸 收度 / Measure the absorbance at 540 nm by UV-VIS This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 號碼(No.): ETR22501100   日期(Date): 13-May-2022 頁數(Page): 6 of 12 台灣納美仕股份有限公司 (NAMICS TAIWAN CO., LTD.) 苗栗縣銅鑼鄉銅科一路3號 (NO. 3, TONGKE 1ST RD ., TONGLUO TOWNSHIP, MIAOLI COUNTY 36645, TAIWAN (R.O.C)) 多溴聯苯/多溴聯苯醚分析流程圖 / Analytical flow chart - PBBs/PBDEs 初次測試程序 / First testing process 選擇性篩檢程序 / Optional screen process 確認程序 / Confirmation process 樣品前處理 / Sample pretreatment 初篩分析/ Screen analysis 樣品萃取 / Sample extraction 索式萃取法 / Soxhlet method 萃取液濃縮/稀釋 Concentrate/Dilute extracted solution Fu 萃取液過濾 / Filter 氣相層析質譜儀 / GC/MS This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 號碼(No.): ETR22501100   日期(Date): 13-May-2022 頁數(Page): 7 of 12 台灣納美仕股份有限公司 (NAMICS TAIWAN CO., LTD.) 苗栗縣銅鑼鄉銅科一路3號 (NO. 3, TONGKE 1ST RD ., TONGLUO TOWNSHIP, MIAOLI COUNTY 36645, TAIWAN (R.O.C)) 可塑劑分析流程圖 / Analytical flow chart - Phthalate 【測試方法/Test method: IEC 62321-8】 樣品前處理/分樣 / Sample pretreatment/separation 樣品以 THF 四氫呋喃溶解萃取 / Sample dissolved/extracted by THF 萃取液稀釋 / Dilute extracted solution 氣相層析質譜儀分析 / Analysis was performed by GC/MS This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 號碼(No.): ETR22501100   日期(Date): 13-May-2022 頁數(Page): 8 of 12 台灣納美仕股份有限公司 (NAMICS TAIWAN CO., LTD.) 苗栗縣銅鑼鄉銅科一路3號 (NO. 3, TONGKE 1ST RD ., TONGLUO TOWNSHIP, MIAOLI COUNTY 36645, TAIWAN (R.O.C)) 六溴環十二烷分析流程圖 / Analytical flow chart - HBCDD 樣品前處理 / Sample pretreatment 樣品萃取 Sample extraction / 超音波萃取法 Ultrasonic method 萃取液濃縮/稀釋 / Concentrate/Dilute extracted solution 萃取液過濾 / Filter 以氣相層析/質譜儀分析 / Analysis was performed by GC/MS Fu 數據 / Data This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 號碼(No.): ETR22501100   日期(Date): 13-May-2022 頁數(Page): 9 of 12 台灣納美仕股份有限公司 (NAMICS TAIWAN CO., LTD.) 苗栗縣銅鑼鄉銅科一路3號 (NO. 3, TONGKE 1ST RD ., TONGLUO TOWNSHIP, MIAOLI COUNTY 36645, TAIWAN (R.O.C)) 鹵素分析流程圖 / Analytical flow chart - Halogen 樣品前處理/分樣 / Sample pretreatment/separation 秤重及將樣品放入樣品槽中 / Weighting and putting sample in cell 燃燒彈/吸收 Oxygen bomb combustion / Absorption 稀釋至固定體積 / Dilution to fixed volume 離子層析儀分析 / Analysis was performed by IC This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 10 of 12 號碼(No.): ETR22501100   日期(Date): 13-May-2022 台灣納美仕股份有限公司 (NAMICS TAIWAN CO., LTD.) 苗栗縣銅鑼鄉銅科一路3號 (NO. 3, TONGKE 1ST RD ., TONGLUO TOWNSHIP, MIAOLI COUNTY 36645, TAIWAN (R.O.C)) 元素(含重金屬)分析流程圖 / Analytical flow chart of Elements (Heavy metal included) 根據以下的流程圖之條件,樣品已完全溶解。 These samples were dissolved totally by pre-conditioning method according to below flow chart. 【參考方法/Reference method:US EPA 3051A、US EPA 3052】 剪裁、製備樣品 / Cutting、Preparation 測試樣品重量 / Sample measurement 硝酸/鹽酸/氫氟酸的微波消化 / Microwave digestion with HNO3/HCl/HF 過濾 / Filtration 殘渣 / Residue 溶液 / Solution 1) 2) 鹼熔融法 / Alkali Fusion 鹽酸溶解 / HCl to dissolve 感應耦合電漿發射光譜儀 (ICP-OES) * US EPA 3051A 方法未添加氫氟酸 / US EPA 3051A method does not add HF. This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 11 of 12 號碼(No.): ETR22501100   日期(Date): 13-May-2022 台灣納美仕股份有限公司 (NAMICS TAIWAN CO., LTD.) 苗栗縣銅鑼鄉銅科一路3號 (NO. 3, TONGKE 1ST RD ., TONGLUO TOWNSHIP, MIAOLI COUNTY 36645, TAIWAN (R.O.C)) 元素以 ICP-OES 分析的消化流程圖 (Flow Chart of digestion for the elements analysis performed by ICP-OES) 根據以下的流程圖之條件,樣品已完全溶解。 / These samples were dissolved totally by pre-conditioning method according to below flow chart. 剪裁、製備樣品 / Cutting、Preparation 測試樣品重量 / Sample Measurement 依據不同樣品的材質而以適當的酸進行消化(如下表所示) / Acid digestion by suitable acid depended on different sample material (as below table) 過濾 / Filtration 殘渣 / Residue 溶液 / Solution 1) 鹼熔融法 / Alkali Fusion 2) 鹽酸溶解 / HCl to dissolve 感應耦合電漿發射光譜儀 / ICP-OES 鋼,銅,鋁,焊錫 / Steel, copper, aluminum, solder 玻璃 / Glass 金,鉑,鈀,陶瓷 / Gold, platinum, palladium, ceramic 銀 / Silver 塑膠 / Plastic 其他 / Others 王水,硝酸,鹽酸,氫氟酸,雙氧水 / Aqua regia, HNO3, HCl, HF, H2O2 硝酸,氫氟酸 / HNO3/HF 王水 / Aqua regia 硝酸 / HNO3 硫酸,雙氧水,硝酸,鹽酸 / H2SO4, H2O2, HNO3, HCl 加入適當的試劑至完全溶解 / Added appropriate reagent to total digestion This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group 測試報告 Test Report 頁數(Page): 12 of 12 號碼(No.): ETR22501100   日期(Date): 13-May-2022 台灣納美仕股份有限公司 (NAMICS TAIWAN CO., LTD.) 苗栗縣銅鑼鄉銅科一路3號 (NO. 3, TONGKE 1ST RD ., TONGLUO TOWNSHIP, MIAOLI COUNTY 36645, TAIWAN (R.O.C)) #PIC * 照片中如有箭頭標示,則表示為實際檢測之樣品/部位. * (The tested sample / part is marked by an arrow if it's shown on the photo.) ** 報告結尾 (End of Report) ** This document is issued by the Company subject to its General Conditions of Service printed overleaf, available on request or accessible at https://www.sgs.com.tw/terms-of-service and, for electronic format documents, subject to Terms and Conditions for Electronic Documents at https://www.sgs.com.tw/terms-of-service. Attention is drawn to the limitation of liability, indemnification and jurisdiction issues defined therein. Any holder of this document is advised that information contained hereon reflects the Company’s findings at the time of its intervention only and within the limits of client’s instruction, if any. The Company’s sole responsibility is to its Client and this document does not exonerate parties to a transaction from exercising all their rights and obligations under the transaction documents. This document cannot be reproduced, except in full, without prior written approval of the Company. Any unauthorized alteration, forgery or falsification of the content or appearance of this document is unlawful and offenders may be prosecuted to the fullest extent of the law. Unless otherwise stated the results shown in this test report refer only to the sample(s) tested. SGS Taiwan Ltd. 台灣檢驗科技股份有限公司 f+886(02)2299 3237 新北市五股區新北產業園區五權七路 25 號 t+886(02)2299 3939 25, Wu Chyuan 7th Road, New Taipei Industrial Park, Wu Ku District, New Taipei City, Taiwan Member of the SGS Group SAFETY DATA SHEET SDS No. SP-30_B 1、CHEMICAL PRODUCT AND COMPANY IDENTIFICATION CHMICAL PRODUCT NAME:EMI FERRITE CORE COMPANY INFORMATION NAME OF MANUFACTURER:King Core Electronics Inc. NAME OF SECTION: ADDRESS:No. 269, Nan Fong Road, Ping Jhen Dist, Tao Yuan City 324, Taiwan TELEPHONE NUMBER: 886-3-4698855 FAX NUMBER: 886-3-4691395 2、HAZARDS IDENTIFICATION PHYSICAL AND CHEMICAL HAZARDS:NA ADVERSE HUMAN HEALTH HAZARD:NA ENVIRONMENTAL EFFECTS:NA 3、COMPOSITION,INFORMATION OR INGREDIENT SUBSTANCE/MIXTURE: Description of Components-Chemical Homogenous sub-part Name Iron Oxide Nickel Oxide Ferrite Core Zinc Oxide Copper Oxide Bismuth oxide Copper Wire Tin Solder Silver wt.% CAS No. ~48 ~15 ~19 ~14.85 ~0.15 ~1.9 ~0.1 ~1 1309-37-1 1314-06-3 1314-13-2 1317-38-0 1304-76-3 7440-50-8 7440-31-5 7440-22-4 4、FIRST AID MEASURES EYE CONTACT: Rinse with good general purpose eye wash SKIN CONTACT: Wash off with soap and water 2017/6/19 1 INHALATION: Terminate exposure and move to fresh air. Seek medical advise INGESTION: Induce drinking of copious quantities of water. Seek medical advise 5、FIRE FIGHTING MEASURES FLASH POINT:Non flammable EXPLOSION LIMIT:NA FIRE-FIGHTING INSTRUCTIONS:NA EXTINGUISH MEDIA:NA 6、ACCIDENTAL RELEASE MEASURES Sweep up into containers. Use appropriate protective clothing; gloves; safety glasses and dust masks if required 7、HANDLING AND STORAGE HANDLING: Fragile, avoid collision and stress STORAGE: Store in clean, dry, well-ventilated environment. Avoid stress 8、EXPOSURE CONTROLS,PERSONAL PROTECTION EXPOSURE GUIDELINES:NA ENGINEERING MEASURES:NA PROTECTIVE EQUIPMENT:NA RESPIRATORY PROTECTION:NA EYE PROTECTION:Safety glasses HAND,SKIN AND BODY PROTECTION:Protective glove, clothing 9、PHYSICAL AND CHEMICAL PROPERTIES APPEARANCE:Black BOILING POINT:NA VAPOUR PRESSURE:NA MELTING POINT:NA SPECIFIC GRAVITY:5g/cm3 2017/6/19 2 SOLUBILITY (IN WATER):Insoluble 10、STABILITY AND REACTIVITY CHEMICAL STABILITY:Stable INCOMPATIBILITY WITH OTHER MAERIALS:Stable HAZARDOUS DECOMPOSITION PRODUCTS:NA HAZARDOUS POLYMERIZATION:NA 11、TOXICOLOGICAL INFORMATION CORROSIVE AND IRRITANT PROPERTIES:NA ALLERGENIC AND SENSITIZING EFFECTS:NA ACUTE TOXICITY:NA SUB-ACUTE TOXICITY:NA CHRONIC TOXICITY:NA CARCINOGENIC EFFECTS:NA MUTAGENIC EFFECTS:NA EFFECTS ON THE REPRODUCTIVE SYSTEM:NA TERATOGENIC EFFECTS:NA 12、ECOLOGICAL INFORMATION BIODEGRADABILITY:NA BIOACCULATION:NA FISH TOXICITY:NA OTHER INFORMATION:NA 13、DISPOSAL CONSIDERATIONS NA 14、TRANSPORT INFORMATION UN CLASS:NA UN NUMBER:NA 15、TEGULATORY INFORMATION JAPAN STATUS EXISTING CHEMICAL SUBSTANCES(MITI):NA 2017/6/19 3 US STATUS TSCA INVENTORY:NA EU STATUS EINECS:NA LABELLING ACCORDING TO EEC DIRECTIVES:NA HAZARD SYMBOL:NA RISK PHRASES:NA SAFETY ADVICES:NA Regulatory information with regard to this substance in your country or in your region Should be examined by your own responsibility 16、OTHER INFORMATION REFERENCES:No specific notes The information herein is given in good faith,but no warranty,express or implied,is made; Please consult the KINGCORE INC. for further information 2017/6/19 4
K5B S5HQ 5x4.6x5.5-2.5Ts-M-T 价格&库存
很抱歉,暂时无法提供与“K5B S5HQ 5x4.6x5.5-2.5Ts-M-T”相匹配的价格&库存,您可以联系我们找货
