BCX54 THRU BCX56
BCX54 THRU BCX56
TRANSISTOR(NPN)
FEATURE
SOT-89
z
z
PNP Complements to BCX51,BCX52,BCX53
Low Voltage
z
High Current
1. BASE
2. COLLECTOR
3. EMITTER
APPLICATIONS
z
Driver Stages of Audio Amplifiers
MAXIMUM RATINGS (TA=25Я unless otherwise noted)
Symbol
VCBO
VCEO
VEBO
Parameter
Collector-Base Voltage
Collector-Emitter Voltage
Value
BCX54
45
BCX55
60
BCX56
100
BCX54
45
BCX55
60
BCX56
80
Unit
V
V
Emitter-Base Voltage
5
V
IC
Collector Current
1
A
PC
Collector Power Dissipation
500
mW mW
Thermal Resistance From Junction To Ambient
250
℃/W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
RθJA
www.tw-gmc.com
1
BCX54 THRU BCX56
ELECTRICAL CHARACTERISTICS (Ta=25 ℃ unless otherwise specified)
Parameter
Symbol
Collector-base breakdown voltage
V(BR)CBO
Collector-emitter breakdown voltage
Emitter-base breakdown voltage
V(BR)CEO*
T est
conditions
IC=100µA,IE=0
IC=10mA,IB=0
Min
BCX54
45
BCX55
60
BCX56
100
BCX54
45
BCX55
60
BCX56
80
Typ
Max
Unit
V
V
5
V
V(BR)EBO
IE=100µA,IC=0
Collector cut-off current
ICBO
VCB=30V,IE=0
0.1
µA
Emitter cut-off current
IEBO
VEB=5V,IC=0
0.1
µA
hFE(1)*
VCE=2V, IC=5mA
40
hFE(2)*
VCE=2V, IC=150mA
63
25
DC current gain
250
hFE(3)*
VCE=2V, IC=0.5A
VCE(sat)*
IC=0.5A,IB=50mA
0.5
V
Base -emitter voltage
VBE*
VCE=2V, IC=0.5A
1
V
Transition frequency
fT
Collector-emitter saturation voltage
VCE=5V,IC=10mA, f=100MHz
130
CLASSIFICATION OF hFE
FE(2)
BCX54
BCX54-10
BCX54-16
RANK
BCX55
BCX55-10
BCX55-16
BCX56
BCX56-10
BCX56-16
RANGE
63–250
63–160
100–250
www.tw-gmc.com
2
MHz
BCX54 THRU BCX56
TYPICAL CHARACTERISTICS
Static Characteristic
(mA)
250
hFE
0.8mA
DC CURRENT GAIN
COLLECTOR CURRENT
IC
0.9mA
150
IC
COMMON EMITTER
VCE=2V
COMMON
EMITTER
Ta=25℃
1.0mA
200
hFE
1000
0.7mA
0.6mA
100
0.5mA
0.4mA
0.3mA
50
Ta=100℃
300
Ta=25℃
100
30
0.2mA
IB=0.1mA
10
2
3
4
COLLECTOR-EMITTER VOLTAGE
VCEsat
1000
VCE
1
5
IC
VBEsat
1.0
BASE-EMMITTER SATURATION
VOLTAGE VBEsat (V)
COLLECTOR-EMMITTER SATURATION
VOLTAGE VCEsat (mV)
300
100
Ta=100℃
Ta=25℃
30
1000
(mA)
IC
0.8
Ta=25℃
Ta=100℃
0.6
0.4
1
10
100
COLLECTOR CURRENT
IC
1000
IC
1
1000
(mA)
10
(mA)
100
COLLECTOR CURRENT
VBE
Cob/ Cib
300
COMMON EMITTER
VCE=2V
IC
1000
(mA)
VCB/ VEB
f=1MHz
IE=0/IC=0
Cib
100
Ta=25℃
(pF)
Ta=100℃
C
100
Ta=25℃
10
1
0.2
0.4
0.6
0.8
BASE-EMITTER VOLTAGE
fT
VBE
Cob
10
1
0.1
1.0
1
0.3
(V)
IC
PC
600
COLLECTOR POWER DISSIPATION
PC (mW)
fT
100
COMMON EMITTER
VCE=5V
10
3
REVERSE BIAS VOLTAGE
(MHz)
500
CAPACITANCE
IC
IC
β=10
10
COLLECTOR CURRENT
100
COLLECTOR CURRENT
β=10
TRANSITION FREQUENCY
10
(V)
V
(V)
Ta
500
400
300
200
100
Ta=25℃
10
10
www.tw-gmc.com
30
COLLECTOR CURRENT
IC
(mA)
25
50
75
AMBIENT TEMPERATURE
3
100
Ta
125
150
BCX54 THRU BCX56
Physical Dimensions
SOT- 89
www.tw-gmc.com
4
很抱歉,暂时无法提供与“BCX56-16”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.40480
- 50+0.23870
- 1000+0.21450
- 国内价格
- 10+0.44972
- 100+0.37714
- 300+0.34085
- 1000+0.23231
- 5000+0.21050
- 10000+0.19959
