CYA1040-3.3UH
CYA1040-3.3UH
    SHOUHAN(首韩)
    SMD,11.6x10.1mm
    固定电感器 SMD,11.6x10.1mm 3.3μH ±20% 11A
CYA1040-3.3UH 数据手册
深圳市首韩科技有限公司 1.Features 公 2.Applications area 司 ①. H igh performance (Isat) realize by metal dust core . ②. Low profile: Thickness max.2.0~5.0mm. ③. Low loss and low resistance. ④. Capable of corresponding high frequency 1MHz~5MHz. ⑤ Ultra low buzz noise, due to composite construction. ⑥. The products contain no lead and also support lead-free soldering. Externl Dimensions (unit : mm ) 有 3. 限 Ideally used in NB/Desktop/server/Graphic card, LCD TV/Projector, etc as DC-DC Converter. 技 UNIT: mm A: 11.6MAX B: 10.1±0 .3 C:4. 0MAX D:2 .5 ±0 .5 E:3 .0± 0 .5 1040 深 圳 CYA 市 4. Product Code 首 韩 科 1R5 3R3 M TOLERANCE 公差 INDUCTANCE VALUE 电感值 DIMENSIONS 尺寸 SERIAL CODE 系列代码 • 电感值Inductance Value (1R0:1.0uH; 100: 10uH; 101:100uH) Code 代码 Tolerance 公差 J ±5% K ±10% L ±15% M ±20% P ±25% N ±30% 深圳市首韩科技有限公司 SHENZHEN SHOUHAN TECHNOLOGYCO.,LTD Tel: 0755-27597601 Fax: 0755-27597491 承 认 书 产品名称 Project: 电感 CYA1040-3.3UH 韩 科 规格型号 Part No: 有 户 Customer: 技 客 限 公 司 SPECIFICATION FOR APPROVAL 首 贵公司承认印 Approal slgnatures 签 章/Signatures 深 圳 市 料 号/Part No. 日期 Date: 拟制/Drawn 李春风 审核/Check 钟华华 批准/Approved 罗孝金 深圳市首韩科技有限公司 5. Electrical Characteristics CYA1040 Series Electrical Characteristics Rdc (mΩ) @25°C Heat Rating Saturation Current DC TEST FREQ (KHZ) C.Y PART NO CYA1040-R36M 0.36±20% 1.05 1.20 34.00 42.00 100KHZ/1.0v CYA1040-R47M 0.47±20% 1.53 1.68 28.00 38.00 100KHZ/1.0v CYA1040-R56M 0.56±20% 1.60 1.80 27.00 32.00 100KHZ/1.0v CYA1040-R68M 0.68±20% 2.10 2.40 23.00 30.00 100KHZ/1.0v CYA1040-1R0M 1.00±20% 3.00 3.30 20.00 26.00 100KHZ/1.0v CYA1040-1R5M 1.50±20% 3.80 4.20 16.00 22.00 100KHZ/1.0v CYA1040-2R2M 2.20±20% 6.00 7.00 有 L0(uH) Inductance (uH)@(0A) 14.00 16.00 100KHZ/1.0v CYA1040-3R3M 3.30±20% 10.80 11.80 11.00 13.00 100KHZ/1.0v CYA1040-4R7M 4.70±20% 14.00 16.50 9.00 12.00 100KHZ/1.0v CYA1040-6R8M 6.80±20% 22.50 25.00 8.00 10.00 100KHZ/1.0v CYA1040-8R2M 8.20±20% 25.00 27.00 7.50 9.00 100KHZ/1.0v CYA1040-100M 10.0±20% 27.00 30.00 6.50 7.00 100KHZ/1.0v CYA1040-150M 15.0±20% 40.00 45.00 6.25 6.00 100KHZ/1.0v CYA1040-220M 22.0±20% 60.00 66.00 5.00 5.50 100KHZ/1.0v 韩 首 市 公 司 Amps. Isat (A) 限 (A) 技 Max. 科 Typ. Current DC Amps . Idc 33.0±20% 85.00 92.00 4.00 4.50 100KHZ/1.0v CYA1040-470M 47.0±20% 129.00 150.00 3.00 4.00 100KHZ/1.0v CYA1040-680M 68.0±20% 230.00 255.00 2.00 3.50 100KHZ/1.0v CYA1040-101M 100.0±20% 260.00 300.00 0.70 1.00 100KHZ/1.0v 深 圳 CYA1040-330M 深圳市首韩科技有限公司 • Notes 司 1.All test data is reference to 25℃ ambient. 2.Idc: DC current (A) that will cause an approximate △T of 40℃ 3. Isat :DC current (A) that will cause L0 to drop approximately 30% 4.Operating Temperature Range -55℃ to +125℃ 5.The part temperature (ambient + temp rise ) should not exceed 125 ℃ under worse case operating conditions. Circuit design, component. PWB trace size and thickness airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the den application. 公 6.The rated current as listde is either the saturation current or the heating current depending on which value is lower. 6.Minimum Packaging and storage 限 • 包装Packing 首 韩 科 技 有 Tape Dimension Reel Dimensions(mm) A 330 +2/-0 CYA0530 330 深 CYA0618 CYA0624 CYA0630 CYA0650 CYA1040 CYA1250 CYA1265 +2/-0 W C 100 12.4 13.2 +2/-0 +2/-0 ±0.2 100 12.4 13.2 +2/-0 +2/-0 ±0.2 圳 CYA0420 N 市 Type 330 100 16.4 13.2 +2/-0 +2/-0 +2/-0 ±0.2 330 100 16.4 13.2 +2/-0 +2/-0 +2/-0 ±0.2 330 100 16.4 13.2 +2/-0 +2/-0 +2/-0 ±0.2 330 100 16.4 13.2 +2/-0 +2/-0 +2/-0 ±0.2 330 100 24.4 13.2 +2/-0 +2/-0 +2/-0 ±0.2 330 100 24.4 13.2 +2/-0 +2/-0 +2/-0 ±0.2 330 100 24.4 13.2 +2/-0 +2/-0 +2/-0 ±0.2 Tape Dimensions(mm) W P P0 A0 B0 H T 12±0.3 8±0.1 4±0.1 4.4±0.1 4.9±0.1 2.3±0.05 0.35±0.05 12±0.3 8±0.1 4±0.1 5.4±0.1 5.9±0.1 3.3±0.05 0.35±0.05 16±0.3 12±0.1 4±0.1 6.9±0.1 7.5±0.1 2.1±0.05 0.35±0.05 16±0.3 12±0.1 4±0.1 6.9±0.1 7.5±0.1 2.7±0.05 0.35±0.05 16±0.3 12±0.1 4±0.1 6.9±0.1 7.5±0.1 3.3±0.05 0.35±0.05 16±0.3 12±0.1 4±0.1 6.9±0.1 7.5±0.1 5.2±0.1 0.4±0.05 24±0.3 16±0.1 4±0.1 10.4±0.1 11.5±0.1 4.3±0.1 0.35±0.05 24±0.3 16±0.1 4±0.1 13.2±0.1 14.4±0.1 5.3±0.1 0.4±0.05 24±0.3 16±0.1 4±0.1 13.2±0.1 14.4±0.1 6.8±0.1 0.5±0.05 深圳市首韩科技有限公司 • Tape Carrier Packaging: Standard Quantity (pcs/reel) Type Standard Quantity (pcs/reel) Type 3000 CYA1250 400 CYA5030 2000 CYA1265 400 CYA6030 1000 CYA1040 1000 公 司 CYA0420 技 有 限 • Tearing Off Force Room Temp. ( )℃ Room Humidity (%) 45~85 • Application Notice Room atm (hPa) 860~1060 Tearing Speed mm/min 300 首 韩 5~35 科 The force for tearing off cover tape is 15 to 60 grams in the arrow direction under the following conditions 市 Storage Conditions To maintain the solderability of terminal electrodes: 1. Temperature and humidity conditions: Less than 30℃ and 70% RH. 2. Recommended products should be used within 6 months form the time of delivery. 圳 3. The packaging material should be kept where no chlorine or sulfur exists in the air. Transportation 1. Products should be handled with care to avoid damage or contamination from perspiration and skin oils . 深 2. The use of tweezers or vacuum pick up is strongly recommended for individual components. Bulk handling should ensure that abrasion and mechanical shock are minimized.
CYA1040-3.3UH 价格&库存
很抱歉,暂时无法提供与“CYA1040-3.3UH”相匹配的价格&库存,您可以联系我们找货
CYA1040-3.3UH
  • 5+2.22547
  • 50+1.78481
  • 150+1.59592
  • 1000+1.36024
  • 2000+1.25532
  • 5000+1.19232
库存:1092
