JW3655EQFNE#TRPBF
JW3655EQFNE#TRPBF
    JOULWATT(杰华特)
    QFN15
    电池充电管理 QFN15
JW3655EQFNE#TRPBF 数据手册
JW3655E High Efficiency, 3A, Multi-Cells Li-Ion Battery Charger DESCRIPTION FEATURES The JW®3655E is a buck boost converter targets HVDC fast charging system. The JW3655E supports 1 to 4 cells Li-ion battery, the full charge voltage and charge current can be programmable through external resistor.  The JW3655E implements the Buck Boost converter with an H-bridge. The integrated low RDS(on) MOSFET minimizes physical footprint, maximizes charge efficiency. Built-in loop compensation simplifies the circuit and design. PFM is engaged to maintain high efficiency at light load current.  JW3655E guarantees robustness with thermal protection. APPLICATIONS Company’sLogois Protected, “JW” and “JOULWATT” are Registered Trademarks of JoulWatt technology Inc.              Integrate low RDS(on) power MOSFET Wide input range: 4.2V-21.0V, support 1 to 4 cells battery charge Full charge voltage can be programmable through external resistor High efficiency 450kHz switching frequency Programmable charge current, up to 3A Quiescent current: >JOULWATT(杰华特) Downloaded From Oneyac.com
JW3655EQFNE#TRPBF 价格&库存
很抱歉,暂时无法提供与“JW3655EQFNE#TRPBF”相匹配的价格&库存,您可以联系我们找货
JW3655EQFNE#TRPBF
    • 1+3.04500
    • 30+2.94000
    • 100+2.73000
    • 500+2.52000
    • 1000+2.41500
    • 2000+2.31000
    库存:96
