FR101WS THRU FR107WS
Surface mount fast recovery rectifiers
Features
2
Low profile package
Ideal for automated placement
Glass passivated chip junctions
Low forward voltage drop
Low leakage current
High forward surge capability
High temperature soldering:
260℃/10 seconds at terminals
Component in accordance to
1
SOD-323
1
2
1.Cathode
2.Anode
RoHS 2011/65/EU and WEEE 2002/96/EC
Major Ratings and Characteristics
IF(AV)
1.0A
Mechanical Date
VRRM
50V to 1000V
Case: SOD-323
IFSM
25A
trr
150nS,250nS,500nS
Molding compound meets
UL 94 V-0 flammability rating
Terminals: Solder plated, solderable per
MIL-STD-750, Method 2026
Polarity:Laser band denotes cathode end
VF
1.3V
TJmax.
150°C
Maximum Ratings & Thermal Characteristics (TA = 25 °C unless otherwise noted)
Item
Symbol
FR10 FR10 FR10 FR10 FR10 FR10 FR10
1WS 2WS 3WS 4WS 5WS 6WS 7WS
Marking code
F1
F2
F3
F4
F5
F6
F7
Unit
Maximum repetitive peak reverse voltage
VRRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
VRMS
35
70
140
280
420
560
700
V
Maximum DC blocking voltage
VDC
50
100
200
400
600
800
1000
V
Maximum average forward rectified current at
TL=105°C
IF(AV)
1.0
A
Peak forward surge current 8.3 ms single half sinewave superimposed on rated load
IFSM
25
A
TJ,TSTG
–55 to +150
RθJL
35
°C/W
Operating and storage temperature range
Thermal resistance from junction to lead
(1)
Electrical Characteristics (TA = 25 °C unless otherwise noted)
Item
Instantaneous forward voltage
IF=1.0A(2)
Maximum reverse current
VR=VDC
Reverse recovery time
Symbol
Test conditions
FR101WS~
FR104WS
VF
TJ=25°C
IF=0.5A
IR=1.0A,Irr=0.25A
trr
FR106WS~
FR107WS
5.0
μA
50
150
250
Unit
V
1.3
IR
TJ=125°C
FR105WS
500
nS
Note1:Mounted on PCB with 0.2x0.2" (5.0mmx5.0mm) copper pad areas
2.Pulsetest:300μs pulse width,1% duty
www.slkormicro.com
1
Rev.1 -- 18 November 2018
Fig.2 Maximum Non-Repetitive Peak Forward
Surge Current
Fig.1 Forward Current Derating Curve
30
Peak Forward Surge Current (A)
Average Forward Rectified Current(A)
1.2
1.0
0.8
0.6
0.4
0.2
25
10
5
1
60
90
120
10
100
150
Number of Cycles at 60 Hz
Ambient Temperature (℃)
Fig.3 Typical Instantaneous Forward
Characteristics
Fig.4 Typical Reverse Characteristics
Instantaneous Rverse Current(μA)
Instantaneous Forward Current (A)
10
1
0.1
100
T J =125°C
10
1
T J =25°C
0.1
0.01
0.01
0.8
1.2
1.6
2
Instantaneous Forward Voltage (V)
www.slkormicro.com
60
80
100
Percent Of Rated Peak Reverse Voltage(%)
2
SOD-323
0.15(0.006)
0.10(0.004)
to
0.1(0.004)max
0.40(0.016)
0.25(0.010)
0°
0.2(0.008)
8°
1.15(0.045)
0.8(0.031)
Cathode bar
0.45(0.018)
1.5(0.059)
1.1(0.043)
0.20(0.008)
1.95(0.077)
1.60(0.063)
3.10 (0.122)
2 65(0 104)
Footprint recommendation:
0.8(0.031)
0.6(0.024)
0.8(0.031)
1.6(0.063)
Package dimensions in millimeters (inches)
www.slkormicro.com
3
很抱歉,暂时无法提供与“FR107WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.15137
- 300+0.11979
- 1200+0.10227
- 3000+0.09177
- 国内价格
- 20+0.16514
- 200+0.13068
- 600+0.11157
- 3000+0.10012
- 9000+0.09018
- 21000+0.08478
