1ASP0419
1ASP0419
    JICTEN(久晨电子)
    插件,P=4.7mm
    拨动开关 SPDT 3Pin 插件,P=4.7mm
1ASP0419 数据手册
POS.1 POS.2 POS.3 ON NONE ON KEYWAY 2-3 EPOXY SEAL Silver RATING 1/4-40 UNS-2A 2B 2-1 N/A COLOR:GRAY SWITCH FUNCTION Q'TY 2 PART NAME PART NO. 1 MNU-1M01A 2 MNU-1M02 3 MNU-1M03 1/4 INCH NUTS 1 1 LOCKING RING LOCKING WASHER FILE NAME:HARDWARE-0002 EPOXY SEAl Without locking ring. With standard locking ring. PANEL MOUNTING SOLDER LUG SPECIFICATIONS MECHANICAL LIFE: 30,000 make-and-break cycles. CONTACT RESISTANCE: 10 mȟġmax. initial @ 2-4VDC 100mA for both silver and gold plated contacts. INSULATION RESISTANCE: 1,000 M ȟġmin. DIELECTRIC STRENGTH: 1,000 Vrms min.@sea level. OPERATING TEMPERATURE: -40°C to 85°C. CONTACT PLATING MATERIALS CASE BUSHING: Glass filled nylon 6/6, flame retardant, heat stabilized(UL94v-0). ACTUATOR: Glass filled nylon 6/6, O-ring seal standard. CONTACT/TERMINAL: Copper alloy. RoHS & Lead Free Q Silver C Gold over Silver Gold R TERMINAL PLATING Gold flash over silver RATINGS 5 Amps @120 VAC or 28VDC Gold over silver 2 Amps @250 VAC Gold 0.4 Volt-Amps(VA) max. @20V max. (AC or DC) ł IJ ij Ĵ ĵ Ķ 䫎嘇 ł Ń ń Ņ ņ ⍇⯢⮠ ᾖ㓡⼴⯢⮠ 㑵ἄ㹓⹎-30ɗᾖ妪䁢-40ɗ 嬲㚜㖍㛇 FEB-14-2020 SCALE (㭼ἳ) : 3 : 2 TITLE TOLERANCE (℔ⶖ) : 0.00mm±0.25mm 0.0mm±0.40mm ANGULAR: ±5° FILE NAME : 1ASP0419 DWG NO. ⚾ġ⎵ ⚾ġ嘇 REV. 䇰ġ㛔 SIZE Sealed Miniature Toggle Switches 1AS1TCB19M1QES-5V B DATE 㖍ġ㛇 FEB - 03 - 2010 A4 UNIT inch mm ╖ỵ SHEET ⻝ġ㔠 1 of 1 APPROVE CHECK DRAW ⮑ġġ㟠 䡢ġ娵 墥ġġ⚾ 䇰㛔 : D ⚾䳁 IRENE 堐╖䶐嘇 : QR-0507
1ASP0419 价格&库存
很抱歉,暂时无法提供与“1ASP0419”相匹配的价格&库存,您可以联系我们找货
