DF12NC(3.0)-50DP-0.5V(51)
    HRS(广濑)
    SMD,P=0.5mm
    板对板连接器 立贴 针脚数:50Pin 间距:0.5mm 排数:2
DF12NC(3.0)-50DP-0.5V(51) 数据手册
APPLICABLE STANDARD OPERATING TEMPERATURE RANGE RATING -10 C TO 60 C(NOTES 2) 50 V AC 0.3 A VOLTAGE CURRENT Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. STORAGE TEMPERATURE RANGE -55 C TO 125 C(NOTES 1) SPECIFICATIONS ITEM TEST METHOD REQUIREMENTS QT AT ACCORDING TO DRAWING. X X X X CONTACT RESISTANCE 20 mV AC OR LESS 1 kHz, 1 mA. 50 m MAX. INSULATION RESISTANCE 100 V DC 500 MΩMAX VOLTAGE PROOF 150 V AC FOR 1 min. NO FLASHOVER OR BREAKDOWN. X X X - - - X - X - X - ① CONTACT RESISTANCE: 50 m MAX. ② INSULATION RESISTANCE: 500 M MIN. ③ NO DAMAGE, CRACK AND LOOSENESS OF PARTS. ① CONTACT RESISTANCE: 50 m MAX. ② INSULATION RESISTANCE: 500 M MIN. ③ NO DAMAGE, CRACK AND LOOSENESS OF PARTS. X - X - ① CONTACT RESISTANCE: 50 m MAX. ② NO HEAVY CORROSION. NO DEFORMATION OF CASE OF EXCESSIVE LOOSENESS OF THE TERMINALS. X - X - CONSTRUCTION GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT. MARKING CONFIRMED VISUALLY. ELECTRIC CHARACTERISTICS MECHANICAL CHARACTERISTICS MECHANICAL OPERATION VIBRATION SHOCK ① CONTACT RESISTANCE: 50 m MAX. ② NO DAMAGE, CRACK AND LOOSENESS OF PARTS. FREQUENCY 10 TO 55 Hz, SINGLE AMPLITUDE ① NO ELECTRICAL DISCONTINUITY OF 1 s. 0.75 mm, AT 2 h, FOR 3 DIRECTIONS. ② NO DAMAGE, CRACK AND LOOSENESS OF PARTS. 2 490 m/s DURATION OF PULSE 11 ms AT 3 TIMES ① NO ELECTRICAL DISCONTINUITY OF 1 s. FOR 3 DIRECTIONS. ② NO DAMAGE, CRACK AND LOOSENESS OF PARTS. 50 TIMES INSERTIONS AND WITHDRAWALS. ENVIRONMENTAL CHARACTERISTICS RAPID CHANGE OF TEMPERATURE TEMPERATURE -65 →15 TO 35 →125 →15 TO 35 C TIME 30 → 2 TO 3 → 30 → 2 TO 3 min UNDER 5 CYCLES. DAMP HEAT (STEADY STATE) EXPOSED AT 40 ± 2 C, 90 TO 95 , 96 h. SULPHUR DIOXIDE EXPOSED IN 25 PPM RH 75 % FOR 96 h. (TEST STANDARD:JEIDA-38) HEAT RESISTANCE OF SOLDERING 【RECOMMENDED TEMPERATURE PROFILE】 《SOLDERING AREA》 MAX250℃, 220℃ FOR 60 SECONDS MAX. 《PREHEATING AREA》 150 TO 180℃ 90~120 SECONDS. MAXIMUM TWICE ACTION IS ALLOWED UNDER THE SAME CONDITION. 【RECOMMENDED MANUAL SOLDELING CONDITION 】 SOLDERING IRON TEMPERATURE 350℃ SOLDERING TIME : WITHIN 3 SECONDS. REMARKS NOTES1:INCLUDING THE TEMPERATURE RISE BY CURRENT. NOTES2:STORAGEIS DEFINED AS LONG-TERM STORAGE OF UNUSED PRODUCTS. APPLY OPERATION TEMPERATURE RANGE TO PRODUCTS MOUNTED ON PCB WITHOUT POWER SUPLLY. UNLESS OTHERWISE SPECIFIED , REFER △ COUNT TO JIS C 5402 . DESCRIPTION OF REVISIONS DESIGNED CHECKED DATE 0 Note QT:Qualification Test FORM HD0011-2-1 AT:Assurance Test X:Applicable Test APPROVED WR.FUKUCHI 20200716 CHECKED TS.MIYAZAKI 20200716 DESIGNED KT.KUSAKA 20200716 DRAWN RN.IIDA 20200715 DRAWING NO. ELC-389248-51-01 SPECIFICATION SHEET PART NO. DF12NB(3.0)-36DS-0.5V(51) HIROSE ELECTRIC CO., LTD. CODE NO. CL537-0187-0-51 0 △ 1/1
DF12NC(3.0)-50DP-0.5V(51) 价格&库存
很抱歉,暂时无法提供与“DF12NC(3.0)-50DP-0.5V(51)”相匹配的价格&库存,您可以联系我们找货
    • 1000+3.33850
    库存:2000
    • 1000+11.683981000+1.46003
    • 2000+11.126602000+1.39038
    • 3000+10.813113000+1.35121
    • 5000+10.430655000+1.30341
    • 7000+10.186227000+1.27287
    • 1+18.814681+2.35108
    • 10+16.0073610+2.00028
    • 25+15.0032825+1.87481
    • 50+14.2859850+1.78518
    • 100+13.60291100+1.69982
    • 250+12.75079250+1.59334
    • 500+12.14196500+1.51726
