PESD0201V05
Features
The best ESD protection for high speed ,high
frequency and low voltage applications
RoHS compliant and halogen free
Ultra-low capacitance : Cj=0.05pF (typ.)
Low clamping voltage according to IEC61000-4-2
Fast response time
IEC61000-4-2 (ESD):Contact±8kV (typ.), ±15kV (max.)
IEC61000-4-2 (ESD):Air ±15kV (typ.), ±25kV (max.)
Surface mount
Applications
Mechanical Data
USB2.0 and USB3.0
Ultra-high-speed data line
Sensitive interfaces lines
Packaging: Tape and Reel
High Definition Multi-media Interface(HDMI)
RoHS/WEEE Compliant
Antenna applications
10/100/1000Mbit/s Ethernet
Molding compound flammability rating:
UL94V-0
Schematic & PIN Configuration
0571-87006810
www.dowosemi.cn
1/4
PESD0201V05
Absolute Maximum Rating
Rating
Symbol
Value
Units
VESD
25
15
kV
Lead Soldering Temperature
TL
260(10seconds)
Junction Temperature
TJ
-55 to + 125
Storage Temperature
Tstg
-55 to + 125
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
Electrical Characteristics
Parameter
Symbol
Continuous Operating Voltage
VDC
Conditions
Min.
Typ.
Max.
Units
5
V
0.1
μA
Reverse Leakage Current
IR
VDC=5V,T=25℃
0.01
Clamping Voltage
VT
IEC61000-4-2
8kVcontact discharge
300
V
Clamping Voltage
VC
IEC61000-4-2
35
V
Junction Capacitance
Cj
VR = 0V, f = 1MHz
0.05
pF
ESD Clamping Test
ESD TESTER
RZ
450 Ω
RG 223/U
50 Ω coax
4 GHz DIGITAL
10×
OSCILLOSCOPE
ATTENUATOR
50 Ω
CZ
DUT (DEVICE UNDER TEST)
IEC 61000-4-2 network
CZ = 150 pF; RZ = 330 Ω
0571-87006810
www.dowosemi.cn
2/4
PESD0201V05
ESD Clamping Test Waveforms
Figure 2: 8kV Contact ESD pulse clamping
per IEC61000-4-2
Figure1: ESD pulse wavefrom
according to IEC 61000-4-2
250
100%
90%
200
30ns
150
60ns
100
50
10%
tr 0.7to 1ns
30
-50
60
50
150
250
tp(ns)
Time(ns)
Solder Reflow Recommendations
Temperatures (°C)
300
250
200
150
100
50
100
150
200
250
Time(seconds)
0571-87006810
www.dowosemi.cn
3/4
PESD0201V05
Outline Drawing
Symbol
Dimension
Min
Typ
Max
A
0.55
0.60
0.65
B
0.25
0.30
0.35
C
0.25
0.30
0.35
H
0.18
0.20
0.22
F
0.255
0.275
0.295
G
0.16
0.18
0.20
Unit
mm
Land Pattern *
0.23mm
0.30mm
0.23mm
0.15mm
0.61mm
* This Land Pattern is For Reference Purposes Only
Ordering Information
Part number
Package
Type
Reel size
MOQ
PESD0201V05
0201
T/R
7 inch
15k/reel
0571-87006810
www.dowosemi.cn
4/4
很抱歉,暂时无法提供与“PESD0201V05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.18026
- 200+0.14170
- 600+0.12032
- 2000+0.10746
- 15000+0.10206
- 30000+0.09602
- 国内价格
- 1+0.41690
- 500+0.13970
- 7500+0.09559
- 15000+0.07590
- 国内价格
- 20+0.16424
- 1500+0.09791
- 6000+0.09644
- 15000+0.09296
