1N47xxxPF
Silicon Planar Power Zener Diodes
for use in stabilizing and clipping circuits with high power
rating. Standard zener voltage tolerance is ±10%. Add
suffix "A" for ±5% tolerance and suffix "B" for ±2%
tolerance. Other tolerances are available upon request.
Max. 0.7
Min. 25.4
Max. 2.8
Black
Cathode Band
Black
Part No.
Black
"ST" Brand
Features
XXX
Max. 4.2
ST
• Lead Free
Min. 25.4
Glass Case DO-41
Dimensions in mm
Absolute Maximum Ratings (Ta = 25℃)
Parameter
Power Dissipation
1)
Junction Temperature
Storage Temperature Range
Thermal Characteristics
Parameter
Thermal Resistance Junction to Ambient Air
1)
1)
Symbol
Value
Unit
Ptot
1
W
Tj
175
Tstg
- 65 to + 175
Symbol
Max.
Unit
RθJA
150
℃/W
Valid provided that leads at a distance of 8 mm from case are kept at ambient temperature.
1/5
Dated : 20/08/2021 Rev: 01
1N47xxxPF
Characteristics at Ta = 25℃ (VF max : 1.2 V at IF = 200 mA)
Zener Voltage Range
Type
1N4727PF
1N4728PF
1N4729PF
1N4730PF
1N4731PF
1N4732PF
1N4733PF
1N4734PF
1N4735PF
1N4736PF
1N4737PF
1N4738PF
1N4739PF
1N4740PF
1N4741PF
1N4742PF
1N4743PF
1N4744PF
1N4745PF
1N4746PF
1N4747PF
1N4748PF
1N4749PF
1N4750PF
1N4751PF
1N4752PF
1N4753PF
1N4754PF
1N4755PF
1N4756PF
1N4757PF
1N4758PF
1N4759PF
1N4760PF
1N4761PF
VZnom
VZT
3)
at lZT
(V)
Min.
(V)
Max.
(V)
3
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
10
11
12
13
15
16
18
24
27
30
33
36
39
43
47
51
56
62
68
75
2.7
2.97
3.24
3.51
3.87
4.23
4.59
5.04
5.58
6.12
6.75
7.38
8.19
9
9.9
10.8
11.7
13.5
14.4
16.2
18
19.8
21.6
24.3
27
29.7
32.4
35.1
38.7
42.3
45.9
50.4
55.8
61.2
67.5
3.3
3.63
3.96
4.29
4.73
5.17
5.61
6.16
6.82
7.48
8.25
9.02
10.01
11
12.1
13.2
14.3
16.5
17.6
19.8
22
24.2
26.4
29.7
33
36.3
39.6
42.9
47.3
51.7
56.1
61.6
68.2
74.8
82.5
(mA)
83
76
69
64
58
53
49
45
41
37
34
31
28
25
23
21
19
17
15.5
14
12.5
11.5
10.5
9.5
8.5
7.5
7
6.5
6
5.5
5
4.5
4
3.7
3.3
Dynamic Resistance 1)
ZZT
Max.
(Ω)
10
10
10
9
9
8
7
5
2
3.5
4
4.5
5
7
8
9
10
14
16
23
25
35
40
45
50
60
70
80
95
110
125
150
175
ZZK
Max.
(Ω)
400
400
400
400
400
500
550
600
700
700
700
700
700
700
700
700
700
700
700
750
750
750
750
750
1000
1000
1000
1000
1500
1500
1500
2000
2000
2000
2000
at IZK
(mA)
1
1
1
1
1
1
1
1
1
1
0.5
0.5
0.5
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
Reverse
Current
IR
at VR
Max.
(V)
(µA)
150
1
150
1
100
1
100
1
50
1
10
1
10
1
10
2
10
3
10
4
10
5
10
6
10
7
10
7.6
5
8.4
5
9.1
5
9.9
5
11.4
5
12.2
5
13.7
5
15.2
5
16.7
5
18.2
5
20.6
5
22.8
5
25.1
5
27.4
5
29.7
5
32.7
5
35.8
5
38.8
5
42.6
5
47.1
5
51.7
5
56
Maximum
Surge
Current 4)
IZSM
(mA)
1375
1375
1260
1190
1070
970
890
810
730
660
605
550
500
454
414
380
344
304
285
250
225
205
190
170
150
135
125
115
110
95
90
80
70
65
60
Maximum
Regulator
Current 2)
Temperature
coefficient
at IZT
IZM (mA)
275
275
252
234
217
193
178
162
146
133
121
110
100
91
83
76
69
61
57
50
45
41
38
34
30
27
25
23
22
19
18
16
14
13
12
-0.08 to -0.05
-0.08 to -0.05
-0.08 to -0.05
-0.07 to -0.02
-0.07 to -0.01
-0.03 to +0.04
-0.01 to +0.04
0.10 to +0.045
+0.01 to +0.055
+0.015 to +0.06
+0.02 to +0.065
0.03 to 0.07
0.035 to 0.075
0.04 to 0.08
0.045 to 0.08
0.045 to 0.085
0.05 to 0.085
0.055 to 0.09
0.055 to 0.09
0.06 to 0.09
0.06 to 0.09
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
1)
The dynamic resistance is derived from the 60 Hz AC voltage which results when an AC current having an RMS value equal to 10% of the
Zener Current (IZT or IZK) is superimposed on IZT or IZK. Dynamic resistance is measured at two points to insure a sharp knee on the
breakdown curve and to eliminate unstable units.
2)
3)
Tested with pulses tp = 20 ms.
4)
The rating listed in the electrical characteristics table is maximum peak, non-repetitive, reverse surge current of 1/2 square wave or
equivalent sine wave pulse of 1/120 second duration superimposed on the test current IZT.
2/5
1N47xxxPF
Zener Voltage Range
Type
VZnom
(V)
1N4727APF
1N4728APF
1N4729APF
1N4730APF
1N4731APF
1N4732APF
1N4733APF
1N4734APF
1N4735APF
1N4736APF
1N4737APF
1N4738APF
1N4739APF
1N4740APF
1N4741APF
1N4742APF
1N4743APF
1N4744APF
1N4745APF
1N4746APF
1N4747APF
1N4748APF
1N4749APF
1N4750APF
1N4751APF
1N4752APF
1N4753APF
1N4754APF
1N4755APF
1N4756APF
1N4757APF
1N4758APF
1N4759APF
1N4760APF
1N4761APF
3
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
10
11
12
13
15
16
18
24
27
30
33
36
39
43
47
51
56
62
68
75
VZT
3)
at lZT
Min.
(V)
Max.
(V)
2.85
3.14
3.42
3.71
4.09
4.47
4.85
5.32
5.89
6.46
7.13
7.79
8.65
9.5
3.15
3.47
3.78
4.1
4.52
4.94
5.36
5.88
6.51
7.14
7.88
8.61
9.56
10.5
10.45
11.55
11.4
12.6
12.35
13.65
14.25
15.75
15.2
17.1
19
20.9
22.8
16.8
18.9
21
23.1
25.2
25.65
28.35
28.5
31.5
31.35
34.65
34.2
37.8
37.05
40.95
40.85
45.15
44.65
49.35
48.45
53.55
53.2
58.9
64.6
58.8
65.1
71.4
(mA)
83
76
69
64
58
53
49
45
41
37
34
31
28
25
23
21
19
17
15.5
14
12.5
11.5
10.5
9.5
8.5
7.5
7
6.5
6
5.5
5
4.5
4
3.7
3.3
ZZT
Max.
(Ω)
10
10
10
9
9
8
7
5
2
3.5
4
4.5
5
7
8
9
10
14
16
23
25
35
40
45
50
60
70
80
95
110
125
150
175
ZZK
Max.
(Ω)
400
400
400
400
400
500
550
600
700
700
700
700
700
700
700
700
700
700
700
750
750
750
750
750
1000
1000
1000
1000
1500
1500
1500
2000
2000
2000
2000
at IZK
(mA)
1
1
1
1
1
1
1
1
1
1
0.5
0.5
0.5
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
Reverse
Current
IR
at VR
Max.
(V)
(µA)
150
1
150
1
100
1
100
1
50
1
10
1
10
1
10
2
10
3
10
4
10
5
10
6
10
7
10
7.6
5
8.4
5
9.1
5
9.9
5
11.4
5
12.2
5
13.7
5
15.2
5
16.7
5
18.2
5
20.6
5
22.8
5
25.1
5
27.4
5
29.7
5
32.7
5
35.8
5
38.8
5
42.6
5
47.1
5
51.7
5
56
Maximum
Surge
Current 4)
IZSM
(mA)
1375
1375
1260
1190
1070
970
890
810
730
660
605
550
500
454
414
380
344
304
285
250
225
205
190
170
150
135
125
115
110
95
90
80
70
65
60
Maximum
Regulator
Current 2)
Temperature
coefficient
at IZT
IZM (mA)
275
275
252
234
217
193
178
162
146
133
121
110
100
91
83
76
69
61
57
50
45
41
38
34
30
27
25
23
22
19
18
16
14
13
12
-0.08 to -0.05
-0.08 to -0.05
-0.08 to -0.05
-0.07 to -0.02
-0.07 to -0.01
-0.03 to +0.04
-0.01 to +0.04
0.10 to +0.045
+0.01 to +0.055
+0.015 to +0.06
+0.02 to +0.065
0.03 to 0.07
0.035 to 0.075
0.04 to 0.08
0.045 to 0.08
0.045 to 0.085
0.05 to 0.085
0.055 to 0.09
0.055 to 0.09
0.06 to 0.09
0.06 to 0.09
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
71.25 78.75
2)
3)
4)
1)
3/5
1N47xxxPF
Zener Voltage Range
Type
VZnom
(V)
1N4727BPF
1N4728BPF
1N4729BPF
1N4730BPF
1N4731BPF
1N4732BPF
1N4733BPF
1N4734BPF
1N4735BPF
1N4736BPF
1N4737BPF
1N4738BPF
1N4739BPF
1N4740BPF
1N4741BPF
1N4742BPF
1N4743BPF
1N4744BPF
1N4745BPF
1N4746BPF
1N4747BPF
1N4748BPF
1N4749BPF
1N4750BPF
1N4751BPF
1N4752BPF
1N4753BPF
1N4754BPF
1N4755BPF
1N4756BPF
1N4757BPF
1N4758BPF
1N4759BPF
1N4760BPF
1N4761BPF
3
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
10
11
12
13
15
16
18
24
27
30
33
36
39
43
47
51
56
62
68
75
VZT
3)
at lZT
Min.
(V)
Max.
(V)
2.94
3.23
3.53
3.82
4.21
4.61
5
5.49
6.08
6.66
7.35
8.04
8.92
9.8
3.06
3.37
3.67
3.98
4.39
4.79
5.2
5.71
6.32
6.94
7.65
8.36
9.28
10.2
10.78
11.22
11.76
12.24
12.74
13.26
14.70
15.30
15.68
16.32
17.64
18.36
19.6
20.4
21.56
22.44
23.52
24.48
26.46
27.54
29.4
30.6
32.34
33.66
35.28
36.72
38.22
39.78
42.14
43.86
46.06
47.94
49.98
52.02
54.88
57.12
60.76
63.24
66.64
69.36
73.5
76.5
(mA)
83
76
69
64
58
53
49
45
41
37
34
31
28
25
23
21
19
17
15.5
14
12.5
11.5
10.5
9.5
8.5
7.5
7
6.5
6
5.5
5
4.5
4
3.7
3.3
ZZT
Max.
(Ω)
10
10
10
9
9
8
7
5
2
3.5
4
4.5
5
7
8
9
10
14
16
23
25
35
40
45
50
60
70
80
95
110
125
150
175
ZZK
Max.
(Ω)
400
400
400
400
400
500
550
600
700
700
700
700
700
700
700
700
700
700
700
750
750
750
750
750
1000
1000
1000
1000
1500
1500
1500
2000
2000
2000
2000
at IZK
(mA)
1
1
1
1
1
1
1
1
1
1
0.5
0.5
0.5
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
Reverse
Current
IR
at VR
Max.
(V)
(µA)
150
1
150
1
100
1
100
1
50
1
10
1
10
1
10
2
10
3
10
4
10
5
10
6
10
7
10
7.6
5
8.4
5
9.1
5
9.9
5
11.4
5
12.2
5
13.7
5
15.2
5
16.7
5
18.2
5
20.6
5
22.8
5
25.1
5
27.4
5
29.7
5
32.7
5
35.8
5
38.8
5
42.6
5
47.1
5
51.7
5
56
Maximum
Surge
Current 4)
IZSM
(mA)
1375
1375
1260
1190
1070
970
890
810
730
660
605
550
500
454
414
380
344
304
285
250
225
205
190
170
150
135
125
115
110
95
90
80
70
65
60
Maximum
Regulator
Current 2)
Temperature
coefficient
at IZT
IZM (mA)
275
275
252
234
217
193
178
162
146
133
121
110
100
91
83
76
69
61
57
50
45
41
38
34
30
27
25
23
22
19
18
16
14
13
12
-0.08 to -0.05
-0.08 to -0.05
-0.08 to -0.05
-0.07 to -0.02
-0.07 to -0.01
-0.03 to +0.04
-0.01 to +0.04
0.10 to +0.045
+0.01 to +0.055
+0.015 to +0.06
+0.02 to +0.065
0.03 to 0.07
0.035 to 0.075
0.04 to 0.08
0.045 to 0.08
0.045 to 0.085
0.05 to 0.085
0.055 to 0.09
0.055 to 0.09
0.06 to 0.09
0.06 to 0.09
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
0.06 to 0.095
1)
2)
3)
4)
4/5
1N47xxxPF
Zener Current (mA)
Zener Current (mA)
Electrical Characteristics Curves
Zener Voltage (V)
Zener Voltage (V)
Fig 2. Zener Characteristics Curve
Fig 1. Zener Characteristics Curve
1000
Differential Zener Impedance (Ω)
1000
Cj , Diode Capacitance (pF)
f=1MHz
TA=25°C
100
VR=0V
VR=2V
VR=5V
VR=20V
VR=30V
10
1
40
50
Iz=1mA
5mA
10mA
20mA
10
1
60
1
10
100
Vz, Zener Voltage (V)
Fig. 4 Typical Zener Impedance vs. Zener Voltage
Power Dissipation (W)
Fig. 3 Junction Capacitance vs Zener Voltage
2mA
100
Ambient Temperature (℃)
Fig 5. Power Derating Curve
5/5
很抱歉,暂时无法提供与“1N4744APF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.10984
- 30+0.10586
- 100+0.09790
- 500+0.08994
- 1000+0.08596
