RS0204
4-Bit Bidirectional Voltage-Level Translator with
Automatic Direction Sensing
1 FEATURES
No Direction-Control
Data Rates
100Mbps
1.2V to 3.6V on A ports and 1.65V to 5.5V
on B Ports (VCCA≤VCCB)
VCC Isolation Feature: If Either VCC Input
is at GND, Both Ports are in the HighImpedance State
Output Enable (OE) Input Circuit
Referenced to VCCA
Low Power Consumption,10µA
Maximum ICC
No Power-Supply Sequencing Required:
Either VCCA or VCCB can be Ramped First
IOFF: Supports Partial-Power-Down Mode
Operation
Extended Temperature: -40°C to +85°C
2 APPLICATIONS
Handset
Smartphone
Tablet
Desktop PC
3 DESCRIPTIONS
This 4-bit non-inverting translator is a bidirectional voltagelevel translator and can be used to establish digital
switching compatibility between mixed-voltage systems. It
uses two separate configurable power-supply rails, with the
A ports supporting operating voltages from 1.2V to 3.6V
while it tracks the VCCA supply, and the B ports supporting
operating voltages from 1.65V to 5.5V while it tracks the
VCCB supply. This allows the support of both lower and
higher logic signal levels while providing bidirectional
translation capabilities between any of the 1.2V,1.5V,
1.8V, 2.5V,3.3V and 5V voltage nodes.
VCCA must not exceed VCCB.
When the output-enable (OE) input is low, all outputs are
placed in the high-impedance state, which significantly
reduces the power-supply quiescent current consumption.
OE has an internal pull-down current source, as long as
VCCA is powered.
To ensure the high-impedance state during power up or
power down, OE should be tied to GND through a pull- down
resistor; the minimum value of the resistor is determined
by the current-sourcing capability of the driver.
The RS0204 is available in Green QFN3.5x3.5-14L,
QFN1.7x2-12L and TSSOP-14 packages. It operates over
an ambient temperature range of -40°C to +85°C.
Device Information (1)
PART
NUMBER
RS0204
(1)
REV A.4
PACKAGE
BODY SIZE (NOM)
QFN3.5x3.5-14L
3.50mm×3.50mm
QFN2x1.7-12L
2.00mm×1.70mm
TSSOP-14
5.00mm×4.40mm
For all available packages, see the orderable addendum at the end
of the data sheet.
1 / 25
www.run-ic.com
RS0204
4 Functional Block Diagram
One
Shot
One
Shot
2 channels
One
Shot
One
Shot
One
Shot
One
Shot
2 / 25
www.run-ic.com
RS0204
Table of Contents
1 FEATURES ...................................................................................................................................................... 1
2 APPLICATIONS ............................................................................................................................................... 1
3 DESCRIPTIONS ............................................................................................................................................... 1
4 Functional Block Diagram ............................................................................................................................. 2
5 Revision History ............................................................................................................................................. 4
6 PACKAGE/ORDERING INFORMATION (1) ..................................................................................................... 5
7 PIN CONFIGURATIONS .................................................................................................................................. 6
8 SPECIFICATIONS ........................................................................................................................................... 9
8.1 Absolute Maximum Ratings ....................................................................................................................... 9
8.2 ESD Ratings............................................................................................................................................... 9
8.3 Recommended Operating Conditions ...................................................................................................... 10
8.4 Electrical Characteristics.......................................................................................................................... 11
8.5 Timing Requirements: .............................................................................................................................. 12
8.5.1 VCCA=1.2V .......................................................................................................................................... 12
8.5.2 VCCA=1.5V±0.1 V ............................................................................................................................... 12
8.5.3 VCCA=1.8V±0.15 V ............................................................................................................................. 12
8.5.4 VCCA=2.5V±0.2 V ............................................................................................................................... 12
8.5.5 VCCA=3.3V±0.3 V ............................................................................................................................... 12
8.6 Switching Characteristics: VCCA=1.2V ...................................................................................................... 13
8.7 Switching Characteristics: VCCA=1.5V ± 0.1V .......................................................................................... 13
8.8 Switching Characteristics: VCCA=1.8V ± 0.15V ........................................................................................ 14
8.9 Switching Characteristics: VCCA=2.5V ± 0.2V .......................................................................................... 14
8.10 Switching Characteristics: VCCA=3.3V ± 0.3V ........................................................................................ 15
9 Operating Characteristics............................................................................................................................ 15
10 Parameter Measurement Information ....................................................................................................... 16
11 Detailed Description ................................................................................................................................... 18
11.1 Overview ................................................................................................................................................ 18
11.2 Architecture ............................................................................................................................................ 18
11.3 Input Driver Requirements ..................................................................................................................... 19
11.4 Output Load Considerations .................................................................................................................. 19
11.5 Enable and Disable ................................................................................................................................ 19
11.6 Pullup or Pulldown Resistors on I/O Lines............................................................................................. 19
11.7 Device Functional Modes....................................................................................................................... 19
12 Application and Implementation ............................................................................................................... 20
12.1 Application Information .......................................................................................................................... 20
12.2 Typical Application ................................................................................................................................. 20
13 PACKAGE OUTLINE DIMENSIONS ........................................................................................................... 21
14 TAPE AND REEL INFORMATION .............................................................................................................. 24
3 / 25
www.run-ic.com
RS0204
5 Revision History
Note: Page numbers for previous revisions may different from page numbers in the current version.
VERSION
Change Date
Change Item
A.0
2021/01/20
Preview version completed
A.1
2021/04/27
Initial version completed
A.2
2021/05/27
A.3
2021/10/12
A.4
2022/11/03
Added TAPE AND REEL INFORMATION
1. Change QFN3.5x3.5-14L PACKAGE OPTION @Page 9
2. Added Detailed Description and Application Information
1. Change the Voltage Waveforms Enable and Disable diagram in Page
16@ A.3 Version
2. Update PACKAGE OPTION in Page 9@ A.3 Version
4 / 25
www.run-ic.com
RS0204
PRODUCT
RS0204
ORDERING
NUMBER
TEMPERATURE
RANGE
PACKAGE
LEAD
PACKAGE
MARKING
MSL(3)
PACKAGE OPTION
(2)
RS0204YTQF14
-40°C ~+85°C
QFN3.5x3.514L
RS0204
MSL3
Tape and Reel,5000
RS0204YUTQH12
-40°C ~+85°C
QFN1.7x2-12L
0204
MSL3
Tape and Reel,4000
RS0204YQ
-40°C ~+85°C
TSSOP-14
RS0204
MSL3
Tape and Reel,4000
NOTE:
(1) This information is the most current data available for the designated devices. This data is subject to change without notice and revision
of this document. For browser-based versions of this data sheet, refer to the right-hand navigation.
(2) There may be additional marking, which relates to the lot trace code information(data code and vendor code),the logo or the
environmental category on the device.
(3) MSL, The Moisture Sensitivity Level rating according to the JEDEC industry standard classifications.
5 / 25
www.run-ic.com
RS0204
VCCA
VCCB
(TOP VIEW)
1
14
A1
2
13
B1
A2
3
12
B2
A3
4
11
B3
A4
5
10
B4
NC
6
9
NC
7
8
GND
OE
Exposed Pad
QFN3.5x3.5-14L
PIN DESCRIPTION
PIN
NAME
TYPE (1)
1
VCCA
P
2
A1
I/O
Input/output A1. Reference to VCCA.
3
A2
I/O
Input/output A2. Reference to VCCA.
4
A3
I/O
Input/output A3. Reference to VCCA.
5
A4
I/O
Input/output A4. Reference to VCCA.
6
NC
No internal connection.
7
GND
8
OE
I
9
NC
Ground.
Output Enable (Active High). Pull OE low to place all outputs in 3state mode. Referenced to VCCA.
10
B4
I/O
Input/output B4. Reference to VCCB.
11
B3
I/O
Input/output B3. Reference to VCCB.
12
B2
I/O
Input/output B2. Reference to VCCB.
13
B1
I/O
Input/output B1. Reference to VCCB.
14
VCCB
P
Exposed Pad
FUNCTION
QFN3.5x3.5-14L
(1)
A Port Supply Voltage.1.2V ≤ VCCA ≤ 3.6V and VCCA ≤ VCCB.
B Ports Supply Voltage.1.65V ≤ VCCB ≤ 5.5V.
Exposed pad should be soldered to PCB board and connected to
GND or left floating.
I=input, O=output, I/O=input and output, P=power
6 / 25
www.run-ic.com
RS0204
PIN CONFIGURATIONS
OE
(TOP VIEW)
VCCA
1
12
11
VCCB
A1
2
10
B1
A2
3
9
B2
A3
4
8
B3
A4
5
7
B4
GND
6
QFN1.7x2-12L
PIN DESCRIPTION
PIN
NAME
TYPE (1)
1
VCCA
P
2
A1
I/O
3
A2
I/O
4
A3
I/O
5
A4
I/O
6
GND
7
B4
I/O
8
B3
I/O
9
B2
I/O
10
B1
I/O
11
VCCB
P
12
OE
I
FUNCTION
QFN1.7x2-12L
A Port Supply Voltage.1.2V ≤ VCCA ≤3.6V and VCCA ≤ VCCB.
Ground.
(1) I=input, O=output, I/O=input and output, P=power
7 / 25
www.run-ic.com
RS0204
PIN CONFIGURATIONS
(TOP VIEW)
VCCA
1
14
VCCB
A1
2
13
B1
A2
3
12
B2
A3
4
11
B3
A4
5
10
B4
NC
6
9
NC
GND
7
8
OE
TSSOP-14
PIN DESCRIPTION
PIN
NAME
TYPE (1)
1
VCCA
P
2
A1
I/O
3
A2
I/O
4
A3
I/O
5
A4
I/O
FUNCTION
TSSOP-14
6
NC
7
GND
8
OE
I
9
NC
Ground.
Output Enable (Active High). Pull OE low to place all outputs in 3-state
10
B4
I/O
11
B3
I/O
12
B2
I/O
13
B1
I/O
14
VCCB
P
8 / 25
www.run-ic.com
RS0204
8 SPECIFICATIONS
Over operating free-air temperature range (unless otherwise noted) (1)
SYMBOL
PARAMETER
VCCA
Supply Voltage Range
VCCB
MIN
MAX
UNIT
-0.3
4.6
V
V
-0.3
6.5
A port
-0.3
4.6
B port
-0.3
6.5
OE
-0.3
4.6
Voltage range applied to any output in the highimpedance or power-off state
A port
-0.3
4.6
B port
-0.3
6.5
Voltage range applied to any output in the high or
low state
A port
-0.3
VCCA+0.3
B port
-0.3
VCCB+0.3
IIK
Input clamp current
VI
很抱歉,暂时无法提供与“RS0204YQ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.66120
- 10+2.73240
- 30+2.33280
- 100+1.83600
- 国内价格
- 1+1.87000
- 100+1.49600
- 1000+1.33100
- 2000+1.25400
- 4000+1.18800
