RS0208YTSS20
RS0208YTSS20
    RUNIC(润石)
    TSSOP-20
    电平移位器 TSSOP-20
RS0208YTSS20 数据手册
RS0208 8-Bit Bidirectional Voltage-Level Translator with Automatic Direction Sensing DESCRIPTION FEATURES • • • • • • • • • No Direction-Control Data Rates 100Mbps 1.2V to 3.6V on A ports and 1.65V to 5.5V on B Ports (VCCA≤VCCB) VCC Isolation Feature: If Either VCC Input is at GND, Both Ports are in the High-Impedance State OE Input Circuit Referenced to VCCA Low Power Consumption,10uA Maximum ICC No Power-Supply Sequencing Required: Either VCCA or VCCB can be Ramped First IOFF: Supports Partial-Power-Down Mode Operation Extended Temperature: -40°C to +85°C APPLICATIONS • • • • Handset Smartphone Tablet Desktop PC This 8-bit non-inverting translator is a bidirectional voltage-level translator and can be used to establish digital switching compatibility between mixed-voltage systems. It uses two separate configurable power-supply rails, with the A ports supporting operating voltages from 1.2V to 3.6V while it tracks the VCCA supply, and the B ports supporting operating voltages from 1.65V to 5.5V while it tracks the VCCB supply. This allows the support of both lower and higher logic signal levels while providing bidirectional translation capabilities between any of the 1.2V,1.5V,1.8V, 2.5V,3.3V and 5V voltage nodes. VCCA must not exceed VCCB. When the output-enable (OE) input is low, all outputs are placed in the high-impedance state, which significantly reduces the power-supply quiescent current consumption. OE has an internal pull-down current source, as long as VCCA is powered. To ensure the high-impedance state during power up or power down, OE should be tied to GND through a pulldown resistor; the minimum value of the resistor is determined by the current-sourcing capability of the driver. The RS0208 is available in Green QFN3*3-20L and TSSOP20 packages. It operates over an ambient temperature range of -40°C to +85°C. Device Information (1) PART NUMBER RS0208 (1) REV A.3 1 / 19 PACKAGE BODY SIZE (NOM) TSSOP20(20) 6.50mm×4.40mm QFN3*3-20L(20) 3.00mm×3.00mm For all available packages, see the orderable addendum at the end of the data sheet. www.run-ic.com RS0208 Functional Block Diagram One Shot One Shot One Shot One Shot One Shot One Shot 2 / 19 www.run-ic.com RS0208 Revision History Note: Page numbers for previous revisions may different from page numbers in the current version. VERSION Change Date Change Item A.0 2021/1/20 Preview version completed A.1 2021/4/25 A.2 2021/11/01 A.3 2022/1/13 Initial version completed 1. Added Detailed Description and Application Information 2. Correct the maximum of OE Input leakage current 3. Add TAPE AND REEL INFORMATION Added Switching Characteristics Min and Max value 3 / 19 www.run-ic.com RS0208 PIN CONFIGURATIONS (TOP VIEW) A1 1 20 B1 VCCA 2 19 VCCB A2 3 18 B2 A3 4 17 B3 A4 5 16 B4 A5 6 15 B5 A6 7 14 B6 A7 8 13 B7 A8 9 12 B8 OE 10 11 GND (TOP VIEW) QFN3*3-20L TSSOP20 PIN DESCRIPTION PIN (1) NAME TYPE (1) 19 A1 I/O 20 VCCA P 3 1 A2 I/O Input/output A2. Reference to VCCA. 4 2 A3 I/O Input/output A3. Reference to VCCA. 5 3 A4 I/O Input/output A4. Reference to VCCA. 6 4 A5 I/O Input/output A5. Reference to VCCA. 7 5 A6 I/O Input/output A6. Reference to VCCA. 8 6 A7 I/O Input/output A7. Reference to VCCA. 9 7 A8 I/O 10 8 OE I 11 9 GND ‒ Input/output A8. Reference to VCCA. Output Enable (Active High). Pull OE low to place all outputs in 3-state mode. Referenced to VCCA. Ground. 12 10 B8 I/O Input/output B8. Reference to VCCB. 13 11 B7 I/O Input/output B7. Reference to VCCB. 14 12 B6 I/O Input/output B6. Reference to VCCB. 15 13 B5 I/O Input/output B5. Reference to VCCB. 16 14 B4 I/O Input/output B4. Reference to VCCB. 17 15 B3 I/O Input/output B3. Reference to VCCB. 18 16 B2 I/O Input/output B2. Reference to VCCB. 19 17 VCCB P 20 18 B1 I/O - Exposed Pad GND - TSSOP20 QFN3*3-20L 1 2 FUNCTION Input/output A1. Reference to VCCA. A Port Supply Voltage.1.2V ≤ VCCA ≤ 3.6V and VCCA ≤ VCCB. B Ports Supply Voltage.1.65V ≤ VCCB ≤ 5.5V. Input/output B1. Reference to VCCB. Exposed pad should be soldered to PCB board and connected to GND or left floating. I=input, O=output, I/O=input and output, P=power 4 / 19 www.run-ic.com RS0208 SPECIFICATIONS Absolute Maximum Ratings Over operating free-air temperature range (unless otherwise noted) (1) SYMBOL PARAMETER MIN MAX UNIT VCCA Supply Voltage Range -0.3 4.6 V VCCB Supply Voltage Range -0.3 6.5 V A port -0.3 4.6 VI(2) Input Voltage Range B port -0.3 6.5 OE -0.3 4.6 Voltage range applied to any output in the highimpedance or power-off state A port -0.3 4.6 B port -0.3 6.5 Voltage range applied to any output in the high or low state A port -0.3 VCCA+0.3 B port -0.3 VCCB+0.3 IIK Input clamp current VI
RS0208YTSS20
物料型号:RS0208
器件简介:RS0208是一款8位双向电压电平转换器,具备自动方向感应功能。它使用两个独立的可配置电源轨,A端口支持1.2V至3.6V的电压,B端口支持1.65V至5.5V的电压。该芯片能够在不同电压系统间建立数字信号的兼容性。
引脚分配:RS0208有20个引脚,包括8个双向输入/输出引脚(A1-A8和B1-B8),供电引脚(VCCA和VCCB),输出使能引脚(OE),以及地引脚(GND)。
参数特性: - 数据传输速率可达100Mbps。 - VCC隔离特性:任一VCC输入为GND时,所有端口处于高阻态。 - 低功耗,最大工作电流为10uA。 - 支持部分断电模式操作。 - 工作温度范围为-40°C至+85°C。
功能详解: - 无需方向控制信号,数据流可以自动从A至B或B至A。 - 输出驱动器设计为弱驱动,可以被外部驱动器覆盖。 - 内部边缘速率加速器(one-shot)用于提高整体数据传输速率。
应用信息:RS0208适用于手机、智能手机、平板电脑和桌面PC等设备,用于不同电压系统间的数字信号转换。
封装信息:RS0208提供QFN33-20L和TSSOP20两种封装形式。
电气特性和详细描述提供了关于输入泄漏电流、功耗、输出电流、输入电容、内部输入至输出电容、传播延迟、输出上升和下降时间等参数的详细信息。还包括了不同VCCA和VCCB电压下的时序要求和开关特性。
