DF12NB(4.0)-60DP-0.5V(51) 数据手册
APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
RATING
-10 C TO
60 C(NOTES 2)
50 V AC
0.3 A
VOLTAGE
CURRENT
Dec.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
STORAGE
TEMPERATURE RANGE
-55 C TO 125 C(NOTES 1)
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT
AT
ACCORDING TO DRAWING.
X
X
X
X
CONTACT RESISTANCE 20 mV AC OR LESS 1 kHz, 1 mA.
50 m MAX.
INSULATION RESISTANCE
100 V DC
500 MΩMAX
VOLTAGE PROOF
150 V AC FOR 1 min.
NO FLASHOVER OR BREAKDOWN.
X
X
X
X
X
X
① CONTACT RESISTANCE: 50 m MAX.
② INSULATION RESISTANCE: 500 M MIN.
③ NO DAMAGE, CRACK AND LOOSENESS OF PARTS.
X
X
② NO HEAVY CORROSION.
NO DEFORMATION OF CASE OF EXCESSIVE
LOOSENESS OF THE TERMINALS.
X
X
CONSTRUCTION
GENERAL EXAMINATION
VISUALLY AND BY MEASURING INSTRUMENT.
MARKING
CONFIRMED VISUALLY.
ELECTRIC CHARACTERISTICS
MECHANICAL CHARACTERISTICS
MECHANICAL OPERATION
VIBRATION
SHOCK
50 m MAX.
② NO DAMAGE, CRACK AND LOOSENESS OF PARTS.
FREQUENCY 10 TO 55 Hz, SINGLE AMPLITUDE
① NO ELECTRICAL DISCONTINUITY OF 1 s.
0.75 mm, AT 2 h, FOR 3 DIRECTIONS.
2
490 m/s DURATION OF PULSE 11 ms AT 3 TIMES ① NO ELECTRICAL DISCONTINUITY OF 1 s.
FOR 3 DIRECTIONS.
50 TIMES INSERTIONS AND WITHDRAWALS.
ENVIRONMENTAL CHARACTERISTICS
RAPID CHANGE OF
TEMPERATURE
TEMPERATURE -65 →15 TO 35 →125 →15 TO 35 C
TIME
30 → 2 TO 3 → 30 → 2 TO 3 min
UNDER 5 CYCLES.
DAMP HEAT
(STEADY STATE)
EXPOSED AT 40 ± 2 C, 90 TO 95 , 96 h.
SULPHUR DIOXIDE
EXPOSED IN 25 PPM RH 75 % FOR 96 h.
(TEST STANDARD:JEIDA-38)
HEAT RESISTANCE OF
SOLDERING
【RECOMMENDED TEMPERATURE PROFILE】
《SOLDERING AREA》
MAX250℃, 220℃ FOR 60 SECONDS MAX.
《PREHEATING AREA》
150 TO 180℃ 90~120 SECONDS.
MAXIMUM TWICE ACTION IS ALLOWED UNDER THE
SAME CONDITION.
【RECOMMENDED MANUAL SOLDELING CONDITION 】
SOLDERING IRON TEMPERATURE 350℃
SOLDERING TIME : WITHIN 3 SECONDS.
REMARKS
NOTES1:INCLUDING THE TEMPERATURE RISE BY CURRENT.
NOTES2:STORAGEIS DEFINED AS LONG-TERM STORAGE OF UNUSED PRODUCTS.
APPLY OPERATION TEMPERATURE RANGE TO PRODUCTS MOUNTED ON PCB WITHOUT POWER SUPLLY.
UNLESS OTHERWISE SPECIFIED , REFER
COUNT
TO JIS C 5402 .
DESCRIPTION OF REVISIONS
DESIGNED
CHECKED
DATE
Note
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test X:Applicable Test
APPROVED
WR.FUKUCHI
20200720
CHECKED
TS.MIYAZAKI
20200720
DESIGNED
KT.KUSAKA
20200720
DRAWN
RN.IIDA
20200717
DRAWING NO.
ELC-389324-51-01
SPECIFICATION SHEET
PART NO.
DF12NB(5.0)-40DP-0.5V(51)
CODE NO.
CL537-0880-0-51
DF12NB(4.0)-60DP-0.5V(51) 价格&库存
很抱歉,暂时无法提供与“DF12NB(4.0)-60DP-0.5V(51)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+10.23840
- 10+8.49960
- 30+7.54920
- 100+6.46920
- 国内价格 香港价格
- 1+18.081711+2.25949
- 10+15.3487810+1.91798
- 25+14.3839925+1.79742
- 50+13.6966250+1.71153
- 100+13.04168100+1.62969
- 250+12.22515250+1.52765
- 500+11.64125500+1.45469
- 国内价格 香港价格
- 1000+11.085701000+1.38527
- 2000+10.556832000+1.31918
- 3000+10.259293000+1.28200
- 5000+9.896455000+1.23666
- 7000+9.664587000+1.20769
- 国内价格 香港价格
- 1+17.154201+2.18480
- 10+14.6003010+1.85950
- 25+13.6557025+1.73920
- 50+13.0610050+1.66350
- 100+12.37300100+1.57590
- 250+11.61500250+1.47930
- 500+11.26510500+1.43480
- 1000+10.752001000+1.36940
- 2000+9.982302000+1.27140
- 国内价格 香港价格
- 1+19.887701+2.48516
- 10+17.3005610+2.16188
- 25+16.5611925+2.06949
- 50+16.1923850+2.02340
- 100+15.45638100+1.93143
- 250+13.98454250+1.74751
- 500+12.88047500+1.60954
- 国内价格 香港价格
- 1000+8.527551000+1.06560
- 2000+8.394312000+1.04895
- 3000+8.305483000+1.03785
- 4000+8.216654000+1.02675
