3S6W4_4805S1.6RP
3S6W4_4805S1.6RP
    GAPTEC
    SIP6
    DC-DC
3S6W4_4805S1.6RP 数据手册
3S6W4_1.6RP series 3W - Single/Dual Outputs - Wide Input - Isolated & Regulated DC-DC Converter DC-DC Converter Wide 4:1 input voltage range Operating temperature range -40°C to +75°C High efficiency up to 86% 3W single and dual outputs I/O isolation 1.6kVDC and 3kVDC option Continuous short circuit protection remote ON/OFF Control for single output only Common specifications 3 Watt The 3S6W4_1.6RP series is an excellent performance and high power density design, Wide 4:1 input voltage ranges: 4.5V-18V,9V-36V and 18V-75V. The highest efficiency allows -40°C to +75°C operating temperatures. The very low stand-by (no-load)input power consumption 50mW typ,makes them an ideal solution for application in battery-powered equipment and instrumentation. Output specifications Short circuit protection: Continuous Item Test condition Operation temperature range: --40°C to +75°C Voltage accuracy ±2 % Case temperature: 100°C MAX Nominal Vin and full load Storage temperature range: -55°C ~+125°C Line regulation Vin=min to max,full load ±0.5 % Lead Temperature 300°C max. 1.5mm from case for 10 sec Load regulation 20% to 100% load ±0.5 % Storage humidity range: < 95% %/°C 150kHz Min - 40°C to +85°C ambient 0.015 Operating Frequency Temperature coefficient MTBF: >1310000 hours (MIL-HDBK-217F@25°C) >187000 hours (MIL-HDBK-217F@71°C) Ripple&Noise 20MHz bandwidth Packing Quantity 30 pcs per Tube Potting Material Epoxy [UL94-V0] Case material: Non-conductive black plastic [UL94-V0] Weight: 3.5g Dimension: 17 x 9.2 x 11.7mm Test condition Input Voltage Range 4.5-18V,9-36V, 18-75V Input filter Capacitor Remote on/off • ON (leave open if not used) • OFF (Series a 1KΩ Resistor) Min Typ Max Max 60 No Load Power Cosumption 50 Operating Frequency 150 Units mVp-p 150 mW kHz Units 4:1 2 Typ Example: 3S6BW4_1205S1.6RP 3 = 3Watt; S6 = SIP6; B = Pinning; W4 = 4:1 Wide input; 4.5-18Vin; 12 = 12Vout; S = Single Output; 1.6 = 1600VDC isolation; R = Regulated Output; Input specifications Item Min Open 4 mA Note: 1. The max. capacitive load should be tested within the input voltage range and under full load conditions; 2. Unless otherwise specified, data in this datasheet should be tested under the conditions of Ta = 25°C, humidity
3S6W4_4805S1.6RP 价格&库存
很抱歉,暂时无法提供与“3S6W4_4805S1.6RP”相匹配的价格&库存,您可以联系我们找货
