WSR3002FH
WSR3002FH
    WAYON(上海维安)
    DFN1006-2L
    肖特基二极管 DFN1006-2L
WSR3002FH 数据手册
Document: W10010046, Rev: B WSR3002FH F Schottky Barrier Diode Features ⚫ ⚫ ⚫ ⚫ Low Forward Voltage High Reliability Small Outline Surface Mount Package RoHS Compliant / Green EMC - Applications ⚫ ⚫ ⚫ ⚫ + DFN1006-2L Low Current Rectification High Speed Switch for Detection Inverse Polarity Protection Low Power Consumption Applications Absolute Maximum Rating (Tamb=25°C unless otherwise noted) Parameter Symbol Value Unit VR 30 V VR(RMB) 21 V IF 200 mA Non-Repetitive Peak Forward Surge Current @ t=8.3ms IFSM 1 A Power Dissipation PD 100 mW RθJA 1000 °C/W Junction Temperature TJ 125 °C Storage Temperature Tstg -55 to 150 °C Peak Repetitive Peak Reverse Voltage RMS Reverse Voltage Forward Continuous Current Thermal Resistance Junction to Ambient Electrical Characteristics (Tamb=25°C unless otherwise specified) Parameter Reverse Breakdown Voltage Reverse Voltage Leakage Current Forward Voltage Symbol VBR IR Test Conditions Min. Typ. Max. Unit 30 - - V VR = 10V - - 30 μA IF = 10mA - - 0.35 IR = 100μA VF V IF = 200mA ©2019 WAYON Corporation www.way-on.com - - 0.50 1 / 3 Schottky Barrier Diode WSR3002FH Typical Characteristics Figure 1. Forward Characteristics ©2019 WAYON Corporation Figure 2. www.way-on.com Reverse Characteristics 2 / 3 Schottky Barrier Diode WSR3002FH Outline Drawing –DFN1006-2L PACKAGE OUTLINE E E1 L1 D D1 DFN1006-2L SYMBOL L L BOTTOM VIEW A TOP VIEW SIDE VIEW INCHES MIN MAX MIN MAX A 0.440 0.550 0.017 0.022 D 2 0.550 0.680 0.022 0.027 E 0.950 1.080 0.037 0.043 D1 0.400 0.600 0.016 0.024 E1 L L1 Land Pattern MILIMETER 0.650REF 0.200 0.300 0.026REF 0.0080.0260.012 0.050REF 0.002REF 0.100 0.004 1.00 0.60 0.60 0.20 0.40 0.40 Marking Codes Part Number WSR3002FH Marking Code F Package Information Qty:10k/Reel CONTACT INFORMATION No.1001, Shiwan (7) Road, Pudong District, Shanghai, P.R.China.201207 Tel: 86-21-68969993 Fax: 86-21-50757680 Email: market@way-on.com WAYON website: http://www.way-on.com For additional information, please contact your local Sales Representative. ® is registered trademark of Wayon Corporation. Specifications are subject to change without notice. The device characteristics and parameters in this data sheet can and do vary in different applications and actual device performance may vary over time. Users should verify actual device performance in their specific applications. ©2019 WAYON Corporation www.way-on.com 3 / 3
WSR3002FH 价格&库存
很抱歉,暂时无法提供与“WSR3002FH”相匹配的价格&库存,您可以联系我们找货
WSR3002FH
    • 50+0.10500
    • 500+0.09450
    • 5000+0.08750
    • 10000+0.08400
    • 30000+0.08050
    • 50000+0.07840
    库存:373
