C31
CBB21 series
金属化聚丙烯膜电容器(浸渍型)
Metallized polypropylene film capacitor(dipped)
■ 外形图 Outline Drawing
Forming Lead Shapes
I
II
III
P F
0mm
P-F
3mm
P F
3mm P-F 8mm
F±0.8mm; A
3mm
F-P 5mm
0mm
F-P
3mm
5.0mm; B=4.5±0.5mm
■ 特点
っ Features
む Metallized polypropylene film
金属化聚丙烯膜介质
高频损耗小
内部温升小
阻燃环氧粉末包封(UL94/V-0)
IV
む Low loss at high frequency
む Small inherent temperature rise
む Flame retardant epoxy resin powder coating(UL94/V-0)
■ 主要用途
っ Typical Applications
● 广泛应用于高频、直流、交流和脉冲电路中
む Widely used in high frequency, DC, AC and pulse circuits
● 适用于大屏幕显视器的 S 校正电路
● 适用于各种高频、大电流场合
む Suitable for S-correction circuits of large screen monitor
む Suitable for the situation where applies high frequency
and high current pulse
■ 技术要求 Specifications
引用标准 Reference Standard
GB/T 10190 (IEC 60384-16)
气候类别 Climatic Category
40/105/21
额定温度 Rated Temperature
85Ⓘ
工作温度 Operating Temperature Range
-40Ⓘ~105Ⓘ
(+85Ⓘ to +105Ⓘ
decreasing factor 1.25% per Ⓘ for UR )
额定电压 Rated Voltage
100V, 250V, 400V, 630V, 1 000V, 1 250V
电容量范围 Capacitance Range
0.0010μF~3.3μF
电容量偏差 Capacitance Tolerance
±5(J), ±10(K), ±20(M)
耐电压 Voltage Proof
1.6UR (5s)
损耗角正切 Dissipation Factor
绝缘电阻 Insulation Resistance
最大脉冲爬升速率 Maximum Pulse Rise Time(dV/
dt):若实际工作电压 U 比额定电压 UR 低,电容器可工
作在更高的 dV/dt 场合,这样 dV/dt 允许值应为右表值
乘以 UR/Uㄌ
If the working voltage(U) is lower than the rated
voltage(UR),the capacitor can be worked at a higher
dV/dt. In this case, the maximum allowed dV/dt is
obtain by multiplying the right value with UR /U.
-4
10×10 (20Ⓘ, 1kHz)
R 100 000MΩ,
RCN 30 000s
CN 0.33μF
CN >0.33μF
(20Ⓘ, 100V, 1min)
Pattern II
dV/dt(V/μs)
UR(V)
P=7.5
P=10.0
P=15.0
P=22.5
100/250
660
560
310
130
400
900
780
600
300
630
1 500
1 200
900
400
1 000/1 250
2 500
2 200
63
C31
CBB21 series
■ 产品编码说明 Part number system
15 位产品代码如下:
The 15 digits part number is formed as follow:
1
2
3
C
3
1
第 1~3 位
4
5
6
7
8
9
10 11 12 13 14 15
型号代码
Digit 1 to 3
C31= CBB21
第 4~5 位
C31= CBB21
直流额定电压
Digit 4 to 5
2A=100V 2E=250V
2G=400V
Digit 6 to 8
3
for example: 103=10×10 pF=0.01μF
容量偏差
Digit 9
Capacitance tolerance
J=±5%, K=±10%, M=±20%
引线脚距 P
第 11 位
Digit 10
Pitch
3=7.5mm 4=10.0mm 5=12.5mm 6=15.0mm
8=20.0mm 9=22.5mm A=25.0mm C=30.0mm
内部特征码
Digit 11
S=Ⓨ型
Digit 12 to 15
Table 1 引线加工和包装代码
⺮ 12 呕 Digit 12
⺮ 13 呕 Digit 13
⺮ 14 呕 Digit 14
代码
说明
代码
说明
代码
explanation
Code
explanation
Code
ammo-pack
3
Lead form and packaging code
lead form and packaging code
Code
弹带包装
Internal use
S=Pattern Ⓨ
第 12~15 位 引线加工和包装代码
A
Rated capacitance value
3
举例:103=10×10 pF=0.01μF
第 10 位
F=7.5mm
4
F=10.0mm
6
F=15.0mm
1
说明
⺮ 15 呕 Digit 15
代码
explanation Code
表示弯脚
A
kinked
说明
explanation
产品在连续的两个载带孔之间
each cap. between two consecutive holes
P3=12.7mm, H=20.0mm (For pitch=7.5mm)
E
P3=25.4mm; H=20.0mm(For pitch=10.0/15.0mm)
(Detail parameter refer to page 17)
F
Y
引线成型
4
F=10.0mm
lead kinked
6
F=15.0mm
7
F=17.5mm
8
F=20.0mm
9
F=22.5mm
直脚
代码
straight lead
Y in the
figure above
Code
45
B=4.5mm
(The length
Of B)
说明 explanation
引线长度 4.5mm
lead length 4.5mm
第 12-15 位代码为 C000 表示标准的引线长度(18mm ~ 30mm)
Digit12-15 code C000 means standard lead length (18mm ~ 30mm)
64
2G=400V
2J=630V 3A=1 000V 3B=1 250V
标称容量
第9位
D.C. rated voltage
2A=100V 2E=250V
第 6~8 位
Series code
B 的长度偏差 ±0.5mm
B Length tolerance ±0.5mm
引线长度偏差 ±0.5mm
C31
CBB21 series
■ 外形尺寸 Dimensions(mm)
Pattern II Reduced sizes
100Vdc(63Vac)/250Vdc(160Vac)#
H
T
P
d
max
max
CN
(μF)
W
max
0.010
0.011
0.012
0.013
0.015
0.016
0.018
0.020
0.022
9.8
9.8
9.8
9.8
9.8
9.8
9.8
9.8
9.8
7.7
7.8
7.9
8.0
7.8
7.9
8.1
8.2
8.4
4.0
4.2
4.3
4.4
4.2
4.3
4.4
4.6
4.8
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
0.024
0.027
0.030
0.033
0.036
0.039
0.043
0.047
9.8
9.8
9.8
9.8
9.8
9.8
9.8
9.8
8.6
7.6
7.7
7.9
8.0
8.1
8.3
8.5
4.9
4.0
4.1
4.2
4.4
4.5
4.7
4.8
0.051
0.056
0.062
0.068
0.075
0.082
0.091
0.10
0.11
12.3
12.3
12.3
12.3
12.3
12.3
12.3
12.3
12.3
8.0
8.1
8.3
8.5
8.6
8.8
8.1
8.3
8.5
0.12
0.13
0.15
0.16
0.18
0.20
0.22
0.24
12.3
12.3
12.3
12.3
12.3
12.3
12.3
12.3
0.27
0.30
0.33
0.36
0.39
0.43
0.47
400Vdc(200Vac)
T
P
d
max
Part number
CN
(μF)
W
max
H
max
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
C312A103-3S****
C312A113-3S****
C312A123-3S****
C312A133-3S****
C312A153-3S****
C312A163-3S****
C312A183-3S****
C312A203-3S****
C312A223-3S****
0.010
0.011
0.012
0.013
0.015
0.016
0.018
0.020
0.022
9.8
9.8
9.8
9.8
9.8
9.8
9.8
9.8
9.8
7.8
7.9
8.0
8.1
8.4
8.5
8.7
8.9
9.1
4.1
4.2
4.4
4.5
4.7
4.8
5.0
5.3
5.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
C312G103-3S****
C312G113-3S****
C312G123-3S****
C312G133-3S****
C312G153-3S****
C312G163-3S****
C312G183-3S****
C312G203-3S****
C312G223-3S****
7.5
7.5
7.5
7.5
7.5
7.5
7.5
7.5
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
C312A243-3S****
C312A273-3S****
C312A303-3S****
C312A333-3S****
C312A363-3S****
C312A393-3S****
C312A433-3S****
C312A473-3S****
0.024
0.027
0.030
0.033
0.036
0.039
0.043
0.047
12.3
12.3
12.3
12.3
12.3
12.3
12.3
12.3
8.0
8.1
8.3
8.5
8.6
8.7
8.8
9.0
4.3
4.5
4.7
4.8
5.0
5.0
5.2
5.4
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
C312G243-4S****
C312G273-4S****
C312G303-4S****
C312G333-4S****
C312G363-4S****
C312G393-4S****
C312G433-4S****
C312G473-4S****
4.3
4.5
4.6
4.8
5.0
5.2
4.5
4.7
4.8
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
C312A513-4S****
C312A563-4S****
C312A623-4S****
C312A683-4S****
C312A753-4S****
C312A823-4S****
C312A913-4S****
C312A104-4S****
C312A114-4S****
0.051
0.056
0.062
0.068
0.075
0.082
0.091
0.10
0.11
12.3
12.3
12.3
12.3
12.3
12.3
12.3
12.3
12.3
9.2
9.4
8.9
9.1
9.3
9.5
9.8
10.0
10.3
5.6
5.8
5.2
5.4
5.7
5.9
6.1
6.4
6.6
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
C312G513-4S****
C312G563-4S****
C312G623-4S****
C312G683-4S****
C312G753-4S****
C312G823-4S****
C312G913-4S****
C312G104-4S****
C312G114-4S****
8.6
8.6
8.9
9.0
9.3
9.5
9.8
10.0
5.0
4.9
5.2
5.4
5.6
5.9
6.1
6.4
10.0
10.0
10.0
10.0
10.0
10.0
10.0
10.0
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
C312A124-4S****
C312A134-4S****
C312A154-4S****
C312A164-4S****
C312A184-4S****
C312A204-4S****
C312A224-4S****
C312A244-4S****
0.12
0.13
0.15
0.16
0.18
0.20
0.22
0.24
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
10.7
10.9
11.2
11.3
11.6
11.9
12.2
12.5
5.5
5.7
6.0
6.1
6.4
6.7
7.0
7.3
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
0.6
0.6
0.6
0.6
0.6
0.6
0.6
0.6
C312G124-6S****
C312G134-6S****
C312G154-6S****
C312G164-6S****
C312G184-6S****
C312G204-6S****
C312G224-6S****
C312G244-6S****
17.5
17.5
17.5
17.5
17.5
17.5
17.5
10.5
10.8
11.0
11.2
11.4
11.6
11.9
5.3
5.5
5.8
6.0
6.2
6.4
6.6
15.0
15.0
15.0
15.0
15.0
15.0
15.0
0.6
0.6
0.6
0.6
0.6
0.6
0.6
C312A274-6S****
C312A304-6S****
C312A334-6S****
C312A364-6S****
C312A394-6S****
C312A434-6S****
C312A474-6S****
0.27
0.30
0.33
0.36
0.39
0.43
0.47
17.5
17.5
17.5
17.5
17.5
17.5
17.5
12.9
13.7
14.1
14.4
14.7
15.1
15.5
7.6
8.0
8.4
8.7
9.0
9.4
9.8
15.0
15.0
15.0
15.0
15.0
15.0
15.0
0.8
0.8
0.8
0.8
0.8
0.8
0.8
C312G274-6S****
C312G304-6S****
C312G334-6S****
C312G364-6S****
C312G394-6S****
C312G434-6S****
C312G474-6S****
0.51
0.56
0.62
0.68
0.75
0.82
0.91
1.0
17.5
17.5
17.5
17.5
17.5
17.5
17.5
17.5
12.1
12.4
12.7
13.5
13.9
14.2
14.9
15.0
6.9
7.2
7.5
7.8
8.2
8.5
8.9
9.3
15.0
15.0
15.0
15.0
15.0
15.0
15.0
15.0
0.6
0.6
0.8
0.8
0.8
0.8
0.8
0.8
C312A514-6S****
C312A564-6S****
C312A624-6S****
C312A684-6S****
C312A754-6S****
C312A824-6S****
C312A914-6S****
C312A105-6S****
0.51
0.56
0.62
0.68
0.75
0.82
0.91
1.0
25.2
25.2
25.2
25.2
25.2
25.2
25.2
25.2
14.8
15.2
15.6
15.9
16.3
16.7
17.2
17.7
7.6
7.9
8.3
9.1
9.6
10.0
10.5
10.9
22.5
22.5
22.5
22.5
22.5
22.5
22.5
22.5
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
C312G514-9S****
C312G564-9S****
C312G624-9S****
C312G684-9S****
C312G754-9S****
C312G824-9S****
C312G914-9S****
C312G105-9S****
1.1
1.2
1.3
1.5
1.6
1.8
2.0
2.2
2.4
2.7
3.0
3.3
17.5
25.2
25.2
25.2
25.2
25.2
25.2
25.2
25.2
25.2
25.2
25.2
15.5
14.8
15.1
15.6
15.9
16.4
16.9
18.3
18.7
19.3
19.9
20.5
9.7
7.5
7.8
8.3
8.6
9.1
10.1
9.9
10.4
10.9
11.6
12.1
15.0
22.5
22.5
22.5
22.5
22.5
22.5
22.5
22.5
22.5
22.5
22.5
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
0.8
C312A115-6S****
C312A125-9S****
C312A135-9S****
C312A155-9S****
C312A165-9S****
C312A185-9S****
C312A205-9S****
C312A225-9S****
C312A245-9S****
C312A275-9S****
C312A305-9S****
C312A335-9S****
Part number
备注 Note 1.“-”表示容量偏差。
- =capacitance tolerance code. M=±20%, K=±10%, J=±5%.
2.“****”表示引线加工和包装代码(见表 1)。
**** =lead form and packing code(refer to table 1).
3. # 当额定电压为 250Vdc 时,第 4~5 位是 2Eㄌ # when the rated voltage is 250Vdc, the digit 4~5 is 2E.
65
C31
CBB21 series
630Vdc(220Vac)
CN
W
H
T
P
(μF) max max max
630Vdc(220Vac)
d
Part number
CN
W H
T
P
(μF) max max max
d
Part number
1 000/1 250Vdc (400Vac)
CN
W H
T
(μF) max max max
P
d
Part number
0.0010 10.0 7.9
4.3
7.5
0.6
C312J102-3S****
0.027 12.3 9.4
5.7 10.0 0.6
C312J273-4S****
0.0010 10.0 7.9
4.3
7.5
0.6
C313A102-3S****
0.0011 10.0 8.1
4.4
7.5
0.6
C312J112-3S****
0.030 12.3 9.6
6.0 10.0 0.6
C312J303-4S****
0.0011 10.0 8.1
4.4
7.5
0.6
C313A112-3S****
0.0012 10.0 8.2
4.5
7.5
0.6
C312J122-3S****
0.033 12.3 9.9
6.2 10.0 0.6
C312J333-4S****
0.0012 10.0 8.2
4.5
7.5
0.6
C313A122-3S****
0.0013 10.0 8.3
4.7
7.5
0.6
C312J132-3S****
0.036 12.3 10.1 6.4 10.0 0.6
C312J363-4S****
0.0013 10.0 8.3
4.7
7.5
0.6
C313A132-3S****
0.0015 10.0 8.1
4.4
7.5
0.6
C312J152-3S****
0.039 12.3 10.3 6.7 10.0 0.6
C312J393-4S****
0.0015 10.0 8.1
4.4
7.5
0.6
C313A152-3S****
0.0016 10.0 8.2
4.5
7.5
0.6
C312J162-3S****
0.043 17.5 10.7 5.4 15.0 0.6
C312J433-6S****
0.0016 10.0 8.2
4.5
7.5
0.6
C313A162-3S****
0.0018 10.0 7.8
4.2
7.5
0.6
C312J182-3S****
0.047 17.5 10.8 5.6 15.0 0.6
C312J473-6S****
0.0018 10.0 7.8
4.2
7.5
0.6
C313A182-3S****
0.0020 10.0 8.0
4.3
7.5
0.6
C312J202-3S****
0.051 17.5 11.0 5.8 15.0 0.6
C312J513-6S****
0.0020 10.0 8.0
4.3
7.5
0.6
C313A202-3S****
0.0022 10.0 8.1
4.5
7.5
0.6
C312J222-3S****
0.056 17.5 11.2 6.0 15.0 0.6
C312J563-6S****
0.0022 10.0 8.1
4.5
7.5
0.6
C313A222-3S****
0.0024
9.8
8.0
4.3
7.5
0.6
C312J242-3S****
0.062 17.5 11.4 6.2 15.0 0.6
C312J623-6S****
0.0024 10.0 7.7
4.0
7.5
0.6
C313A242-3S****
0.0027
9.8
8.1
4.5
7.5
0.6
C312J272-3S****
0.068 17.5 11.7 6.5 15.0 0.6
C312J683-6S****
0.0027 10.0 7.8
4.2
7.5
0.6
C313A272-3S****
0.0030
9.8
8.3
4.7
7.5
0.6
C312J302-3S****
0.075 17.5 11.9 6.7 15.0 0.6
C312J753-6S****
0.0030 10.0 8.0
4.4
7.5
0.6
C313A302-3S****
0.0033
9.8
8.5
4.8
7.5
0.6
C312J332-3S****
0.082 17.5 12.2 7.0 15.0 0.6
C312J823-6S****
0.0033 10.0 8.2
4.5
7.5
0.6
C313A332-3S****
0.0036
9.8
8.0
4.4
7.5
0.6
C312J362-3S****
0.091 17.5 12.5 7.3 15.0 0.6
C312J913-6S****
0.0036 10.0 8.3
4.7
7.5
0.6
C313A362-3S****
0.0039
9.8
8.2
4.5
7.5
0.6
C312J392-3S****
0.10
17.5 12.8 7.6 15.0 0.8
C312J104-6S****
0.0039 10.0 8.4
4.8
7.5
0.6
C313A392-3S****
0.0043
9.8
8.3
4.7
7.5
0.6
C312J432-3S****
0.11
17.5 13.6 7.9 15.0 0.8
C312J114-6S****
0.0043 10.0 8.2
4.5
7.5
0.6
C313A432-3S****
0.0047
9.8
8.5
4.9
7.5
0.6
C312J472-3S****
0.12
17.5 13.9 8.2 15.0 0.8
C312J124-6S****
0.0047 10.0 8.3
4.7
7.5
0.6
C313A472-3S****
0.0051
9.8
8.6
5.0
7.5
0.6
C312J512-3S****
0.13
17.5 14.2 8.5 15.0 0.8
C312J134-6S****
0.0051 10.0 8.5
4.8
7.5
0.6
C313A512-3S****
0.0056
9.8
8.8
5.2
7.5
0.6
C312J562-3S****
0.15
17.5 14.7 9.0 15.0 0.8
C312J154-6S****
0.0056 10.0 8.7
5.0
7.5
0.6
C313A562-3S****
0.0062
9.8
9.0
5.4
7.5
0.6
C312J622-3S****
0.16
17.5 15.0 9.3 15.0 0.8
C312J164-6S****
0.0062 10.0 8.7
5.0
7.5
0.6
C313A622-3S****
0.0068 12.3 8.0
4.4 10.0 0.6
C312J682-4S****
0.18
17.5 15.5 9.8 15.0 0.8
C312J184-6S****
0.0068 12.0 8.9
5.2 10.0 0.6
C313A682-4S****
0.0075 12.3 8.2
4.5 10.0 0.6
C312J752-4S****
0.20
17.5 16.0 10.3 15.0 0.8
C312J204-6S****
0.0075 12.0 9.1
5.4 10.0 0.6
C313A752-4S****
0.0082 12.3 8.3
4.7 10.0 0.6
C312J822-4S****
0.22
25.2 15.2 7.9 22.5 0.8
C312J224-9S****
0.0082 12.0 9.3
5.6 10.0 0.6
C313A822-4S****
0.0091 12.3 8.5
4.9 10.0 0.6
C312J912-4S****
0.24
25.2 15.5 8.2 22.5 0.8
C312J244-9S****
0.0091 12.0 9.5
5.9 10.0 0.6
C313A912-4S****
0.010
12.3 7.8
4.1 10.0 0.6
C312J103-4S****
0.27
25.2 15.9 9.2 22.5 0.8
C312J274-9S****
0.010 12.0 9.9
6.3 10.0 0.6
C313A103-4S****
0.011
12.3 7.9
4.2 10.0 0.6
C312J113-4S****
0.30
25.2 16.4 9.6 22.5 0.8
C312J304-9S****
0.012
12.3 8.0
4.4 10.0 0.6
C312J123-4S****
0.33
25.2 16.8 10.0 22.5 0.8
C312J334-9S****
0.013
12.3 8.1
4.5 10.0 0.6
C312J133-4S****
0.36
25.2 17.2 10.4 22.5 0.8
C312J364-9S****
0.015
12.3 8.3
4.7 10.0 0.6
C312J153-4S****
0.39
25.2 17.6 10.8 22.5 0.8
C312J394-9S****
0.016
12.3 8.5
4.8 10.0 0.6
C312J163-4S****
0.43
25.2 18.1 11.3 22.5 0.8
C312J434-9S****
0.018
12.3 8.6
4.9 10.0 0.6
C312J183-4S****
0.47
25.2 18.6 11.8 22.5 0.8
C312J474-9S****
0.020
12.3 8.8
5.1 10.0 0.6
C312J203-4S****
0.51
25.2 19.0 12.2 22.5 0.8
C312J514-9S****
0.022
12.3 8.9
5.3 10.0 0.6
C312J223-4S****
0.56
25.2 19.6 12.8 22.5 0.8
C312J564-9S****
0.024
12.3 9.1
5.5 10.0 0.6
C312J243-4S****
3. # 当额定电压为 1 250Vdc 时,第 4~5 位是 3Bㄌ
# when the rated voltage is 1 250Vdc, the digit 4~5 is 3B.
4.“@”不用作跨线,请参见抗干扰电容器(Page 109)。
@ Not suitable for across-the-line applications. Pls refer to interference Suppression Capacitors(Page 109).
66
很抱歉,暂时无法提供与“C313A472K3SA31C”相匹配的价格&库存,您可以联系我们找货
