Gas Discharge Tube
3R-6S Series
Features
Stable breakdown voltage
High insulation resistance
High current rating
Low capacitance (≤2pF)
Stable performance over life
Large absorbing transient current capability
Fast response time
RoHS compliant
Standard Size: 6.0mm*8.5mm
Meets MSL level 1, per J-STD-020
Storage and operating temperature: -40℃ ~ +90℃
GDT Graphical Symbol
a
b
TIP
RING
e
GROUND (center electrode)
Applications
Repeaters, Modems
Subscriber protection
Telephone Interface, Line cards
Data communication equipment
Line test equipment
Branch exchange
Alarm system
Tuner
Antenna protection
Part Number Code and Marking
www.liownsemi.com
掌握芯技术Core Technology
(V0)
Gas Discharge Tube
3R-6S Series
Dimensions
Symbol
Dimensions(mm)
D
6.0±0.2
D1
6.0±0.2
D2
7.0±0.2
T
8.5±0.5
T1
0.5±0.1
T2
1.5±0.2
Electrical Characteristics (TA=25℃)
DC
Part
Number
Spark-over
Marking
Voltage
Maximum
Nominal
Impulse
Impulse
Spark-over
Discharge
Voltage
Current
100V/s
1000V/µs
8/20µs,
10 times
Alternating
Impulse
Discharge
Life
Current
50Hz,1sec
Minimum
Maximum
Insulation
Capacitance
Resistance
10/1000µs,
Test
100A
Voltage
GΩ
1MHz
3R075LM-6S
075
75V±20%
700V
5KA
5A
300 times
25VDC
1
2pF
3R090LM-6S
090
90V±20%
700V
5KA
5A
300 times
50VDC
1
2pF
3R150LM-6S
150
150V±20%
700V
5KA
5A
300 times
100VDC
1
2pF
3R230LM-6S
230
230V±20%
700V
5KA
5A
300 times
100VDC
1
2pF
3R250LM-6S
250
250V±20%
700V
5KA
5A
300 times
100VDC
1
2pF
3R300LM-6S
300
300V±20%
800V
5KA
5A
300 times
100VDC
1
2pF
3R350LM-6S
350
350V±20%
900V
5KA
5A
300 times
100VDC
1
2pF
3R400LM-6S
400
400V±20%
1000V
5KA
5A
300 times
250VDC
1
2pF
3R470LM-6S
470
470V±20%
1100V
5KA
5A
300 times
250VDC
1
2pF
3R600LM-6S
600
600V±20%
1300V
5KA
5A
300 times
250VDC
1
2pF
3R075MM-6S
075M
75V±20%
700V
10KA
10A
300 times
25VDC
1
2pF
3R090MM-6S
090M
90V±20%
700V
10KA
10A
300 times
50VDC
1
2pF
3R150MM-6S
150M
150V±20%
700V
10KA
10A
300 times
100VDC
1
2pF
3R230MM-6S
230M
230V±20%
700V
10KA
10A
300 times
100VDC
1
2pF
3R250MM-6S
250M
250V±20%
700V
10KA
10A
300 times
100VDC
1
2pF
3R300MM-6S
300M
300V±20%
800V
10KA
10A
300 times
100VDC
1
2pF
3R350MM-6S
350M
350V±20%
900V
10KA
10A
300 times
100VDC
1
2pF
3R400MM-6S
400M
400V±20%
1000V
10KA
10A
300 times
250VDC
1
2pF
3R470MM-6S
470M
470V±20%
1100V
10KA
10A
300 times
250VDC
1
2pF
3R600MM-6S
600M
600V±20%
1300V
10KA
10A
300 times
250VDC
1
2pF
www.liownsemi.com
(V0)
Gas Discharge Tube
3R-6S Series
Test Methods and Results
Items
DC Spark-over
Voltage
Maximum Impulse
Spark-over Voltage
Impulse
Discharge Current
Alternating
Discharge Current
Test Method
Standard
measured with voltage ramp dv/dt=100V/s.
measured with voltage ramp dv/dt=1000V/μs.
applied through center electrode with 8/20μs waveform, for 10 times with
3min interval time, which will be equally divided between each side electrode
to center electrode, without causing the DC breakdown voltage to change
more than 25% from its initial measured value.
Rated RMS value of AC current at 50Hz, 1 sec. for 10 times with interval
time 3 min. DC spark-over voltage shall not change more than ±25% from
its initial value. Test is between each side electrode and center electrode.
Insulation
Resistance
measured between each side electrodes and center electrode.
Capacitance
Test frequency: 1MHz
To meet
the specified
value
Soldering Parameters
Reflow Soldering
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) ( tS)
TS max to TL
-Ramp-up Rate
Time maintained above:
-Temperature (TL)
-Time (tL)
150℃
200℃
60-180 seconds
3℃/second max.
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
20-40 seconds
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
www.liownsemi.com
8 minutes max.
(V0)
Gas Discharge Tube
3R-6S Series
Packaging Specification
Tape
Reel
Symbol
Dimension (mm)
W
16.0±0.2
P0
4.0±0.1
P1
12.0±0.2
P2
4.0±0.1
D0
1.55±0.1
E
1.75±0.1
F
7.5±0.1
A0
6.35±0.1
K0
6.3±0.1
B0
8.8±0.1
t0
0.5±0.1
D0
13.3±1.0
D1
100.0±2.0
D2
330.0±2.0
W
16.5±0.5
Quantity: 800pcs
www.liownsemi.com
(V0)
很抱歉,暂时无法提供与“3R090MM-6S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.23260
- 10+4.16556
- 30+3.62178
- 100+3.09852
- 500+3.04722
- 800+2.88306
