TVS Diode Arrays
LY323DCXXUL Series
Description
The LY323DCXXUL is a bi-directional TVS diode array, utilizing leading monolithic silicon technology to provide fast
response time and low ESD clamping voltage, making this device an ideal solution for protecting voltage sensitive
high-speed data lines. It complies with IEC 61000-4-2 (ESD), ±30kV air and ±30kV contact discharge. It is assembled
into a lead-free SOD-323 package. The small size, low capacitance and high ESD surge protection make it a ideal
choice to protect cell phone, wireless systems, and communication equipment.
Features
Low clamping voltage
Ultra low leakage current
Operating voltage: 3.3V~24V
RoHS compliant
IEC-61000-4-2 ESD ±30kV Air, ±30kV Contact
Packaging: 7 inch reel, 3000pcs/reel
Applications
USB Ports
Smart Phones
Wireless Systems
Ethernet 10/100/1000 Bast T
Pin Configuration and Marking
1
2
Circuit and Pin Schematic
www.liownsemi.com
掌握芯技术Core Technology
(V2)
TVS Diode Arrays
LY323DCXXUL Series
Absolute Maximum Ratings (TA=25℃)
Parameter
Symbol
Value
Peak Pulse Power (8/20µs)
PPP
300W
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
VESD
±30kV
±30kV
Ambient Temperature Range
TA
−55℃ to +125℃
Storage Temperature Range
TSTG
−55℃ to +150℃
Electrical Characteristics (TA=25℃)
Part
Number
Marking
Reverse
Working
Voltage
Reverse
Breakdown
Voltage
@IT=1mA
Reverse
Leakage
Current
@VRWM
Clamping
Voltage
@8/20µs
Peak
Pulse
Current
Junction
Capacitance
@VR=0V, f=1MHz
VRWM (V)
VBR (V)
IR (µA)
VC (V)
IPP (A)
CJ (pF)
Max.
Min.
Max.
@1A
@IPP Max.
Max.
Typ.
LY323DC03UL
CC
3.3
4.4
0.2
7
16
21
1
LY323DC05UL
AC
5.0
6.0
0.2
10
1
LY323DC08UL
BC
8.0
8.5
0.2
9
19.5
18
1
LY323DC12UL
DC
12.0
13.3
0.2
18
25
14
1
LY323DC15UL
EC
15.0
16.7
0.2
21
30
10
1
LY323DC24UL
HC
24.0
27.0
0.2
36
55
6
1
www.liownsemi.com
(V2)
TVS Diode Arrays
LY323DCXXUL Series
Typical Characteristic Curves (TA=25℃)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. Pulse Derating Curve
10000
1000
100
10
0.1
1
10
td-Pulse Width (µs)
Figure 3. Pulse Waveform (8/20µs)
100
Figure 4. Pulse Waveform (IEC61000-4-2)
I
100%
% of Peak Pulse Current
90%
10%
tr=0.7~1ns
30ns
60ns
www.liownsemi.com
t
(V2)
TVS Diode Arrays
LY323DCXXUL Series
Soldering Parameters
Reflow Soldering
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) ( tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
www.liownsemi.com
20-40 seconds
8 minutes max.
(V2)
TVS Diode Arrays
LY323DCXXUL Series
Dimensions (SOD-323)
Millimeters
A
D
H2
Side View
Top View
t
www.liownsemi.com
H
H1
Inches
Symbol
Min.
Max.
Min.
Max.
A
2.30
2.80
0.091
0.110
B
1.15
1.40
0.045
0.055
C
0.25
0.40
0.001
0.016
D
1.60
1.80
0.063
0.071
H
0.80
1.10
0.031
0.043
H1
0.80
0.90
0..031
0.035
H2
0.00
0.10
0.000
0.004
t
0.08
0.18
0.003
0.007
(V2)
很抱歉,暂时无法提供与“LY323DC05UL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.38988
- 100+0.30637
- 300+0.26461
- 3000+0.24143
- 6000+0.21639
- 9000+0.20377
