0603N101F251CT
0603N101F251CT
    WALSIN(华新科)
    MLCC 100PF 250V NPO 0603
0603N101F251CT 数据手册
Multilayer Ceramic Capacitors Approval Sheet MULTILAYER CERAMIC CAPACITORS Middle & High Voltage Series (200V to 4kV) 0402 to 1812 Sizes NP0 & X7R Dielectrics Halogen Free & RoHS compliance *Contents in this sheet are subject to change without prior notice. Page 1 of 12 ASC_Middle & High Voltage Jul. 2023 Multilayer Ceramic Capacitors Approval Sheet 1. INTRODUCTION WTC middle and high voltage series MLCC is designed by a special internal electrode pattern, which can reduce voltage concentrations by distributing voltage gradients throughout the entire capacitor. This special design also affords increased capacitance values in a given case size and voltage rating. Capacitors with X7R dielectrics are not intended for AC line filtering applications. Capacitors may require protective surface coating to prevent external arcing. 2. FEATURES 3. APPLICATIONS a. b. a. b. c. d. High voltage in a given case size. High stability and reliability. Snubbers in high frequency power converters. High voltage coupling/DC blocking. DC-DC converters. Back-lighting inverters 4. HOW TO ORDER 1808 N 100 J 202 C T Size Dielectric Capacitance Tolerance Rated voltage Termination Packaging Inch (mm) 0402 (1005) 0603 (1608) 0805 (2012) 1206 (3216) 1210 (3225) 1808 (4520) 1812 (4532) Page 2 of 12 N=NP0 (C0G) B=X7R Two significant digits followed by no. of zeros. And R is in place of decimal point. eg.: 0R5=0.5pF 1R0=1.0pF 100=10x100 =10pF B=±0.1pF C=±0.25pF D=±0.5pF F=±1% G=±2% J=±5% K=±10% M=±20% Two significant digits C=Cu/Ni/Sn followed by no. of zeros. And R is in place of decimal point. T=7” reeled G=13” reeled 201=200 VDC 251=250 VDC 401=400 VDC 451=450 VDC 501=500 VDC 631=630 VDC 102=1000 VDC 152=1500 VDC 202=2000 VDC 252=2500 VDC 302=3000 VDC 402=4000 VDC ASC_Middle & High Voltage Jul. 2023 Multilayer Ceramic Capacitors Approval Sheet 5. EXTERNAL DIMENSIONS Size Inch (mm) L (mm) W (mm) 0402 (1005) 1.00±0.05 0.50±0.05 1.60±0.10 1.60 +0.15/-0.10 0.80±0.10 0.80 +0.15/-0.10 T (mm)/Symbol 0.50±0.05 N Remark MB (mm) # 0.25 +0.05/-0.10 0.80±0.07 S 0603(1608) 0.40±0.15 0.80 X +0.15/-0.10 A 0.60±0.10 2.00±0.15 1.25±0.10 0.80±0.10 B 0.50±0.20 0805 (2012) 1.25±0.10 D # 2.00±0.20 1.25±0.20 1.25±0.20 I # B 0.80±0.10 3.20±0.15 1.60±0.15 0.95±0.10 C # 0.60±0.20 1206 (3216) 1.25±0.10 D # (0.5±0.25)* 3.20±0.20 1.60±0.20 1.60±0.20 G # 3.20+0.3/-0.1 1.60+0.3/-0.1 1.60+0.3/-0.1 P # 0.95±0.10 C # 3.20±0.30 2.50±0.20 1.25±0.10 D # G # 1.60±0.20 1210 (3225) 0.75±0.25 3.20±0.40 2.50±0.30 2.00±0.20 K # 2.50±0.30 M # 3.20±0.60** 2.50±0.50** 2.50±0.50** 1.25±0.10 D # 1808 (4520) 4.50+0.5/-0.3 2.03±0.25 1.60±0.20 G # 0.50±0.25 2.00±0.20 K # D # 1.25±0.10 3.20±0.30 1.60±0.20 G # 1812 (4532) 4.50+0.5/-0.3 2.00±0.20 K # 0.50±0.25 2.50±0.30 M # 3.20±0.40 2.80±0.30 U # # Reflow soldering only is recommended. * For 1206_1000V ~3000V products. ** For 1210(100V)/Cap>1µF or 1210(250V)/Cap>0.47µF or 1210(400V~630V)/Cap>0.22µF L T W MB MB Fig. 1 The outline of MLCC 6. GENERAL ELECTRICAL DATA Dielectric Size Capacitance* Capacitance tolerance*** NP0 X7R 0402, 0603, 0805, 1206, 1210, 1808, 1812 0.1pF to 0.022µF Cap≤5pF: C (±0.25pF) 5pF
0603N101F251CT
1. 物料型号:文档中列出了多种尺寸和电压等级的MLCC,如0402、0603、0805、1206、1210、1808和1812,以及它们的额定电压范围从200V到4000V。
2. 器件简介:WTA中高电压系列MLCC采用特殊的内部电极图案设计,可降低电压集中,并在给定的尺寸和电压等级下提供更高的电容值。
3. 引脚分配:文档中没有明确提供引脚分配图,但通常MLCC的两端是电极。
4. 参数特性: - 电容值范围:从0.1pF到22μF。 - 电容公差:根据电容值的不同,公差从±5%到±20%不等。 - 额定电压:200VDC到4000VDC。 - 绝缘电阻:在额定电压下,电阻需满足特定条件。
5. 功能详解: - 适用于高频电源转换器中的扼流器、高压耦合/直流阻断、DC-DC转换器和背光逆变器等应用。
6. 应用信息:MLCC适用于多种高压和高频应用,包括但不限于电源转换和背光照明。
7. 封装信息:提供了MLCC的外部尺寸和标记,以及推荐的回流焊接条件。
8. 订购信息:提供了订购MLCC所需的尺寸、介质、电容值、公差、额定电压、端接和包装信息的表格。
9. 电气数据:包括电容值范围、公差、额定电压、Q/DF值、绝缘电阻、介质强度、工作温度范围和电容变化特性。
10. 可靠性测试条件和要求:列出了视觉和机械检查、电容Q/D.F.、介质强度、绝缘电阻、温度系数、端接粘附强度、振动抵抗、焊接性、弯曲测试和耐焊热测试等测试条件和要求。
11. 存储和处理条件:建议在5到40°C和20到70%相对湿度的条件下存储产品,推荐在一年内使用,并在需要时检查焊锡性。
12. 推荐焊接条件:提供了适用于SnAgCu系列焊膏的回流焊接和波峰焊接的推荐条件。
0603N101F251CT 价格&库存
很抱歉,暂时无法提供与“0603N101F251CT”相匹配的价格&库存,您可以联系我们找货
