SH18N152F500CT
SH18N152F500CT
    WALSIN(华新科)
    MLCC 1500PF 50V NPO 0603
SH18N152F500CT 数据手册
Multilayer Ceramic Capacitors Approval Sheet MULTILAYER CERAMIC CAPACITORS Soft Termination Series (SH_6.3V to 3000V) NP0, X7R & X5R Dielectrics 0402 to 2225 Sizes Halogen Free & RoHS Compliance *Contents in this sheet are subject to change without prior notice. Page 1 of 27 ASC_Soft termination_(SH) Jun. 2023 Multilayer Ceramic Capacitors Approval Sheet 1. INTRODUCTION WTC soft termination series MLCC is designed and with a polymer layer within end terminations of product, which can absorb mechanical stress caused by PCB handling in SMT line and reduce the mechanical impact for product. It will offer more robust and reliable performance in applications. 2. FEATURES 3. APPLICATIONS a. MLCC’s termination are with a soft & flexible polymer layer to withstand high bending stress in SMT line. b. Available for any item in standard series range. a. b. c. Power supply and related industries. Lighting industry. The other mechanical stress concerned products. 4. HOW TO ORDER SH 31 B 104 K 500 C T Series Size Dielectric Capacitance Tolerance Rated voltage Termination Packaging Two significant digits followed by no. of zeros. And R is in place of decimal point. Eg. 104=10x104 =100nF B=±0.1pF C=±0.25pF D=±0.5pF F=±1% G=±2% J=±5% K=±10% M=±20% SH=Soft termination Page 2 of 27 15=0402 (1005) 18=0603 (1608) 21=0805 (2012) 31=1206 (3216) 32=1210 (3225) 42=1808 (4520) 43=1812 (4532) 46=1825 (4563) 55=2220 (5750) 56=2225 (5763) N=NP0 (C0G) B=X7R X=X5R ASC_Soft termination_(SH) Two significant C=Ag Polymer T=7” reeled digits followed by /Ni/Sn G=13” reeled no. of zeros. And R is in place of decimal point. 6R3=6.3 VDC 100=10 VDC 160=16 VDC 250=25 VDC 500=50 VDC 101=100 VDC 201=200 VDC 251=250 VDC 401=400 VDC 451=450 VDC 501=500 VDC 631=630 VDC 102=1000 VDC 152=1500 VDC 202=2000 VDC 252= 2500 VDC 302=3000 VDC Jun. 2023 Multilayer Ceramic Capacitors Approval Sheet 5. EXTERNAL DIMENSIONS & CONSTRUCTIONS Size Inch (mm) 0402 (1005) 0603 (1608) 0805 (2012) L (mm) W (mm) T (mm)/Symbol Remark MB (mm) # 0.25 +0.05/-0.10 1.00±0.20 0.50±0.20 0.50±0.20 E 1.60±0.20 0.80±0.10 0.80±0.07 S 1.60±0.30 0.80±0.30 0.80±0.30 0.60±0.10 0.80±0.10 1.25±0.10 1.25±0.30 0.80±0.10 X A B D I B 0.95±0.10 1.15±0.15 C J # # 1.25±0.10 D # 2.00±0.20 1.25±0.10 2.00±0.30 1.25±0.30 3.20+0.4/-0.1 1.60±0.15 1206 (3216) W 0.50±0.20 # # 1.60±0.20 G # 1.60±0.50 1.60±0.50 P # 0.95±0.10 C # 1.25±0.10 1.60±0.20 2.00±0.20 2.50±0.50 1.25±0.10 2.00±0.20 1.25±0.10 D G K M D K D # # # # # # # 1.60±0.20 2.00±0.20 2.50±0.50 G K M # # # 0.75±0.25 (0.50±0.25)* # # 0.75±0.35 # 0.85±0.35 3.20±0.60 2.50±0.50 1808 (4520) 4.50+0.6/-0.4 2.03±0.25 1812 (4532) 4.50+0.6/-0.4 1825 (4563) 4.50+0.6/-0.4 6.30±0.40 2220 (5750) 5.70±0.50 5.00±0.40 3.20±0.30 3.20±0.40 2225 (5763) 5.70±0.50 6.30±0.40 # Reflow soldering only is recommended. * For 1206≧1000V, 1812_200V~4000V products. 2.00±0.20 (K) 2.50±0.30 (M) 2.80±0.30 (U) MB 0.60±0.20 (0.50±0.25)* 1.60±0.20 1210 (3225) MB Fig. 1 The outline of MLCC 3.20±0.50 2.50±0.20 T 0.40±0.15 3.20+0.4/-0.1 3.20±0.40 L 0.75±0.25 0.50±0.25 0.85±0.35 6. GENERAL ELECTRICAL DATA Dielectric NP0 Size 0402, 0603, 0805, 1206, 1210, 1808, 1812, 1825, 2220, 2225 Capacitance range* Capacitance tolerance** X7R 0.1pF to 0.1µF Cap≤5pF: B (±0.1pF), C (±0.25pF) 5pF104 (6.3V,10V), 0402≧ 225 (6.3V), 0402/475 (10V), 0603/106 (6.3V), X7S: 0402/225(6.3V) 25V Q/ D.F. (Dissipation Factor) NP0: Cap≥30pF, Q≥1000; Cap0.1µF;0805≧1µF(0805/X7R>0.47µF); X7R: ≦10% 1206≧2.2µF;1210≧10µF;TT series 0603/475(6.3V) ≦12.5% 1206/X5R=10µF X5R: #1 35V ≦3.5% ≦10% 0603≧1µF;0805≥2.2µF;1206≧2.2µF;1210≧10µF 0201≧ 224 (6.3V,10V,16V) , ≦5% 0201≧0.01µF(0201/X5R=0.01µF);0805≧1µF;1210≧10µF* 0402≧ 475 (6.3V,16V), 0402≧ 225(10V), ≦ 7% 0603≧0.33µF 0603=106 (6.3V) 16V #1 Excluding X5R/0201/105(6.3V);225(10V) , 0402X475M6R3 (1.0±0.2Vrms,1KHz±10%) 10V 6.3V *Before initial measurement (Class II only): To apply de-aging at 150°C for 1hr then set 4V for 24±2 hrs at room temp. 4. Dielectric Strength *To apply voltage: ≦100V: 250% of rated voltage. 200V ~ 300V: 200% of rated voltage. 400V ~ 450V: 120% of rated voltage. 500V ~ 999V: 150% of rated voltage. 1000V ~ 3000V: 120% of rated voltage. 4000V: 110% of rated voltage. *Duration: 1 to 5 sec. *Charge & discharge current less than 50mA. 0201≧0.1µF(0201/X5R>0.01µF);0603≧0.47µF;TT series; 0402≧0.10µF(0402/X7R≧0.056µF);0805≧2.2µF; 1206≧4.7µF;1210≧22µF(1210/X5R≧10µF)* ≦12.5% 0402≧0.47µF;0805/X5R/X6S=10µF 0201≧0.01µF(0201/X5R=0.01µF);0402≧0.033µF; ≦5% 0603≧0.15µF;0805≧0.68µF;1206≧2.2µF;1210≧4.7µF 0201≧0.1µ(0201/X5R>0.01µF;0201/X7R≧0.022µF);0402≧0.22uF; ≦3.5% ≦10% 0603>0.47µF;0805≧2.2µF;1206≧4.7µF;1210≧22µF;TT series ≦12.5% 0402/X5R≧1µF;0402/X6S=1µF;0805/X5R/X6S=10µF 0201≧0.012µF;0402≧0.22µF;0603≧0.33µF;TT series; ≦10% 0805≧2.2µF;1206≧2.2µF;1210≧22µF:01R5/X5R ≦5% ≦12.5% 0805/X5R/X6S=10µF ≦15% 0201≧0.1µF(0201/X5R>0.1µF);0402≧1µF;0603/X5R≧10µF 0201≧0.1µF(0201/X5R>0.1µF);0402≧1µF(0402/X6S≧0.47µF); ≦15% 0603≧10µF;0805≧4.7µF;1206≧47µF;1210≧100µF;TT series ≦10% ≦20% 0402≧2.2µF ≦15% ----- ≦3.5% ≦10% * No evidence of damage or flash over during test. * "Room condition" Temperature: 15 to 35°C, Relativ e humidity: 25 to 75%, Atmospheric pressure: 86 to 106kPa. Page 19 of 27 ASC_Soft termination_(SH) Jun. 2023 Multilayer Ceramic Capacitors No. 5. Item Insulation Approval Sheet Test Condition Requirements 10GΩ or RxC≧500Ω-F whichever is smaller. *Test temp.: Room Temperature. Class II (X7R, X7E, X5R,X6S,X7S) Resistance *To apply rated voltage for MAX. 120sec. 6. Temperature Coefficient Rated voltage Insulation Resistance 100V: All X7R 50V:0402>0.01µF;0603≥1µF;0805≥1µF;1206≥4.7µF;1210≥4.7µF 35V:0805≥2.2µF;1206≧2.2µF;1210≧10µF 25V:0402≥1µF;0603≥2.2µF;0805≥2.2µF;1206≥10µF;1210≥10µF 16V: 0201≥0.1µF,0402≥0.22µF;0603≥1µF; 0805≥2.2µF;1206≥10µF;1210≥47µF 10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;0805≥2.2µF; 1206≥4.7µF;1210≥47µF 6.3V ; 4V ; TT series; Size≥1812 10GΩ or RxC≧100 Ω-F whichever is smaller. Rated voltage Insulation Resistance All X6S items, All X7S items 100V: 1210≥3.3µF 50V: 0402≥0.1µF; 0603≥2.2µF; 0805≥10µF;1206≥10µF 35V: 0603≥1µF; 25V: 0201≥0.1µF; 0402≥2.2µF;0603≥10µF; 0805≥10µF;1206≥22µF 16V: 0603≥10µF; 0402≥1µF; 0201≥0.22µF 10V: 0201>0.1µF; 0402≥1µF; 0603≥10µF; 0805≥47µF; TT21>4.7µF 6.3V: 0201≥0.1µF; 0402≥1µF;0603>4.7µF;0805≥47µF;1206≥10µF; TT15>1.0µF 4V:0603≥22µF; 0805≥47µF; 1206≥100µF RxC≧50 Ω-F. ≥10GΩ or RxC≥100Ω-F whichever is smaller Rated voltage: To apply rated voltage 200~630V (500V max.) for 60 sec. Rated voltage: To apply 500V for 60 >630V sec. With no electrical load. T.C. Operating Temp NPO -55~125°C at 25°C X7R -55~125°C at 25°C X7S -55 ~ 125°C at 25°C X5R -55~ 85°C at 25°C X6S -55~105°C at 25°C *Before initial measurement (Class II only): To apply de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. * Measurement voltage for Class II: 01005 Cap≤0.01µF: 0.5V Cap>0.01µF: 0.2V *0201X104/6.3V~25V: 0.5V 0201X224&474/10V: 0.5V 0402 Cap0.01µF;0603≥1µF;0805≥1µF;1206≥4.7µF;1210≥4.7µF 35V:0603≥1µF;0805≥2.2µF; 1206≧2.2µF;1210≧10µF 25V:0201≧0.1uF; 0402≥0.22µF; 0603≥2.2µF;0805≥2.2µF; 1206≥10µF;1210≥10µF 16V: 0201≧0.1uF;0402≥0.22µF;0603≥1µF;0805≥2.2µF; 1206≥10µF;1210≥47µF 10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;0805≥2.2µF; 1206≥4.7µF;1210≥47µF 6.3V ; 4V ; TT series ; All X6S/X7S items; Size≥1812 1GΩ or RxC≧10 Ω-F whichever is smaller. * "Room condition" Temperature: 15 to 35°C, Relativ e humidity: 25 to 75%, Atmospheric pressure: 86 to 106kPa. Page 22 of 27 ASC_Soft termination_(SH) Jun. 2023 Multilayer Ceramic Capacitors No 14 Item Humidity (Damp Heat) Load Approval Sheet Test Condition Requirements *Test temp.:40±2°C *Humidity:90~95%RH *Test time:500+24/-0 hrs. *To apply voltage: Rated voltage (MAX. 500V) *Before initial measurement (Class II only): To apply de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. * Cap. / DF(Q) / I.R. Measurement to be made after de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. * No remarkable damage. Cap change: NP0: ±7.5% or 0.75pF whichever is larger. X7R, X5R, X6S, X7S: ≥10V**,within ±12.5%; ≦6.3V within ±25%; TT series & C≥ 1uF,within ±25% **10V: 0603≧4.7µF;0402≧1µF;0201≧0.1µF, within ±25%; Q/D.F. value: NP0: C≥30pF,Q≥200;C0.1µF;0805≧1µF(0805/X7R>0.47µF); 1206≧2.2µF;1210≧10µF; TT series 0603≧1µF;0805≥2.2µF;1206≧2.2µF;1210≧10µF 0201≧0.01µF(0201/X5R=0.01µF);0805≧1µF;1210≧10µF* 0603≧0.33µF 0201≧0.1µF(0201/X5R>0.01µF); 0603≧0.47µF;TTseries 0402≧0.10µF(0402/X7R≧0.056µF);0805≧2.2µF; 1206≧4.7µF;1210≧22µF(1210/X5R≧10µF)*; 0402≧0.47µF 0603≧0.15µF;0805≧0.68µF;1206≧2.2µF;1210≧4.7µF 16V ≦5% 10V ≦7.5% 6.3V ≦15% ≦30% 0201≧0.1µF;0402≧1µF(0402/X6S≧0.47µF); 0603≧10µF;0805≧4.7µF;1206≧47µF;1210≧100µF;TT series 4V ≦20% --- --- ≦15% 0201≧0.01µF(0201/X7R≧0.022µF);0402≧0.033µF; 0603>0.47µF;0805≧2.2µF;1206≧4.7µF;1210≧22µF;TT series ≦15% 0201≧0.012µF;0402≧0.22µF; 0603≧0.33µF;0805≧2.2µF;1206≧2.2µF;1210≧22µF ≦20% 0201≧0.1µF;0402≧1µF;0603/X5R≧10µF;TT series;01R5/X5R *I.R.: ≥10V, 500MΩ or 25 Ω-F whichever is smaller. Class II (X7R, X5R, X6S, X7S) Rated voltage Insulation Resistance 100V: All X7R;1210≥3.3µF 50V: 0402>0.01µF;0603≥1µF;0805≥1µF;1206≥4.7µF;1210≥4.7µF 35V:0603≥1µF;0805≥2.2µF; 1206≧2.2µF;1210≧10µF 25V:0201≧0.1uF; 0402≥0.22µF; 0603≥2.2µF;0805≥2.2µF; 1206≥10µF;1210≥10µF 16V: 0201≧0.1uF;0402≥0.22µF;0603≥1µF;0805≥2.2µF; 1206≥10µF;1210≥47µF 10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;0805≥2.2µF; 1206≥4.7µF;1210≥47µF 6.3V ; 4V ; TT series ; All X6S/X7S items; Size≥1812 500MΩ or RxC≧5 Ω-F whichever is smaller. * "Room condition" Temperature: 15 to 35°C, Relativ e humidity: 25 to 75%, Atmospheric pressure: 86 to 106kPa. Page 23 of 27 ASC_Soft termination_(SH) Jun. 2023 Multilayer Ceramic Capacitors No 15. Item Approval Sheet Test Condition Requirements High Temperature * Test temp.: NP0, X7R/X7E/X7S: 125±3°C Load X6S: 105±3°C (Endurance) X5R: 85±3°C *Test time: 1000+24/-0 hrs. *To apply voltage: (1) 100% of rated voltage for below range. Rated Capacitance Size Dielectric voltage range ≦10V C≧ 0.1µF X5R/X7R/ 0201 ≧16V C >0.1µF X6S/X7S ≦16V C >1.0µF X5R 25V,50V C≧1.0µF 6.3V,10V 0402 C >1.0µF X6S 16V,25V C≧1.0µF X7R/X7S/Y5V 6.3V,10V C≧1.0µF 4V C≧22µF X5R/X7R/ X6S/X7S 6.3V,10V C≧4.7µF#1 0603 25V C≧1.0µF X5R/X6S/X7S X7R 35V C≧1.0µF 4V C≧47µF X5R/X7R/ 6.3V C≧22µF X6S/X7S 10V,50V C≧10µF 16V C >10µF 0805 X6S 25V C≧10µF X7R/X7S C≧10µF 16V,25V C≧22µF X5R C≧47µF 1206 X5R/X7R/X6S ≦6.3V 16V C≧47µF X5R/X7R/X6S 1210 100V C≧3.3µF X7R **1WV items must follow de-rating conditions. * No remarkable damage. Cap change: NP0: ±3.0% or ±0.3pF whichever is larger X7R, X5R, X6S, X7S: ≥10V**,within ±12.5%; ≦6.3V within ±25%; TT series & C≥ 1uF,within ±25% **10V: 0603≧4.7µF;0402≧1µF;0201≧0.1µF, within ±25%; Q/D.F. value: NP0: More than 30pF, Q≥350 10pF≤C0.01µF X7R/X5R/ 0402 X6S 10~25V C≧0.22µF 50V~100V C>0.22µF X7S 50V C>0.1µF X7R 25V C=1.0µF 0603 50V C≧1.0µF X5R X5R/X7R/ 10V,16V C≧1.0µF X6S/X7S 100V C≧0.47µF 50V C≧0.68µF X5R/X7R/ 0805 X6S/X7S 35V C≧2.2µF 10~25V C≧4.7µF 100V C≧1.0µF X7R 50V C≧2.2µF 1206 100V C>1.0µF X5R/X6S/ X7S 50V C=4.7µF C≧2.2µF 1210 X5R/X7R/ 50V~100V X6S/X7S 1825 2220 100V~250V C≧1.0µF X7R 2225 (3)≦6.3V or C≧10µF: 150% of rated voltage. (4) 10V~250V: 200% of rated voltage. (5) 400V~450V: 120% of rated voltage. (6) 500V: 150% of rated voltage. (7) 630V~3000V:120% of rated voltage, Excluding ≦3% ≦6% 1206≧0.47µF ≦7.5% 0603≧0.068µF;0805>0.1µF;1206≧1µF;1210≧2.2µF;TT series ≦20% 0805>0.22µF;1210≧3.3µF ≦6% 0201(50V);0603≧0.047µF;0805≧0.18µF;1206≧0.47µF ≦10% 0201≧0.01uF;1210≧3.3µF 10V 6.3V 4V ≦20% ≦10% ≦14% ≦15% ≦20% ≦10% ≦5% ≦15% 0402≧0.012µF;0603>0.1µF;0805≧1µF(0805/X7R>0.47µF); 1206≧2.2µF;1210≧10µF; TT series 0603≧1µF;0805≥2.2µF;1206≧2.2µF;1210≧10µF 0201≧0.01µF(0201/X5R=0.01µF);0805≧1µF;1210≧10µF* 0603≧0.33µF 0201≧0.1µF(0201/X5R>0.01µF); 0603≧0.47µF;TTseries 0402≧0.10µF(0402/X7R≧0.056µF);0805≧2.2µF; 1206≧4.7µF;1210≧22µF(1210/X5R≧10µF)*; 0402≧0.47µF 0603≧0.15µF;0805≧0.68µF;1206≧2.2µF;1210≧4.7µF 0201≧0.01µF(0201/X7R≧0.022µF);0402≧0.033µF; 0603>0.47µF;0805≧2.2µF;1206≧4.7µF;1210≧22µF;TT series 0201≧0.012µF;0402≧0.22µF; 0603≧0.33µF;0805≧2.2µF;1206≧2.2µF;1210≧22µF ≦20% 0201≧0.1µF;0402≧1µF;0603/X5R≧10µF;TT series;01R5/X5R 0201≧0.1µF;0402≧1µF(0402/X6S≧0.47µF); ≦15% ≦30% 0603≧10µF;0805≧4.7µF;1206≧47µF;1210≧100µF;TT series ≦7.5% ≦15% ≦20% --- --- *I.R.: ≥10V, 1GΩ or 50 Ω-F whichever is smaller. Class II (X7R, X5R, X6S, X7S) Insulation Resistance Rated voltage 100V: All X7R;1210≥3.3µF 50V: 0402>0.01µF;0603≥1µF;0805≥1µF;1206≥4.7µF;1210≥4.7µF 35V:0603≥1µF;0805≥2.2µF; 1206≧2.2µF;1210≧10µF 25V:0201≧0.1uF; 0402≥0.22µF; 0603≥2.2µF;0805≥2.2µF; 1206≥10µF;1210≥10µF 16V: 0201≧0.1uF;0402≥0.22µF;0603≥1µF;0805≥2.2µF; 1206≥10µF;1210≥47µF 10V:0201≥47nF;0402≥0.47µF;0603≥0.47µF;0805≥2.2µF; 1206≥4.7µF;1210≥47µF 6.3V ; 4V ; TT series ; All X6S/X7S items; Size≥1812 1GΩ or RxC≧ 10 Ω-F whichever is smaller. 1210/X7R/103/2KV(110% of rated voltage) &1812N472&1812N562(1KV): 100% of rated voltage. (8) 4000V: 110% of rated voltage * Before initial measurement (Class II only): To apply de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. * Cap. / DF(Q) / I.R. Measurement to be made after de-aging at 150°C for 1hr then set for 24±2 hrs at room temp. ** De-rating conditions: * "Room condition" Temperature: 15 to 35°C, Relativ e humidity: 25 to 75%, Atmospheric pressure: 86 to 106kPa. Page 24 of 27 ASC_Soft termination_(SH) Jun. 2023 Multilayer Ceramic Capacitors Approval Sheet APPENDIXES ◙ Tape & reel dimensions Fig. 2 The dimension of paper tape Fig. 3 The dimension of plastic tape Size 0402 0603 Thickness N,E S,X A0 B0 0.70 +/-0.20 1.20 +/-0.20 1.05 +/-0.30 1.80 +/-0.30 T ≦0.80 ≦1.20 K0 - - - - W 8.00 +/-0.30 4.00 +/-0.10 40.00 +/-0.10 2.00 +/-0.05 2.00 +/-0.05 1.50 +0.1/-0 8.00 +/-0.30 4.00 +/-0.10 40.00 +/-0.20 4.00 +/-0.10 2.00 +/-0.05 1.50 +0.1/-0 8.00 +/-0.30 4.00 +/-0.10 40.00 +/-0.20 4.00 +/-0.10 2.00 +/-0.05 1.50 +0.1/-0 8.00 +/-0.30 4.00 +/-0.10 40.00 +/-0.20 4.00 +/-0.10 2.00 +/-0.05 1.50 +0.1/-0 P0 10xP0 P1 P2 D0 D1 - - E 1.75 +/-0.10 3.50 +/-0.05 1.75 +/-0.10 3.50 +/-0.05 F 0805 1206 1210 1808 1812 1825 2220 2225 C,J, D G,P C,D, G,K M D,F, G,K D,F, G,K M,U K M,U K M,U K M,U 1.50 1.50 1.90 < 1.80 < 2.00 +/-0.20 +/-0.20 +/-0.50 2.30 2.30 3.50 < 2.70 < 3.70 +/-0.20 +/-0.20 +/-0.50 0.23 0.23 ≦1.15 ≦1.20 ≦1.20 +/-0.1 +/-0.1
SH18N152F500CT 价格&库存
很抱歉,暂时无法提供与“SH18N152F500CT”相匹配的价格&库存,您可以联系我们找货
