PCT1/4AK
PCT1/4AK
    SUNTSU
    CAP TANT 1UF 10% 4V 1206
PCT1/4AK 数据手册
PCT SERIES STANDARD AND EXTENDED RANGE TANTALUM CAPACITORS FEATURES - Surface Mount (SMT) Tantalum Capacitors - Meets or Exceeds EIA 535 BAAC and IECQ standards (QC300801/US001, IS-28) - Capacitance range: 0.1μF to 1500μF - Voltage range: 4 to 50 WVDC - Down sized, extended range values - Low profile sizes: XL, AL, BL, CL, DL - Surge tested for maximum robustness - Operating Temperature range -55°C to +125°C - Precision molded case with flat surfaces for vacuum pick-up Laser marking and bold videcon – readable polarity Compliant terminations Glue pad on underside for bonding to circuit board prior to soldering Encapsulant material satisfies the UL 94 V0 flammability classification MSL (moisture sensitivity level) per IPC/Jedec J-STD020B is level 1 PART NUMBERING GUIDE PCT 10 / 35 D K SERIES TYPE (optional) OPTIONAL -13 = 13 inch diameter Tape & Reel = 7 inch standard Tape & Reel TL = Tin/Lead TOLERANCE M = (±20%) K = (±10%) CAPACITANCE in microfarads (µF) Ex. 0.68µF would be .68 CASE SIZE A (3216-18) B (3528-21) C (6032-28) D (7343-31) H (7343-43) Z (7361-38) XL (2012-12) Low Profile AL (3216-12) Low Profile BL (3528-12) Low Profile CL (6032-15) Low Profile DL (7343-20) Low Profile VOLTAGE 4 6(6.3) 10 16 20 25 35 50 ELECTRICAL SPECIFICATION Technical Data: Capacitance Range Capacitance Tolerance Rated Voltage DC (VR) Category Voltage DC (VC) Surge Voltage (VS) Surge Voltage (VS) Temperature Range Reliability All technical data relate to an ambient temperature of +25°C 0.10µF to 1500µF ±10% (K); ±20% (M) 4 6.3 10 16 20 25 35 2.7 4 7 10 13 17 23 5.2 8 13 20 26 32 46 3.2 5 8 13 16 20 28 -55°C to +125°C with 2/3 Vr (linear derating) required for operation above +85°C Level M (1% per 1000 hours at rated voltage (VR), rated temperature (85°C) and 0.1Ω/volt circuit impedance. Fixed Tantalum Specifications: EIA 525BAAC and IECQ standards (QC300801/US001, IS-28) Solder-ability: Sn Plated Terminations – meets requirements of IEC 68 2.20 test Ta and MIL-STD=202, Method 208 MSL (moisture sensitivity level): Level 1 of IPC/Jedec J-STD-020B ≤+85°C ≤+125°C ≤+85°C ≤+125°C Qualifications CASE SIZE CROSS REFERENCE: CAPACITANCE AND VOLTAGE RATING (Rated Voltage DC@ 85°C) Cap (μF) 4V 6.3V 10V 16V 20V 0.10 0.15 0.22 0.33 0.47 0.68 1.0 1.5 2.2 3.3 4.7 6.8 10.0 15.0 22.0 33.0 47.0 68.0 100.0 150.0 220.0 330.0 470.0 680.0 1000.0 1500.0 50 33 65 40 25V 35V 50V A, AL, XL A, AL, XL A, AL, XL A, AL, XL A, AL, XL A, AL, XL A, AL, XL A, AL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, A, AL, BL, XL A, AL, BL, XL A, AL, BL, XL A, AL, BL, XL A, AL, BL, XL A, AL, BL, XL A, AL, BL, XL AL, BL A, AL, B, BL, C XL A, AL, B, BL, C XL A, AL, B, BL, C XL A, AL, B, BL, C XL A, AL, B, BL, C XL A, AL, B, BL, C XL A, AL, B, BL, C XL A, AL, B, BL, C A, AL, B, BL, C XL A, AL, B, BL, C, CL, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, CL, D, DL, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, D, DL, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, CL, D, DL, H, Z, XL A, AL, BL, C, CL, D, DL, H, Z A, B, BL, C, CL, D, DL, H, Z A, B, BL, C, CL, D, DL, H, Z A, B, BL, C, CL, D, DL, H, Z B, C, CL, D, DL, H, Z B, C, CL, D, DL, H A, AL, B, BL, C XL A, AL, B, BL, C, CL, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, CL, D, DL, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, D, DL, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, CL, D, DL, H, Z A, B, BL, C, CL, D, DL, H, Z A, B, BL, C, CL, D, DL, H, Z B, C, CL, D, DL, H, Z B, C, CL, D, DL, H, Z B, C, CL, D, DL, H, Z C, D, DL, H A, AL, B, BL, C XL A, AL, B, BL, C, CL, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, CL, D, DL, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, D, DL, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, CL, D, DL, H A, B, BL, C, CL, D, DL, H, Z A, B, C, CL, D, DL, H, Z B, C, CL, D, DL, H, Z A, AL, B, BL, C XL A, AL, B, BL, C, CL, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, CL, D, DL, XL A, AL, B, BL, C, CL, D, DL, H A, AL, B, BL, C, D, DL A, B, BL, C, CL, D, DL, H A, B, BL, C, CL, D, DL, H B, C, CL, D, DL, H, Z B, C, CL, D, DL, H, Z A, AL, B, BL, C XL A, AL, B, BL, C, CL, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, D, XL A, B, BL, C, CL, D, DL A, B, BL, C, CL, D, DL, H A, AL, B, BL, C A, AL, B, BL, C, CL, XL A, B, BL, C, CL, D, DL A, B, BL, C, CL, D, DL, H A, B, BL, C, D, DL B, C, D, DL B, C, CL, D, DL, H B, C, D, DL, H, Z C, D, DL, H, J C, D, DL, H A, AL, B, BL, C A, B, C A, AL, B, BL, C, CL A, B, C, CL A, AL, B, BL, C, D A, B, BL, C, D B, C, D A, B, BL, C, D A, B, BL, C, D B, C, D B, C, D, DL C, D, DL C, D, DL, H C, D, DL C, D, DL C, D, DL B, C, CL, D, DL, H C, D, DL, H D, H B, C, CL, D, DL, H C, D, DL, H C, D, DL, H D, H B, C, CL, D, DL, H, Z C, D, DL, H, Z D, DL, H, Z Z C, D, DL, H, Z D, H, Z D, H, Z C, CL, D, DL, H, Z C, D, DL, H, Z D, DL, H, Z H, Z C, D, DL, H, Z C, D, DL, H, Z H, Z Z B, C, CL, D, DL, H, Z C, D, DL, H, Z D, H, Z H, Z C, D, DL, H, Z D, DL, H, Z H, Z Z C, D, DL, H H C, D, DL, H, J D, H, J J D, DL, H H D, DL, H H D, H, Z H, Z H 142 Technology Dr., Suite 150 Irvine, CA 92618 www.suntsu.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE REV. 10/19/20 Telephone • 949.783.7300 Facsimile • 949.783.7301 PCT SERIES STANDARD AND EXTENDED RANGE TANTALUM CAPACITORS OUTLINE DRAWING AND PAD PRINT TAPE AND REEL DIMENSION (3) 0805 Footprint Compatible (4) 1206 Footprint Compatible NOTE: Dimensions in millimeters (mm) NEMCO Size EIA Size ±0.2 ± 0.2 ± 0.3 ± 0.1 ±0.3 S Min. PSL PL PS PW ±0.3 (Pitch) (MAX) I ±1 ±0.05 A(4) 3216-18 3.2 1.6 1.6 1.2 0.8 1.10 3.8 1.4 1.0 1.8 8 4 2.3 1.0 9.5 3.5 B 3528-21 3.5 2.8 1.9 2.2 0.8 1.40 4.0 1.4 1.2 2.8 8 4 2.6 1.0 9.5 3.5 C 6032-28 6.0 3.2 2.5 2.2 1.3 2.90 6.5 2.0 2.5 2.8 12 8 3.3 1.5 13 5.5 D 7343-31 7.3 4.3 2.8 2.4 1.3 4.40 8.0 2.0 4.0 3.0 12 8 3.6 1.5 13 5.5 H 7343-43 7.3 4.3 4.1 2.4 1.3 4.40 8.0 2.0 4.0 3.0 12 8 4.8 1.5 13 5.5 Z 7361-38 7.3 6.1 3.45 3.1 1.4 4.40 8.0 2.0 4.0 3.7 12 8 4.8 1.5 13 5.5 XL(3) 2012-12 2.05 1.3 1.2 1.2 0.5 0.85 2.7 1.0 0.8 1.6 8 4 1.9 1.0 9.5 3.5 AL(4) 3216-12 3.2 1.6 1.2 1.2 0.8 1.10 3.8 1.4 1.0 1.8 8 4 1.9 1.0 9.5 3.5 BL 3528-12 3.5 2.8 1.2 2.2 0.8 1.40 4.0 1.4 1.2 2.8 8 4 1.9 1.0 9.5 3.5 CL 6032-15 6.0 3.2 1.5 2.2 1.3 2.90 6.5 2.0 2.5 2.8 8 4 1.9 1.0 9.5 3.5 DL 7343-20 7.3 4.3 2.0 2.4 1.3 4.40 8.0 2.0 4.0 3.0 8 4 1.7 1.0 9.5 3.5 L W1 H W2 P TW PT REFLOW PROFILE M N F MARKING Case Sizes: XL, A, AL, B, BL Capacitance with μ representing decimal Voltage Code Polarity (+) C4µ7 DATE CODE C4µ7 = 4.7 µfd / 16V Case Sizes: C, CL, D, DL, H, Z Polarity (+) Capacitance Voltage Tantalum capacitors are lead-free system compatible system components, meeting the requirements of J-STD-020 standard. Maximum peak temperature 260°C for 10 seconds maximum, 3 reflow cycles. There are several important general soldering considerations for tantalum capacitors. • Soldering temperature and time should be the minimum for a good connection. • Recommended soldering profiles are designed to insure that the temperature of the internal construction of the capacitors does not exceed +220°C. • Positioning capacitors near components radiating heat such as power transistors should be avoided. • Allow for an increase to ESR ratings of 1.25 x catalog limit post PCB assembly. NEMCO reserves the right to supply a higher voltage rating, Voltage VDC 4V 6.3V 10V 16V 20V 25V 35V 50V Voltage Code G J A C D E V T tighter tolerance and/or lower ESR in the same case size, to the same reliability standards. 142 Technology Dr., Suite 150 Irvine, CA 92618 www.suntsu.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE REV. 10/19/20 Telephone • 949.783.7300 Facsimile • 949.783.7301 PCT SERIES STANDARD AND EXTENDED RANGE TANTALUM CAPACITORS RATINGS AND PART NUMBER REFERENCE 4 V DC @ 85°C Capacitance (μF) 2.2 2.2 3.3 3.3 4.7 4.7 6.8 6.8 6.8 10.0 10.0 10.0 15.0 15.0 15.0 22.0 22.0 22.0 33.0 33.0 33.0 33.0 47.0 47.0 47.0 68.0 68.0 68.0 68.0 100.0 100.0 100.0 100.0 150.0 150.0 150.0 150.0 220.0 220.0 220.0 220.0 220.0 330.0 330.0 330.0 470.0 470.0 470.0 470.0 680.0 680.0 680.0 1000.0 1000.0 1500.0 Case Size AL XL AL XL AL XL AL BL XL AL BL XL AL BL XL AL BL XL A AL BL CL A BL CL A B BL CL A B BL CL B C CL DL B C CL D DL C D DL C D DL H D DL H D H H Nemco Part No. PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT10 PCT15 PCT15 PCT15 PCT22 PCT22 PCT22 PCT33 PCT33 PCT33 PCT33 PCT47 PCT47 PCT47 PCT68 PCT68 PCT68 PCT68 PCT100 PCT100 PCT100 PCT100 PCT150 PCT150 PCT150 PCT150 PCT220 PCT220 PCT220 PCT220 PCT220 PCT330 PCT330 PCT330 PCT470 PCT470 PCT470 PCT470 PCT680 PCT680 PCT680 PCT1000 PCT1000 PCT1500 / 4AL _ / 4XL _ / 4AL _ / 4XL _ / 4AL _ / 4XL _ / 4AL _ / 4BL _ / 4XL _ / 4AL _ / 4BL _ / 4XL _ / 4AL _ / 4BL _ / 4XL _ / 4AL _ / 4BL _ / 4XL _ / 4A _ / 4AL _ / 4BL _ / 4CL _ / 4A _ / 4BL _ / 4CL _ / 4A _ / 4B _ / 4BL _ / 4CL _ / 4A _ / 4B _ / 4BL _ / 4CL _ / 4B _ / 4C _ / 4CL _ / 4DL _ / 4B _ / 4C _ / 4CL _ / 4D _ / 4DL _ / 4C _ / 4D _ / 4DL _ / 4C _ / 4D _ / 4DL _ / 4H _ / 4D _ / 4DL _ / 4H _ /4D _ /4H _ /4H _ 6.3 V DC @ 85°C (2.7 V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.6 0.5 0.6 0.6 0.6 0.9 0.9 0.9 1.3 1.3 1.3 1.3 1.9 1.9 1.9 2.7 2.7 2.7 2.7 4.0 4.0 4.0 4.0 6.0 6.0 6.0 6.0 8.8 8.8 8.8 8.8 8.8 13.2 13.2 13.2 18.8 18.8 18.8 18.8 27.2 27.2 27.2 40.0 40.0 60.0 tan δ max. (%) 6 6 6 6 6 6 6 6 6 6 6 6 8 6 8 8 6 8 6 8 6 6 8 10 6 10 6 15 6 30 8 14 6 10 6 6 6 12 8 8 8 8 8 8 12 14 12 14 10 14 25 14 60 14 30 ESR @ 100kHz max. (Ω) 25.0 25.0 18.0 20.0 10.0 12.0 8.0 6.0 5.2 6.0 5.0 7.0 4.0 2.0 4.0 3.5 1.9 3.8 3.0 1.7 1.7 0.6 2.6 2.0 0.5 1.5 1.8 1.5 0.4 1.4 0.9 1.4 1.3 1.5 0.3 1.3 0.4 1.1 1.2 1.2 0.9 0.3 0.3 0.9 0.4 0.3 0.9 0.9 0.5 0.5 0.2 0.9 0.2 0.4 0.2 Capacitance (μF) 1.5 1.5 2.2 2.2 3.3 3.3 4.7 4.7 4.7 6.8 6.8 6.8 10.0 10.0 10.0 10.0 15.0 15.0 15.0 15.0 15.0 22.0 22.0 22.0 22.0 22.0 33.0 33.0 33.0 33.0 33.0 47.0 47.0 47.0 47.0 47.0 68.0 68.0 68.0 68.0 100.0 100.0 100.0 100.0 100.0 150.0 150.0 150.0 150.0 150.0 220.0 220.0 220.0 220.0 330.0 330.0 330.0 330.0 470.0 470.0 470.0 680.0 1000.0 1000.0 Case Size AL XL AL XL AL XL AL BL XL AL BL XL A AL BL XL A AL B BL XL A AL B BL CL A B BL C CL A B BL C CL B C CL D B C CL D DL B C CL D DL C D DL H C D DL H D DL H H H Z Nemco Part No. PCT1.5 PCT1.5 PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT10 PCT10 PCT15 PCT15 PCT15 PCT15 PCT15 PCT22 PCT22 PCT22 PCT22 PCT22 PCT33 PCT33 PCT33 PCT33 PCT33 PCT47 PCT47 PCT47 PCT47 PCT47 PCT68 PCT68 PCT68 PCT68 PCT100 PCT100 PCT100 PCT100 PCT100 PCT150 PCT150 PCT150 PCT150 PCT150 PCT220 PCT220 PCT220 PCT220 PCT330 PCT330 PCT330 PCT330 PCT470 PCT470 PCT470 PCT680 PCT1000 PCT1000 / 6AL _ / 6XL _ / 6AL _ / 6XL _ / 6AL _ / 6XL _ / 6AL _ / 6BL _ / 6XL _ / 6AL _ / 6BL _ / 6XL _ / 6A _ / 6AL _ / 6BL _ / 6XL _ / 6A _ / 6AL _ / 6B _ / 6BL _ / 6XL _ / 6A _ / 6AL _ / 6B _ / 6BL _ / 6CL _ / 6A _ / 6B _ / 6BL _ / 6C _ / 6CL _ / 6A _ / 6B _ / 6BL _ / 6C _ / 6CL _ / 6B _ / 6C _ / 6CL _ / 6D _ / 6B _ / 6C _ / 6CL _ / 6D _ / 6DL _ / 6B _ / 6C _ / 6CL _ / 6D _ / 6DL _ / 6C _ / 6D _ / 6DL _ / 6H _ / 6C _ / 6D _ / 6DL _ / 6H _ / 6D _ / 6DL _ / 6H _ / 6H _ / 6H _ / 6Z _ (4 V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.6 0.6 0.6 0.6 0.9 0.9 1.0 1.0 0.9 1.4 1.3 1.4 1.4 1.3 2.1 2.1 2.1 2.1 2.1 2.8 3.0 2.8 3.0 3.0 4.0 4.3 4.3 4.3 6.3 6.3 6.3 6.3 6.3 9.5 9.5 9.0 9.5 9.0 13.9 13.9 13.9 13.9 19.8 20.8 20.8 20.8 28.0 28.2 28.0 42.8 60.0 60.0 tan δ max. (%) 6 6 6 6 6 6 6 6 6 6 6 8 6 8 6 8 6 8 6 6 8 6 10 6 8 6 8 6 10 6 6 10 6 10 6 6 8 6 6 6 10 6 6 6 6 10 6 8 6 6 8 8 10 8 12 8 8 8 12 20 10 10 20 16 ESR @ 100kHz max. (Ω) 25.0 25.0 18.0 20.0 9.0 12.0 7.5 6.0 7.0 2.6 5.0 7.0 4.0 4.0 4.0 6.0 3.5 4.0 2.5 3.5 4.1 3.0 1.8 2.5 2.5 0.6 3.2 2.2 2.5 1.8 1.8 1.6 2.0 1.6 1.6 1.5 0.9 1.5 1.5 0.9 1.7 0.9 0.9 0.9 0.9 1.2 1.3 0.3 0.9 0.4 1.2 0.4 0.9 0.4 0.5 0.4 0.4 0.4 0.4 0.2 0.4 0.5 0.2 0.4 _ Insert tolerance M(±20%) or K(±10%) to complete the Nemco part number NEMCO reserves the right to supply a higher voltage rating, tighter tolerance and/or lower ESR in the same case size, to the same reliability standards. 142 Technology Dr., Suite 150 Irvine, CA 92618 www.suntsu.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE REV. 10/19/20 Telephone • 949.783.7300 Facsimile • 949.783.7301 PCT SERIES STANDARD AND EXTENDED RANGE TANTALUM CAPACITORS RATINGS AND PART NUMBER REFERENCE 10 V DC @ 85°C Capacitance (μF) 1.0 1.0 1.5 1.5 2.2 2.2 2.2 3.3 3.3 3.3 4.7 4.7 4.7 4.7 6.8 6.8 6.8 6.8 6.8 10.0 10.0 10.0 10.0 10.0 15.0 15.0 15.0 15.0 15.0 22.0 22.0 22.0 22.0 22.0 33.0 33.0 33.0 33.0 47.0 47.0 47.0 47.0 47.0 68.0 68.0 68.0 100.0 100.0 100.0 100.0 100.0 150.0 150.0 150.0 150.0 220.0 220.0 220.0 220.0 330.0 330.0 470.0 Case Size AL XL AL XL A AL XL AL BL XL A AL BL XL A AL B BL XL A AL B BL XL A AL B BL CL A B BL C CL A B C CL B C CL D DL B C D B C CL D DL C D DL H C D DL H D H H Nemco Part No. PCT1 PCT1 PCT1.5 PCT1.5 PCT2.2 PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT10 PCT10 PCT10 PCT15 PCT15 PCT15 PCT15 PCT15 PCT22 PCT22 PCT22 PCT22 PCT22 PCT33 PCT33 PCT33 PCT33 PCT47 PCT47 PCT47 PCT47 PCT47 PCT68 PCT68 PCT68 PCT100 PCT100 PCT100 PCT100 PCT100 PCT150 PCT150 PCT150 PCT150 PCT220 PCT220 PCT220 PCT220 PCT330 PCT330 PCT470 / 10AL _ / 10XL _ / 10AL _ / 10XL _ / 10A _ / 10AL _ / 10XL _ / 10AL _ / 10BL _ / 10XL _ / 10A _ / 10AL _ / 10BL _ / 10XL _ / 10A _ / 10AL _ / 10B _ / 10BL _ / 10XL _ / 10A _ / 10AL _ / 10B _ / 10BL _ / 10XL _ / 10A _ / 10AL _ / 10B _ / 10BL _ / 10CL _ / 10A _ / 10B _ / 10BL _ / 10C _ / 10CL _ / 10A _ / 10B _ / 10C _ / 10CL _ / 10B _ / 10C _ / 10CL _ / 10D _ / 10DL _ / 10B _ / 10C _ / 10D _ / 10B _ / 10C _ / 10CL _ / 10D _ / 10DL _ / 10C _ / 10D _ / 10DL _ / 10H _ / 10C _ / 10D _ / 10DL _ / 10H _ / 10D _ / 10H _ / 10H _ 16 V DC @ 85°C (7 V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.7 0.7 0.7 0.7 0.7 1.0 1.0 1.0 1.0 1.0 1.5 1.5 1.5 1.5 1.5 2.2 2.2 2.2 2.2 2.2 3.3 3.3 3.3 3.3 4.7 4.7 4.7 4.7 4.7 6.8 6.8 6.8 10.0 10.0 10.0 10.0 10.0 15.0 15.0 15.0 15.0 22.0 22.0 22.0 22.0 33.0 33.0 47.0 tan δ max. (%) 4 4 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 8 6 6 20 6 6 6 8 6 8 6 8 6 6 8 6 6 6 8 6 6 6 6 6 6 6 8 8 6 6 6 8 8 6 8 8 8 10 8 8 8 10 ESR @ 100kHz max. (Ω) 25.0 25.0 20.0 20.0 7.0 12.0 15.0 8.0 6.0 8.0 5.0 5.0 5.0 9.0 4.0 4.0 3.0 4.0 5.2 3.0 4.0 2.5 3.0 6.0 3.2 2.0 2.8 2.8 0.7 3.0 2.4 2.2 1.8 0.6 1.7 1.8 1.6 1.6 1.0 1.2 1.4 0.9 0.5 1.4 1.3 0.9 1.4 1.2 0.4 0.9 0.9 0.9 0.9 1.2 0.9 0.5 0.5 0.5 0.5 0.9 0.9 0.5 Capacitance (μF) 0.68 0.68 1.0 1.0 1.0 1.0 1.5 1.5 1.5 2.2 2.2 2.2 2.2 3.3 3.3 3.3 3.3 3.3 4.7 4.7 4.7 4.7 6.8 6.8 6.8 6.8 6.8 10.0 10.0 10.0 10.0 10.0 15.0 15.0 15.0 15.0 15.0 22.0 22.0 22.0 22.0 33.0 33.0 33.0 33.0 33.0 47.0 47.0 47.0 47.0 68.0 68.0 68.0 100.0 100.0 100.0 100.0 150.0 150.0 150.0 220.0 330.0 Case Size AL XL A AL BL XL A AL XL A AL BL XL A AL B BL XL A AL B BL A AL B BL C A B BL C CL A B BL C CL B C CL D B C CL D DL C CL D DL C D DL C D DL H D DL H H H Nemco Part No. PCT.68 PCT.68 PCT1 PCT1 PCT1 PCT1 PCT1.5 PCT1.5 PCT1.5 PCT2.2 PCT2.2 PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT3.3 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT10 PCT10 PCT10 PCT15 PCT15 PCT15 PCT15 PCT15 PCT22 PCT22 PCT22 PCT22 PCT33 PCT33 PCT33 PCT33 PCT33 PCT47 PCT47 PCT47 PCT47 PCT68 PCT68 PCT68 PCT100 PCT100 PCT100 PCT100 PCT150 PCT150 PCT150 PCT220 PCT330 / 16AL _ / 16XL _ / 16A _ / 16AL _ / 16BL _ / 16XL _ / 16A _ / 16AL _ / 16XL _ / 16A _ / 16AL _ / 16BL _ / 16XL _ / 16A _ / 16AL _ / 16B _ / 16BL _ / 16XL _ / 16A _ / 16AL _ / 16B _ / 16BL _ / 16A _ / 16AL _ / 16B _ / 16BL _ / 16C _ / 16A _ / 16B _ / 16BL _ / 16C _ / 16CL _ / 16A _ / 16B _ / 16BL _ / 16C _ / 16CL _ / 16B _ / 16C _ / 16CL _ / 16D _ / 16B _ / 16C _ / 16CL _ / 16D _ / 16DL _ / 16C _ / 16CL _ / 16D _ / 16DL _ / 16C _ / 16D _ / 16DL _ / 16C _ / 16D _ / 16DL _ / 16H _ / 16D _ / 16DL _ / 16H _ / 16H _ / 16H _ (10 V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.8 0.8 0.8 0.8 1.1 1.1 1.1 1.1 1.1 1.6 1.6 1.6 1.6 1.6 2.4 2.4 2.4 2.4 2.4 3.5 3.5 3.5 3.5 5.3 5.3 5.3 5.3 5.3 7.5 7.5 7.5 7.5 10.9 10.9 10.9 16.0 16.0 16.0 16.0 24.0 24.0 24.0 35.2 52.8 tan δ max. (%) 4 4 4 4 4 4 6 6 6 6 6 6 6 6 6 6 6 8 6 8 6 6 6 8 6 6 6 8 6 8 6 6 6 6 6 6 6 6 6 6 6 8 6 6 6 6 6 6 6 6 6 6 6 8 6 8 6 6 15 8 10 30 ESR @ 100kHz max. (Ω) 25.0 25.0 11.0 15.0 5.0 20.0 8.0 12.0 10.0 6.5 6.0 6.5 6.5 5.0 5.0 4.5 5.0 5.0 4.0 4.5 3.5 4.5 3.5 2.4 2.5 3.5 2.5 3.0 2.8 2.2 2.0 2.0 2.0 2.5 2.0 1.8 0.7 2.3 1.0 1.6 1.1 2.1 1.5 1.5 0.9 0.9 0.5 0.4 0.9 0.7 1.3 0.9 0.9 1.0 0.6 0.9 0.9 0.9 0.3 0.3 0.5 0.4 _ Insert tolerance M(±20%) or K(±10%) to complete the Nemco part number NEMCO reserves the right to supply a higher voltage rating, tighter tolerance and/or lower ESR in the same case size, to the same reliability standards. 142 Technology Dr., Suite 150 Irvine, CA 92618 www.suntsu.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE REV. 10/19/20 Telephone • 949.783.7300 Facsimile • 949.783.7301 PCT SERIES STANDARD AND EXTENDED RANGE TANTALUM CAPACITORS RATINGS AND PART NUMBER REFERENCE 20 V DC @ 85°C Capacitance (μF) 0.10 0.10 0.15 0.15 0.22 0.22 0.33 0.33 0.47 0.47 0.68 0.68 0.68 1.0 1.0 1.0 1.0 1.5 1.5 1.5 1.5 2.2 2.2 2.2 2.2 2.2 3.3 3.3 3.3 4.7 4.7 4.7 6.8 6.8 6.8 6.8 10.0 10.0 10.0 15.0 15.0 15.0 22.0 22.0 22.0 22.0 22.0 33.0 33.0 33.0 47.0 47.0 47.0 47.0 68.0 68.0 68.0 68.0 100.0 100.0 150.0 Case Size AL XL AL XL AL XL AL XL AL XL AL BL XL A AL BL XL A AL BL XL A AL B BL XL A B BL A B BL A B BL C B C CL B C CL B C CL D DL C D DL C D DL H C D DL H D H H Nemco Part No. PCT.1 PCT.1 PCT.15 PCT.15 PCT.22 PCT.22 PCT.33 PCT.33 PCT.47 PCT.47 PCT.68 PCT.68 PCT.68 PCT1 PCT1 PCT1 PCT1 PCT1.5 PCT1.5 PCT1.5 PCT1.5 PCT2.2 PCT2.2 PCT2.2 PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT10 PCT15 PCT15 PCT15 PCT22 PCT22 PCT22 PCT22 PCT22 PCT33 PCT33 PCT33 PCT47 PCT47 PCT47 PCT47 PCT68 PCT68 PCT68 PCT68 PCT100 PCT100 PCT150 / 20AL _ / 20XL _ / 20AL _ / 20XL _ / 20AL _ / 20XL _ / 20AL _ / 20XL _ / 20AL _ / 20XL _ / 20AL _ / 20BL _ / 20XL _ / 20A _ / 20AL _ / 20BL _ / 20XL _ / 20A _ / 20AL _ / 20BL _ / 20XL _ / 20A _ / 20AL _ / 20B _ / 20BL _ / 20XL _ / 20A _ / 20B _ / 20BL _ / 20A _ / 20B _ / 20BL _ / 20A _ / 20B _ / 20BL _ / 20C _ / 20B _ / 20C _ / 20CL _ / 20B _ / 20C _ / 20CL _ / 20B _ / 20C _ / 20CL _ / 20D _ / 20DL _ / 20C _ / 20D _ / 20DL _ / 20C _ / 20D _ / 20DL _ / 20H _ / 20C _ / 20D _ / 20DL _ / 20H _ / 20D _ / 20H _ / 20H _ 25 V DC @ 85°C (13V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.7 0.7 0.7 0.9 0.9 0.9 1.4 1.4 1.4 1.4 2.0 2.0 2.0 3.0 3.0 3.0 4.4 4.4 4.4 4.4 4.4 6.6 6.6 6.6 9.4 9.4 9.4 9.4 13.6 13.6 13.6 13.6 20.0 20.0 30.0 tan δ max. (%) 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 8 6 6 6 6 6 8 ESR @ 100kHz max. (Ω) 25.0 25.0 25.0 25.0 25.0 25.0 25.0 25.0 25.0 25.0 25.0 15.0 20.0 9.0 12.0 9.0 20.0 6.5 5.4 6.5 9.6 5.3 4.5 3.5 6.0 6.0 4.5 3.0 3.0 4.0 3.0 3.0 2.4 2.5 2.6 2.0 2.1 2.2 1.9 2.0 1.7 1.7 1.8 1.6 1.6 0.9 0.9 1.5 0.9 0.6 0.5 0.9 0.9 0.9 0.5 0.4 0.9 0.9 0.5 0.4 0.3 Capacitance (μF) 0.15 0.22 0.33 0.47 0.47 0.68 0.68 1.0 1.0 1.0 1.5 1.5 1.5 1.5 2.2 2.2 2.2 3.3 3.3 3.3 3.3 3.3 4.7 4.7 4.7 4.7 4.7 6.8 6.8 6.8 10.0 10.0 10.0 10.0 15.0 15.0 15.0 22.0 22.0 22.0 33.0 33.0 47.0 47.0 47.0 68.0 100.0 100.0 150.0 Case Size XL XL XL AL XL AL XL A AL XL A AL B BL A B BL A B BL C CL A B BL C CL B C CL B C CL D C D DL C D DL D H D DL H H H Z Z Nemco Part No. PCT.15 PCT.22 PCT.33 PCT.47 PCT.47 PCT.68 PCT.68 PCT1 PCT1 PCT1 PCT1.5 PCT1.5 PCT1.5 PCT1.5 PCT2.2 PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT3.3 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT4.7 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT10 PCT10 PCT15 PCT15 PCT15 PCT22 PCT22 PCT22 PCT33 PCT33 PCT47 PCT47 PCT47 PCT68 PCT100 PCT100 PCT150 / 25XL _ / 25XL _ / 25XL _ / 25AL _ / 25XL _ / 25AL _ / 25XL _ / 25A _ / 25AL _ / 25XL _ / 25A _ / 25AL _ / 25B _ / 25BL _ / 25A _ / 25B _ / 25BL _ / 25A _ / 25B _ / 25BL _ / 25C _ / 25CL _ / 25A _ / 25B _ / 25BL _ / 25C _ / 25CL _ / 25B _ / 25C _ / 25CL _ / 25B _ / 25C _ / 25CL _ / 25D _ / 25C _ / 25D _ / 25DL _ / 25C _ / 25D _ / 25DL _ / 25D _ / 25H _ / 25D _ / 25DL _ / 25H _ / 25H _ / 25H _ / 25Z _ / 25Z _ (17 V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.6 0.6 0.6 0.8 0.8 0.8 0.8 0.8 1.2 1.2 1.2 1.2 1.2 1.7 1.7 1.7 2.5 2.5 2.5 2.5 3.8 3.8 3.8 5.5 5.5 5.5 8.3 8.3 11.8 11.8 11.8 17.0 25.0 25.0 37.5 tan δ max. (%) 4 4 4 4 4 4 4 4 4 4 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 10 8 10 ESR @ 100kHz max. (Ω) 24.0 21.0 17.0 14.0 15.0 10.0 13.0 8.0 8.0 8.0 7.5 5.4 5.0 5.0 7.0 4.5 4.5 3.7 3.5 3.5 2.8 1.6 3.1 1.5 3.1 2.4 1.2 2.8 2.0 2.0 2.5 1.8 1.8 1.2 1.6 1.0 1.0 1.4 0.9 0.9 0.9 0.9 0.9 0.9 0.9 0.9 0.3 0.4 0.4 _ Insert tolerance M(±20%) or K(±10%) to complete the Nemco part number NEMCO reserves the right to supply a higher voltage rating, tighter tolerance and/or lower ESR in the same case size, to the same reliability standards. 142 Technology Dr., Suite 150 Irvine, CA 92618 www.suntsu.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE REV. 10/19/20 Telephone • 949.783.7300 Facsimile • 949.783.7301 PCT SERIES STANDARD AND EXTENDED RANGE TANTALUM CAPACITORS RATINGS AND PART NUMBER REFERENCE 35 V DC @ 85°C Capacitance (μF) 0.10 0.10 0.10 0.15 0.15 0.15 0.22 0.22 0.22 0.33 0.33 0.33 0.47 0.47 0.47 0.47 0.47 0.68 0.68 0.68 0.68 1.0 1.0 1.0 1.0 1.5 1.5 1.5 1.5 2.2 2.2 2.2 2.2 3.3 3.3 3.3 3.3 4.7 4.7 4.7 6.8 6.8 6.8 10.0 10.0 10.0 10.0 15.0 15.0 15.0 22.0 22.0 22.0 33.0 33.0 33.0 47.0 47.0 68.0 Case Size A AL XL A AL XL A AL XL A AL XL A AL B BL XL A AL B BL A AL B BL A B BL C A B BL C B C CL D B C D C D DL C D DL H C D DL D DL H D H Z H Z Z Nemco Part No. PCT.1 PCT.1 PCT.1 PCT.15 PCT.15 PCT.15 PCT.22 PCT.22 PCT.22 PCT.33 PCT.33 PCT.33 PCT.47 PCT.47 PCT.47 PCT.47 PCT.47 PCT.68 PCT.68 PCT.68 PCT.68 PCT1 PCT1 PCT1 PCT1 PCT1.5 PCT1.5 PCT1.5 PCT1.5 PCT2.2 PCT2.2 PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT10 PCT10 PCT15 PCT15 PCT15 PCT22 PCT22 PCT22 PCT33 PCT33 PCT33 PCT47 PCT47 PCT68 / 35A _ / 35AL _ / 35XL _ / 35A _ / 35AL _ / 35XL _ / 35A _ / 35AL _ / 35XL _ / 35A _ / 35AL _ / 35XL _ / 35A _ / 35AL _ / 35B _ / 35BL _ / 35XL _ / 35A _ / 35AL _ / 35B _ / 35BL _ / 35A _ / 35AL _ / 35B _ / 35BL _ / 35A _ / 35B _ / 35BL _ / 35C _ / 35A _ / 35B _ / 35BL _ / 35C _ / 35B _ / 35C _ / 35CL _ / 35D _ / 35B _ / 35C _ / 35D _ / 35C _ / 35D _ / 35DL _ / 35C _ / 35D _ / 35DL _ / 35H _ / 35C _ / 35D _ / 35DL _ / 35D _ / 35DL _ / 35H _ / 35D _ / 35H _ / 35Z _ / 35H _ / 35Z _ / 35Z _ 50 V DC @ 85°C (23 V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.8 0.8 0.8 0.8 1.2 1.2 1.2 1.2 1.2 1.6 1.6 2.4 2.4 2.3 3.5 3.5 3.5 3.5 5.3 5.3 5.3 7.7 7.7 7.7 11.6 11.6 11.6 16.5 16.5 23.8 tan δ max. (%) 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 ESR @ 100kHz max. (Ω) 24.0 24.0 29.0 21.0 21.0 24.0 18.0 18.0 21.0 15.0 15.0 17.0 12.0 12.0 10.0 10.0 15.0 8.0 8.0 8.0 8.0 7.5 7.5 6.5 6.5 7.5 5.2 5.2 4.5 4.5 4.2 4.2 3.5 3.5 2.5 1.6 2.5 3.1 2.2 1.5 1.8 1.3 0.9 1.6 1.0 1.0 0.9 1.4 0.9 0.6 0.9 0.5 0.5 0.9 0.9 0.5 0.9 0.4 0.5 Capacitance (μF) 0.10 0.10 0.15 0.15 0.15 0.22 0.22 0.22 0.33 0.33 0.33 0.47 0.47 0.47 0.47 0.47 0.68 0.68 0.68 1.0 1.0 1.0 1.0 1.5 1.5 1.5 2.2 2.2 2.2 3.3 3.3 3.3 4.7 4.7 4.7 6.8 6.8 6.8 10.0 10.0 15.0 15.0 22.0 Case Size A AL A AL B A AL B B AL BL A AL B BL C A B C A B C CL B C D B C D C D DL C D DL C D DL D H D H Z Nemco Part No. PCT.1 PCT.1 PCT.15 PCT.15 PCT.15 PCT.22 PCT.22 PCT.22 PCT.33 PCT.33 PCT.33 PCT.47 PCT.47 PCT.47 PCT.47 PCT.47 PCT.68 PCT.68 PCT.68 PCT1 PCT1 PCT1 PCT1 PCT1.5 PCT1.5 PCT1.5 PCT2.2 PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT15 PCT15 PCT22 / 50A _ / 50AL _ / 50A _ / 50AL _ / 50B _ / 50A _ / 50AL _ / 50B _ / 50B _ / 50AL _ / 50BL _ / 50A _ / 50AL _ / 50B _ / 50BL _ / 50C _ / 50A _ / 50B _ / 50C _ / 50A _ / 50B _ / 50C _ / 50CL _ / 50B _ / 50C _ / 50D _ / 50B _ / 50C _ / 50D _ / 50C _ / 50D _ / 50DL _ / 50C _ / 50D _ / 50DL _ / 50C _ / 50D _ / 50DL _ / 50D _ / 50H _ / 50D _ / 50H _ / 50Z _ (33 V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.7 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.8 0.8 0.8 1.1 1.1 1.1 1.6 1.7 1.7 0.5 2.4 2.4 3.4 3.4 3.4 5.0 5.0 7.5 7.5 11.0 tan δ max. (%) 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 6 8 6 6 8 8 6 6 6 4 4 6 6 6 6 6 6 6 4 6 8 ESR @ 100kHz max. (Ω) 22.0 19.0 15.0 16.0 17.0 18.0 13.0 14.0 12.0 11.0 11.0 9.5 9.5 9.5 9.5 8.0 7.9 8.0 7.0 6.6 7.0 5.5 4.4 5.4 4.5 4.0 4.5 2.5 2.5 2.5 2.0 1.7 1.4 1.4 1.2 1.0 1.0 0.9 0.8 1.0 0.6 0.6 0.6 _ Insert tolerance M(±20%) or K(±10%) to complete the Nemco part number NEMCO reserves the right to supply a higher voltage rating, tighter tolerance and/or lower ESR in the same case size, to the same reliability standards. 142 Technology Dr., Suite 150 Irvine, CA 92618 www.suntsu.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE REV. 10/19/20 Telephone • 949.783.7300 Facsimile • 949.783.7301 PCT SERIES STANDARD AND EXTENDED RANGE TANTALUM CAPACITORS PACKAGING REFERENCE CASE SIZE NEMCO A B C D H Z Low Profile Sizes XL AL BL CL DL 142 Technology Dr., Suite 150 Irvine, CA 92618 CASE SIZE STANDARD PACKAGING AVAILABLE EIA IECQ 7” Reel Quantity 3216-18 3528-21 6032-28 7343-31 7343-43 7361-37 2000 2000 500 500 400 400 8000 8000 3000 2500 1500 1500 2012-12 3216-12 3528-12 6032-15 7343-20 2500 2500 2500 1000 1000 10000 10000 10000 5000 5000 www.suntsu.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE REV. 10/19/20 13” Reel Quantity Telephone • 949.783.7300 Facsimile • 949.783.7301
PCT1/4AK
物料型号:PCT系列标准和扩展范围的钽电容
器件简介: - 这些是表面贴装(SMT)钽电容,符合EIA 535 BAAC和IECQ标准。 - 电容范围从0.1μF到1500μF,电压范围从4VDC到50VDC。 - 提供了不同尺寸和电压等级的选项,包括低轮廓尺寸。
引脚分配: - 钽电容通常有两个引脚,一个用于正极,一个用于负极。
参数特性: - 电容公差有10%(K)和20%(M)两种。 - 工作温度范围为-55°C至+125°C。 - 封装材料满足UL 94 V0的阻燃等级。 - 湿度敏感度等级(MSL)为IPC/Jedec J-STD020B的1级。
功能详解: - 钽电容以其小尺寸、大电容和低等效串联电阻(ESR)而广泛应用于电源滤波、信号耦合等。
应用信息: - 适用于需要高可靠性和稳定性的应用,如军事、医疗、工业和汽车电子。
封装信息: - 提供多种封装尺寸,包括标准尺寸和低轮廓尺寸,以适应不同的电路板设计需求。
其他信息: - 钽电容在焊接时需要特别注意,以避免内部结构温度超过+220°C。 - 标记方式包括激光标记和清晰的极性标识。
PCT1/4AK 价格&库存
很抱歉,暂时无法提供与“PCT1/4AK”相匹配的价格&库存,您可以联系我们找货
