PTMIC476YT070
PTMIC476YT070
    CAL-CHIP
    Y7343-20
    钽电容 47μF ±20% 16V
PTMIC476YT070 数据手册
CONDUCTIVE POLYMER SOLID ELECTROLYTIC CHIP CAPACITORS - PT SERIES FEATURES - Conductive Polymer Electrode - Benign Failure Mode Under Recommended Use Conditions - Lower ESR - 3x Reflow 260°C Compatible - 100% Surge Current Tested - CV Range: 0.47-470μF / 2.5-125V - 14 Case Sizes Available APPLICATIONS MARKINGS - Smart Phone, Tablets, Notebook, LCD TV, Power Supplies - A, B, C, D, E, H, K, S, T, U, W, X, Y, 5 CASE POLYMER LOGO CAPACITANCE VALUE IN pF 476 = 47uF TECHNICAL SPECIFICATIONS RATED VOLTAGE E=25 V POLARITY BAND (ANODE+) (see page 2 for table) TECHNICAL DATA All thechnical data relate to an ambient temperature of +25°C CAPACITANCE TOLERANCE ±20% LEAKAGE CURRENT DCL 0.1 CV RESISTANCE TO SOLDERING HEAT ID CODE CASE DIMENSTIONS millimeters (inches) CODE EIA CODE EIA METRIC "L±0.20 (0.008)" "W+0.20 (0.008) –0.10 (0.004)" "H+0.20 (0.008) –0.10 (0.004)" "W1 ±0.20 (0.008)" "A+0.30 (0.012) –0.20 (0.008)" S Min. A 1206 3216-18 3.20 (0.126) 1.60 (0.063) 1.60 (0.063) 1.20 (0.047) 0.80 (0.031) 1.10 (0.043) L W H A S W1 A B 1210 3528-21 3.50 (0.138) 2.80 (0.110) 1.90 (0.075) 2.20 (0.087) 0.80 (0.031) 1.40 (0.055) C 2312 6032-28 6.00 (0.236) 3.20 (0.126) 2.60 (0.102) 2.20 (0.087) 1.30 (0.051) 2.90 (0.114) D 2917 7343-31 7.30 (0.287) 4.30 (0.169) 2.90 (0.114) 2.40 (0.094) 1.30 (0.051) 4.40 (0.173) E 2917 7343-43 7.30 (0.287) 4.30 (0.169) 4.10 (0.162) 2.40 (0.094) 1.30 (0.051) 4.40 (0.173) H 1210 3528-15 3.50 (0.138) 2.80 (0.110) 1.50 (0.059) max 2.20 (0.087) 0.80 (0.031) 1.40 (0.055) K 1206 3216-10 3.20 (0.126) 1.60 (0.063) 1.00 (0.039) max 1.20 (0.047) 0.80 (0.031) 1.10 (0.043) S 1206 3216-12 3.20 (0.126) 1.60 (0.063) 1.20 (0.047) max 1.20 (0.047) 0.80 (0.031) 1.10 (0.043) T 1210 3528-12 3.50 (0.138) 2.80 (0.110) 1.20 (0.047) max 2.20 (0.087) 0.80 (0.031) 1.40 (0.055) U 2924 7361-43 7.30 (0.287) 6.10 (0.240) 4.10 (0.162) 3.10 (0.122) 1.30 (0.051) 4.40 (0.173) W 2312 6032-15 6.00 (0.236) 3.20 (0.126) 1.50 (0.059) max 2.20 (0.087) 1.30 (0.051) 2.90 (0.114) X 2917 7343-15 7.30 (0.287) 4.30 (0.169) 1.50 (0.059) max 2.40 (0.094) 1.30 (0.051) 4.40 (0.173) Y 2917 7343-20 7.30 (0.287) 4.30 (0.169) 2.00 (0.079) max 2.40 (0.094) 1.30 (0.051) 4.40 (0.173) 5 2917 7343-40 7.30 (0.287) 4.30 (0.169) 3.80 (0.150) 2.40 (0.094) 1.30 (0.051) 4.40 (0.173 W1 dimensions applies to the termination width for A dimensional area only PART NUMBERING PT M OJ 226 A T 045 PRODUCT TYPE TOLERANCE RATED VOLTAGE CAPACITANCE CASE SIZE TERMINATION FINISH ESR CODE T: 100% Matte Tin Sn) plated Three digits specify ESR in mΩ (045 = 45 mΩ) M = ±20% OE: 2.5V OG: 4V OJ: 6.3V IA: 10V IC: 16V ID: 20V IE: 25V IV: 35V IX: 50V 1J: 63V 1P: 75V 2A: 100V 2B: 125V Two significant digits followed by no. of zeros And R in place of decimal point. A B C D E H K S T U W X Y 5 *NOTE: Conductive Polymer Capacitors are designed to operate within the limits of the environmental conditions specified for each series. If operated continuously at their maximum temperature and / or humidity limit, or beyond these limits, capacitors may exhibit a parametric shift in capacitance and increases in ESR. These changes may occur earlier if the specified environmental conditions are exceeded. Similarly, their normal operational time period will be significantly extended if their general duty cycle includes operation below maximum temperature within humidity controlled environments. Careful attention should be paid to maximum temperature with associated high humidity environments as well as voltage derating, ripple current and current surges. 1 CAPACITANCE AND RATED VOLTAGE RANGE - Letter denotes case size CAP RATED VOLTAGE DC (VR) TO 85°C 2.5V (e) 4V (G) 6.3V (J) 10V (A) 16V (C) 20V (D) 25V (E) 35V (V) 50V (T) 63V (J) 75V (P) UF CODE 0.47 474 0.68 684 B(400) B(300) 1 105 B(300) B(300) C(300) 1.5 155 B(200) B(300) C(300) C(300) 2.2 225 B(200) B(300) C(300) C(200) 335 A(500) B(200) B(300) C(200) C(200) A(500) B(100,150) B(150,200) C(200) C(200) X(250) Y(250)" C(200) D(120) D(150) A(150) B(90,150) T(100,150) C(200) C(200) D(120) D(120) E(100,150) D(120) 3.3 4.7 475 6.8 685 10 106 15 156 22 100V (A) 125 (B) B(400) K(300,500) A(200) A(300) A(200,300) A(200) B(100,200) T(100,150,200) A(150) B(150) A(150) B(90,100,150) B(200) C(200) Y(70) D(90,120) E(70,100) E(100,150) A(300) A(300) A(200) B(90,150) B(150) B(100,150) Y(90) B(200) C(200) D(70,100) Y(70,100) D(150) E(70,100) E(150) 226 A(300) A(300), B(70), K(400) S(400),T(150) B(70,300) T(70,150) A(300) B(70,150) B(90,150) X(100) Y(70) B(100,150) C(100) D(60,100) X(100), Y(70) D(70,100) Y(150) D(90), E(75), E(150) 33 336 A(300) A(200) B(70,200) T(150) B(70,200) C(100), T(70,150) A(200),B(150) H(150) Y(45,60,70) X(100) Y(70) D(60,100) X(70,100) Y(60,70,100) D(70,100) E(55,70) U(70) Y(100) 47 476 A(200) T(80)" A(70,100,200) B(55,70) T(55,70,80,120) B(70) C(100), H(100) D(45,70), H(150) X(45,70) Y(45,70) D(55), X(55,70) Y(70) D(60,100) E(50) Y(100)" E(55) U(70) Y(100) 68 686 A(250) A(250), B(70) T(80) B(55,70) C(55,100), H(100) T(200), W(70) D(45,55) Y(45,55) D(50) Y(50) D(55) E(45) Y(50) "D(70) E(50) Y(100) 100 107 A(200) B(55,70) A(200), B(40,70) T(70,150) A(100,150) B(40,45,55,70) C(70,100) T(200), W(70) D(18,25,45,55,80) Y(18,25,45,55) D(50) E(40) Y(50) C(70) D(55) E(45) Y(55) D(55,70) E(80) U(70) 150 157 B(70) B(70) D(15) Y(15,25,45) B(35,45,55,70) D(12,15,25,40) H(70,200),W(70) Y(15,25,40) D(25,40,45,55) Y(25,40,45,55) C(70) D(40,50,70) E(25,40) Y(40,50,70) 220 227 B(35,45,70) B(35,45,60,70) D(12,15,25,40) Y(15,25,40) B(70,200) D(12,15,25,35,40,50) H(170) Y(15,18,25,35,40,50) D(15,25,40,50) Y(15,25,40,50) D(35,50) E(50) 330 337 B(35,45,70,Y) (25,40) D(15,25,40,50) Y(15,25,40,50) D(12,15,18,25,40,50) Y(15,25,40,50) D(25) 5(35,100) E(35, 50,70) 5(100) 470 477 D(12,15,25,40,50) Y(15,25,40,50) D(12,15,25,40,50) Y(15,25,40,50) D(25,45) X(35,50,100) U(70) D(250) D(250) U(100) U(70) 5(100) - Released ratings, (ESR ratings in mOhms in parentheses) - Engineering samples - please contact Cal-Chip Electronics. - Note: Voltage ratings are minimum values. Cal-Chip Electronics reserves the right to supply higher voltage ratings in the same case size, to the same reliability standards. 2 RATINGS & PART NUMBER REFERENCE PART NUMBER CASE SIZE CAP. (μF) RATED VOLTAGE (V) MAX OPERATING TEMP. (C) DCL MAX (UA) DF MAX (%) ESR MAX. @100kHz (m Ω) 100KHZ RMS CURRENT (mA) 45°C 85°C 105°C 125°C PRODUCT CATEGORY MSL 2.5 Volt @ 85°C PTMOB686AT250 PTMOB107AT200 PTMOB107BT055 PTMOB107BT070 PTMOB157BT070 A A B B B 68 100 100 100 150 2.5 2.5 2.5 2.5 2.5 105 105 125 125 105 17 25 25 25 37.5 6 6 6 6 6 250 200 55 70 70 600 700 1500 1300 1300 400 500 1100 900 900 300 300 700 600 600 – – 400 300 – 3 3 0 1 3 3 3 3 3 3 PTMOB227BT035 PTMOB227BT045 PTMOB227BT070 PTMOB337BT035 PTMOB337BT045 B B B B B 220 220 220 330 330 2.5 2.5 2.5 2.5 2.5 105 105 105 105 105 55 55 55 82.5 82.5 8 8 8 8 8 35 45 70 35 45 1900 1700 1300 1900 1700 1300 1200 900 1300 1200 900 800 600 900 800 – – – – – 3 3 3 3 3 3 3 3 3 3 PTMOB337BT070 PTMOB337YT025 PTMOB337YT040 PTMOB477DT012 PTMOB477DT015 B Y Y D D 330 330 330 470 470 2.5 2.5 2.5 2.5 2.5 105 105 105 105 105 82.5 82.5 82.5 117.5 117.5 8 6 6 6 6 70 25 40 12 15 1300 2700 2200 4300 3900 900 1900 1500 3000 2700 600 1200 1000 1900 1800 – – – – – 3 2 3 2 2 3 3 3 3 3 PTMOB477DT025 PTMOB477DT040 PTMOB477DT050 PTMOB477YT015 PTMOB477YT025 D D D Y Y 470 470 470 470 470 2.5 2.5 2.5 2.5 2.5 105 105 105 85 105 117.5 117.5 117.5 117.5 117.5 6 6 6 6 6 25 40 50 15 25 3000 2400 2100 3500 2700 2100 1700 1500 2500 1900 1400 1100 900 – 1200 – – – – – 2 3 3 5 3 3 3 3 3 3 PTMOB477YT040 PTMOB477YT050 Y Y 470 470 2.5 2.5 105 105 117.5 117.5 6 6 40 50 2200 1900 1500 1300 1000 900 – – 3 3 3 3 4 VOLT @ 85°C PTMOJ156AT300 PTMOJ226AT300 PTMOJ336AT300 PTMOJ476AT200 PTMOJ476TT080 A A A A T 15 22 33 47 47 4 4 4 4 4 125 125 125 105 105 6 8.8 13.2 18.8 18.8 6 6 6 6 8 300 300 300 200 80 600 600 600 700 1100 400 400 400 500 800 300 300 300 300 500 200 200 200 – – 1 1 1 3 3 3 3 3 3 3 PTMOJ686AT250 PTMOJ686BT070 PTMOJ686TT080 PTMOJ107AT200 PTMOJ107BT040 A B T A B 68 68 68 100 100 4 4 4 4 4 105 125 105 105 105 27.2 27.2 27.2 40 40 6 6 8 6 8 250 70 80 200 40 600 1300 1100 700 1800 400 900 800 500 1300 300 600 500 300 800 – 300 – – – 3 1 3 3 3 3 3 3 3 3 PTMOJ107BT070 PTMOJ107TT070 PTMOJ107TT150 PTMOJ157BT070 PTMOJ157DT015 B T T B D 100 100 100 150 150 4 4 4 4 4 125 105 105 105 105 40 40 40 60 60 8 8 8 6 6 70 70 150 70 15 1300 1200 800 1300 3900 900 800 600 900 2700 600 500 400 600 1800 300 – – – – 0 3 3 3 2 3 3 3 3 3 PTMOJ157YT015 PTMOJ157YT025 PTMOJ157YT045 PTMOJ227BT035 PTMOJ227BT045 Y Y Y B B 150 150 150 220 220 4 4 4 4 4 105 105 105 105 105 60 60 60 88 88 6 6 6 10 10 15 25 45 35 45 3500 2700 2000 1900 1700 2500 1900 1400 1300 1200 1600 1200 900 900 800 – – – – – 2 2 3 3 3 3 3 3 3 3 PTMOJ227BT060 PTMOJ227BT070 PTMOJ227DT012 PTMOJ227DT015 PTMOJ227DT025 B B D D D 220 220 220 220 220 4 4 4 4 4 105 105 105 105 105 88 88 88 88 88 10 10 6 6 6 60 70 12 15 25 1400 1300 4300 3900 3000 1000 900 3000 2700 2100 600 600 1900 1800 1400 – – – – – 3 3 2 2 2 3 3 3 3 3 PTMOJ227DT040 PTMOJ227YT015 PTMOJ227YT025 PTMOJ227YT040 PTMOJ337DT015 D Y Y Y D 220 220 220 220 330 4 4 4 4 4 105 105 105 105 105 88 88 88 88 132 6 6 6 6 6 40 15 25 40 15 2400 3500 2700 2200 3900 1700 2500 1900 1500 2700 1100 1600 1200 1000 1800 – – – – – 2 2 2 3 2 3 3 3 3 3 PTMOJ337DT025 PTMOJ337DT040 PTMOJ337DT050 PTMOJ337YT015 PTMOJ337YT025 D D D Y Y 330 330 330 330 330 4 4 4 4 4 105 105 105 85 105 132 132 132 132 132 6 6 6 6 6 25 40 50 15 25 3000 2400 2100 3500 2700 2100 1700 1500 2500 1900 1400 1100 900 – 1200 – – – – – 2 3 3 5 3 3 3 3 3 3 PTMOJ337YT040 PTMOJ337YT050 PTMOJ477DT012 PTMOJ477DT015 PTMOJ477DT025 Y Y D D D 330 330 470 470 470 4 4 4 4 4 105 105 105 105 105 132 132 188 188 188 6 6 6 6 6 40 50 12 15 25 2200 1900 4300 3900 3000 1500 1300 3000 2700 2100 1000 900 1900 1800 1400 – – – – – 3 3 2 2 2 3 3 3 3 3 PTMOJ477DT040 PTMOJ477DT050 PTMOJ477YT015 PTMOJ477YT025 PTMOJ477YT040 PTMOJ477YT050 D D Y Y Y Y 470 470 470 470 470 470 4 4 4 4 4 4 105 105 85 105 105 105 188 188 188 188 188 188 6 6 6 6 6 6 40 50 15 25 40 50 2400 2100 3500 2700 2200 1900 1700 1500 2500 1900 1500 1300 1100 900 – 1200 1000 900 – – – – – 2 2 5 3 3 3 3 3 3 3 3 3 3 RATINGS & PART NUMBER REFERENCE PART NUMBER CASE SIZE CAP. (μF) RATED VOLTAGE (V) MAX OPERATING TEMP. (C) DCL MAX (UA) DF MAX (%) ESR MAX. @100kHz (m Ω) 100KHZ RMS CURRENT (mA) 45°C 85°C 105°C 125°C PRODUCT CATEGORY MSL 6.3 Volt @ 85°C 4 PTMOJ106AT300 PTMOJ156AT300 PTMOJ226AT300 PTMOJ226BT070 PTMOJ226KT400 A A A B K 10 15 22 22 22 6.3 6.3 6.3 6.3 6.3 125 125 125 125 105 6 9 13.2 13.2 13.2 6 6 6 6 8 300 300 300 70 400 600 600 600 1300 500 400 400 400 900 400 300 300 300 600 200 200 200 200 300 – 1 1 1 0 3 3 3 3 3 3 PTMOJ226ST400 PTMOJ226TT150 PTMOJ336AT200 PTMOJ336BT070 PTMOJ336BT200 S T A B B 22 22 33 33 33 6.3 6.3 6.3 6.3 6.3 105 105 105 125 125 13.2 13.2 19.8 19.8 19.8 8 6 6 6 6 400 150 200 70 200 500 800 700 1300 800 400 600 500 900 600 200 400 300 600 400 – – – 300 200 3 3 3 0 0 3 3 3 3 3 PTMOJ336TT150 PTMOJ476AT070 PTMOJ476AT100 PTMOJ476AT200 PTMOJ476BT055 T A A A B 33 47 47 47 47 6.3 6.3 6.3 6.3 6.3 105 105 105 105 105 19.8 28.2 28.2 28.2 28.2 8 6 6 6 6 150 70 100 200 55 800 1200 1000 700 1500 600 800 700 500 1100 400 500 500 300 700 – – – – – 3 3 3 3 2 3 3 3 3 3 PTMOJ476BT070 PTMOJ476TT055 PTMOJ476TT070 PTMOJ476TT080 PTMOJ476TT120 B T T T T 47 47 47 47 47 6.3 6.3 6.3 6.3 6.3 125 105 105 105 105 28.2 28.2 28.2 28.2 28.2 6 8 8 8 8 70 55 70 80 120 1300 1300 1200 1100 900 900 900 800 800 600 600 600 500 500 400 300 – – – – 1 3 3 3 3 3 3 3 3 3 PTMOJ686BT055 PTMOJ686BT070 PTMOJ686CT055 PTMOJ686CT100 PTMOJ686HT100 B B C C H 68 68 68 68 68 6.3 6.3 6.3 6.3 6.3 125 125 125 125 105 40.8 40.8 40.8 40.8 40.8 8 8 6 6 6 55 70 55 100 100 1500 1300 1800 1300 1000 1100 900 1300 900 700 700 600 800 600 500 400 300 500 300 – 1 1 1 1 3 3 3 3 3 3 PTMOJ686TT200 PTMOJ686WT070 PTMOJ107AT100 PTMOJ107AT150 PTMOJ107BT040 T W A A B 68 68 100 100 100 6.3 6.3 6.3 6.3 6.3 105 125 105 105 105 40.8 40.8 60 60 60 8 8 10 10 10 200 70 100 150 40 700 1400 1000 800 1800 500 1000 700 600 1300 300 600 500 400 800 – 400 – – – 3 1 3 3 3 3 3 3 3 3 PTMOJ107BT045 PTMOJ107BT055 PTMOJ107BT070 PTMOJ107CT070 PTMOJ107CT100 B B B C C 100 100 100 100 100 6.3 6.3 6.3 6.3 6.3 105 105 105 105 105 60 60 60 60 60 10 10 10 6 6 45 55 70 70 100 1700 1500 1300 1600 1300 1200 1100 900 1100 900 800 700 600 700 600 – – – – – 3 3 3 3 3 3 3 3 3 3 PTMOJ107TT200 PTMOJ107WT070 PTMOJ157BT035 PTMOJ157BT045 PTMOJ157BT055 T W B B B 100 100 150 150 150 6.3 6.3 6.3 6.3 6.3 105 105 105 105 105 60 ` \\\ 90 90 90 10 6 10 10 10 200 70 35 45 55 700 1400 1900 1700 1500 500 1000 1300 1200 1100 300 600 900 800 700 – – – – – 3 3 3 3 3 3 3 3 3 3 PTMOJ157BT070 PTMOJ157DT012 PTMOJ157DT015 PTMOJ157DT025 PTMOJ157DT040 B D D D D 150 150 150 150 150 6.3 6.3 6.3 6.3 6.3 105 105 105 105 105 90 90 90 90 90 10 6 6 6 6 70 12 15 25 40 1300 4300 3900 3000 2400 900 3000 2700 2100 1700 600 1900 1800 1400 1100 – – – – – 3 2 2 2 2 3 3 3 3 3 PTMOJ157HT070 PTMOJ157HT200 PTMOJ157WT070 PTMOJ157YT015 PTMOJ157YT025 H H W Y Y 150 150 150 150 150 6.3 6.3 6.3 6.3 6.3 105 105 105 105 105 90 90 90 90 90 6 6 6 6 6 70 200 70 15 25 1200 700 1400 3500 2700 800 500 1000 2500 1900 500 300 600 1600 1200 – – – – – 3 3 3 2 2 3 3 3 3 3 PTMOJ157YT040 PTMOJ227BT070 PTMOJ227BT200 PTMOJ227DT012 PTMOJ227DT015 Y B B D D 150 220 220 220 220 6.3 6.3 6.3 6.3 6.3 105 105 105 105 105 90 132 132 132 132 6 10 10 6 6 40 70 200 12 15 2200 1300 800 4300 3900 1500 900 600 3000 2700 1000 600 400 1900 1800 – – – – – 3 3 3 2 2 3 3 3 3 3 PTMOJ227DT025 PTMOJ227DT035 PTMOJ227DT040 PTMOJ227DT050 PTMOJ227HT170 D D D D H 220 220 220 220 220 6.3 6.3 6.3 6.3 6.3 105 105 105 105 105 132 132 132 132 132 6 6 6 6 10 25 35 40 50 170 3000 2500 2400 2100 800 2100 1800 1700 1500 600 1400 1100 1100 900 400 – – – – – 2 3 3 3 3 3 3 3 3 3 PTMOJ227YT015 PTMOJ227YT018 PTMOJ227YT025 PTMOJ227YT035 PTMOJ227YT040 Y Y Y Y Y 220 220 220 220 220 6.3 6.3 6.3 6.3 6.3 85 105 105 105 105 132 132 132 132 132 6 6 6 6 6 15 18 25 35 40 3500 3200 2700 2300 2200 2500 2200 1900 1600 1500 – 1400 1200 1000 1000 – – – – – 5 3 2 2 2 3 3 3 3 3 PTMOJ227YT050 PTMOJ337DT012 PTMOJ337DT015 PTMOJ337DT018 PTMOJ337DT025 Y D D D D 220 330 330 330 330 6.3 6.3 6.3 6.3 6.3 105 105 105 105 105 132 198 198 198 198 6 6 6 6 6 50 12 15 18 25 1900 4300 3900 3500 3000 1300 3000 2700 2500 2100 900 1900 1800 1600 1400 – – – – – 2 3 3 3 3 3 3 3 3 3 RATINGS & PART NUMBER REFERENCE PART NUMBER CASE SIZE CAP. (μF) RATED VOLTAGE (V) MAX OPERATING TEMP. (C) DCL MAX (UA) DF MAX (%) ESR MAX. @100kHz (m Ω) 100KHZ RMS CURRENT (mA) 45°C 85°C 105°C 125°C PRODUCT CATEGORY MSL 6.3 Volt @ 85°C PTMOJ337DT040 PTMOJ337DT050 PTMOJ337YT015 PTMOJ337YT025 PTMOJ337YT040 D D Y Y Y 330 330 330 330 330 6.3 6.3 6.3 6.3 6.3 105 105 85 105 105 198 198 198 198 198 6 6 12 10 12 40 50 15 25 40 2400 2100 3500 2700 2200 1700 1500 2500 1900 1500 1100 900 – 1200 1000 – – – – – 2 2 5 3 3 3 3 3 3 3 PTMOJ337YT050 PTMOJ477DT025 PTMOJ477DT045 PTMOJ477XT035 PTMOJ477XT050 PTMOJ477XT100 Y D D X X X 330 470 470 470 470 470 6.3 6.3 6.3 6.3 6.3 105 105 105 105 105 105 198 282 282 282 282 282 12 6 6 6 6 6 50 25 45 35 50 100 1900 3000 2200 2200 1900 1300 1300 2100 1500 1500 1300 900 900 1400 1000 1000 900 600 – – – – – – 3 2 2 3 3 3 3 3 3 3 3 3 10 Volt @ 85°C PTMIA475KT300 PTMIA475KT500 PTMIA106AT200 PTMIA106AT300 PTMIA156AT200 K K A A A 4.7 4.7 10 10 15 10 10 10 10 10 105 105 125 125 125 4.7 4.7 10 10 15 6 6 6 6 6 300 500 200 300 200 500 400 700 600 700 400 300 500 400 500 200 200 300 300 300 – – 200 200 200 3 3 1 1 1 3 3 3 3 3 PTMIA226BT070 PTMIA226BT300 PTMIA226TT070 PTMIA226TT150 PTMIA336BT070 B B T T B 22 22 22 22 33 10 10 10 10 10 125 125 105 105 125 22 22 22 22 33 6 6 6 6 6 70 300 70 150 70 1300 600 1200 800 1300 900 400 800 600 900 600 300 500 400 600 300 200 – – 300 0 0 3 3 0 3 3 3 3 3 PTMIA336BT200 PTMIA336CT100 PTMIA336TT070 PTMIA336TT150 PTMIA476BT070 B C T T B 33 33 33 33 47 10 10 10 10 10 125 125 105 105 105 33 33 33 33 47 6 6 6 6 6 200 100 70 150 70 800 1300 1200 800 1300 600 900 800 600 900 400 600 500 400 600 200 300 – – – 0 1 3 3 3 3 3 3 3 3 PTMIA476CT100 PTMIA476HT100 PTMIA686DT045 PTMIA686DT055 PTMIA686YT045 C H D D Y 47 47 68 68 68 10 10 10 10 10 125 105 125 125 105 47 47 68 68 68 6 6 6 6 6 100 100 45 55 45 1300 1000 2200 2000 2000 900 700 1500 1400 1400 600 500 1000 900 900 300 – 600 500 – 1 3 0 0 3 3 3 3 3 3 PTMIA686YT055 PTMIA107DT018 PTMIA107DT025 PTMIA107DT045 PTMIA107DT055 Y D D D D 68 100 100 100 100 10 10 10 10 10 105 105 105 105 105 68 100 100 100 100 6 6 6 6 6 55 18 25 45 55 1800 3500 3000 2200 2000 1300 2500 2100 1500 1400 800 1600 1400 1000 900 – – – – – 3 2 2 3 3 3 3 3 3 3 PTMIA107DT080 PTMIA107YT018 PTMIA107YT025 PTMIA107YT045 PTMIA107YT055 D Y Y Y Y 100 100 100 100 100 10 10 10 10 10 105 105 105 105 105 100 100 100 100 100 6 6 6 6 6 80 18 25 45 55 1700 3200 2700 2000 1800 1200 2200 1900 1400 1300 800 1400 1200 900 800 – – – – – 3 2 2 3 3 3 3 3 3 3 PTMIA157DT025 PTMIA157DT040 PTMIA157DT045 PTMIA157DT055 PTMIA157YT025 D D D D Y 150 150 150 150 150 10 10 10 10 10 105 105 105 105 105 150 150 150 150 150 6 6 6 6 6 25 40 45 55 25 3000 2400 2200 2000 2700 2100 1700 1500 1400 1900 1400 1100 1000 900 1200 – – – – – 3 3 3 3 3 3 3 3 3 3 PTMIA157YT040 PTMIA157YT045 PTMIA157YT055 PTMIA227DT015 PTMIA227DT025 Y Y Y D D 150 150 150 220 220 10 10 10 10 10 105 105 105 105 105 150 150 150 220 220 6 6 6 6 6 40 45 55 15 25 2200 2000 1800 3900 3000 1500 1400 1300 2700 2100 1000 900 800 1800 1400 – – – – – 3 3 3 3 3 3 3 3 3 3 PTMIA227DT040 PTMIA227DT050 PTMIA227YT015 PTMIA227YT025 PTMIA227YT040 D D Y Y Y 220 220 220 220 220 10 10 10 10 10 105 105 85 105 105 220 220 220 220 220 6 6 6 6 6 40 50 15 25 40 2400 2100 3500 2700 2200 1700 1500 2500 1900 1500 1100 900 – 1200 1000 – – – – – 3 3 5 3 3 3 3 3 3 3 PTMIA227YT050 PTMIA337DT025 PTMIA3375T035 PTMIA3375T100 Y D 5 5 220 330 330 330 10 10 10 10 105 105 105 105 220 330 330 330 6 6 10 10 50 25 35 100 1900 3000 2600 1500 1300 2100 1800 1100 900 1400 1200 700 – – – – 3 2 2 2 3 3 3 3 200 200 100 200 100 700 700 1100 800 1000 500 500 800 600 700 300 300 500 400 500 200 200 300 200 300 1 1 1 1 1 3 3 3 3 3 16 Volt @ 85°C PTMIC685AT200 PTMIC106AT200 PTMIC106BT100 PTMIC106BT200 PTMIC106TT100 A A B B T 6.8 10 10 10 10 16 16 16 16 16 125 125 125 125 125 10.9 16 16 16 16 6 6 6 6 6 5 RATINGS & PART NUMBER REFERENCE PART NUMBER CASE SIZE CAP. (μF) RATED VOLTAGE (V) MAX OPERATING TEMP. (C) DCL MAX (UA) DF MAX (%) ESR MAX. @100kHz (m Ω) 100KHZ RMS CURRENT (mA) 45°C 85°C 105°C 125°C PRODUCT CATEGORY MSL 16 Volt @ 85°C PTMIC106TT150 PTMIC106TT200 PTMIC156BT090 PTMIC156BT150 PTMIC226AT300 T T B B A 10 10 15 15 22 16 16 16 16 16 125 125 125 125 105 16 16 24 24 35.2 6 6 6 6 10 150 200 90 150 300 800 700 1200 900 600 600 500 800 600 400 400 300 500 400 300 200 200 300 200 – 1 1 0 0 3 3 3 3 3 3 PTMIC226BT070 PTMIC226BT150 PTMIC336AT200 PTMIC336BT150 PTMIC336HT150 B B A B H 22 22 33 33 33 16 16 16 16 16 125 125 105 125 105 35.2 35.2 52.8 52.8 52.8 8 6 10 8 6 70 150 200 150 150 1300 900 700 900 800 900 600 500 600 600 600 400 300 400 400 300 200 – 200 – 0 0 3 0 3 3 3 3 3 3 PTMIC336YT045 PTMIC336YT060 PTMIC336YT070 PTMIC476DT045 PTMIC476DT070 Y Y Y D D 33 33 33 47 47 16 16 16 16 16 105 105 105 125 125 52.8 52.8 52.8 75.2 75.2 6 6 6 6 6 45 60 70 45 70 2000 1800 1600 2200 1800 1400 1300 1100 1500 1300 900 800 700 1000 800 – – – 600 500 2 2 2 0 0 3 3 3 3 3 PTMIC476HT150 PTMIC476XT045 PTMIC476XT070 PTMIC476YT045 PTMIC476YT070 H X X Y Y 47 47 47 47 47 16 16 16 16 16 105 105 105 105 105 75.2 75.2 75.2 75.2 75.2 6 6 6 6 6 150 45 70 45 70 800 2000 1600 2000 1600 600 1400 1100 1400 1100 400 900 700 900 700 – – – – – 3 2 2 2 2 3 3 3 3 3 PTMIC686DT050 PTMIC686YT050 PTMIC107DT050 PTMIC107ET040 PTMIC107YT050 D Y D E Y 68 68 100 100 100 16 16 16 16 16 105 105 105 105 105 108.8 108.8 160 160 160 6 6 6 6 6 50 50 50 40 50 2100 1900 2100 2500 1900 1500 1300 1500 1800 1300 900 900 900 1100 900 – – – – – 2 2 2 2 2 3 3 3 3 3 PTMIC157CT070 PTMIC157DT040 PTMIC157DT050 PTMIC157DT070 PTMIC157ET025 C D D D E 150 150 150 150 150 16 16 16 16 16 125 85 85 105 125 240 240 240 240 240 10 6 6 6 8 70 40 50 70 25 1600 2400 2100 1800 3200 1100 1700 1500 1300 2200 700 – – 800 1400 400 – – – 800 0 5 5 3 0 3 3 3 3 3 PTMIC157ET040 PTMIC157YT040 PTMIC157YT050 PTMIC157YT070 PTMIC227DT035 E Y Y Y D 150 150 150 150 220 16 16 16 16 16 125 105 105 105 105 240 240 240 240 352 10 6 6 6 10 40 40 50 70 35 2500 2200 1900 1600 2500 1800 1500 1300 1100 1800 1100 1000 900 700 1100 600 – – – – 0 3 3 3 2 3 3 3 3 3 PTMIC227DT050 PTMIC227ET050 PTMIC337ET035 PTMIC337ET050 PTMIC337ET070 D E E E E 220 220 330 330 330 16 16 16 16 16 105 125 105 105 105 352 352 528 528 528 10 10 10 10 10 50 50 35 50 70 2100 2200 2700 2200 1900 1500 1500 1900 1500 1300 900 1000 1200 1000 900 – 600 – – – 2 0 2 2 2 3 3 3 3 3 PTMIC3375T100 PTMIC4775T100 5 5 330 470 16 16 105 105 528 752 10 10 100 100 1500 1500 1100 1100 700 700 – – 2 3 3 3 PTMID106AT150 PTMID106BT150 PTMID156BT150 PTMID226BT090 PTMID226BT150 A B B B B 10 10 15 22 22 20 20 20 20 20 105 125 125 105 105 20 20 30 44 44 6 8 8 6 6 150 150 150 90 150 800 900 900 1200 900 600 600 600 800 600 400 400 400 500 400 – 200 200 – – 3 0 0 3 3 3 3 3 3 3 PTMID226XT100 PTMID226YT070 PTMID336XT100 PTMID336YT070 PTMID476DT055 X Y X Y D 22 22 33 33 47 20 20 20 20 20 105 105 105 105 105 44 44 66 66 94 8 6 6 6 6 100 70 100 70 55 1300 1600 1300 1600 2000 900 1100 900 1100 1400 600 700 600 700 900 – – – – – 2 2 2 2 2 3 3 3 3 3 PTMID476XT055 PTMID476XT070 PTMID476YT070 PTMID686DT055 PTMID686ET045 X X Y D E 47 47 47 68 68 20 20 20 20 20 105 105 125 105 105 94 94 94 136 136 6 6 6 6 6 55 70 70 55 45 1800 1600 1600 2000 2400 1300 1100 1100 1400 1700 800 700 700 900 1100 – – 400 – – 3 3 0 3 2 3 3 3 3 3 PTMID686YT050 PTMID107CT070 PTMID107DT055 PTMID107ET045 PTMID107YT055 PTMID227UT070 Y C D E Y U 68 100 100 100 100 220 20 20 20 20 20 20 105 125 105 125 105 105 136 200 200 200 200 440 6 10 6 10 6 12 50 70 55 45 55 70 1900 1600 2000 2400 1800 2300 1300 1100 1400 1700 1300 1600 900 700 900 1100 800 1000 – 400 – 600 – – 2 0 2 0 2 2 3 3 3 3 3 3 20 Volt @ 85°C 6 RATINGS & PART NUMBER REFERENCE PART NUMBER CASE SIZE CAP. (μF) RATED VOLTAGE (V) MAX OPERATING TEMP. (C) DCL MAX (UA) DF MAX (%) ESR MAX. @100kHz (m Ω) 100KHZ RMS CURRENT (mA) 45°C 85°C 105°C 125°C PRODUCT CATEGORY MSL 25 Volt @ 85°C PTMIE475AT500 PTMIE475BT100 PTMIE475BT150 PTMIE685AT150 PTMIE685BT090 A B B A B 4.7 4.7 4.7 6.8 6.8 25 25 25 25 25 125 105 105 105 105 11.8 11.8 11.8 17 17 6 6 6 6 6 500 100 150 150 90 400 1100 900 800 1200 300 800 600 600 800 200 500 400 400 500 100 – – – – 1 3 3 3 2 3 3 3 3 3 PTMIE685BT150 PTMIE685TT100 PTMIE685TT150 PTMIE106AT150 PTMIE106BT090 B T T A B 6.8 6.8 6.8 10 10 25 25 25 25 25 105 105 105 105 105 17 17 17 25 25 6 6 6 6 6 150 100 150 150 90 900 1000 800 800 1200 600 700 600 600 800 400 500 400 400 500 – – – – – 3 3 3 3 2 3 3 3 3 3 PTMIE106BT100 PTMIE106BT150 PTMIE156BT100 PTMIE156BT150 PTMIE156YT090 B B B B Y 10 10 15 15 15 25 25 25 25 25 105 105 105 105 105 25 25 37.5 37.5 37.5 6 6 6 6 6 100 150 100 150 90 1100 900 1400 900 1400 800 600 1400 600 1000 500 400 900 400 600 – – – – – 2 2 2 2 2 3 3 3 3 3 PTMIE226BT100 PTMIE226BT150 PTMIE226CT100 PTMIE226DT060 PTMIE226DT100 B B C D D 22 22 22 22 22 25 25 25 25 25 105 105 105 105 105 55 55 55 55 55 6 6 6 6 6 100 150 100 60 100 1100 900 1300 1900 1500 800 600 900 1300 1100 500 400 600 900 700 – – – – – 2 2 3 2 2 3 3 3 3 3 PTMIE226XT100 PTMIE226YT070 PTMIE336DT060 PTMIE336DT100 PTMIE336XT070 X Y D D X 22 22 33 33 33 25 25 25 25 25 105 105 105 105 105 55 55 82.5 82.5 82.5 8 6 6 6 6 100 70 60 100 70 1300 1600 1900 1500 1600 900 1100 1300 1100 1100 600 700 900 700 700 – – – – – 2 3 2 2 2 3 3 3 3 3 PTMIE336XT100 PTMIE336YT060 PTMIE336YT070 PTMIE336YT100 PTMIE476DT060 X Y Y Y D 33 33 33 33 47 25 25 25 25 25 105 105 105 105 105 82.5 82.5 82.5 82.5 117.5 6 6 6 6 6 100 60 70 100 60 1300 1800 1600 1400 1900 900 1300 1100 1000 1300 600 800 700 600 900 – – – – – 2 2 2 2 3 3 3 3 3 3 PTMIE476DT100 PTMIE476ET050 PTMIE476YT100 PTMIE686DT070 PTMIE686ET050 D E Y D E 47 47 47 68 68 25 25 25 25 25 105 105 105 105 105 117.5 117.5 117.5 170 170 6 6 6 6 6 100 50 100 70 50 1500 2200 1400 1800 2200 1100 1500 1000 1300 1500 700 1000 600 800 1000 – – – – – 3 3 3 2 3 3 3 3 3 3 PTMIE686YT100 PTMIE107DT055 PTMIE107DT070 PTMIE107ET080 PTMIE107UT070 PTMIE157UT070 Y D D E U U 68 100 100 100 100 150 25 25 25 25 25 25 105 105 105 105 125 105 170 250 250 250 250 375 6 6 6 6 12 12 100 55 70 80 70 70 1400 2000 1800 1800 2300 2300 1000 1400 1300 1300 1600 1600 600 900 800 800 1000 1000 – – – – 600 – 3 2 2 2 1 2 3 3 3 3 3 3 35 Volt @ 85°C PTMIV155BT200 PTMIV225BT200 PTMIV335AT500 PTMIV335BT200 PTMIV475BT200 B B A B B 1.5 2.2 3.3 3.3 4.7 35 35 35 35 35 105 105 125 105 105 5.3 7.7 11.6 11.6 16.5 6 6 6 6 6 200 200 500 200 200 800 800 400 800 800 600 600 300 600 600 400 400 200 400 400 – – 100 – – 2 3 1 3 3 3 3 3 3 3 PTMIV475CT200 PTMIV685CT200 PTMIV106BT200 PTMIV106CT200 PTMIV106YT070 C C B C Y 4.7 6.8 10 10 10 35 35 35 35 35 105 105 105 105 105 16.5 23.8 35 35 35 6 6 6 6 6 200 200 200 200 70 900 900 800 900 1600 600 600 600 600 1100 400 400 400 400 700 – – – – – 3 3 2 3 2 3 3 3 3 3 PTMIV156BT200 PTMIV156CT200 PTMIV156DT070 PTMIV156DT100 PTMIV156YT070 B C D D Y 15 15 15 15 15 35 35 35 35 35 105 105 105 105 105 52.5 52.5 52.5 52.5 52.5 6 6 6 6 6 200 200 70 100 70 800 900 1800 1500 1600 600 600 1300 1100 1100 400 400 800 700 700 – – – – – 2 3 3 3 3 3 3 3 3 3 PTMIV156YT100 PTMIV226DT070 PTMIV226DT100 PTMIV226YT150 PTMIV336DT070 Y D D Y D 15 22 22 22 33 35 35 35 35 35 105 105 105 105 105 52.5 77 77 77 115.5 6 6 6 6 6 100 70 100 150 70 1400 1800 1500 1100 1800 1000 1300 1100 800 1300 600 800 700 500 800 – – – – – 3 2 2 3 2 3 3 3 3 3 PTMIV336DT100 PTMIV336ET055 PTMIV336ET070 PTMIV336UT070 PTMIV336YT100 D E E U Y 33 33 33 33 33 35 35 35 35 35 105 105 105 125 105 115.5 115.5 115.5 115.5 115.5 6 6 6 12 6 100 55 70 70 100 1500 2100 1900 2300 1400 1100 1500 1300 1600 1000 700 900 900 1000 600 – – – 600 – 2 3 3 1 3 3 3 3 3 3 PTMIV476ET055 PTMIV476UT070 PTMIV476YT100 PTMIV157UT100 E U Y U 47 47 47 150 35 35 35 35 105 125 105 105 164.5 164.5 164.5 525 6 12 6 10 55 70 100 100 2100 2300 1400 1900 1500 1600 1000 1300 900 1000 600 900 – 600 – – 2 1 3 2 3 3 3 3 7 RATINGS & PART NUMBER REFERENCE PART NUMBER CASE SIZE CAP. (μF) RATED VOLTAGE (V) MAX OPERATING TEMP. (C) DCL MAX (UA) DF MAX (%) ESR MAX. @100kHz (m Ω) 100KHZ RMS CURRENT (mA) 45°C 85°C 105°C 125°C PRODUCT CATEGORY MSL 50 Volt @ 85°C PTMIX684BT400 PTMIX105BT300 PTMIX155BT300 PTMIX155CT300 PTMIX225BT300 B B B C B 0.68 1 1.5 1.5 2.2 50 50 50 50 50 105 105 105 105 125 3.4 5 7.5 7.5 11 6 6 6 6 8 400 300 300 300 300 600 600 600 800 600 400 400 400 600 400 300 300 300 400 300 – – – – 200 3 3 3 3 0 3 3 3 3 3 PTMIX225CT300 PTMIX335BT300 PTMIX335CT200 PTMIX475CT200 PTMIX475XT250 C B C C X 2.2 3.3 3.3 4.7 4.7 50 50 50 50 50 105 125 105 105 105 11 16.5 16.5 23.5 23.5 6 8 8 8 6 300 300 200 200 250 800 600 900 900 800 600 400 600 600 600 400 300 400 400 400 – 200 – – – 3 0 3 3 2 3 3 3 3 3 PTMIX475YT250 PTMIX685CT200 PTMIX685DT120 PTMIX106DT090 PTMIX106DT120 Y C D D D 4.7 6.8 6.8 10 10 50 50 50 50 50 105 105 105 105 105 23.5 34 34 50 50 6 8 10 10 10 250 200 120 90 120 900 900 1400 1600 1400 600 600 1000 1100 1000 400 400 600 700 600 – – – – – 2 3 3 3 3 3 3 3 3 3 PTMIX106ET070 PTMIX106ET100 PTMIX156DT150 PTMIX156ET070 PTMIX156ET100 E E D E E 10 10 15 15 15 50 50 50 50 50 105 105 125 105 105 50 50 75 75 75 6 6 8 6 6 70 100 150 70 100 1900 1600 1200 1900 1600 1300 1100 800 1300 1100 900 700 500 900 700 – – 300 – – 3 3 1 3 3 3 3 3 3 3 PTMIX226DT090 PTMIX226ET075 PTMIX226ET150 D E E 22 22 22 50 50 50 125 125 105 110 110 110 8 8 8 90 75 150 1600 1800 1300 1100 1300 900 700 800 600 400 500 – 1 1 2 3 3 3 PTMIJ474BT400 PTMIJ684BT300 PTMIJ105BT300 PTMIJ105CT300 PTMIJ155CT300 B B B C C 0.47 0.68 1 1 1.5 63 63 63 63 63 105 105 105 105 105 3 4.3 6.3 6.3 9.5 8 8 8 6 6 400 300 300 300 300 600 600 600 800 800 400 400 400 600 600 300 300 300 400 400 – – – – – 3 3 3 3 3 3 3 3 3 3 PTMIJ225CT200 PTMIJ335CT200 PTMIJ475CT200 PTMIJ475DT120 PTMIJ685DT120 C C C D D 2.2 3.3 4.7 4.7 6.8 63 63 63 63 63 105 105 105 105 105 13.9 20.8 29.6 29.6 42.8 6 6 6 6 6 200 200 200 120 120 900 900 900 1400 1400 600 600 600 1000 1000 400 400 400 600 600 – – – – – 3 3 3 3 3 3 3 3 3 3 PTMIJ685ET100 PTMIJ685ET150 PTMIJ106ET100 PTMIJ106ET150 PTMIJ156ET150 E E E E E 6.8 6.8 10 10 15 63 63 63 63 63 105 105 105 105 105 42.8 42.8 63 63 94.5 6 6 6 6 8 100 150 100 150 150 1600 1300 1600 1300 1300 1100 900 1100 900 900 700 600 700 600 600 – – – – – 3 3 3 3 2 3 3 3 3 3 PTM1J475DT150 PTM1J685DT120 D D 4.7 6.8 75 75 105 105 150 120 1200 1400 800 1000 500 600 – – 3 3 3 3 PTM2A475DT250 D 4.7 100 105 250 900 600 400 – 4 3 250 900 600 400 – 4 3 63 Volt @ 85°C 75 Volt @ 85°C 35.3 51 6 6 100 Volt @ 85°C 47 8 125 Volt @ 85°C PTM2B335DT250 8 D 3.3 125 105 41.2 8 RECOMMENDED DERATING FACTOR - Voltage and temperature derating as percentage of Vr RATED VOLTAGE RATED VOLTAGE RECOMMENDED APPLICATION VOLTAGE FOR Vr ≤ 10V RECOMMENDED APPLICATION VOLTAGE FOR Vr ≤ 10V RECOMMENDED APPLICATION VOLTAGE FOR Vr ≥ 16V RECOMMENDED APPLICATION VOLTAGE FOR Vr ≥ 16V -55°C 85°C 105°C 67% 67% 60% 60% 54% 54% 125°C -55°C 85°C PRODUCT CATEGORY 0 125°C PRODUCT CATEGORY 1 100% RATED VOLTAGE RATED VOLTAGE 90% RECOMMENDED APPLICATION VOLTAGE FOR Vr ≤ 10V RECOMMENDED APPLICATION VOLTAGE FOR Vr ≤ 10V 80% 80% RECOMMENDED APPLICATION VOLTAGE FOR Vr ≥ 16V RECOMMENDED APPLICATION VOLTAGE FOR Vr ≥ 16V 72% 64% -55°C 85°C 105°C PRODUCT CATEGORY 2 -55°C 85°C 105°C PRODUCT CATEGORY 3, 4 100% RATED VOLTAGE 90% RECOMMENDED APPLICATION VOLTAGE PRODUCT CATEGORY 5 FOR Vr ≤ 10V 80% RECOMMENDED APPLICATION VOLTAGE FOR Vr ≥ 16V -55°C 85°C PRODUCT CATEGORY 5 9 PRODUCT CATEGORY 0, 1 (TEMPERATURE RANGE -55°C TO +125°C) TEST CONIDTION ENDURANCE Apply rated voltage (Ur) at 85ºC (CATEGORY 1) or 105ºC (CATEGORY 0) or 2/3 rated voltage (Ur) at 125ºC (all CATEGORIES) for 2000 hours through a circuit impedance of ≤0.1Ω/V. Stabilize at room temperature for 1-2 hours before measuring. STORAGE LIFE HUMIDITY TEMPERATURE STABILITY SURGE VOLTAGE MECHANICAL SHOCK VIBRATION CHARACTERISTICS Store at 125ºC, no voltage applied, for 2000 hours. Stabilize at room temperature for 1-2 hours before measuring Store at 65ºC and 95% relative humidity fo 500 hours, with no applied voltage. Stabilize at room temperature and humidity for 1-2 hours before measuring. STEP TEMPERATURE °C DURATION 1 +20 15 2 -55 15 3 +20 15 4 +85 15 5 +125 15 6 +20 15 Apply 1.3x 2/3x rated voltage (Ur) at 125ºC for 1000 cycles of duration 6 min (30 sec charge, 5 min 30 sec discharge) through a charge /discharge resistance of 1000Ω MIL-STD-202, Method 213, Condition C MIL-STD-202, Method 204, Condition D Visual Examination no visible damage DCL 1.25 x initial limit ∆C/C within +10/-20% of initial value DF 1.5 x initial limit ESR 2 x initial limit Visual Examination no visible damage DCL 2 x initial limit ∆C/C within +10/-20% of initial value DF 1.5 x initial limit ESR 2 x initial limit Visual Examination no visible damage DCL 3 x initial limit ∆C/C within +35/-5% of initial value DF 1.5 x initial limit ESR 2 x initial limit Visual Examination +20°C -55°C +20°C +85°C +125°C +20°C DCL IL* N/A IL* 10 X IL* 12.5 X IL* IL* ∆C/C N/A +0/=20% ±5% +20/-0% +30/-0% +5% IL* 1.5 X IL* IL* 1.5 X IL* 2 X IL* IL* DF Visual Examination no visible damage DCL initial limit ∆C/C within +10/-20% of initial value DF 1.25 x initial limit Visual Examination no visible damage DCL initial limit ∆C/C within ±5% of initial value DF initial limit ESR 1.25 x initial limit Visual Examination no visible damage DCL initial limit ∆C/C within ±5% of initial value DF initial limit ESR 1.25 x initial limit *Initial Limit: Initial measurement max. 1hr after the removal from dry pack or after pretreatment at 85°C for 24 hours. 10 PRODUCT CATEGORY 2, 3, 4 (TEMPERATURE RANGE -55°C TO +105°C) TEST CONIDTION ENDURANCE Apply rated voltage (Ur) at 85ºC for 2000 hours through a circuit impedance of ≤0.1Ω/V (all CATEGORIES). And/or apply rated voltage (Ur) (CATEGORY 2) or 0.8x rated voltage (CATEGORY 3, 4) at 105°C for 2000 hours through a circuit impedance of ≤0.1Ω/V Always stabilize at room temperature for 1-2 hours before measuring. STORAGE LIFE HUMIDITY TEMPERATURE STABILITY SURGE VOLTAGE MECHANICAL SHOCK VIBRATION CHARACTERISTICS Store at 105ºC, no voltage applied, for 2000 hours. Stabilize at room temperature for 1-2 hours before measuring. Store at 65ºC and 95% relative humidity for 500 hours, with no applied voltage. Stabilize at room temperature and humidity for 1-2 hours before measuring. STEP TEMPERATURE °C DURATION 1 +20 15 2 -55 15 3 +20 15 4 +85 15 5 +105 15 6 +20 15 Apply 1.3x rated voltage (Ur) at 105ºC for CATEGORY 2, or apply 1.3x 0.8x rated voltage (Ur) at 105ºC for CATEGORY 3, 4 for 1000 cycles of duration 6 min (30 sec charge, 5 min 30 sec discharge) through a charge / discharge resistance of 1000Ω MIL-STD-202, Method 213, Condition C MIL-STD-202, Method 204, Condition D Visual Examination no visible damage DCL 1.25 x initial limit ∆C/C within +10/-20% of initial value DF 1.5 x initial limit ESR 2 x initial limit Visual Examination no visible damage DCL (VR ≤ 75V) 1.25 x initial limit DCL (VR > 75V) 2 x initial limit ∆C/C within +10/-20% of initial value DF 1.5 x initial limit ESR 2 x initial limit Visual Examination no visible damage DCL 3 x initial limit ∆C/C within +35/-5% of initial value DF 1.5 x initial limit ESR 2 x initial limit Visual Examination +20°C -55°C +20°C +85°C +125°C +20°C DCL IL* N/A IL* 10 X IL* 12.5 X IL* IL* ∆C/C N/A +0/=20% ±5% +20/-0% +30/-0% +5% IL* 1.5 X IL* IL* 1.5 X IL* 2 X IL* IL* DF Visual Examination no visible damage DCL initial limit ∆C/C within +10/-20% of initial value DF 1.25 x initial limit Visual Examination no visible damage DCL initial limit ∆C/C within ±5% of initial value DF initial limit ESR 1.25 x initial limit Visual Examination no visible damage DCL initial limit ∆C/C within ±5% of initial value DF initial limit ESR 1.25 x initial limit *Initial Limit: Initial measurement max. 1hr after the removal from dry pack or after pretreatment at 85°C for 24 hours. 11 PRODUCT CATEGORY 5 (TEMPERATURE RANGE -55°C TO +85°C) TEST ENDURANCE STORAGE LIFE HUMIDITY TEMPERATURE STABILITY SURGE VOLTAGE MECHANICAL SHOCK VIBRATION CONIDTION CHARACTERISTICS Apply rated voltage (Ur) at 85ºC for 2000 hours through a circuit impedance of ≤0.1Ω/V. Stabilize at room temperature for 1-2 hours before measuring. Store at 85ºC, no voltage applied, for 2000 hours. Stabilize at room temperature for 1-2 hours before measuring Store at 65ºC and 95% relative humidity for 500 hours, with no applied voltage. Stabilize at room temperature and humidity for 1-2 hours before measuring. STEP TEMPERATURE °C DURATION 1 +20 15 2 -55 15 3 +20 15 4 +85 15 5 +125 15 Apply 1.3x rated voltage (Ur) at 85ºC for 1000 cycles of duration 6 min (30 sec charge, 5 min 30 sec discharge) through a charge / discharge resistance of 1000Ω MIL-STD-202, Method 213, Condition C MIL-STD-202, Method 204, Condition D Visual Examination no visible damage DCL 1.25 x initial limit ∆C/C within +10/-20% of initial value DF 1.5 x initial limit ESR 2 x initial limit Visual Examination no visible damage DCL 1.25 x initial limit ∆C/C within +10/-20% of initial value DF 1.5 x initial limit ESR 2 x initial limit Visual Examination no visible damage DCL 5 x initial limit ∆C/C within +35/-5% of initial value DF 1.5 x initial limit ESR 2 x initial limit Visual Examination +20°C -55°C +20°C +85°C +125°C +20°C DCL IL* N/A IL* 10 X IL* 12.5 X IL* IL* ∆C/C N/A +0/=20% ±5% +20/-0% +30/-0% +5% IL* 1.5 X IL* IL* 1.5 X IL* 2 X IL* IL* DF Visual Examination no visible damage DCL initial limit ∆C/C within +10/-20% of initial value DF 1.25 x initial limit Visual Examination no visible damage DCL initial limit ∆C/C within ±5% of initial value DF initial limit ESR 1.25 x initial limit Visual Examination no visible damage DCL initial limit ∆C/C within ±5% of initial value DF initial limit ESR 1.25 x initial limit *Initial Limit: Initial measurement max. 1hr after the removal from dry pack or after pretreatment at 85°C for 24 hours. 12
PTMIC476YT070 价格&库存
很抱歉,暂时无法提供与“PTMIC476YT070”相匹配的价格&库存,您可以联系我们找货
PTMIC476YT070
  • 1+16.156011+2.08911
  • 10+10.8436410+1.40218
  • 50+8.7332250+1.12928
  • 100+8.08153100+1.04501
  • 500+6.97919500+0.90247
库存:1000
PTMIC476YT070
  • 1000+6.638061000+0.85836
  • 2000+6.357132000+0.82203
  • 3000+6.216383000+0.80383
  • 5000+6.060365000+0.78366
  • 7000+5.969157000+0.77186
  • 10000+5.8814110000+0.76052
库存:1000
