CML_C0G Series
Stackpole Electronics, Inc.
Resistive Product Solutions
Multilayer Ceramic Chip Capacitor
Features:
-55°C to 125°C operating temperature range
EIA sizes 0402, 0603, 0805, 1206, 1210 and 1812
Capacitance offering from 0.1 pF to 0.1 uF
100% RoHS compliant and lead free without exemption
Halogen free
REACH compliant
Construction
1 - Ceramic layers (dielectric)
2 - Inner electrodes
3 - Base termination
4 - Nickel plating layer
5 - Tin plating layer
Electrical Specifications
Type/Code
Dielectric
Code
CML0402
C0G
CML0603
C0G
CML0805
C0G
CML1206
C0G
Standard Tolerance
Code
Description
C
± 0.25 pF
J
C
J
C
J
C
± 5%
± 0.25 pF
± 5%
± 0.25 pF
± 5%
± 0.25 pF
J
± 5%
C
J
C
CML1812
C0G
J
Note: Capacitance values < 10 pF: B = ± 0.1 pF may be available
Note: Capacitance values ≥ 10 pF: G = ± 2% may be available
CML1210
Capacitance Range
50V
100V
0.1 pF - 8.2 pF
10 pF - 1000 pF
0.1 pF - 6.8 pF
10 pF - 6800 pF
0.3 pF - 6,8 pF
10 pF - 0.022 uF
0.3 pF - 8.2 pF
10 pF - 3300 pF
3900 pF - 4700 pF
10 pF - 0.1 uF
10 pF - 0.1 uF
± 0.25 pF
± 5%
± 0.25 pF
± 5%
C0G
0.5 pF - 8.2 pF
10 pF - 1000 pF
0.5 pF - 8.2 pF
10 pF - 3300 pF
0.5 pF - 8.2 pF
10 pF - 3300 pF
1 pF - 8.2 pF
10 pF - 6800 pF
3 pF - 8.2 pF
10 pF - 0.01 uF
How to Order
C
M
Product Series
Code Description
Multilayer
CML
Ceramic
L
Size
Code
0402
0603
0805
1206
1210
1812
4
Dielectric
Code
C0G
C
Capacitance Range
0.1pF to 0.10uF (E12)
EIA Code Capacitance
0R1
0.1 pF
100
10 pF
101
100 pF
102
1000 pF
103
0.01 uF
104
0.1 uF
Rev Date: 6/13/2023
This specification may be changed at any time without prior notice.
Please confirm technical specifications before you order and/or use.
G
Tolerance (*)
Code Description
B
± 0.1 pF
C
± 0.25 pF
G
± 2%
J
± 5%
1
Code
T
J
T
5
Packaging
Description
Size and Quantity
7" Paper Reel Refer to Packaging
Specifications
7" Plastic Tape
V
Max Working
Voltage
50V
100V
(*) Other tolerances may be available. Contact Stackpole.
1
www.seielect.com
marketing@seielect.com
CML_C0G Series
Capacitance and Voltage Available
Dielectric
Size
EIA
Code
VDCW
0R1
0.1 pF
0R2
0.2 pF
0R3
0.3 pF
0R4
0.4 pF
0R5
0.5 pF
0R6
0.6 pF
0R7
0.7 pF
0R8
0.8 pF
0R9
0.9 pF
1R0
1 pF
1R2
1.2 pF
1R5
1.5 pF
1R8
1.8 pF
2R0
2 pF
2R2
2.2 pF
2R7
2.7 pF
3R0
3 pF
3R3
3.3 pF
3R9
3.9 pF
4R7
4.7 pF
5R0
5 pF
5R6
5.6 pF
6R8
6.8 pF
8R2
8.2 pF
100
10 pF
120
12 pF
150
15 pF
180
18 pF
220
22 pF
270
27 pF
330
33 pF
390
39 pF
470
47 pF
560
56 pF
680
68 pF
820
82 pF
101
100 pF
121
120 pF
151
150 pF
181
180 pF
221
220 pF
271
270 pF
331
330 pF
391
390 pF
471
470 pF
561
560 pF
681
680 pF
751
750 pF
821
820 pF
102
1000 pF
122
1200 pF
152
1500 pF
182
1800 pF
222
2200 pF
272
2700 pF
332
3300 pF
392
3900 pF
472
4700 pF
562
5600 pF
682
6800 pF
822
8200 pF
103
0.01 uF
C0G
0402
50V
0603
50V
0805
100V
50V
Rev Date: 6/13/2023
1206
100V
2
50V
1210
100V
50V
1812
100V
50V
100V
www.seielect.com
CML_C0G Series
Capacitance and Voltage Available (cont.)
Dielectric
Size
EIA
Code
VDCW
123
0.012 uF
153
0.015 uF
183
0.018 uF
223
0.022 uF
273
0.027 uF
333
0.033 uF
473
0.047 uF
563
0.056 uF
683
0.068 uF
823
0.082 uF
104
0.1 uF
C0G
0402
50V
0603
50V
0805
100V
50V
1206
100V
50V
1210
100V
50V
1812
100V
50V
100V
Mechanical Specifications and Packaging Specifications
Type/Code
Voltage
Capacitance Value
CML0402C0G
50V
0.1 pF - 1000 pF
CML0603C0G
50V - 100V
0.1 pF - 6800 pF
50V
CML0805C0G
0.3 pF - 1500 pF
4700 pF
1800 pF - 3900 pF
5600 pF - 8200 pF
0.01 uF - 0.022 uF
100V
0.5 pF - 3300 pF
0.3 pF - 8200 pF
50V
CML1206C0G
0.01 uF - 0.1 uF
100V
0.5 pF - 3300 pF
50V
10 pF - 0.1 uF
100V
1 pF - 6800 pF
50V
10 pF - 0.1 uF
100V
3 pF - 0.01 uF
CML1210C0G
CML1812C0G
L
0.039
1.00
0.063
1.60
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.177
4.50
0.177
4.50
Rev Date: 6/13/2023
W
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.016
0.40
0.016
0.40
0.020
0.50
0.031
0.80
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.063
1.60
0.063
1.60
0.063
1.60
0.098
2.50
0.098
2.50
0.126
3.20
0.126
3.20
3
H
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.020
0.50
0.031
0.80
0.028
0.70
0.031
0.80
0.047
1.20
0.031
0.80
0.028
0.70
0.063
1.60
0.031
0.80
0.047
1.20
0.047
1.20
0.047
1.20
0.047
1.20
a
0.002
0.05
0.004
0.10
0.002
0.05
0.004
0.09
0.004
0.10
0.004
0.10
0.002
0.05
0.004
0.10
0.004
0.09
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.010
0.25
0.012
0.30
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
Unit
0.004
0.10
0.004
0.10
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Packaging (7" Reel) Qty.
Paper Tape
Plastic Tape
10000
4000
4000
4000
2000
4000
4000
2000
4000
3000
2000
1000
1000
www.seielect.com
CML_C0G Series
Environmental Characteristics
Test
Test Specification
Capacitance
Test Condition
Should be within the specified tolerance.
Dissipation Factor
(DF)
C0G
(Class I)
Insulation Resistance
C0G
(Class I)
DF
≤ 0.56%
1.5 [(150 / Cr) + 7] x 10 - 4
≤ 0.15%
≤ 0.15%
C ≤ 10 nF, Ri ≥ 50000 MΩ
C > 10 nF, RI*CR ≥ 500 S
Dielectric
Withstanding
Voltage
No breakdown or damage.
Solderability
At least 95% of the terminal electrode is covered by new solder.
Visual appearance: No visible damage.
Resistance to
Soldering Heat
C0G
≤ ± 0.5% or ± 0.5 pF
whichever is larger
DF
Same to initial value
IR
Appearance: No visible damage. At least 95% of the terminal
Resistance to
Flexure of Substrate
(Bending Strength)
Appearance: No visible damage. Δ C/C: ≤ ± 10%
Item
Δ C/C
Termination Adhesion
No visible damage
C0G: Δ C/C: ≤ ± 1% or ± 1 pF, whichever is larger
Temperature Cycle
Rev Date: 6/13/2023
4
C0G: (Class I)
Cap ≤ 1000 pF 1.0 ± 0.2 Vrms, 1 MHz ± 10%
Cap > 1000 pF 1.0 ± 0.2 Vrms, 1 KHz ± 10%
Capacitance
Measuring Frequency Measuring Voltage
Cr < 5 pF
1 MHZ ± 10%
5 pF ≤ Cr < 50 pF
1 ± 0.2 Vrms
50 pF ≤ Cr ≤ 1000 pF
> 1000 pF
1 KHZ ± 10%
Measuring Voltage: Rated Voltage (Max 500V)
Duration: 60 ± 5 seconds
Test Humidity: ≤ 75%
Test Temperature: 25°C ± 5°C
Test Current: ≤ 50 mA
Measuring voltage:
Class I: 300% rated voltage
Duration: 1 ~ 5 seconds
Charge/Discharge Current: 50 mA max.
Preheating Conditions: 80ºC to 120°C, 10 ~ 30 seconds
Solder Temperature: 235ºC ± 5% (Sn/Pb: 63/37)
Duration: 2 ± 0.5 seconds
Solder Temperature: 245ºC ± 5°C (Lead-free)
Preheating Conditions: 100ºC to 200°C; 10 ± 2 minutes
Solder Temperature: 265ºC ± 5°C
Duration: 10 ± 1 seconds
Clean the capacitor with solvent and examine it with
a 10X (min.) microscope.
Recovery Time: 24 ± 2 hours
Recovery Condition: Room temperature.
Test Board: AI2O3 or PCB
Warp: 1 mm
Speed: 0.5 mm/second
The measurement should be made with the board in the bending
position.
Unit: mm
Applied Force: 5 N
Preheating Conditions: up-category
Temperature: 1 hour
Recovery Time: 24 ± 1 hours
Initial Measurement
Cycling times: 5 times, 1 cycle, 4 steps:
Step
Temp. ( °C )
Time (min.)
Low-category temp.
1
30 ± 3
C0G: -55ºC
2
Normal temp. (+20)
2-3
Up-category temp.
3
30 ± 3
C0G: +125ºC
4
Normal temp. (+20ºC)
2-3
Recovery time after test: 24 ± 2 hours
www.seielect.com
CML_C0G Series
Environmental Characteristics (cont.)
Test
Moisture
Resistance
Life Test
Test Specification
Test Condition
Temperature: 40ºC ± 2°C
Humidity: 90 ~ 95% R.H.
Duration: 500 hours
Recovery Conditions: Room temperature
Recovery Time: 24 hours (Class I)
Low-voltage (< 100V)
Applied Voltage: 1.5 x rated voltage
Duration: 1000 hours
Temperature: 125°C (C0G)
Applied voltage:
100V ≤ rated voltage < 500V: 2 multiple
500V ≤ rated voltage ≤ 1000V: 1.5 multiple
> 1000V rated voltage: 1.2 multiple
C0G: Δ C/C: ≤ ± 2% or ± 1 pF, whichever is larger
DF: Not more than twice of initial value.
IR: C0G: Ri ≥ 2500 M Ω or RI*CR ≥ 25 S whichever is smaller
IR: C0G: Ri ≥ 4000 M Ω or RI*CR ≥ 40 S whichever is smaller
Middle and High
Voltage Life Test
IR: C0G: Ri ≥ 4000 M Ω or Ri*CR ≥ 40 S whichever is smaller
Reel Specifications
Type/Code
CML_C0G
(all sizes)
A
7.008 ± 0.079
178.00 ± 2.00
B
C
D
0.118
3.00
0.512 ± 0.020
13.00 ± 0.50
0.827 ± 0.031
21.00 ± 0.80
E
F
1.969 or more
50.00 or more
G
0.394 ± 0.059
10.00 ± 1.50
Unit
0.472 max inches
12.00 max mm
Paper Tape Specifications
Type/Code
CML0402C0G
CML0603C0G
CML0805C0G
CML1206C0G
A0
0.026
0.65
0.043
1.10
0.057
1.45
0.071
1.80
B0
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.045
1.15
0.075
1.90
0.091
2.30
0.134
3.40
Rev Date: 6/13/2023
T
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.031
0.80
0.043
1.10
0.043
1.10
0.043
1.10
5
below
below
max
max
max
max
max
max
W
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
P0
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
Unit
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
CML_C0G Series
Paper Tape Specifications (cont.)
Type/Code
CML0402C0G
CML0603C0G
CML0805C0G
CML1206C0G
P1
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
P2
0.002
0.05
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.157
4.00
0.157
4.00
0.157
4.00
D0
0.002
0.05
0.002
0.05
0.004
0.10
0.004
0.10
E
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
F
0.002
0.05
0.002
0.05
0.002
0.05
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
Unit
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
inches
mm
inches
mm
inches
mm
inches
mm
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
inches
mm
inches
mm
inches
mm
inches
mm
Unit
max
max
max
max
max
max
max
max
inches
mm
inches
mm
inches
mm
inches
mm
Plastic Tape Specifications
Type/Code
CML0805C0G
CML1206C0G
CML1210C0G
CML1812C0G
A
CML1206C0G
CML1210C0G
CML1812C0G
C
D
J
E
F
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.093
2.35
0.142
3.60
0.135
3.42
0.195
4.95
G
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.315
8.00
0.315
8.00
0.315
8.00
0.472
12.00
H
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.217
5.50
0.157
4.00
0.157
4.00
0.157
4.00
0.315
8.00
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.004
0.10
0.004
0.10
0.002
0.05
0.002
0.05
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
Type/Code
CML0805C0G
B
0.061
1.55
0.077
1.95
0.106
2.70
0.144
3.66
T
0.059
1.50
0.073
1.85
0.126
3.20
0.157
4.00
Unit
Recommended Solder Pad for Wave Soldering
Type
0603
0805
1206
1210
Unit
0.063
0.079
0.126
0.126
inches
Lengh (L)
1.60
2.00
3.20
3.20
mm
0.031
0.049
0.063
0.098
inches
Width (W)
0.80
1.25
1.60
2.50
mm
0.031 ~ 0.039 0.039 ~ 0.055 0.071 ~ 0.098 0.071 ~ 0.098 inches
a
0.80 ~ 1.00
1.00 ~ 1.40
1.80 ~ 2.50
1.80 ~ 2.50
mm
0.020 ~ 0.031 0.031 ~ 0.059 0.031 ~ 0.067 0.031 ~ 0.067 inches
b
0.50 ~ 0.80
0.80 ~ 1.50
0.80 ~ 1.70
0.80 ~ 1.70
mm
0.024 ~ 0.031 0.035 ~ 0.047 0.047 ~ 0.063 0.071 ~ 0.098 inches
c
0.60 ~ 0.80
0.90 ~ 1.20
1.20 ~ 1.60
1.80 ~ 2.50
mm
NOTE: Solder pad information is for reference only.
Rev Date: 6/13/2023
6
www.seielect.com
CML_C0G Series
Recommended Solder Pad for Reflow Soldering
Type
0402
0603
0.043
0.063
Lengh (L)
1.10
1.60
0.020
0.031
Width (W)
0.50
0.80
0.018 ~ 0.022
0.024 ~ 0.031
a
0.45 ~ 0.55
0.60 ~ 0.80
0.016 ~ 0.020
0.024 ~ 0.031
b
0.40 ~ 0.50
0.60 ~ 0.80
0.018 ~ 0.022
0.024 ~ 0.031
c
0.45 ~ 0.55
0.60 ~ 0.80
0805
0.079
2.00
0.049
1.25
0.031 ~ 0.047
0.80 ~ 1.20
0.024 ~ 0.047
0.60 ~ 1.20
0.035 ~ 0.063
0.90 ~ 1.60
1206
0.126
3.20
0.063
1.60
0.071 ~ 0.098
1.80 ~ 2.50
0.024 ~ 0.059
0.60 ~ 1.50
0.047 ~ 0.079
1.20 ~ 2.00
1210
0.126
3.20
0.098
2.50
0.071 ~ 0.098
1.80 ~ 2.50
0.024 ~ 0.059
0.60 ~ 1.50
0.071 ~ 0.126
1.80 ~ 3.20
1812
0.177
4.50
0.126
3.20
0.098 ~ 0.138
2.50 ~ 3.50
0.039 ~ 0.071
1.00 ~ 1.80
0.091 ~ 0.138
2.30 ~ 3.50
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
RoHS Compliance
Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various
regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances”
(RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our
compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as
amended by Directive (EU) 2015/863/EU as regards the list of restricted substances.
RoHS Compliance Status
Standard
Product
Series
Description
CML
Package /
Standard
Termination Series RoHS
Type
Compliant
SMD
YES
Lead-Free Termination
Composition
Lead-Free
Mfg. Effective Date
(Std Product Series)
100% Matte Sn over Ni
Always
Lead-Free
Effective Date
Code
(YY/WW)
Always
“Conflict Metals” Commitment
We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern
Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry
is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do
not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding
Conflict Minerals.
Compliance to “REACH”
We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and
compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of
Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List.
Environmental Policy
It is the policy of Stackpole Electronics, Inc. to protect the environment in all localities in which we operate. We continually strive to
improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment
and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution.
Rev Date: 6/13/2023
7
www.seielect.com
CML_X5R Series
Features:
-55°C to 85°C operating temperature range
Capacitance offering from 0.047 uF to 100 uF
Halogen free
REACH compliant
Construction
Type / Code
Dielectric
Code
CML0402
Standard Tolerance
Code
Description
X5R
K
X5R
K
± 10%
CML0805
X5R
K
± 10%
CML1206
X5R
K
± 10%
CML1812
X5R
K
X5R
25V
10 uF
50V
± 10%
4.7 uF - 22 uF
33 uF - 47 uF
68 uF - 100 uF
4.7 uF - 6.8 uF
10 uF
15 uF - 22 uF
33 uF - 47 uF
± 10%
K
16V
120 pF - 0.039 uF
0.047 uF - 0.1 uF
0.12 uF - 0.47 uF
0.47 uF - 1 uF
1.2 uF - 2.2 uF
150 pF - 0.39 uF
0.47 uF - 2.2 uF
150 pF - 4.7 uF
± 10%
CML0603
CML1210
Capacitance Range
10V
Note: J = ± 5% tolerance may be available
How to Order
C
M
Product Series
Code Description
Multilayer
CML
Ceramic
L
Size
Code
0402
0603
0805
1206
1210
1812
4
Dielectric
Code
X5R
X
Capacitance Range
473
0.047 uF
104
0.1 uF
105
1 uF
106
10 uF
107
100 uF
Rev Date: 6/13/2023
5
R
Tolerance (*)
Code Description
J
± 5%
K
± 10%
1
Code
T
4
K
T
5
Packaging
Description
Size
Quantity
Specifications
7" Plastic Tape
1
V
Max Working
Voltage
10V
16V
25V
50V
www.seielect.com
CML_X5R Series
Dielectric
X5R
EIA
Size
0402
0603
0805
1206
1210
1812
Code VDCW 10V 16V 25V 50V 10V 16V 25V 50V 10V 16V 25V 10V 16V 25V 50V 10V 16V 25V 10V 16V 25V
473 0.047 uF
563 0.056 uF
683 0.068 uF
823 0.082 uF
104
0.1 uF
154
0.15 uF
224
0.22 uF
334
0.33 uF
474
0.47 uF
684
0.68 uF
105
1 uF
155
1.5 uF
225
2.2 uF
335
3.3 uF
475
4.7 uF
685
6.8 uF
106
10 uF
156
15 uF
226
22 uF
336
33 uF
476
47 uF
686
68 uF
107
100 uF
Type / Code
Voltage
Capacitance Range
CML0402X5R
10V - 50V
0.1 uF - 4.7 uF
CML0603X5R
10V - 50V
0.47 uF - 10 uF
1 uF
1.5 uF
10V - 16V
2.2 uF
CML0805X5R
3.3 uF - 22 uF
1 uF
25V
1.5 uF - 2.2 uF
3.3 uF - 10 uF
L
0.039
1.00
0.063
1.60
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
Rev Date: 6/13/2023
W
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.020
0.50
0.031
0.80
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
2
H
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.020
0.50
0.031
0.80
0.039
1.00
0.047
1.20
0.031
0.80
0.047
1.20
0.039
1.00
0.047
1.20
0.047
1.20
a
0.002
0.05
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.010
0.25
0.012
0.30
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
Unit
0.004
0.10
0.004
0.10
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
Paper Tape Plastic Tape
10000
4000
3000
3000
4000
2000
3000
3000
2000
www.seielect.com
CML_X5R Series
Mechanical Specifications and Packaging Specifications (cont.)
Type / Code
Voltage
Capacitance Range
2.2 uF - 3.3 uF
10V
4.7 uF - 22 uF
47 uF
CML1206X5R
2.2 uF - 3.3 uF
16V - 25V
4.7 uF - 22 uF
2.2 uF - 3.3 uF
50V
4.7 uF - 10 uF
4.7 uF
10V
6.8 uF - 10 uF
15 uF - 100 uF
4.7 uF
CML1210X5R
16V
6.8 uF - 10 uF
15 uF - 47 uF
4.7 uF
25V
6.8 uF - 10 uF
15 uF - 22 uF
CML1812X5R
10V - 25V
4.7 uF - 47 uF
L
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.177
4.50
W
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.016
0.40
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.126
3.20
H
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.047
1.20
0.063
1.60
0.071
1.80
0.047
1.20
0.063
1.60
0.047
1.20
0.063
1.60
0.047
1.20
0.071
1.80
0.098
2.50
0.047
1.20
0.071
1.80
0.098
2.50
0.047
1.20
0.071
1.80
0.098
2.50
0.071
1.80
a
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.010
0.25
0.004
0.10
0.004
0.10
0.010
0.25
0.004
0.10
0.004
0.10
0.010
0.25
0.004
0.10
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
Unit
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
3000
2000
2000
3000
2000
3000
2000
2000
2000
500
2000
2000
500
2000
2000
500
1000
Test
Capacitance
Dissipation
Factor
(DF)
X5R
X5R
(Class II) (≥ 0402)
Insulation
Resistance
X5R
(Class II)
Dielectric
Withstanding
Voltage
Test Specification
Test Condition
X5R: (Class II)
Cap ≤ 10 uF 1.0 ± 0.2 Vrms, 1 KHz ± 10%
Cap > 10 uF 0.5 ± 0.1 Vrms, 120 Hz ± 10%
≥ 50V
≤ 2.5%
25V
16V
≤ 3.5% (C < 0.47 uF)
≤ 10.0% (C ≥ 0.47 uF)
10V
≤ 5% (C < 0.15 uF)
≤ 10.0% ( C ≥ 0.15
C ≤ 25 nF, Ri ≥ 10,000 MΩ
C > 25 nF, RI*CR > 100 S
Rev Date: 6/13/2023
3
Measuring voltage:
Class II: 250% rated voltage
www.seielect.com
CML_X5R Series
Test
Solderability
Resistance to
Soldering Heat
Test Specification
Test Condition
Item
X5R
Δ C/C
-5 ~ + 10%
DF
IR
Appearance: No visible damage. At least 95% of the terminal electrode is
Resistance to
Flexure of
Substrate
(Bending
Strength)
Termination
Adhesion
No visible damage
X5R: Δ C/C: ≤ ± 10%
Temperature
Cycle
Moisture
Resistance
Life Test
X5R: Δ C/C: ≤ ± 10%
IR: X5R: Ri ≥ 1000 MΩ or RI*CR ≥ 25 S whichever is smaller
X5R: Δ C/C: ≤ ± 20%
IR: X5R: Ri ≥ 2000 MΩ or RI*CR ≥ 50 S whichever is smaller
Rev Date: 6/13/2023
4
Solder Temperature: 265ºC ± 5 °C
Warp: 1 mm
Speed: 0.5 mm / second
bending position.
Unit: mm
Applied Force: 5 N
Preheating Conditions: up-category temperature 1 hour
Initial Measurement
Step
Temp. (°C)
Time (min.)
Low-category temp.
1
30 ± 3
X5R: -55ºC
2
2-3
Up-category temp.
3
30 ± 3
X5R: +85ºC
4
2-3
Duration: 500 hours
Recovery Time: 48 hours (Class II)
Temperature: 85°C (X5R)
www.seielect.com
CML_X5R Series
Reel Specifications
Type/Code
CML_X5R
(all sizes)
A
7.008 ± 0.079
178.00 ± 2.00
B
C
D
0.118
3.00
0.512 ± 0.020
13.00 ± 0.50
0.827 ± 0.031
21.00 ± 0.80
E
F
1.969 or more
50.00 or more
G
0.394 ± 0.059
10.00 ± 1.50
Unit
0.472 max inches
12.00 max mm
Type/Code
CML0402X5R
CML0603X5R
CML0805X5R
CML1206X5R
A0
0.026
0.65
0.043
1.10
0.057
1.45
0.071
1.80
Type/Code
CML0402X5R
CML0603X5R
CML0805X5R
CML1206X5R
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
B0
± 0.004
± 0.10
± 0.004
± 0.10
± 0.006
± 0.15
± 0.008
± 0.20
P1
0.002
0.05
0.004
0.10
0.004
0.10
0.004
0.10
0.045
1.15
0.075
1.90
0.091
2.30
0.134
3.40
0.079
2.00
0.157
4.00
0.157
4.00
0.157
4.00
T
± 0.004
± 0.10
± 0.004
± 0.10
± 0.006
± 0.15
± 0.008
± 0.20
P2
Rev Date: 6/13/2023
0.002
0.05
0.002
0.05
0.004
0.10
0.004
0.10
5
W
P0
Unit
0.031 below
0.80 below
0.043 max
1.10 max
0.043 max
1.10 max
0.043 max
1.10 max
D0
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
E
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
F
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
inches
mm
inches
mm
inches
mm
inches
mm
Unit
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
0.002
0.05
0.002
0.05
0.002
0.05
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
CML_X5R Series
Type/Code
CML0805X5R
CML1206X5R
CML1210X5R
CML1812X5R
A
CML1206X5R
CML1210X5R
CML1812X5R
C
D
J
E
F
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.093
2.35
0.142
3.60
0.135
3.42
0.195
4.95
G
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.315
8.00
0.315
8.00
0.315
8.00
0.472
12.00
H
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.217
5.50
0.157
4.00
0.157
4.00
0.157
4.00
0.315
8.00
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.004
0.10
0.004
0.10
0.002
0.05
0.002
0.05
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
Type/Code
CML0805X5R
B
0.061
1.55
0.077
1.95
0.106
2.70
0.144
3.66
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
T
0.059
1.50
0.073
1.85
0.126
3.20
0.157
4.00
Unit
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
inches
mm
inches
mm
inches
mm
inches
mm
Unit
max
max
max
max
max
max
max
max
inches
mm
inches
mm
inches
mm
inches
mm
Type
0603
0805
1206
1210
Unit
0.063
0.079
0.126
0.126
inches
Lengh (L)
1.60
2.00
3.20
3.20
mm
0.031
0.049
0.063
0.098
inches
Width (W)
0.80
1.25
1.60
2.50
mm
a
0.80 ~ 1.00
1.00 ~ 1.40
1.80 ~ 2.50
1.80 ~ 2.50
mm
b
0.50 ~ 0.80
0.80 ~ 1.50
0.80 ~ 1.70
0.80 ~ 1.70
mm
c
0.60 ~ 0.80
0.90 ~ 1.20
1.20 ~ 1.60
1.80 ~ 2.50
mm
Type
0402
0603
0.043
0.063
Lengh (L)
1.10
1.60
0.020
0.031
Width (W)
0.50
0.80
0.018 ~ 0.022
0.024 ~ 0.031
a
0.45 ~ 0.55
0.60 ~ 0.80
0.016 ~ 0.020
0.024 ~ 0.031
b
0.40 ~ 0.50
0.60 ~ 0.80
0.018 ~ 0.022
0.024 ~ 0.031
c
0.45 ~ 0.55
0.60 ~ 0.80
Rev Date: 6/13/2023
0805
0.079
2.00
0.049
1.25
0.031 ~ 0.047
0.80 ~ 1.20
0.024 ~ 0.047
0.60 ~ 1.20
0.035 ~ 0.063
0.90 ~ 1.60
6
1206
0.126
3.20
0.063
1.60
0.071 ~ 0.098
1.80 ~ 2.50
0.024 ~ 0.059
0.60 ~ 1.50
0.047 ~ 0.079
1.20 ~ 2.00
1210
0.126
3.20
0.098
2.50
0.071 ~ 0.098
1.80 ~ 2.50
0.024 ~ 0.059
0.60 ~ 1.50
0.071 ~ 0.126
1.80 ~ 3.20
1812
0.177
4.50
0.126
3.20
0.098 ~ 0.138
2.50 ~ 3.50
0.039 ~ 0.071
1.00 ~ 1.80
0.091 ~ 0.138
2.30 ~ 3.50
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
CML_X5R Series
RoHS Compliance
Standard
Product
Series
Description
CML
Package /
Standard
Type
Compliant
SMD
YES
Composition
Lead-Free
Mfg. Effective Date
Always
Lead-Free
Effective Date
Code
(YY/WW)
Always
Conflict Minerals.
Rev Date: 6/13/2023
7
www.seielect.com
CML_X7R Series
Features:
Capacitance offering from 100 pF to 47 uF
Halogen free
REACH compliant
Construction
Type/Code
Dielectric
Code
CML0402
X7R
K
± 10%
CML0603
X7R
K
± 10%
CML0805
Standard Tolerance
Code
Description
X7R
K
± 10%
CML1206
X7R
K
± 10%
CML1210
X7R
K
± 10%
CML1812
X7R
K
± 10%
Capacitance Range
16V
25V
120 pF - 0.039 uF
0.012 uF - 0.1 uF
150 pF - 0.1 uF
0.012 uF - 0.18 uF
0.12 uF - 0.33 uF
0.12 uF - 2.2 uF
150 pF - 0.1 uF
0.12 uF - 0.39 uF
0.12 uF - 2.2 uF
150 pF - 1 uF
2.2 uF - 4.7 uF
220 pF - 10 uF
22 uF
47 uF
470 pF - 4.7 uF
6.8 uF
10V
50V
100V
150 pF - 2.2 uF
270 pF - 1 uF
Note: J = 5% tolerance may be available
How to Order
C
M
Product Series
Code Description
Multilayer
CML
Ceramic
L
Size
Code
0402
0603
0805
1206
1210
1812
Dielectric
Code
X7R
X
Capacitance Range
101
100 pF
102
1000 pF
103
0.01 uF
104
0.1 uF
105
1 uF
106
10 uF
Rev Date: 6/13/2023
7
R
Tolerance (*)
Code Description
J
± 5%
K
± 10%
1
Code
T
3
K
T
Packaging
Description
Size
Quantity
7" Paper Reel
Refer to Packaging
Specifications
7" Plastic Tape
1
5
V
Max Working
Voltage
10V
16V
25V
50V
100V
www.seielect.com
CML_X7R Series
Dielectric
X7R
Size
0402
0603
0805
1206
1210
1812
EIA
Code VDCW 10V 16V 25V 50V 10V 16V 25V 50V 100V 10V 16V 25V 50V 100V 10V 16V 25V 50V 100V 10V 16V 25V 50V 100V 16V 25V 50V 100V
101
100 pF
121
120 pF
151
150 pF
181
180 pF
201
200 pF
221
220 pF
271
270 pF
331
330 pF
391
390 pF
471
470 pF
561
560 pF
681
680 pF
751
750 pF
821
820 pF
102 1000 pF
122 1200 pF
152 1500 pF
182 1800 pF
222 2200 pF
272 2700 pF
332 3300 pF
392 3900 pF
472 4700 pF
562 5600 pF
682 6800 pF
822 8200 pF
103
0.01 uF
123 0.012 uF
153 0.015 uF
183 0.018 uF
223 0.022 uF
273 0.027 uF
333 0.033 uF
393 0.039 uF
473 0.047 uF
563 0.056 uF
683 0.068 uF
823 0.082 uF
104
0.1 uF
124
0.12 uF
154
0.15 uF
184
0.18 uF
224
0.22 uF
274
0.27 uF
334
0.33 uF
394
0.39 uF
474
0.47 uF
564
0.56 uF
684
0.68 uF
824
0.82 uF
105
1 uF
125
1.2 uF
155
1.5 uF
225
2.2 uF
335
3.3 uf
475
4.7 uF
685
6.8 uF
106
10 uF
226
22 uf
476
47 uF
Rev Date: 6/13/2023
2
www.seielect.com
CML_X7R Series
Type/Code
Voltage
Capacitance Range
CML0402X7R
10V - 50V
100 pF - 0.47 uF
CML0603X7R
10V - 100V
150 pF - 2.2 uF
150 pF - 0.33 uF
0.47 uF
0.56 uF - 0.68 uF
10V
0.82 uF - 1 uF
1.5 uF
2.2 uF
3.3 uF - 10 uF
150 pF - 0.33 uF
0.47 uF
0.56 uF - 0.68 uF
CML0805X7R
16V
0.82 uF - 1 uF
1.5 uF
2.2 uF
3.3 uF - 4.7 uF
150 pF - 0.33 uF
0.47 uF
0.56 uF - 0.68 uF
25V
0.82 uF - 1 uF
1.5 uF - 2.2 uF
3.3 uF - 4.7 uF
L
0.039
1.00
0.063
1.60
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
Rev Date: 6/13/2023
W
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.020
0.50
0.031
0.80
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
3
H
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.020
0.50
0.031
0.80
0.031
0.80
0.031
0.80
0.047
1.20
0.039
1.00
0.047
1.20
0.031
0.80
0.047
1.20
0.031
0.80
0.031
0.80
0.047
1.20
0.039
1.00
0.047
1.20
0.031
0.80
0.047
1.20
0.031
0.80
0.031
0.80
0.047
1.20
0.039
1.00
0.047
1.20
0.047
1.20
a
0.002
0.05
0.006
0.15
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.010
0.25
0.016
0.40
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
Unit
0.004
0.10
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
10000
4000
4000
4000
3000
3000
3000
4000
2000
4000
4000
3000
3000
3000
4000
2000
4000
4000
3000
3000
2000
2000
www.seielect.com
CML_X7R Series
Type/Code
Voltage
Capacitance Range
150 pF - 0.33 uF
0.47 uF
50V
0.56 uF - 0.68 uF
0.82 uF - 1 uF
CML0805X7R
1.5 uF - 2.2 uF
100 pF
100V
150 pF - 0.047 uF
0.056 uF - 0.1 uF
200 pF - 0.33 uF
0.47 uF - 0.68 uF
0.82 uF - 1.5 uF
10V
2.2 uF
3.3 uF
4.7 uF - 22 uF
200 pF - 0.33 uF
0.47 uF - 0.68 uF
0.82 uF - 1.5 uF
16V - 25V
2.2 uF
CML1206X7R
3.3 uF
4.7 uF - 10 uF
200 pF - 0.33 uF
0.47 uF - 0.68 uF
0.82 uF - 1.5 uF
50V
2.2 uF
3.3 uF
4.7 uF
150 pF - 0.056 uF
100V
0.068 uF - 0.33 uF
0.47 uF - 1 uF
L
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
Rev Date: 6/13/2023
W
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.049
1.25
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
4
H
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.031
0.80
0.031
0.80
0.047
1.20
0.039
1.00
0.047
1.20
0.028
0.70
0.031
0.80
0.047
1.20
0.031
0.80
0.047
1.20
0.031
0.80
0.063
1.60
0.047
1.20
0.063
1.60
0.031
0.80
0.047
1.20
0.031
0.80
0.063
1.60
0.047
1.20
0.063
1.60
0.031
0.80
0.047
1.20
0.031
0.80
0.063
1.60
0.047
1.20
0.063
1.60
0.031
0.80
0.047
1.20
0.063
1.60
a
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.020
0.50
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.012
0.30
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.012
0.30
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.012
0.30
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.020
0.50
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
Unit
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.008
0.20
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
4000
4000
3000
3000
3000
4000
4000
3000
4000
3000
4000
2000
3000
2000
4000
3000
4000
2000
3000
2000
4000
3000
4000
2000
3000
2000
4000
3000
2000
www.seielect.com
CML_X7R Series
Type/Code
Voltage
Capacitance Range
220 pF - 0.47 uF
0.68 uF - 1 uF
10V
4.7 uF
10 uF
47 uF
220 pF - 0.47 uF
0.68 uF - 1 uF
16V - 25V
4.7 uF
CML1210X7R
10 uF
22 uF
220 pF - 0.47 uF
0.68 uF - 1 uF
50V
4.7 uF
10 uF
150 pF - 0.22 uF
100V
0.33 uF - 2.2 uF
470 pF - 1 uF
16V - 25V
1.5 uF - 6.8 uF
470 pF - 1 uF
CML1812X7R
50V
1.5 uF - 4.7 uF
270 pF - 0.56 uF
100V
0.68 uF - 1 uF
L
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.177
4.50
0.177
4.50
0.177
4.50
0.177
4.50
0.177
4.50
0.177
4.50
Rev Date: 6/13/2023
W
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.016
0.40
0.016
0.40
0.016
0.40
0.016
0.40
0.016
0.40
0.016
0.40
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.098
2.50
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
0.126
3.20
5
H
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.047
1.20
0.063
1.60
0.047
1.20
0.071
1.80
0.098
2.50
0.047
1.20
0.063
1.60
0.047
1.20
0.071
1.80
0.098
2.50
0.047
1.20
0.063
1.60
0.071
1.80
0.098
2.50
0.055
1.40
0.063
1.60
0.063
1.60
0.071
1.80
0.063
1.60
0.071
1.80
0.063
1.60
0.063
1.60
a
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.010
0.25
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.010
0.25
0.004
0.10
0.004
0.10
0.004
0.10
0.010
0.25
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.009
0.24
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
0.024
0.60
Unit
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
2000
2000
2000
2000
500
2000
2000
2000
2000
500
2000
2000
2000
500
2000
2000
1000
1000
1000
1000
1000
500
www.seielect.com
CML_X7R Series
Test
Capacitance
Dissipation
Factor
(DF)
X7R
X7R
(Class II) (≥ 0402)
Insulation
Resistance
X7R
(Class II)
Test Specification
Test Condition
X7R: (Class II)
Cap ≤ 10uF 1.0 ± 0.2 Vrms, 1 KHz ± 10%
Cap > 10uF 0.5 ± 0.1 Vrms, 120 Hz ± 10%
≥ 50V
≤ 2.5%
25V
16V
≤ 3.5% (C < 0.47uF)
≤ 10.0% (C ≥ 0.47uF)
10V
≤ 5% (C < 0.15uF)
≤ 10.0% ( C ≥ 0.15 uF)
C ≤ 25nF, Ri ≥ 10000M Ω
C > 25nF, RI*CR > 100S
Dielectric
Withstanding
Voltage
Solderability
Resistance to
Soldering
Heat
Item
X7R
Δ C/C
-5 ~ + 10%
DF
IR
Appearance: No visible damage. At least 95% of the terminal electrode is covered
by new solder.
Resistance to
Flexure of
Substrate
(Bending
Strength)
Termination
Adhesion
No visible damage
Measuring voltage:
Warp: 1 mm
bending position.
Unit: mm
Applied Force: 5 N
Initial Measurement
Step
Temp. (°C)
Time (min.)
Low-category
1
30 ± 3
temp.
X7R: -55ºC
Normal temp.
2
2-3
(+20ºC)
X7R: Δ C/C: ≤ ± 10%
Temperature
Cycle
3
Up-category temp.
30 ± 3
X7R: +125ºC
Normal temp.
4
2-3
(+20ºC)
Rev Date: 6/13/2023
6
www.seielect.com
CML_X7R Series
Test
Moisture
Resistance
Life Test
Middle and
High Voltage
Life Test
Test Specification
Test Condition
X7R: Δ C/C: ≤ ± 10%
IR: X7R: Ri ≥ 1000M Ω or RI*CR ≥ 25S whichever is smaller
Duration: 500 hours
Temperature: 125°C (X7R)
Applied voltage: 100V ≤ rated voltage < 500V: 2 multiple
X7R: Δ C/C: ≤ ± 20%
IR: X7R: Ri ≥ 2000M Ω or RI*CR ≥ 50 S whichever is smaller
X7R: Δ C/C: ≤ ± 20%
IR: X7R Ri ≥ 2000M Ω or Ri*CR ≥ 50 S whichever is smaller
Reel Specifications
Type/Code
CML_X7R
(all sizes)
A
7.008 ± 0.079
178.00 ± 2.00
B
C
D
0.118
3.00
0.512 ± 0.020
13.00 ± 0.50
0.827 ± 0.031
21.00 ± 0.80
E
F
1.969 or more
50.00 or more
G
0.394 ± 0.059
10.00 ± 1.50
Unit
0.472 max inches
12.00 max mm
Type/Code
CML0402X7R
CML0603X7R
CML0805X7R
CML1206X7R
A0
0.026
0.65
0.043
1.10
0.057
1.45
0.071
1.80
B0
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.045
1.15
0.075
1.90
0.091
2.30
0.134
3.40
T
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
Rev Date: 6/13/2023
0.031
0.80
0.043
1.10
0.043
1.10
0.043
1.10
7
below
below
max
max
max
max
max
max
W
0.315
8.00
0.315
8.00
0.315
8.00
0.315
8.00
P0
0.004
0.10
0.004
0.10
0.006
0.15
0.008
0.20
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
Unit
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
inches
mm
inches
mm
inches
mm
inches
mm
www.seielect.com
CML_X7R Series
Type/Code
CML0402X7R
CML0603X7R
CML0805X7R
CML1206X7R
P1
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
P2
0.002
0.05
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.157
4.00
0.157
4.00
0.157
4.00
D0
0.002
0.05
0.002
0.05
0.004
0.10
0.004
0.10
E
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
F
0.002
0.05
0.002
0.05
0.002
0.05
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.138
3.50
Unit
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
inches
mm
inches
mm
inches
mm
inches
mm
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
inches
mm
inches
mm
inches
mm
inches
mm
Unit
max
max
max
max
max
max
max
max
inches
mm
inches
mm
inches
mm
inches
mm
Type/Code
CML0805X7R
CML1206X7R
CML1210X7R
CML1812X7R
A
CML1206X7R
CML1210X7R
CML1812X7R
C
D
J
E
F
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.093
2.35
0.142
3.60
0.135
3.42
0.195
4.95
G
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.315
8.00
0.315
8.00
0.315
8.00
0.472
12.00
H
0.008
0.20
0.008
0.20
0.004
0.10
0.004
0.10
0.138
3.50
0.138
3.50
0.138
3.50
0.217
5.50
0.157
4.00
0.157
4.00
0.157
4.00
0.315
8.00
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.079
2.00
0.079
2.00
0.079
2.00
0.079
2.00
0.004
0.10
0.004
0.10
0.002
0.05
0.002
0.05
0.157
4.00
0.157
4.00
0.157
4.00
0.157
4.00
0.004
0.10
0.004
0.10
0.004
0.10
0.004
0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
0.059-0/+0.004
1.5-0/+0.10
Type/Code
CML0805X7R
B
0.061
1.55
0.077
1.95
0.106
2.70
0.144
3.66
0.002
0.05
0.002
0.05
0.002
0.05
0.002
0.05
0.069
1.75
0.069
1.75
0.069
1.75
0.069
1.75
T
0.059
1.50
0.073
1.85
0.126
3.20
0.157
4.00
Unit
Type
0603
0805
1206
1210
Unit
0.063
0.079
0.126
0.126
inches
Lengh (L)
1.60
2.00
3.20
3.20
mm
0.031
0.049
0.063
0.098
inches
Width (W)
0.80
1.25
1.60
2.50
mm
a
0.80 ~ 1.00
1.00 ~ 1.40
1.80 ~ 2.50
1.80 ~ 2.50
mm
b
0.50 ~ 0.80
0.80 ~ 1.50
0.80 ~ 1.70
0.80 ~ 1.70
mm
c
0.60 ~ 0.80
0.90 ~ 1.20
1.20 ~ 1.60
1.80 ~ 2.50
mm
Rev Date: 6/13/2023
8
www.seielect.com
CML_X7R Series
Type
0402
0603
0.043
0.063
Lengh (L)
1.10
1.60
0.020
0.031
Width (W)
0.50
0.80
0.018 ~ 0.022
0.024 ~ 0.031
a
0.45 ~ 0.55
0.60 ~ 0.80
0.016 ~ 0.020
0.024 ~ 0.031
b
0.40 ~ 0.50
0.60 ~ 0.80
0.018 ~ 0.022
0.024 ~ 0.031
c
0.45 ~ 0.55
0.60 ~ 0.80
0805
0.079
2.00
0.049
1.25
0.031 ~ 0.047
0.80 ~ 1.20
0.024 ~ 0.047
0.60 ~ 1.20
0.035 ~ 0.063
0.90 ~ 1.60
1206
0.126
3.20
0.063
1.60
0.071 ~ 0.098
1.80 ~ 2.50
0.024 ~ 0.059
0.60 ~ 1.50
0.047 ~ 0.079
1.20 ~ 2.00
1210
0.126
3.20
0.098
2.50
0.071 ~ 0.098
1.80 ~ 2.50
0.024 ~ 0.059
0.60 ~ 1.50
0.071 ~ 0.126
1.80 ~ 3.20
1812
0.177
4.50
0.126
3.20
0.098 ~ 0.138
2.50 ~ 3.50
0.039 ~ 0.071
1.00 ~ 1.80
0.091 ~ 0.138
2.30 ~ 3.50
Unit
inches
mm
inches
mm
inches
mm
inches
mm
inches
mm
RoHS Compliance
Standard
Product
Series
Description
CML
Package /
Standard
Type
Compliant
SMD
YES
Composition
Lead-Free
Mfg. Effective Date
Always
Lead-Free
Effective Date
Code
(YY/WW)
Always
Conflict Minerals.
Rev Date: 6/13/2023
9
www.seielect.com
