TSL2561T
TSL2561T
    AMSOSRAM(艾迈斯半导体)
    TMB6
    环境光传感器 TMB-6 Ambient 2.7~3.6V
TSL2561T 数据手册
TSL2561 Light-to-Digital Converter General Description The TSL2561 are light-to-digital converters that transform light intensity to a digital signal output capable of direct I²C interface. Each device combines one broadband photodiode (visible plus infrared) and one infrared-responding photodiode on a single CMOS integrated circuit capable of providing a near-photopic response over an effective 20-bit dynamic range (16-bit resolution). Two integrating ADCs convert the photodiode currents to a digital output that represents the irradiance measured on each channel. This digital output can be input to a microprocessor where illuminance (ambient light level) in lux is derived using an empirical formula to approximate the human eye response. The TSL2561 device supports a traditional level style interrupt that remains asserted until the firmware clears it. While useful for general purpose light sensing applications, the TSL2561 devices are designed particularly for display panels (LCD, OLED, etc.) with the purpose of extending battery life and providing optimum viewing in diverse lighting conditions. Display panel backlighting, which can account for up to 30 to 40 percent of total platform power, can be automatically managed. Both devices are also ideal for controlling keyboard illumination based upon ambient lighting conditions. Illuminance information can further be used to manage exposure control in digital cameras. The TSL2561 devices are ideal in notebook/tablet PCs, LCD monitors, flat-panel televisions, cell phones, and digital cameras. In addition, other applications include street light control, security lighting, sunlight harvesting, machine vision, and automotive instrumentation clusters. Ordering Information and Content Guide appear at end of datasheet. ams Datasheet [v1-01] 2018-Apr-23 Page 1 Document Feedback TSL2561 − General Description Key Benefits & Features The benefits and features of TSL2561, Light-to-Digital Converter is listed below: Figure 1: Added Value of Using TSL2561 Benefits Features • Enables Operation in IR Light Environments • Patented Dual-Diode Architecture • Enables Dark Room to High Lux Sunlight Operation • 1M:1 Dynamic Range • Reduces Micro-Processor Interrupt Overhead • Programmable Interrupt Function • Digital Interface is Less Susceptible to Noise • I2C Digital Interface • Reduces Board Space Requirements while Simplifying Designs • Available in 2.6mm x 3.8mm TMB Packages • Approximates Human Eye Response • Programmable Interrupt Function with User-Defined Upper and Lower Threshold Settings • 16-Bit Digital Output with I²C Fast-Mode at 400kHz • Programmable Analog Gain and Integration Time Supporting 1,000,000-to-1 Dynamic Range • Automatically Rejects 50/60Hz Lighting Ripple • Low Active Power (0.75mW typical) with Power Down Mode Page 2 Document Feedback ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − General Description Block Diagram The functional blocks of this device are shown below: Figure 2: TSL2561 Block Diagram Channel 0 Visible and IR VDD = 2.7 V to 3.5 V ADDR SEL Integrating A/D Converter Channel 1 IR Only Address Select Command Register ADC Register Interrupt INT SCL Two-Wire Serial Interface SDA ams Datasheet [v1-01] 2018-Apr-23 Page 3 Document Feedback TSL2561 − Detailed Description Detailed Description The TSL2561 is a second-generation ambient light sensor device. It contains two integrating analog-to-digital converters (ADC) that integrate currents from two photodiodes. Integration of both channels occurs simultaneously. Upon completion of the conversion cycle, the conversion result is transferred to the Channel 0 and Channel 1 data registers, respectively. The transfers are double-buffered to ensure that the integrity of the data is maintained. After the transfer, the device automatically begins the next integration cycle. Communication to the device is accomplished through a standard, two wire I²C serial bus. Consequently, the TSL2561 device can be easily connected to a microcontroller or embedded controller. No external circuitry is required for signal conditioning, thereby saving PCB real estate as well. Since the output of the TSL2561 device is digital, the output is effectively immune to noise when compared to an analog signal. The TSL2561 device also supports an interrupt feature that simplifies and improves system efficiency by eliminating the need to poll a sensor for a light intensity value. The primary purpose of the interrupt function is to detect a meaningful change in light intensity. The concept of a meaningful change can be defined by the user both in terms of light intensity and time, or persistence, of that change in intensity. The TSL2561 device has the ability to define a threshold above and below the current light level. An interrupt is generated when the value of a conversion exceeds either of these limits. Page 4 Document Feedback ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Pin Assignments The TSL2561 pin assignments are described below: Pin Assignments Figure 3: Pin Diagram of Package T 6-Lead TMB (Top View) Package T 6-Lead TMB: Package drawings are not to scale 6 SDA VDD 1 5 INT ADDR SEL 2 4 SCL GND 3 Figure 4: Terminal Functions Terminal Type Description Name Pin No. ADDR SEL 2 GND 3 INT 5 O Interrupt - open drain output (active low) SCL 4 I I2C serial clock input terminal SDA 6 I/O VDD 1 ams Datasheet [v1-01] 2018-Apr-23 I I2C address select - three-state Power supply ground. All voltages are referenced to GND. I2C serial data I/O terminal Supply voltage Page 5 Document Feedback TSL2561 − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 5: Absolute Maximum Ratings over Operating Free-Air Temperature Range (unless otherwise noted) Symbol Parameter Min Max Unit 3.8 V -0.5 3.8 V VDD Supply voltage (1) VO Digital output voltage range IO Digital output current -1 20 mA Storage temperature range -40 85 °C Tstrg ESDHBM ESD tolerance, human body model ±2000 V Note(s): 1. All voltages are with respect to GND. Page 6 Document Feedback ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Electrical Characteristics Electrical Characteristics All limits are guaranteed. The parameters with min and max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. Figure 6: Recommended Operating Conditions Symbol Min Nom Max Unit Supply voltage 2.7 3 3.6 V TA Operating free-air temperature -30 70 °C VIL SCL, SDA input low voltage -0.5 0.8 V VIH SCL, SDA input high voltage 2.1 3.6 V VDD Parameter Figure 7: Electrical Characteristics over Recommended Operating Free-Air Temperature Range (unless otherwise noted) Symbol IDD VOL ILEAK Parameter Test Conditions Min Typ Max Unit Active 0.24 0.6 mA Power down 3.2 15 μA Supply current 3mA sink current 0 0.4 V 6mA sink current 0 0.6 V -5 5 μA INT, SDA output low voltage Leakage current ams Datasheet [v1-01] 2018-Apr-23 Page 7 Document Feedback TSL2561 − Electrical Characteristics Figure 8: Operating Characteristics, High Gain (16×), VDD = 3V, TA = 25°C (unless otherwise noted) (1), (2), (3), (4) Symbol fOSC Parameter Test Conditions TSL2561T Channel Oscillator frequency Dark ADC count value Ee = 0, Tint = 402ms Unit Min Typ Max 690 735 780 Ch0 0 4 Ch1 0 4 kHz counts Ch0 65535 Ch1 65535 Ch0 37177 Ch1 37177 Ch0 5047 Ch1 5047 Tint > 178ms Full scale ADC count value (5) Tint = 101ms counts Tint = 13.7ms λp = 640nm, Tint = 101ms Ch0 Ee = 36.3μW/cm2 Ch1 λp = 940nm, Tint = 101ms Ch0 Ee = 119μW/cm2 Ch1 λp = 640nm, Tint = 101ms Ch0 Ee = 41μW/cm2 Ch1 λp = 940nm, Tint = 101ms Ch0 Ee = 135μW/cm2 Ch1 750 1000 1250 200 counts ADC count value 700 1000 1300 820 counts ADC count value ratio: Ch1/Ch0 Re Irradiance responsivity Page 8 Document Feedback λp = 640nm, Tint = 101ms 0.15 0.20 0.25 λp = 940nm, Tint = 101ms 0.69 0.82 0.95 λp = 640nm, Tint = 101ms λp = 940nm, Tint = 101ms Ch0 27.5 Ch1 5.5 Ch0 8.4 Ch1 6.9 counts/ (μW/cm2) ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Electrical Characteristics Symbol Rv Parameter Illuminance responsivity ADC count value ratio: Ch1/Ch0 RV Illuminance responsivity, low gain mode (6) (Sensor Lux)/(actual Lux), high gain mode (7) Test Conditions TSL2561T Channel Unit Min Typ Fluorescent light source: Tint = 402ms Ch0 36 Ch1 4 Incandescent light source: Tint = 402ms Ch0 144 Ch1 72 Max counts/lux Fluorescent light source: Tint = 402ms 0.11 Incandescent light source: Tint = 402ms 0.5 Fluorescent light source: Tint = 402ms Ch0 2.3 Ch1 0.25 Incandescent light source: Tint = 402ms Ch0 9 Ch1 4.5 counts/lux Fluorescent light source: Tint = 402ms 0.65 1 1.35 Incandescent light source: Tint = 402ms 0.60 1 1.40 Note(s): 1. Optical measurements are made using small-angle incident radiation from light-emitting diode optical sources. Visible 640nm LEDs and infrared 940nm LEDs are used for final product testing for compatibility with high-volume production. 2. The 640nm irradiance E e is supplied by an AlInGaP light-emitting diode with the following characteristics: peak wavelength λ p = 640nm and spectral halfwidth Δλ½ = 17nm. 3. The 940nm irradiance Ee is supplied by a GaAs light-emitting diode with the following characteristics: peak wavelength λp = 940nm and spectral halfwidth Δλ½ = 40nm. 4. Integration time T int, is dependent on internal oscillator frequency (f osc) and on the integration field value in the timing register as described in the Register Set section. For nominal f osc = 735kHz, nominal Tint = (number of clock cycles)/f osc. Field value 00: T int = (11 × 918)/f osc = 13.7ms Field value 01: T int = (81 × 918)/f osc = 101ms Field value 10: T int = (322 × 918)/f osc = 402ms Scaling between integration times vary proportionally as follows: 11/322 = 0.034 (field value 00), 81/322 = 0.252 (field value 01), and 322/322 = 1 (field value 10). 5. Full scale ADC count value is limited by the fact that there is a maximum of one count per two oscillator frequency periods and also by a 2-count offset. Full scale ADC count value = ((number of clock cycles)/2 − 2) Field value 00: Full scale ADC count value = ((11 × 918)/2 − 2) = 5047 Field value 01: Full scale ADC count value = ((81 × 918)/2 − 2) = 37177 Field value 10: Full scale ADC count value = 65535, which is limited by 16-bit register. This full scale ADC count value is reached for 131074 clock cycles, which occurs for T int = 178ms for nominal f osc = 735kHz. ams Datasheet [v1-01] 2018-Apr-23 Page 9 Document Feedback TSL2561 − Electrical Characteristics 6. Low gain mode has 16× lower gain than high gain mode: (1/16 = 0.0625). 7. The sensor Lux is calculated using the empirical formula shown in Calculating Lux of this data sheet based on measured Ch0 and Ch1 ADC count values for the light source specified. Actual Lux is obtained with a commercial luxmeter. The range of the (sensor Lux) / (actual Lux) ratio is estimated based on the variation of the 640nm and 940nm optical parameters. Devices are not 100% tested with fluorescent or incandescent light sources. Figure 9: AC Electrical Characteristics, VDD = 3V, TA = 25°C (unless otherwise noted) Parameter (1) Symbol Min Typ Max Unit Conversion time 12 100 400 ms f(SCL) Clock frequency (I²C) 0 400 kHz t(BUF) Bus free time between start and stop condition 1.3 μs t(HDSTA) Hold time after (repeated) start condition. After this period, the first clock is generated. 0.6 μs t(SUSTA) Repeated start condition setup time 0.6 μs t(SUSTO) Stop condition setup time 0.6 μs t(HDDAT) Data hold time 0 t(SUDAT) Data setup time 100 ns t(LOW) SCL clock low period 1.3 μs t(HIGH) SCL clock high period 0.6 μs t(CONV) Test Conditions 0.9 μs tF Clock/data fall time 300 ns tR Clock/data rise time 300 ns Ci Input pin capacitance 10 pF Note(s): 1. Specified by design and characterization; not production tested. Page 10 Document Feedback ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Electrical Characteristics Figure 10: Timing Diagrams t(LOW) t(R) t(F) VIH SCL VIL t(HDSTA) t(BUF) t(HIGH) t(HDDAT) t(SUSTA) t(SUSTO) t(SUDAT) VIH SDA VIL P Stop Condition S S Start Condition Start P Stop t(LOWSEXT) SCLACK SCLACK t(LOWMEXT) t(LOWMEXT) t(LOWMEXT) SCL SDA ams Datasheet [v1-01] 2018-Apr-23 Page 11 Document Feedback TSL2561 − Typical Characteristics Typical Characteristics Figure 11: Spectral Responsivity 1 Normalized Responsivity 0.8 Channel 0 Photodiode 0.6 0.4 0.2 Channel 1 Photodiode 0 300 400 500 600 700 800 900 1000 1100 λ − Wavelength − nm Figure 12: Normalized Responsivity vs. Angular Displacement T Package 1.0 Optical Axis Normalized Responsivity 0.8 0.6 0.4 0.2 0 −90 Page 12 Document Feedback −60 −30 0 30 60  − Angular Displacement − ° 90 ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Principles of Operation Principles of Operation Analog-to-Digital Converter The TSL2561 contains two integrating analog-to-digital converters (ADC) that integrate the currents from the channel 0 and channel 1 photodiodes. Integration of both channels occurs simultaneously, and upon completion of the conversion cycle the conversion result is transferred to the channel 0 and channel 1 data registers, respectively. The transfers are double buffered to ensure that invalid data is not read during the transfer. After the transfer, the device automatically begins the next integration cycle. Digital Interface Interface and control of the TSL2561 is accomplished through a two-wire serial interface to a set of registers that provide access to device control functions and output data. The serial interface is compatible with I²C bus Fast-Mode. The TSL2561 offers three slave addresses that are selectable via an external pin (ADDR SEL). The slave address options are shown in Figure 13. Figure 13: Slave Address Selection ADDR SEL Terminal Level Slave Address GND 0101001 Float 0111001 VDD 1001001 Note(s): 1. The Slave Addresses are 7 bits. A read/write bit should be appended to the slave address by the master device to properly communicate with the TSL2561 device. ams Datasheet [v1-01] 2018-Apr-23 Page 13 Document Feedback TSL2561 − Principles of Operation Register Set The TSL2561 is controlled and monitored by sixteen registers (three are reserved) and a Command Register accessed through the serial interface. These registers provide for a variety of control functions and can be read to determine results of the ADC conversions. The Register Set is summarized in Figure 14. Figure 14: Register Address Address Register Name Register Function -- COMMAND Specifies register address 0h CONTROL Control of basic functions 1h TIMING 2h THRESHLOWLOW Low byte of low interrupt threshold 3h THRESHLOWHIGH High byte of low interrupt threshold 4h THRESHHIGHLOW Low byte of high interrupt threshold 5h THRESHHIGHHIGH High byte of high interrupt threshold 6h INTERRUPT 7h -- 8h CRC 9h -- Reserved Ah ID Part number/Rev ID Bh -- Reserved Ch DATA0LOW Low byte of ADC channel 0 Dh DATA0HIGH High byte of ADC channel 0 Eh DATA1LOW Low byte of ADC channel 1 Fh DATA1HIGH High byte of ADC channel 1 Integration time/gain control Interrupt control Reserved Factory test - not a user register The mechanics of accessing a specific register depends on the specific I 2C protocol used. Refer to the section on I 2C protocols. In general, the Command Register is written first to specify the specific control/status register for following read/write operations. Page 14 Document Feedback ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Principles of Operation Command Register The Command Register specifies the address of the target register for subsequent read and write operations. The Send Byte protocol is used to configure the Command Register. The Command Register contains eight bits as described in Figure 15. The Command Register defaults to 00h at power on. Figure 15: Command Register 7 6 5 4 CMD CLEAR WORD BLOCK 3 2 1 0 ADDRESS Field Bit Description CMD 7 Select Command Register. Must write as 1. CLEAR 6 Interrupt clear. Clears any pending interrupt. This bit is a write-one-to-clear bit. It is self clearing. WORD 5 I 2C Write/Read Word Protocol. 1 indicates that this I 2C transaction is using either the I2C Write Word or Read Word protocol. BLOCK 4 Block Write/Read Protocol. 1 indicates that this transaction is using either the Block Write or the Block Read protocol.(1) ADDRESS 3:0 Register Address. This field selects the specific control or status register for following write and read commands according to Figure 14. Note(s): 1. An I²C block transaction will continue until the Master sends a stop condition. ams Datasheet [v1-01] 2018-Apr-23 Page 15 Document Feedback TSL2561 − Principles of Operation Control Register (0h) The Control Register contains two bits and is primarily used to power the TSL2561 device up and down as shown in Figure 16. Figure 16: Control Register 7 6 5 4 3 2 Resv Resv Resv Resv Resv Resv 1 0 POWER Field Bit Description Resv 7:2 Reserved. Write as 0. POWER 1:0 Power up/power down. By writing a 03h to this register, the device is powered up. By writing a 00h to this register, the device is powered down(1). Note(s): 1. If a value of 03h is written, the value returned during a read cycle will be 03h. This feature can be used to verify that the device is communicating properly. Timing Register (1h) The Timing Register controls both the integration time and the gain of the ADC channels. A common set of control bits is provided that controls both ADC channels. The Timing Register defaults to 02h at power on. Figure 17: Timing Register 7 6 5 4 3 2 Resv Resv Resv GAIN Manual Resv 1 0 INTEG Field Bit Description Resv 7:5 GAIN 4 Switches gain between low gain and high gain modes. Writing a 0 selects low gain (1×); writing a 1 selects high gain (16×). Manual 3 Manual timing control. Writing a 1 begins an integration cycle. Writing a 0 stops an integration cycle(1) Resv 2 Reserved. Write as 0. INTEG 1:0 Reserved. Write as 0. Integrate time. This field selects the integration time for each conversion. Note(s): 1. This field only has meaning when INTEG = 11. It is ignored at all other times. Page 16 Document Feedback ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Principles of Operation Integration time is dependent on the INTEG FIELD VALUE and the internal clock frequency. Nominal integration times and respective scaling between integration times scale proportionally as shown in Figure 18. See Note4 and Note5 for detailed information regarding how the scale values were obtained; see Calculating Lux for further information on how to calculate lux. Figure 18: Integration Time INTEG Field Value Scale Nominal Integration Time 00 0.034 13.7ms 01 0.252 101ms 10 1 402ms 11 -- N/A The manual timing control feature is used to manually start and stop the integration time period. If a particular integration time period is required that is not listed in Figure 18, then this feature can be used. For example, the manual timing control can be used to synchronize the TSL256x device with an external light source (e.g. LED). A start command to begin integration can be initiated by writing a 1 to this bit field. Correspondingly, the integration can be stopped by simply writing a 0 to the same bit field. Interrupt Threshold Register (2h − 5h) The Interrupt Threshold registers store the values to be used as the high and low trigger points for the comparison function for interrupt generation. If the value generated by channel 0 crosses below or is equal to the low threshold specified, an interrupt is asserted on the interrupt pin. If the value generated by channel 0 crosses above the high threshold specified, an interrupt is asserted on the interrupt pin. Registers THRESHLOWLOW and THRESHLOWHIGH provide the low byte and high byte, respectively, of the lower interrupt threshold. Registers THRESHHIGHLOW and THRESHHIGHHIGH provide the low and high bytes, respectively, of the upper interrupt threshold. The high and low bytes from each set of registers are combined to form a 16-bit threshold value. The interrupt threshold registers default to 00h on power up. ams Datasheet [v1-01] 2018-Apr-23 Page 17 Document Feedback TSL2561 − Principles of Operation Figure 19: Interrupt Threshold Register Register Address Bits Description THRESHLOWLOW 2h 7:0 ADC channel 0 lower byte of the low threshold THRESHLOWHIGH 3h 7:0 ADC channel 0 upper byte of the low threshold THRESHHIGHLOW 4h 7:0 ADC channel 0 lower byte of the high threshold THRESHHIGHHIGH 5h 7:0 ADC channel 0 upper byte of the high threshold Note(s): 1. Since two 8-bit values are combined for a single 16-bit value for each of the high and low interrupt thresholds, the Send Byte protocol should not be used to write to these registers. Any values transferred by the Send Byte protocol with the MSB set would be interpreted as the COMMAND field and stored as an address for subsequent read/write operations and not as the interrupt threshold information as desired. The Write Word protocol should be used to write byte-paired registers. For example, the THRESHLOWLOW and THRESHLOWHIGH registers (as well as the THRESHHIGHLOW and THRESHHIGHHIGH registers) can be written together to set the 16-bit ADC value in a single transaction. Interrupt Control Register (6h) The Interrupt Register controls the extensive interrupt capabilities of the TSL2561.The interrupt persist bit field (PERSIST) provides control over when interrupts occur. A value of 0 causes an interrupt to occur after every integration cycle regardless of the threshold settings. A value of 1 results in an interrupt after one integration time period outside the threshold window. A value of N (where N is 2 through15) results in an interrupt only if the value remains outside the threshold window for N consecutive integration cycles. For example, if N is equal to 10 and the integration time is 402ms, then the total time is approximately 4 seconds. When a level Interrupt is selected, an interrupt is generated whenever the last conversion results in a value outside of the programmed threshold window. The interrupt is active-low and remains asserted until cleared by writing the Command Register with the CLEAR bit set. Note(s): Interrupts are based on the value of Channel 0 only. Figure 20: Interrupt Control Register 7 6 Resv Resv 5 4 3 2 INTR 1 0 PERSIST Field Bits Resv 7:6 Reserved. Write as 0. INTR 5:4 INTR Control Select. This field determines mode of interrupt logic according to Figure 21, below. Page 18 Document Feedback Description ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Principles of Operation Field Bits Description PERSIST 3:0 Interrupt persistence. Controls rate of interrupts to the host processor as shown in Figure 22, below. Figure 21: Interrupt Control Select INTR Field Value Read Value 00 Interrupt output disabled 01 Level Interrupt 10 Reserved 11 Test Mode: Sets interrupt and functions as mode 10 Note(s): 1. Field value of 11 may be used to test interrupt connectivity in a system or to assist in debugging interrupt service routine software. Figure 22: Interrupt Persistence Select Persist Field Value Interrupt Persist Function 0000 Every ADC cycle generates interrupt 0001 Any value outside of threshold range 0010 2 integration time periods out of range 0011 3 integration time periods out of range 0100 4 integration time periods out of range 0101 5 integration time periods out of range 0110 6 integration time periods out of range 0111 7 integration time periods out of range 1000 8 integration time periods out of range 1001 9 integration time periods out of range 1010 10 integration time periods out of range 1011 11 integration time periods out of range 1100 12 integration time periods out of range 1101 13 integration time periods out of range 1110 14 integration time periods out of range 1111 15 integration time periods out of range ams Datasheet [v1-01] 2018-Apr-23 Page 19 Document Feedback TSL2561 − Principles of Operation ID Register (Ah) The ID Register provides the value for both the part number and silicon revision number for that part number. It is a read-only register, whose value never changes. Figure 23: ID Register 7 6 5 4 3 2 PARTNO Field 1 0 REVNO Bits Description Part Number Identification: PARTNO REVNO Page 20 Document Feedback 7:4 3:0 Field Value Device Number 0101 TSL2561T Revision number identification ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Principles of Operation ADC Channel Data Registers (Ch − Fh) The ADC channel data are expressed as 16-bit values spread across two registers. The ADC channel 0 data registers, DATA0LOW and DATA0HIGH provide the lower and upper bytes, respectively, of the ADC value of channel 0. Registers DATA1LOW and DATA1HIGH provide the lower and upper bytes, respectively, of the ADC value of channel 1. All channel data registers are read-only and default to 00h on power up. Figure 24: ADC Channel Data Registers Register Address Bits Description DATA0LOW Ch 7:0 ADC channel 0 lower byte DATA0HIGH Dh 7:0 ADC channel 0 upper byte DATA1LOW Eh 7:0 ADC channel 1 lower byte DATA1HIGH Fh 7:0 ADC channel 1 upper byte The upper byte data registers can only be read following a read to the corresponding lower byte register. When the lower byte register is read, the upper eight bits are strobed into a shadow register, which is read by a subsequent read to the upper byte. The upper register will read the correct value even if additional ADC integration cycles end between the reading of the lower and upper registers. Note(s): The Read Word protocol can be used to read byte-paired registers. For example, the DATA0LOW and DATA0HIGH registers (as well as the DATA1LOW and DATA1HIGH registers) may be read together to obtain the 16-bit ADC value in a single transaction. ams Datasheet [v1-01] 2018-Apr-23 Page 21 Document Feedback TSL2561 − Device Operation Device Operation Basic Operation After applying V DD, the device will initially be in the power-down state. To operate the device, issue a command to access the Control Register followed by the data value 03h to power up the device. At this point, both ADC channels will begin a conversion at the default integration time of 400ms. After 400ms, the conversion results will be available in the DATA0 and DATA1 registers. Configuring the Timing Register The command, timing, and control registers are initialized to default values on power up. Setting these registers to the desired values would be part of a normal initialization or setup procedure. In addition, to maximize the performance of the device under various conditions, the integration time and gain may be changed often during operation. Interrupts The interrupt feature of the TSL2561 device simplifies and improves system efficiency by eliminating the need to poll the sensor for a light intensity value. Interrupt styles are determined by the INTR field in the Interrupt Register. The interrupt feature may be disabled by writing a field value of 00h to the Interrupt Control Register so that polling can be performed. The versatility of the interrupt feature provides many options for interrupt configuration and usage. The primary purpose of the interrupt function is to provide a meaningful change in light intensity. However, it also be used as an end-of-conversion signal. The concept of a meaningful change can be defined by the user both in terms of light intensity and time, or persistence, of that change in intensity. The TSL2561 device implements two 16-bit-wide interrupt threshold registers that allow the user to define a threshold above and below the current light level. An interrupt will then be generated when the value of a conversion exceeds either of these limits. For simplicity of programming, the threshold comparison is accomplished only with Channel 0. This simplifies calculation of thresholds that are based, for example, on a percent of the current light level. It is adequate to use only one channel when calculating light intensity differences since, for a given light source, the channel 0 and channel 1 values are linearly proportional to each other and thus both values scale linearly with light intensity. To further control when an interrupt occurs, the TSL2561 device provides an interrupt persistence feature. This feature allows the user to specify a number of conversion cycles for which a light intensity exceeding either interrupt threshold must persist before actually generating an interrupt. This can be used to Page 22 Document Feedback ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Device Operation prevent transient changes in light intensity from generating an unwanted interrupt. With a value of 1, an interrupt occurs immediately whenever either threshold is exceeded. With values of N, where N can range from 2 to 15, N consecutive conversions must result in values outside the interrupt window for an interrupt to be generated. For example, if N is equal to 10 and the integration time is 402ms, then an interrupt will not be generated unless the light level persists for more than 4 seconds outside the threshold. An interrupt is cleared by setting the CLEAR bit (bit 6) in the Command Register. To configure the interrupt as an end-of-conversion signal, the interrupt PERSIST field is set to 0. An interrupt will be generated upon completion of each conversion. The interrupt threshold registers are ignored. In order to generate an interrupt on demand during system test or debug, a test mode (INTR = 11) can be used. Calculating Lux The TSL2561 is intended for use in ambient light detection applications such as display backlight control, where adjustments are made to display brightness or contrast based on the brightness of the ambient light, as perceived by the human eye. Conventional silicon detectors respond strongly to infrared light, which the human eye does not see. This can lead to significant error when the infrared content of the ambient light is high, such as with incandescent lighting, due to the difference between the silicon detector response and the brightness perceived by the human eye. This problem is overcome in the TSL2561 through the use of two photodiodes. One of the photodiodes (channel 0) is sensitive to both visible and infrared light, while the second photodiode (channel 1) is sensitive primarily to infrared light. An integrating ADC converts the photodiode currents to digital outputs. Channel 1 digital output is used to compensate for the effect of the infrared component of light on the channel 0 digital output. The ADC digital outputs from the two channels are used in a formula to obtain a value that approximates the human eye response in the commonly used Illuminance unit of Lux: ams Datasheet [v1-01] 2018-Apr-23 Page 23 Document Feedback TSL2561 − Device Operation T Package For 0 < CH1/CH0 ≤ 0.50 Lux = 0.0304 × CH0 - 0.062 × CH0 × ((CH1/CH0) 1.4) For 0.50 < CH1/CH0 ≤ 0.61 Lux = 0.0224 × CH0 - 0.031 × CH1 For 0.61 < CH1/CH0 ≤ 0.80 Lux = 0.0128 × CH0 - 0.0153 × CH1 For 0.80 < CH1/CH0 ≤ 1.30 Lux = 0.00146 × CH0 - 0.00112 × CH1 For CH1/CH0 > 1.30 Lux = 0 The formulas shown above were obtained by optical testing with fluorescent and incandescent light sources, and apply only to open-air applications. Optical apertures (e.g. light pipes) will affect the incident light on the device. Page 24 Document Feedback ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Application Information: Hardware Application Information: Hardware Power Supply Decoupling and Application Hardware Circuit The power supply lines must be decoupled with a 0.1μF capacitor placed as close to the device package as possible (Figure 25). The bypass capacitor should have low effective series resistance (ESR) and low effective series inductance (ESI), such as the common ceramic types, which provide a low impedance path to ground at high frequencies to handle transient currents caused by internal logic switching. Figure 25: Bus Pull-Up Resistors VBUS RP RP VDD RPI TSL2560/ TSL2561 0.1 F INT SCL SDA Pull-up resistors (R p) maintain the SDAH and SCLH lines at a high level when the bus is free and ensure the signals are pulled up from a low to a high level within the required rise time. For a complete description of I²C maximum and minimum R p values, please review the I²C Specification at http://www.nxp.com. A pull-up resistor (RPI) is also required for the interrupt (INT), which functions as a wired-AND signal in a similar fashion to the SCL and SDA lines. A typical impedance value between 10kΩ and 100kΩ can be used. Please note that while Figure 25 shows INT being pulled up to V DD, the interrupt can optionally be pulled up to V BUS. ams Datasheet [v1-01] 2018-Apr-23 Page 25 Document Feedback TSL2561 − Application Information: Hardware PCB Pad Layout Suggested PCB pad layout guidelines for the TMB-6 (T) surface mount package is shown in Figure 26. Figure 26: Suggested T Package PCB Layout 3.80 0.90 0.90 0.25 0.70 2.60 0.70 0.70 Note(s): 1. All linear dimensions are in millimeters. 2. This drawing is subject to change without notice. Page 26 Document Feedback ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Packaging Mechanical Data Packaging Mechanical Data Figure 27: Package T - Six-Lead TMB Plastic Surface Mount Packaging Configuration PACKAGE TMB-6 Six-Lead Surface Mount Device TOP VIEW TOP VIEW 1.90 0.31 PIN 1 R 0.20 6 Pls 2.60 PIN 4 3.80 Photo-Active Area END VIEW 0.88 1.35 0.50 BOTTOM VIEW 0.90 TYP 0.90 TYP 0.60 TYP 0.30 TYP 0.30 TYP Pb Lead Free Note(s): 1. All linear dimensions are in millimeters. Dimension tolerance is ±0.20mm unless otherwise noted. 2. The photo-active area is 1398μm by 203μm. 3. Package top surface is molded with an electrically nonconductive clear plastic compound having an index of refraction of 1.55. 4. Contact finish is 0.5μm minimum of soft gold plated over a 18μm thick copper foil pattern with a 5μm to 9μm nickel barrier. 5. The underside of the package includes copper traces used to connect the pads during package substrate fabrication. Accordingly, exposed traces and vias should not be placed under the footprint of the TMB package in a PCB layout. 6. This package contains no lead (Pb). 7. This drawing is subject to change without notice. ams Datasheet [v1-01] 2018-Apr-23 Page 27 Document Feedback TSL2561 − Packaging Mechanical Data Figure 28: TSL2561 TMB Carrier Tape 0.30  0.050 2.10 SIDE VIEW 1.75  0.100 B  1.50 4  0.100 END VIEW 2  0.100 8 Typ TOP VIEW 12  0.100 5.50  0.100  1.50 R 0.20 TYP B A A DETAIL B DETAIL A 2.90  0.100 Ao 3.09 MAX R 0.20 TYP R 0.20 TYP 4.29 MAX 4.10  0.100 Bo 1.80 Ko Note(s): 1. All linear dimensions are in millimeters. 2. The dimensions on this drawing are for illustrative purposes only. Dimensions of an actual carrier may vary slightly. 3. Symbols on drawing A o, Bo, and K o are defined in ANSI EIA Standard 481-B 2001. 4. Each reel is 178 millimeters in diameter and contains 1000 parts. 5. ams AG packaging tape and reel conform to the requirements of EIA Standard 481-B. 6. In accordance with EIA standard, device pin 1 is located next to the sprocket holes in the tape. 7. This drawing is subject to change without notice. Page 28 Document Feedback ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Manufacturing Information Manufacturing Information The T packages have been tested and have demonstrated an ability to be reflow soldered to a PCB substrate. The process, equipment, and materials used in these test are detailed below. The solder reflow profile describes the expected maximum heat exposure of components during the solder reflow process of product on a PCB. Temperature is measured on top of component. The components should be limited to a maximum of three passes through this solder reflow profile. Figure 29: TSL2561 Solder Reflow Profile Parameter Reference TSL2561 Average temperature gradient in preheating Soak time 2.5°C/s tsoak 2 to 3 minutes Time above 217°C t1 Max 60 s Time above 230°C t2 Max 50 s Time above Tpeak -10°C t3 Max 10 s Tpeak 260° C (-0°C/+5°C) Peak temperature in reflow Temperature gradient in cooling Max -5°C/s Figure 30: TSL2561 Solder Reflow Profile Graph Tpeak Not to scale — for reference only T3 T2 Temperature (C) T1 Time (s) t3 t2 tsoak ams Datasheet [v1-01] 2018-Apr-23 t1 Page 29 Document Feedback TSL2561 − Manufacturing Information Moisture Sensitivity Optical characteristics of the device can be adversely affected during the soldering process by the release and vaporization of moisture that has been previously absorbed into the package molding compound. To ensure the package molding compound contains the smallest amount of absorbed moisture possible, each device is dry-baked prior to being packed for shipping. Devices are packed in a sealed aluminized envelope with silica gel to protect them from ambient moisture during shipping, handling, and storage before use. The T package have been assigned a moisture sensitivity level of MSL 3 and the devices should be stored under the following conditions: • Temperature Range: 5°C to 50°C • Relative Humidity: 60% maximum • Total Time: 6 months from the date code on the aluminized envelope - if unopened • Opened Time: 168 hours or fewer Rebaking will be required if the devices have been stored unopened for more than 6 months or if the aluminized envelope has been open for more than 168 hours. If rebaking is required, it should be done at 90°C for 4 hours. Page 30 Document Feedback ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Ordering & Contact Information Ordering & Contact Information Figure 31: Ordering Information Ordering Code Device Interface Package - Leads Package Designator TSL2561T TSL2561 I²C TMB-6 T Buy our products or get free samples online at: www.ams.com/ICdirect Technical Support is available at: www.ams.com/Technical-Support Provide feedback about this document at: www.ams.com/Document-Feedback For further information and requests, e-mail us at: ams_sales@ams.com For sales offices, distributors and representatives, please visit: www.ams.com/contact Headquarters ams AG Tobelbader Strasse 30 8141 Premstaetten Austria, Europe Tel: +43 (0) 3136 500 0 Website: www.ams.com ams Datasheet [v1-01] 2018-Apr-23 Page 31 Document Feedback TSL2561 − RoHS Compliant & ams Green Statement RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories, including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams AG knowledge and belief as of the date that it is provided. ams AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams AG and ams AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. Page 32 Document Feedback ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams AG, Tobelbader Strasse 30, 8141 Premstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. This product is provided by ams AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. ams Datasheet [v1-01] 2018-Apr-23 Page 33 Document Feedback TSL2561 − Document Status Document Status Document Status Product Preview Preliminary Datasheet Datasheet Datasheet (discontinued) Page 34 Document Feedback Product Status Definition Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs ams Datasheet [v1-01] 2018-Apr-23 TSL2561 − Revision Information Revision Information Changes from 1-00 (2016-May-05) to current revision 1-01 (2018-Apr-23) Page Removed all instances of TSL2560CS/T/FN/CL and TSL2561CS/FN/CL Updated Figure 4 5 Removed I²C Protocols including figures Updated text under Figure 14 (Replaced all instances of SMBus with I2C) 14 Updated Figure 15 and notes under it (Replaced all instances of SMB with I2C) 15 Updated text under Interrupt Control Register (6h) 18 Updated Figure 21 19 Renamed “Application Information: Software” to “Device Operation” 22 Removed pseudo code under Basic Operation 22 Removed pseudo code under Configuring the Timing Register 22 Updated text and removed pseudo code under Interrupts 22 Removed Simplified Lux Calculation including pseudo code Note(s): 1. Page and figure numbers for the previous version may differ from page and figure numbers in the current revision. 2. Correction of typographical errors is not explicitly mentioned. ams Datasheet [v1-01] 2018-Apr-23 Page 35 Document Feedback TSL2561 − Content Guide Content Guide Page 36 Document Feedback 1 2 3 General Description Key Benefits & Features Block Diagram 4 5 6 7 12 Detailed Description Pin Assignments Absolute Maximum Ratings Electrical Characteristics Typical Characteristics 13 13 13 14 15 16 16 17 18 20 21 Principles of Operation Analog-to-Digital Converter Digital Interface Register Set Command Register Control Register (0h) Timing Register (1h) Interrupt Threshold Register (2h − 5h) Interrupt Control Register (6h) ID Register (Ah) ADC Channel Data Registers (Ch − Fh) 22 22 22 22 23 24 Device Operation Basic Operation Configuring the Timing Register Interrupts Calculating Lux T Package 25 25 26 Application Information: Hardware Power Supply Decoupling and Application Hardware Circuit PCB Pad Layout 27 Packaging Mechanical Data 29 30 Manufacturing Information Moisture Sensitivity 31 32 33 34 35 Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information ams Datasheet [v1-01] 2018-Apr-23 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: ams OSRAM: TSL2561T
TSL2561T 价格&库存
很抱歉,暂时无法提供与“TSL2561T”相匹配的价格&库存,您可以联系我们找货
