AC-DC Power Supplies PCB Mount Type
World wide Isolated
Safety
Approvals
OCP
OVP
TUHS-series
Feature
P.C.board mount AC-DC Converter
Design flexibility for Hold-Up time and expected life
Small size
Built-in overcurrent and overvoltage protection circuits
High efficiency by synchronous rectification technology
(TUHS25)
Not built-in aluminum and tantalum electrolytic capacitor
CE marking
Low voltage directive
RoHS Directive
UKCA marking
Electrical Equipment Safety Regulations
RoHS Regulations
Safety Approval
UL60950-1, C-UL, EN62368-1
5-year warranty
www.cosel.co.jp/en/
December 27, 2022
TUHS-1
Ordering information
TUHS3
TUH
1
S
2
3
3
F
05
4
5
1 Series name
2 Single output
3 Output wattage
4 Universal Input
5 Output voltage
R
ClassⅡ
*Avoid short circuit between +BC and -BC. It may cause the failure of inside components.
*To use TUHS, external components are required. Refer to the instruction manual for details.
MODEL
TUHS3F05
TUHS3F12
TUHS3F15
TUHS3F24
MAX OUTPUT WATTAGE[W]
3.00
3.00
3.00
3.12
DC OUTPUT
5V 0.6A
12V 0.25A
15V 0.2A
24V 0.13A
MODEL
TUHS3F05
TUHS3F12
TUHS3F15
TUHS3F24
VOLTAGE[V]
AC85 - 264 1f DC120 - 370
SPECIFICATIONS
CURRENT[A]
INPUT
0.08typ (Io=100%)
ACIN 200V
0.05typ (Io=100%)
FREQUENCY[Hz]
EFFICIENCY[%]
OUTPUT
ACIN 100V
50/60 (47 - 63)
ACIN 100V
79typ
81typ
81typ
81typ
ACIN 200V
78typ
79typ
79typ
79typ
INRUSH CURRENT
Limited by external components
VOLTAGE[V]
5
12
15
24
CURRENT[A]
0.6
0.25
0.2
0.13
LINE REGULATION[mV]
20max
48max
60max
96max
LOAD REGULATION[mV]
40max
100max
120max
150max
30 to 100% Load *1
RIPPLE[mVp-p] 0 to 30% Load
AC85V - 240V *1
30 to 100% Load *1
RIPPLE
0 to 30% Load
NOISE[mVp-p]
AC85V - 240V *1
0 to +85C
TEMPERATURE
REGULATION[mV] -40 to +85C
120max
160max
160max
200max
400max
480max
480max
580max
160max
200max
200max
240max
480max
560max
560max
660max
100max
180max
240max
360max
150max
270max
360max
480max
DRIFT[mV]
20max
48max
60max
96max
11.40 - 12.60
14.25 - 15.75
23.00 - 25.00
16.50 - 24.00
26.40 - 38.40
*2
OUTPUT VOLTAGE SETTING[V] 4.90 - 5.30
Works over 105% of rating and recover automatically
PROTECTION CIRCUIT OVERCURRENT PROTECTION
AND OTHERS
OVERVOLTAGE PROTECTION[V] 5.50 - 8.00
13.20 - 19.20
ISOLATION
ENVIRONMENT
SAFETY
AND NOISE
REGULATIONS
OTHERS
INPUT-OUTPUT
AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (20±15C)
OPERATING TEMP.,HUMID.AND ALTITUDE
-40 to +85C, 20 - 95%RH (Non condensing) (Refer to “Derating”), 3,000m (10,000 feet) max
STORAGE TEMP.,HUMID.AND ALTITUDE
-40 to +100C, 20 - 95%RH (Non condensing), 9,000m (30,000 feet) max
VIBRATION
10 - 55Hz, 49.0m/s2 (5G), 3minutes period, 60minutes each along X, Y and Z axis
IMPACT
196.1m/s2 (20G), 11ms, once each along X, Y and Z axis
AGENCY APPROVALS
UL60950-1, C-UL (CSA60950-1), EN62368-1
CONDUCTED NOISE
Complies with FCC-B,VCCI-B,CISPR-B,EN55022-B *3
HARMONIC ATTENUATOR Complies with IEC61000-3-2 (Class A) (Not built-in to active filter)
CASE SIZE/WEIGHT
28.7X12.7X17.5mm[1.13X0.50X0.69 inches] (WXHXD) / 15g max
COOLING METHOD
Convection / Forced air
*1 Refer to instruction manual for measuring method of electric characteristics.
*2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C, with the input voltage held constant at the rated value.
*3 Do not ground secondly circuit, in case of a standard adapted.
* Measured with 18μF capasitor as Cbc.
TUHS-2
December 27, 2022
www.cosel.co.jp/en/
TUHS3
External view
Name Plate
+BC
-BC
¶Recommending size for processing PCB
(TOP VIEW)
+Vout
AC2
-Vout
5.08
[0.2]
0.5
1±0.1
5.08
[0.2]
¶ Dimensions in :
[0.09]
2.3
2.3
[0.09]
5.08
[0.2]
7.82
[0.25]
¶ Div. : 0.2inch
[0.31]
[0.5]
[0.02]
24.1
[0.95]
6.4
3.5
[0.14]
12.9
17.5
[0.69]
[0.51]
12.7
12.9
[0.51]
6.4
[0.25]
AC1
mm
[inch]
¶ Tolerance : ±0.5 [±0.02]
¶ Weight : 15g max
¶ Case material : PBT
¶ Pin material : Copper
¶ Plating treatment of pin : Lead free plating
¶ Dimensions in mm, [ ]=inches
5.08
[0.2]
24.1
[0.95]
28.7
[1.13]
www.cosel.co.jp/en/
December 27, 2022
TUHS-3
TUHS5
TUH
1
S
2
5
3
F
05
4
5
1 Series name
2 Single output
3 Output wattage
4 Universal Input
5 Output voltage
R
ClassⅡ
MODEL
TUHS5F05
TUHS5F12
TUHS5F15
TUHS5F24
5.00
5.40
5.10
5.28
DC OUTPUT
5V 1A
12V 0.45A
15V 0.34A
24V 0.22A
MODEL
TUHS5F05
TUHS5F12
TUHS5F15
TUHS5F24
VOLTAGE[V]
SPECIFICATIONS
CURRENT[A]
INPUT
0.13typ (Io=100%)
ACIN 200V
0.08yp (Io=100%)
FREQUENCY[Hz]
EFFICIENCY[%]
OUTPUT
ACIN 100V
50/60 (47 - 63)
ACIN 100V
78typ
82typ
82typ
83typ
ACIN 200V
79typ
82typ
82typ
83typ
INRUSH CURRENT
VOLTAGE[V]
5
12
15
24
CURRENT[A]
1
0.45
0.34
0.22
LINE REGULATION[mV]
20max
48max
60max
96max
LOAD REGULATION[mV]
40max
100max
120max
150max
30 to 100% Load *1
AC85V - 240V *1
30 to 100% Load *1
RIPPLE
0 to 30% Load
NOISE[mVp-p]
AC85V - 240V *1
0 to +80C
TEMPERATURE
REGULATION[mV] -40 to +80C
120max
160max
160max
200max
400max
480max
480max
580max
160max
200max
200max
240max
480max
560max
560max
660max
100max
180max
240max
360max
150max
270max
360max
480max
DRIFT[mV]
20max
48max
60max
96max
11.40 - 12.60
14.25 - 15.75
23.00 - 25.00
16.50 - 24.00
26.40 - 38.40
*2
AND OTHERS
13.20 - 19.20
ISOLATION
ENVIRONMENT
SAFETY
AND NOISE
REGULATIONS
OTHERS
INPUT-OUTPUT
VIBRATION
IMPACT
AGENCY APPROVALS
CONDUCTED NOISE
CASE SIZE/WEIGHT
COOLING METHOD
* Measured with 22μF capasitor as Cbc.
TUHS-4
December 27, 2022
www.cosel.co.jp/en/
TUHS5
External view
Name Plate
+BC
-BC
(TOP VIEW)
+Vout
AC2
-Vout
5.08
[0.2]
0.5
1±0.1
5.08
[0.2]
¶ Dimensions in :
[0.09]
2.3
2.3
[0.09]
5.08
[0.2]
7.82
[0.25]
¶ Div. : 0.2inch
[0.31]
[0.5]
[0.02]
24.1
[0.95]
6.4
3.5
[0.14]
12.9
17.5
[0.69]
[0.51]
12.7
12.9
[0.51]
6.4
[0.25]
AC1
mm
[inch]
¶ Weight : 15g max
5.08
[0.2]
24.1
[0.95]
28.7
[1.13]
www.cosel.co.jp/en/
December 27, 2022
TUHS-5
TUHS10
TUH
1
S
2
10
3
F
05
4
5
1 Series name
2 Single output
3 Output wattage
4 Universal Input
5 Output voltage
R
ClassⅡ
MODEL
TUHS10F05
TUHS10F12
TUHS10F15
TUHS10F24
10.00
10.80
10.10
10.80
DC OUTPUT
5V 2A
12V 0.9A
15V 0.67A
24V 0.45A
MODEL
TUHS10F05
TUHS10F12
TUHS10F15
TUHS10F24
VOLTAGE[V]
SPECIFICATIONS
CURRENT[A]
INPUT
0.25typ (Io=100%)
ACIN 200V
0.14typ (Io=100%)
FREQUENCY[Hz]
EFFICIENCY[%]
OUTPUT
ACIN 100V
50/60 (47 - 63)
ACIN 100V
81typ
85typ
85typ
86typ
ACIN 200V
82typ
85typ
85typ
87typ
INRUSH CURRENT
VOLTAGE[V]
5
12
15
24
CURRENT[A]
2
0.9
0.67
0.45
LINE REGULATION[mV]
20max
48max
60max
96max
LOAD REGULATION[mV]
40max
100max
120max
150max
30 to 100% Load *1
AC85V - 240V *1
30 to 100% Load *1
RIPPLE
0 to 30% Load
NOISE[mVp-p]
AC85V - 240V *1
0 to +70C
TEMPERATURE
REGULATION[mV] -40 to +70C
120max
160max
160max
200max
400max
480max
480max
580max
160max
200max
200max
240max
480max
560max
560max
660max
100max
180max
240max
360max
150max
270max
360max
480max
DRIFT[mV]
20max
48max
60max
96max
11.40 - 12.60
14.25 - 15.75
23.00 - 25.00
16.50 - 24.00
26.40 - 38.40
*2
AND OTHERS
13.20 - 19.20
ISOLATION
ENVIRONMENT
SAFETY
AND NOISE
REGULATIONS
OTHERS
INPUT-OUTPUT
VIBRATION
IMPACT
AGENCY APPROVALS
CONDUCTED NOISE
CASE SIZE/WEIGHT
33.0X15.0X22.0mm[1.3X0.59X0.86 inches] (WXHXD) / 25g max
COOLING METHOD
* Measured with 47μF capasitor as Cbc.
TUHS-6
December 27, 2022
www.cosel.co.jp/en/
TUHS10
External view
Name Plate
+BC -BC
(TOP VIEW)
AC1
+Vout
AC2
5.08
[0.2]
28
[1.1]
7.62
[0.3]
0.5
[0.02]
2.5
2.5
[0.1]
7.62
[0.3]
9.38
[0.37]
6.4
[0.25]
¶ Dimensions in :
[0.1]
12.9
[0.51]
22
[0.87]
3.5
[0.14]
15
[0.59]
17
[0.67]
12.9
[0.51]
6.4
[0.25]
-Vout
¶ Div. : 0.2inch
mm
[inch]
¶ Weight : 25g max
5.08
[0.2]
28
[1.1]
33
[1.3]
www.cosel.co.jp/en/
December 27, 2022
TUHS-7
TUHS15
TUH
1
S
2
15
3
F
12
4
5
1 Series name
2 Single output
3 Output wattage
4 Universal Input
5 Output voltage
R
ClassⅡ
MODEL
TUHS15F12
TUHS15F15
TUHS15F24
15.00
15.00
15.12
DC OUTPUT
12V 1.25A
15V 1A
24V 0.63A
MODEL
TUHS15F12
TUHS15F15
TUHS15F24
VOLTAGE[V]
SPECIFICATIONS
CURRENT[A]
INPUT
0.35typ (Io=100%)
ACIN 200V
0.18typ (Io=100%)
FREQUENCY[Hz]
EFFICIENCY[%]
OUTPUT
ACIN 100V
50/60 (47 - 63)
ACIN 100V
85typ
85typ
86typ
ACIN 200V
85typ
85typ
87typ
INRUSH CURRENT
VOLTAGE[V]
12
15
24
CURRENT[A]
1.25
1
0.63
LINE REGULATION[mV]
48max
60max
96max
LOAD REGULATION[mV]
100max
120max
150max
30 to 100% Load *1
AC85V - 240V *1
30 to 100% Load *1
RIPPLE
0 to 30% Load
NOISE[mVp-p]
AC85V - 240V *1
0 to +50C
TEMPERATURE
REGULATION[mV] -40 to +50C
160max
160max
200max
480max
480max
580max
200max
200max
240max
560max
560max
660max
180max
240max
360max
270max
360max
480max
DRIFT[mV]
48max
60max
96max
14.25 - 15.75
23.00 - 25.00
*2
OUTPUT VOLTAGE SETTING[V] 11.40 - 12.60
AND OTHERS
OVERVOLTAGE PROTECTION[V] 13.20 - 19.20
16.50 - 24.00
ISOLATION
ENVIRONMENT
SAFETY
AND NOISE
REGULATIONS
OTHERS
26.40 - 38.40
INPUT-OUTPUT
VIBRATION
IMPACT
AGENCY APPROVALS
CONDUCTED NOISE
CASE SIZE/WEIGHT
COOLING METHOD
* Measured with 68μF capasitor as Cbc.
TUHS-8
December 27, 2022
www.cosel.co.jp/en/
TUHS15
External view
Name Plate
+BC -BC
(TOP VIEW)
AC1
+Vout
AC2
5.08
[0.2]
28
[1.1]
7.62
[0.3]
0.5
[0.02]
2.5
2.5
[0.1]
7.62
[0.3]
9.38
[0.37]
6.4
[0.25]
¶ Dimensions in :
[0.1]
12.9
[0.51]
22
[0.87]
3.5
[0.14]
15
[0.59]
17
[0.67]
12.9
[0.51]
6.4
[0.25]
-Vout
¶ Div. : 0.2inch
mm
[inch]
¶ Weight : 25g max
5.08
[0.2]
28
[1.1]
33
[1.3]
www.cosel.co.jp/en/
December 27, 2022
TUHS-9
TUHS25
TUH
1
S
2
25
3
F
05
4
5
1 Series name
2 Single output
3 Output wattage
4 Universal Input
5 Output voltage
R
ClassⅡ
MODEL
TUHS25F05
TUHS25F12
TUHS25F15
TUHS25F24
25.00
25.20
25.50
26.40
DC OUTPUT
5V 5A
12V 2.1A
15V 1.7A
24V 1.1A
MODEL
TUHS25F05
TUHS25F12
TUHS25F15
TUHS25F24
VOLTAGE[V]
SPECIFICATIONS
CURRENT[A]
INPUT
0.55typ (Io=100%)
ACIN 200V
0.35typ (Io=100%)
FREQUENCY[Hz]
EFFICIENCY[%]
OUTPUT
ACIN 100V
50/60 (47 - 63)
ACIN 100V
87typ
88typ
88typ
89typ
ACIN 200V
87typ
88typ
88typ
90typ
INRUSH CURRENT
VOLTAGE[V]
5
12
15
24
CURRENT[A]
5
2.1
1.7
1.1
LINE REGULATION[mV]
20max
48max
60max
96max
LOAD REGULATION[mV]
40max
100max
120max
150max
30 to 100% Load *1
AC85V - 240V *1
30 to 100% Load *1
RIPPLE
0 to 30% Load
NOISE[mVp-p]
AC85V - 240V *1
0 to +50C
TEMPERATURE
120max
160max
160max
200max
400max
480max
480max
580max
160max
200max
200max
240max
480max
560max
560max
660max
100max
180max
240max
360max
150max
270max
360max
480max
DRIFT[mV]
20max
48max
60max
96max
11.40 - 12.60
14.25 - 15.75
23.00 - 25.00
16.50 - 24.00
26.40 - 38.40
*2
AND OTHERS
13.20 - 19.20
ISOLATION
ENVIRONMENT
SAFETY
AND NOISE
REGULATIONS
OTHERS
INPUT-OUTPUT
VIBRATION
IMPACT
AGENCY APPROVALS
CONDUCTED NOISE
CASE SIZE/WEIGHT
36.0X16.5X25.4mm[1.42X0.65X1.0 inches] (WXHXD) / 40g max
COOLING METHOD
* Measured with 120μF capasitor as Cbc.
TUHS-10
December 27, 2022
www.cosel.co.jp/en/
TUHS25
External view
Name Plate
+BC -BC
(TOP VIEW)
AC1
7.62
[0.3]
+Vout
30.48
[1.2]
-Vout
[0.02]
[0.65]
16.5
0.5
7.62
[0.3]
20.32
[0.8]
10.16
[0.4]
AC2
¶ Dimensions in :
2.76
7.62
[0.11]
[0.3]
7.62
[0.3]
10.16
[0.4]
[0.4]
2.54
[0.1]
10.16
3.5
[0.14]
[0.8]
[1.0]
20.32
25.4
¶ Div. : 0.2inch
mm
[inch]
¶ Weight : 40g max
30.48
[1.2]
36
[1.42]
www.cosel.co.jp/en/
December 27, 2022
TUHS-11
TUHS-series
Pin Configuration
¿TUHS3/TUHS5
AC2
- Vout
AC1
+BC
No.
+Vout
Bottom View
1
2
3
4
5
6
- BC
¿TUHS10/TUHS15
6 - Vout
AC2 2
+ BC 3
Function
AC input
+BC
-BC
+DC
-DC
output
output
output
output
5 + Vout
Bottom View
AC1 1
Pin
Connection
AC1
AC2
+BC
-BC
+VOUT
-VOUT
4 - BC
¿TUHS25
AC2 2
6 - Vout
Bottom View
AC1 1
5 + Vout
4 - BC
+ BC 3
Implementation・Mounting Method
Mounting method
¡The unit can be mounted in any direction. When two or more power supplies are used side by side, position them with proper intervals
to allow enough air ventilation. The temperature around each power supply should not exceed the temperature range shown in derating
curve.
¡Avoid placing the AC input line pattern layout underneath the unit.It will increase the line conducted noise. Make sure to leave an ample
distance between the line pattern layout and the unit. Also avoid placing the DC output line pattern underneath the unit because it may
increase the output noise. Lay out the pattern away from the unit.
¡Avoid placing the signal line pattern layout underneath the unit because the power supply might become unstable. Lay out the pattern
away from the unit.
Stress to the pins
¡Applying excessive stress to the input or output pins of the power module may damage
internal connections. Avoid applying stress in excess of that shown in right figure.
Less than
19.6N(2kgf)
¡Input/output pin are soldered to the PCB internally. Do not pull or bend a lead powerfully.
¡If it is expected that stress is applied to the input/output pin due to vibration or impact,
reduce the stress to the pin by taking such measures as fixing the unit to the PCB by sili-
Less than
19.6N(2kgf)
Less than
19.6N(2kgf)
cone rubber, etc.
Soldering
¡Flow soldering: 260C for up to 15 seconds.
¡Soldering iron (26W): 450C for up to 5 seconds.
Derating
¿Derating curve for input voltage
100
Load[%]
Load[%]
100
50
40
AC50V
DC70V
AC85V
DC120V
in
Vin
AC85V V
DC120V
(b)TUHS5,TUHS10,TUHS15,TUHS25
(a)TUHS3
TUHS-12
AC50V
DC70V
December 27, 2022
www.cosel.co.jp/en/
TUHS-series
Derating
¿TUHS3F Ambient temperature derating curve
(Reference value)
Load factor[%]
100
80
60
40
Convection (0.2m/s),Forced air (2.0m/s)
-20
60
85
80
100
Ambient temperature[C]
¿TUHS5F Ambient temperature derating curve
at forced air (Reference value)
100
100
80
80
Load factor[%]
Load factor[%]
at convection cooling (Reference value)
75
60
40
Convection(0.2m/s)
1TUHS5F05,TUHS5F12,TUHS5F15
2TUHS5F24
-20
60
75
85
80
60
40
Forced air(2.0m/s)
100
-20
¿TUHS10F Ambient temperature derating curve
100
80
80
60
-40
Convection(0.2m/s)
1TUHS10F05,TUHS10F15
2TUHS10F12,TUHS10F24
-20
55
60
85
80
40
Forced air(2.0m/s)
100
-20
75
85
80
100
1
3
2
Load factor[%]
Load factor[%]
60
100
80
60
-40
40
¿TUHS15F Ambient temperature derating curve
100
60
40
85
80
100
Load factor[%]
Load factor[%]
40
Convection(0.2m/s)
1TUHS15F12
2TUHS15F15
3TUHS15F24
-20
45
60
85
80
80
60
40
-40
www.cosel.co.jp/en/
Forced air(2.0m/s)
1TUHS15F12,TUHS15F15
2TUHS15F24
-20
60
75
85
80
100
December 27, 2022
TUHS-13
TUHS-series
Derating
¿TUHS25F Ambient temperature derating curve
100
3
80
2
1
60
40
Load factor[%]
Load factor[%]
100
Convection(0.2m/s)
1TUHS25F05
2TUHS25F12,TUHS25F24
3TUHS25F15
-20
60
85
80
80
75
60
40
Forced air(2.0m/s)
1TUHS25F05,TUHS25F15
-40
-20
75
85
80
100
¡Derating curve is shown below. Note: In the hatched area, the specification of Ripple, Ripple Noise is different from other area.
¡Please have sufficient ventilation to keep the temperature of point A in Instruction Manual6. Please also make sure that the ambient temperature does not exceed 85C.
Instruction Manual
◆ It is neccessary to read the “Instruction Manual” and “Before using our product” before you use our product.
Instruction Manual
Before using our product https://en.cosel.co.jp/technical/caution/index.html
https://www.cosel.co.jp/redirect/catalog/en/TUHS/
TUHS
NOTICE
Basic Characteristics Data
Model
TUHS3F
Circuit method
Switching
frequency
[kHz]
Inrush
Input
current
current protection
[A]
circuit
Series/Parallel
operation availability
PCB/Pattern
Material
Single Double
Series
Parallel
sided
sided operation operation
Flyback converter 80-250 *3
*1
Resistor
glass fabric base,epoxy resin
Yes
Yes
*2
TUHS5F
*1
Resistor
Yes
Yes
*2
TUHS10F
*1
Resistor
Yes
Yes
*2
Resistor
Yes
Yes
*2
Thermistor glass fabric base,epoxy resin
Yes
Yes
*2
TUHS15F
*1
TUHS25F
*1
*1 R
efer to Specification.
efer to instruction manual.
*2 R
*3 The value changes depending on input and load.
TUHS-14
December 27, 2022
www.cosel.co.jp/en/
