PDF700S480
PDF700S480
    CINCON
    全砖
    AC/DC CONVERTER 700W
PDF700S480 数据手册
PDF700S SERIES 700 WATT AC-DC BRICK POWER SUPPLY WITH PFC Features ⚫ Universal Input Range 90~264Vac ⚫ Efficiency up to 91.5% ⚫ Full Brick Size ⚫ Class I ⚫ Approval Safety IEC/EN/UL 62368-1 ⚫ Operating Altitude 5000m ⚫ Remote On/Off ⚫ Over Temperature Protection ⚫ Over Voltage Protection ⚫ Continuous Short Circuit Protection ⚫ Baseplate Cooling RIPPLE & VOLTAGE LINE LOAD %EFF. NOISE ACCURACY REGULATION REGULATION (Typ.) NOTE1 & 2 NOTE3 NOTE4 NOTE5 NOTE6 ±1.0% ±0.5% ±0.5% 87.5% 29.2 A 120 mV 240 mV ±1.0% ±0.5% ±0.5% 90% MODEL OUTPUT OUTPUT NUMBER VOLTAGE CURRENT PDF700S120 12 V 58.4 A PDF700S240 24 V PDF700S280 28 V 25.0 A 280 mV ±1.0% ±0.5% ±0.5% 90.5% PDF700S480 48 V 14.6 A 480 mV ±1.0% ±0.5% ±0.5% 91% 12.5 A 560 mV ±1.0% ±0.5% ±0.5% 91.5% PDF700S560 56 V Note: 1. External components are required. please refer to the application note. 2. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for ripple & noise measuring @20MHz BW. 3. Voltage accuracy is set at 60% load. 4. Line regulation is measured from 100Vac to 264Vac with full load. 5. Load regulation is measured from 60%±40% rated load. 6. Typical efficiency at 230Vac and full load at 25℃. 7. When the aluminum case of brick reaches temperature 100℃. the unit will be OTP. the unit need sufficient convection and heat sink. PART NUMBER Series PDF700 Number of Outputs X PDF700 Nominal Output Voltage XXX 120:12V 240:24V 280:28V 480:48V 560:56V S:Single Part Number Example: PDF700S120:700W, Single 12Vdc Output www.cincon.com 1 REVISION: V12 PDF700S Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Input Voltage Min. Typ. Max. Units All 90 264 Vac All -40 100 Storage Temperature All -55 Operating Altitude All Operating Case Temperature At the center of base plate 105 ℃ ℃ 5000 m Max. Units INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Operating Voltage Range All 100 240 Vac Input Frequency Range All 47 63 Hz Maximum Input Current 100% Load, Vin=100Vac All 9 A Leakage Current Only PDF700S Brick Vin=240Vac, Cold Start at 25℃ (External inrush resister 10Ω) All 0.01 mA All 35 A 77 Vac Units Inrush Current Under Voltage Protection Power Factor All 230Vac/50Hz @ Full load 63 All 70 0.97 OUTPUT CHARACTERISTICS PARAMETER Output Voltage Set Point Operating Output Current Range NOTES and CONDITIONS Vin=115Vac and 230Vac, Io=60% Io max, Tc=25℃ Vin=115Vac and 230Vac, Tc=25℃ Device Min. Typ. Max. PDF700S120 11.88 12 12.12 PDF700S240 23.76 24 24.24 PDF700S280 27.72 28 28.28 PDF700S480 47.52 48 48.48 PDF700S560 55.44 56 56.56 PDF700S120 0 58.4 PDF700S240 0 29.2 PDF700S280 0 25.0 PDF700S480 0 14.6 PDF700S560 0 12.5 Vin=115Vac (Refer to the application note) All Load Regulation 20% Load to 100% Load All Line Regulation Vin=High Line to low line Holdup Time 16 Vdc A mS Output Voltage Regulation All Output Voltage Trim Range Po≦max rated power, Io≦Io_max Over Current Protection Hiccup mode, auto recovery Over Voltage Protection Output Ripple and Noise www.cincon.com Latch off (recycle AC input to restart) ±0.5 % ±0.5 % PDF700S560 -5 +1.8 Others -5 +5 All 105 195 PDF700S120 14.8 16.8 PDF700S240 30.3 33.6 PDF700S280 34.4 39.2 PDF700S480 55.9 57.6 PDF700S560 58.0 59.9 1. Add a 0.1uF ceramic capacitor and a 10uF aluminum electrolytic capacitor to output. 2. Oscilloscope is 20MHz band width. 3. Ambient temperature=25℃. PDF700S120 80 120 PDF700S240 160 240 PDF700S280 180 280 4. The output capacitor is necessary, such as load capacitance in the table below. PDF700S480 260 480 PDF700S560 260 560 2 % % Vdc mV REVISION: V12 PDF700S PARAMETER Load Capacitance NOTES and CONDITIONS Typ. Series Device Min. Max. PDF700S120 11700 58340 1. Ambient temperature=25℃ PDF700S240 8000 29170 2. Input voltage is 115Vac and 230Vac 3. Output is max. load PDF700S280 8000 25000 PDF700S480 2820 14590 PDF700S560 2820 12500 Device Min. Units uF EFFICIENCY PARAMETER NOTES and CONDITIONS PDF700S120 Efficiency Typ. Max. Units 87.5 1. Output is rated load PDF700S240 90 2. Ambient temperature=25℃ @ input voltage is 230Vac PDF700S280 90.5 PDF700S480 91 PDF700S560 91.5 % ISOLATION CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Input to Output 1 minute (without dielectric breakdown) Input to Earth (Ground) 1 minute (without dielectric breakdown) Output to Earth (Ground) 1 minute (without dielectric breakdown) All Isolation Resistance Input to Output All 100 Device Min. Typ. Max. Units All 3000 Vac All 2000 Vac 500 Vac MΩ FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Over Temperature Shutdown Over Temperature Recovery All Temperature at the center part of base plate, auto recovery Typ. Max. 220 kHz 110 All Units ℃ 105 GENERAL SPECIFICATIONS PARAMETER NOTES and CONDITIONS MTBF Io=100%, Ta=25°C per MIL-HDBK-217F All Humidity Non-condensing Meets MIL-STD-810F Table 516.5,Table 516.5-I 10ms, each axis 3 times(±X、±Y、 ±Z axis) Meets MIL-STD-810F Table 514.5CVIII,15~2000Hz, X、Y、Z axis, 1hr (each axis),. total 3 hrs. All Shock Vibration Device Min. Typ. Max. Units 93 k hours % RH 250 All 75 g All 4 g 210 grams Weight All Dimensions All 4.60x2.40x0.50 Inches (116.8x61.0x12.7mm) Case Material Plastic DAP UL 94V-0 Base Plate Material Aluminum Baseplate Potting Material UL 94V-0 Safety Class I, IEC/EN/UL 62368-1 EMC Emission EN55032 Class A Conducted Disturbance EN55032 Class A Radiated Disturbance EN55032 Class A Harmonic Current Emissions EN61000-3-2:2014 Voltage Fluctuations & Flicker EN61000-3-3:2013 EMC Immunity EN55035 Electrostatic Discharge (ESD) Radio-Frequency, Continuous Radiated Disturbance Electrical Fast Transient (EFT) IEC 61000-4-2:2008, Air Discharge: ±8kV Contact Discharge: ±4kV Criterion A IEC 61000-4-3:2020 Criterion A IEC61000-4-4:2012, ±1kV, ±2kV Criterion A www.cincon.com 3 REVISION: V12 PDF700S Series GENERAL SPECIFICATIONS Surge Conducted Disturbances, Induced by RF Fields Power Frequency Magnetic Field Voltage Dips Voltage Interruptions IEC61000-4-5:2014+A1:2017 L-N: ±0.5kV, ±1kV, ±2kV, L-E(ground): ±0.5kV, ±1kV, ±2kV, ±4kV Criterion A IEC 61000-4-6:2013+COR1:2015 Criterion A IEC 61000-4-8:2009 Criterion A IEC 61000-4-11:2004+A1:2017, Dip: 30% Reduction, Dip >95% Reduction Criterion A IEC 61000-4-11:2004+A1:2017, >95% Reduction Criterion B Application Note Link PDF700S Series App Notes CHARACTERISTIC CURVE Simplified Application Circuit Power Derating Curve 110 100 90 80 70 60 50 40 30 20 10 0 PDF700S120 Derating Curve with Heatsink M-B012 (Vin=230V) Natural Rated Power (%) Rated Power (%) PDF700S120 Derating Curve with Heatsink M-B012 (Vin=115V) 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 80 90 110 100 90 80 70 60 50 40 30 20 10 0 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 100 10 20 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 80 90 100 50 60 70 110 100 90 80 70 60 50 40 30 20 10 0 80 90 100 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 Ambient Temperature (℃) www.cincon.com 40 PDF700S240/280/480/560 Derating Curve with Heatsink M-B012 (Vin=230V) Rated Power (%) Rated Power (%) PDF700S240/280/480/560 Derating Curve with Heatsink M-B012 (Vin=115V) 110 100 90 80 70 60 50 40 30 20 10 0 30 Ambient Temperature (℃) Ambient Temperature (℃) 10 20 30 40 50 60 70 80 90 100 Ambient Temperature (℃) 4 REVISION: V12 PDF700S PDF700S120/240/280/480/560 Input Voltage Derating Curve 110 Rated Power (%) Series 100 90 80 90 110 130 150 170 190 210 230 250 Input Voltage (Vac) Performance Data 95% 90% 90% Efficincy (%) 95% 85% 80% 75% 115V 70% 65% 60% 10% Efficincy (%) PDF700S240 (Eff Vs Io) 20% 30% 40% 50% 60% 70% 80% 85% 80% 75% 60% 10% 90% 100% 30% 40% 50% 60% 70% 80% PDF700S280 (Eff Vs Io) PDF700S480 (Eff Vs Io) 95% 90% 85% 80% 75% 115V 70% 65% 40% 50% 60% 70% 80% 90% 100% Current Load (%) 90% 100% 85% 80% 75% 115V 70% 65% 230V 30% 20% Current Load (%) 90% 20% 230V Current Load (%) 95% 60% 10% 115V 70% 65% 230V Efficincy (%) Efficincy (%) PDF700S120 (Eff Vs Io) 60% 10% 230V 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) PDF700S560 (Eff Vs Io) 95% Efficincy (%) 90% 85% 80% 75% 115V 70% 65% 60% 10% 230V 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 5 REVISION: V12 PDF700S Series MECHANICAL SPECIFICATION 4.20 [106.7] 4.60 [116.8] 0.58 [14.7] 0.157 [4.00] 2-0.591 [15.00] 3-0.157 [4.00] 0.354 [9.00] 0.50[12.7] 1.48 [37.7] 2.40 [61.0] ] 2.0 0.394 [10.00] 8[Φ 0.0 2-Φ 1.0 ] 1.41 [35.7] 11Φ0 .04 [Φ 0.20 [5.0] 0.22 [5.5] 0.2 [5.1] 2.00 [50.8] 0.394 [10.00] Mounting Inserts Φ3.5 Through 4Pl. All Dimensions In Inches[mm] Tolerance Inches:x.xx = ±0.02 , x.xxx=± 0.010 Millimeters:x.x = ±0.5, x.xx±0.25 sales@cincon.com.tw www.cincon.com 6 REVISION: V12
PDF700S480 价格&库存
很抱歉,暂时无法提供与“PDF700S480”相匹配的价格&库存,您可以联系我们找货
