ESMQ201VRD272MA50S
ESMQ201VRD272MA50S
    NCC(贵弥功)
    插件
    2700 µF 200 V 铝电解电容器 径向,罐 - 卡入式 - 4 引线 85°C 时为 2000 小时
ESMQ201VRD272MA50S 数据手册
LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS SMQ Standard snap-ins, 85℃ SMR Series Downsized ・Endurance with ripple current : 2,000 hours at 85℃ ・Non solvent resistant type ・RoHS2 Compliant SMQ ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -25 to +85℃ 160 to 450Vdc ±20% (M) I≦3 CV Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V) Rated voltage (Vdc) 160 to 250V 315 to 400V 420 & 450V tanδ (Max.) 0.15 0.15 0.20 Rated voltage (Vdc) 160 to 250V 315 to 400V 420 & 450V Z(-25℃)/Z(+20℃) 4 8 8 Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) (at 20℃, 120Hz) (at 20℃ after 5 minutes) (at 20℃, 120Hz) (at 120Hz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 2,000 hours at 85℃. Capacitance change ≦±20% of the initial value D. F. (tanδ) ≦200% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 85℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to Item 4.1 of JIS C 5101-4. Capacitance change ≦±15% of the initial value D. F. (tanδ) ≦150% of the initial specified value Leakage current ≦The initial specified value Endurance Shelf Life ◆DIMENSIONS [mm] Code : VS (φ22 to φ35) : Standard Sleeve (PET : Black) ●Terminal PC board pin-out (View from Solder side) Negative mark Sleeve (PET : Black) PC board pin-out (View from Solder side) φD+1max. φD+1max. 10 Vent Negative mark 2-1.2×6 2-φ2 4.0±0.5 L±2 Code : LI (φ35) 4.2±0.5 ●Terminal Vent 5±0.5 L±2 4.5±1 14.2±1 The standard design has no plastic disc. ◆PART NUMBERING SYSTEM 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 E S MQ A A A V S N A A A M A A A S Supplement code Size code Capacitance tolerance code Capacitance code (ex. 82µF:820, 3,300µF:332) Dummy terminal code Terminal code (VS, LI) Voltage code (ex. 160V:161, 315V:3B1, 450V:451) Series code Category Please refer to "Product code guide (snap-in type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Standard snap-ins, 85℃ SMQSeries ◆STANDARD RATINGS WV (Vdc) 160 180 200 Cap (µF) 560 680 820 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,500 1,500 1,800 1,800 1,800 2,200 2,200 2,700 3,300 3,900 470 560 680 680 820 820 1,000 1,000 1,000 1,200 1,200 1,200 1,200 1,500 1,500 1,500 1,800 1,800 1,800 2,200 2,200 2,700 3,300 390 470 560 560 680 680 820 820 820 1,000 1,000 1,000 1,000 1,200 1,200 1,200 1,500 1,500 1,500 1,800 1,800 2,200 2,200 2,700 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 85℃, 120Hz) 22 ×25 22 ×30 22 ×35 22 ×40 25.4×30 22 × 45 25.4× 35 30 × 25 22 × 50 25.4× 40 30 ×30 35 ×25 25.4 ×45 30 ×35 35 ×30 30 ×40 35 ×35 35 ×40 35 ×45 35 ×50 22 ×25 22 ×30 22 ×30 25.4×25 22 ×35 25.4× 30 22 ×45 25.4×35 30×25 22×50 25.4×40 30×30 35×25 25.4×45 30×35 35×30 25.4×50 30×40 35×30 30×45 35×40 35×45 35×50 22×25 22 ×30 22×30 25.4 ×25 22 ×35 25.4×30 22×40 25.4×30 30×25 22 ×45 25.4×35 30 × 30 35 × 25 25.4× 40 30 ×30 35 ×30 25.4 ×50 30 ×35 35 ×30 30 ×45 35 ×35 30 ×50 35 ×40 35 ×50 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 2.25 2.50 2.75 3.00 3.00 3.25 3.25 3.25 3.73 3.73 3.73 3.73 4.20 4.20 4.20 4.78 4.78 5.45 5.75 6.00 2.08 2.25 2.50 2.50 2.75 2.75 3.00 3.00 3.00 3.31 3.31 3.31 3.31 3.83 3.83 3.83 4.32 4.32 4.32 4.92 4.92 5.52 5.75 1.68 1.85 2.43 2.43 2.68 2.68 2.93 2.93 2.93 3.25 3.25 3.25 3.25 3.50 3.50 3.50 3.87 3.87 3.87 4.32 4.32 4.92 4.92 5.45 Part No. ESMQ161VSN561MP25S ESMQ161VSN681MP30S ESMQ161VSN821MP35S ESMQ161VSN102MP40S ESMQ161VSN102MQ30S ESMQ161VSN122MP45S ESMQ161VSN122MQ35S ESMQ161VSN122MR25S ESMQ161VSN152MP50S ESMQ161VSN152MQ40S ESMQ161VSN152MR30S ESMQ161VSN152MA25S ESMQ161VSN182MQ45S ESMQ161VSN182MR35S ESMQ161VSN182MA30S ESMQ161VSN222MR40S ESMQ161VSN222MA35S ESMQ161VSN272MA40S ESMQ161VSN332MA45S ESMQ161VSN392MA50S ESMQ181VSN471MP25S ESMQ181VSN561MP30S ESMQ181VSN681MP30S ESMQ181VSN681MQ25S ESMQ181VSN821MP35S ESMQ181VSN821MQ30S ESMQ181VSN102MP45S ESMQ181VSN102MQ35S ESMQ181VSN102MR25S ESMQ181VSN122MP50S ESMQ181VSN122MQ40S ESMQ181VSN122MR30S ESMQ181VSN122MA25S ESMQ181VSN152MQ45S ESMQ181VSN152MR35S ESMQ181VSN152MA30S ESMQ181VSN182MQ50S ESMQ181VSN182MR40S ESMQ181VSN182MA30S ESMQ181VSN222MR45S ESMQ181VSN222MA40S ESMQ181VSN272MA45S ESMQ181VSN332MA50S ESMQ201VSN391MP25S ESMQ201VSN471MP30S ESMQ201VSN561MP30S ESMQ201VSN561MQ25S ESMQ201VSN681MP35S ESMQ201VSN681MQ30S ESMQ201VSN821MP40S ESMQ201VSN821MQ30S ESMQ201VSN821MR25S ESMQ201VSN102MP45S ESMQ201VSN102MQ35S ESMQ201VSN102MR30S ESMQ201VSN102MA25S ESMQ201VSN122MQ40S ESMQ201VSN122MR30S ESMQ201VSN122MA30S ESMQ201VSN152MQ50S ESMQ201VSN152MR35S ESMQ201VSN152MA30S ESMQ201VSN182MR45S ESMQ201VSN182MA35S ESMQ201VSN222MR50S ESMQ201VSN222MA40S ESMQ201VSN272MA50S WV (Vdc) 250 315 350 Cap (µF) 270 330 390 390 470 470 560 560 560 680 680 680 820 820 820 820 1,000 1,000 1,000 1,200 1,200 1,500 1,500 1,800 180 220 270 330 330 330 390 390 390 470 470 470 470 560 560 560 680 680 820 820 1,000 1,000 150 180 220 270 270 330 330 390 390 390 390 470 470 470 560 560 560 680 680 820 820 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 85℃, 120Hz) 22 × 25 22 × 30 22 × 30 25.4 × 25 22 × 35 25.4 × 30 22 × 40 25.4× 30 30 × 25 22 × 45 25.4 × 35 30 × 30 22 × 50 25.4 × 40 30 × 30 35 × 25 25.4 × 45 30 × 35 35 × 30 30 × 40 35 × 35 30 × 50 35 × 40 35 × 45 22 × 25 22 × 30 22 × 30 22 × 40 25.4 × 30 30 × 25 22 × 45 25.4 × 35 30 × 30 22 × 50 25.4 × 40 30 × 30 35 × 25 25.4 × 45 30 × 35 35 × 30 30 × 40 35 × 35 30 × 45 35 × 40 30 × 50 35 × 45 22 × 25 22 × 30 22 × 35 22 × 40 25.4 × 30 22 × 45 25.4 × 35 22 × 50 25.4 × 40 30 × 30 35 × 25 25.4 × 45 30 × 35 35 × 30 25.4 × 50 30 × 40 35 × 30 30 × 45 35 × 35 30 × 50 35 × 45 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 1.31 1.75 1.91 1.91 2.11 2.11 2.25 2.25 2.25 2.50 2.50 2.50 2.77 2.77 2.77 2.77 3.32 3.32 3.32 3.53 3.53 4.04 4.04 4.55 1.21 1.41 1.60 1.82 1.82 1.82 2.01 2.01 2.01 2.27 2.27 2.27 2.27 2.56 2.56 2.56 2.87 2.87 3.25 3.25 3.63 3.63 1.12 1.22 1.44 1.66 1.66 1.88 1.88 2.06 2.06 2.06 2.06 2.40 2.40 2.40 2.60 2.60 2.60 2.96 2.96 3.25 3.25 Part No. ESMQ251VSN271MP25S ESMQ251VSN331MP30S ESMQ251VSN391MP30S ESMQ251VSN391MQ25S ESMQ251VSN471MP35S ESMQ251VSN471MQ30S ESMQ251VSN561MP40S ESMQ251VSN561MQ30S ESMQ251VSN561MR25S ESMQ251VSN681MP45S ESMQ251VSN681MQ35S ESMQ251VSN681MR30S ESMQ251VSN821MP50S ESMQ251VSN821MQ40S ESMQ251VSN821MR30S ESMQ251VSN821MA25S ESMQ251VSN102MQ45S ESMQ251VSN102MR35S ESMQ251VSN102MA30S ESMQ251VSN122MR40S ESMQ251VSN122MA35S ESMQ251VSN152MR50S ESMQ251VSN152MA40S ESMQ251VSN182MA45S ESMQ3B1VSN181MP25S ESMQ3B1VSN221MP30S ESMQ3B1VSN271MP30S ESMQ3B1VSN331MP40S ESMQ3B1VSN331MQ30S ESMQ3B1VSN331MR25S ESMQ3B1VSN391MP45S ESMQ3B1VSN391MQ35S ESMQ3B1VSN391MR30S ESMQ3B1VSN471MP50S ESMQ3B1VSN471MQ40S ESMQ3B1VSN471MR30S ESMQ3B1VSN471MA25S ESMQ3B1VSN561MQ45S ESMQ3B1VSN561MR35S ESMQ3B1VSN561MA30S ESMQ3B1VSN681MR40S ESMQ3B1VSN681MA35S ESMQ3B1VSN821MR45S ESMQ3B1VSN821MA40S ESMQ3B1VSN102MR50S ESMQ3B1VSN102MA45S ESMQ351VSN151MP25S ESMQ351VSN181MP30S ESMQ351VSN221MP35S ESMQ351VSN271MP40S ESMQ351VSN271MQ30S ESMQ351VSN331MP45S ESMQ351VSN331MQ35S ESMQ351VSN391MP50S ESMQ351VSN391MQ40S ESMQ351VSN391MR30S ESMQ351VSN391MA25S ESMQ351VSN471MQ45S ESMQ351VSN471MR35S ESMQ351VSN471MA30S ESMQ351VSN561MQ50S ESMQ351VSN561MR40S ESMQ351VSN561MA30S ESMQ351VSN681MR45S ESMQ351VSN681MA35S ESMQ351VSN821MR50S ESMQ351VSN821MA45S Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 LARGE CAPACITANCE ALUMINUM ELECTROLYTIC CAPACITORS Standard snap-ins, 85℃ SMQSeries ◆STANDARD RATINGS WV (Vdc) Cap (µF) 350 1,000 120 150 180 220 220 270 270 270 330 330 330 330 390 390 390 470 470 470 560 560 680 680 820 100 120 150 150 180 180 220 220 220 270 270 400 420 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 85℃, 120Hz) 35 ×50 22 ×25 22 ×30 22 ×35 22 ×40 25.4×30 22 × 45 25.4× 35 30 × 25 22 × 50 25.4× 40 30 ×30 35 ×25 25.4 ×45 30 ×35 35 ×30 25.4×50 30 ×40 35 ×30 30 ×45 35 ×35 30 ×50 35 ×40 35 ×45 22 ×25 22 ×25 22 ×30 25.4× 25 22 ×35 25.4×30 22×40 25.4×35 30 ×25 22 ×50 25.4×35 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.15 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 3.54 1.02 1.16 1.44 1.49 1.49 1.67 1.67 1.67 1.90 1.90 1.90 1.90 2.13 2.13 2.13 2.39 2.39 2.39 2.69 2.69 2.96 2.96 3.25 0.97 1.08 1.30 1.30 1.48 1.48 1.65 1.65 1.65 1.94 1.94 Part No. ESMQ351VSN102MA50S ESMQ401VSN121MP25S ESMQ401VSN151MP30S ESMQ401VSN181MP35S ESMQ401VSN221MP40S ESMQ401VSN221MQ30S ESMQ401VSN271MP45S ESMQ401VSN271MQ35S ESMQ401VSN271MR25S ESMQ401VSN331MP50S ESMQ401VSN331MQ40S ESMQ401VSN331MR30S ESMQ401VSN331MA25S ESMQ401VSN391MQ45S ESMQ401VSN391MR35S ESMQ401VSN391MA30S ESMQ401VSN471MQ50S ESMQ401VSN471MR40S ESMQ401VSN471MA30S ESMQ401VSN561MR45S ESMQ401VSN561MA35S ESMQ401VSN681MR50S ESMQ401VSN681MA40S ESMQ401VSN821MA45S ESMQ421VSN101MP25S ESMQ421VSN121MP25S ESMQ421VSN151MP30S ESMQ421VSN151MQ25S ESMQ421VSN181MP35S ESMQ421VSN181MQ30S ESMQ421VSN221MP40S ESMQ421VSN221MQ35S ESMQ421VSN221MR25S ESMQ421VSN271MP50S ESMQ421VSN271MQ35S WV (Vdc) 420 450 Cap (µF) 270 330 330 330 390 390 390 470 470 560 560 680 82 100 120 150 150 180 180 220 220 220 220 270 270 270 330 330 330 390 390 470 470 560 560 Rated ripple current Case size tanδ (Arms/ φD×L(mm) 85℃, 120Hz) 30 × 30 25.4 × 45 30 × 35 35 × 30 25.4 × 50 30 × 35 35 × 30 30 × 40 35 × 35 30 × 50 35 × 40 35 × 45 22 × 25 22 × 25 22 × 30 22 × 35 25.4 × 25 22 × 40 25.4 × 30 22 × 45 25.4 × 40 30 × 30 35 × 25 22 × 50 25.4 × 40 30 × 30 25.4 × 50 30 × 40 35 × 30 30 × 40 35 × 35 30 × 45 35 × 40 30 × 50 35 × 45 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 0.20 1.94 2.17 2.17 2.17 2.27 2.27 2.27 2.61 2.61 2.82 2.82 3.11 0.83 0.93 1.04 1.19 1.19 1.35 1.35 1.55 1.55 1.55 1.55 1.78 1.78 1.78 2.01 2.01 2.01 2.24 2.24 2.53 2.53 2.82 2.82 Part No. ESMQ421VSN271MR30S ESMQ421VSN331MQ45S ESMQ421VSN331MR35S ESMQ421VSN331MA30S ESMQ421VSN391MQ50S ESMQ421VSN391MR35S ESMQ421VSN391MA30S ESMQ421VSN471MR40S ESMQ421VSN471MA35S ESMQ421VSN561MR50S ESMQ421VSN561MA40S ESMQ421VSN681MA45S ESMQ451VSN820MP25S ESMQ451VSN101MP25S ESMQ451VSN121MP30S ESMQ451VSN151MP35S ESMQ451VSN151MQ25S ESMQ451VSN181MP40S ESMQ451VSN181MQ30S ESMQ451VSN221MP45S ESMQ451VSN221MQ40S ESMQ451VSN221MR30S ESMQ451VSN221MA25S ESMQ451VSN271MP50S ESMQ451VSN271MQ40S ESMQ451VSN271MR30S ESMQ451VSN331MQ50S ESMQ451VSN331MR40S ESMQ451VSN331MA30S ESMQ451VSN391MR40S ESMQ451VSN391MA35S ESMQ451VSN471MR45S ESMQ451VSN471MA40S ESMQ451VSN561MR50S ESMQ451VSN561MA45S ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) 160 to 250Vdc 315 to 450Vdc 50 0.81 0.77 120 1.00 1.00 300 1.17 1.16 1k 1.32 1.30 10k 1.45 1.41 50k 1.50 1.43 The deterioration of aluminum electrolytic capacitors accelerates their life due to the internal heating produced by ripple current. For details, refer to Section "5-3 Ripple Current Effect on Lifetime" in the catalog, Technical Note. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023 ALUMINUM ELECTROLYTIC CAPACITORS Product Guide ■ Always read "Notes on Use" before using the product in order to enable you to use the product correctly and prevent any faults and accidents from occurring. ■ Request the Product Specification on the product of NIPPON CHEMI-CON CORPORATION to refer to it as well as this brochure prior to the order of the products. Some specific notes on use of the ordered product may be described in the specifications. ■ The products listed in this catalog are designed and manufactured for general electronics equipment use and are not intended for use in applications that can adversely affect human life; where the malfunction of equipment may cause damage to life or property. In addition, our products are not intended to be used in specific applications that may cause a major social impact. Please consult with us in advance of usage of our products in the following listed applications. ① Aerospace equipment ② Power generation equipment such as thermal power, nuclear power etc. ③ Medical equipment ④ Transport equipment (automobiles, trains, ships, etc.) ⑤ Transportation control equipment ⑥ Disaster prevention / crime prevention equipment ⑦ Highly publicized information processing equipment ⑧ Submarine equipment ⑨ Other applications that are not considered general-purpose applications. ■ The circuits described as examples in this catalog and the "delivery specifications" are featured in order to show the operations and usage of our products, however, this fact does not guarantee that the circuits are available to function in your equipment systems. We are not in any case responsible for any failures or damage caused by the use of information contained herein. You should examine our products, of which the characteristics are described in the "delivery specifications" and other documents, and determine whether or not our products suit your requirements according to the specifications of your equipment systems. Therefore, you bear final responsibility regarding the use of our products. Please make sure that you take appropriate safety measures such as use of redundant design and malfunction prevention measures in order to prevent fatal accidents and/or fires in the event any of our products malfunction. ■ We strongly recommend our customers to purchase Nippon Chemi-Con products only through our official sales channels. We assume no responsibility for any defects or damages caused by using products purchased from outside our official sales channel or of counterfeit goods. In addition, we will ask the customer to pay the investigation cost for products purchased outside our official sales channel. ■ We reserve the right to discontinue production and delivery of products. We do not guarantee that all the products included in this catalog will be available in the future. The aforementioned does not apply in the case of individual agreements deviating from the foregoing for customer-specific products ■ We continually strive to improve the quality and reliability of our products, but in any case that our product does not meet our published specifications, please stop using it promptly and contact us immediately. As for compensation for non-conforming goods delivered by Chemi-Con, we will limit it only to goods found in non-compliance of our published specifications. This may be accomplished by a no cost replacement of non-conforming individual products, a credit of the piece price paid per each individual non-conforming product, or in other ways deemed necessary. In addition, we have an established system with enhanced traceability, therefore we will limit the applicable lot items for any potential compensation. Part Numbering System Part Numbering System (Appendix) Standardization Available Items by Manufacturing Locations Environmental Measures Technical Note Precautions and Guidelines Recommended Soldering Conditions Taping, Lead-preforming and Packaging Available Terminals for Snap-in and Screw Mount Type Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001X 2023
ESMQ201VRD272MA50S 价格&库存
很抱歉,暂时无法提供与“ESMQ201VRD272MA50S”相匹配的价格&库存,您可以联系我们找货
