TFETBLJANF-19.440000
    TAITIEN(泰艺)
    DIP8
    OSC TCXO 19.4400MHZ CMOS DIP
TFETBLJANF-19.440000 数据手册
TF Type 20.4 x 12.8 mm Voltage Controlled Temperature re Compensated Crystal Oscillator FEATURE - Typical 20.4 x 12.8 x 7.8 mm. - Hermetically Sealed 14 Pin DIP Package - Double sealed metal case and high reliability - VCTCXO available TYPICAL APPLICATION - Large-Scale equipment - WLAN/WiMAX - Military Communication Equipmet RoHS Compliant DIMENSION (mm) SOLDER PAD LAYOUT (mm) [ SIDE VIEW ] 7.8Max [ BOTTOM VIEW ] 20.4 ± 0.4 8 14 Pin 1 Symbol 4.58 ± 0.2 7 0.8 1 0.45 12.2 ± 0.2 15.24 ± 0.15 Pad# 1 7 8 14 6.4 ± 0.5 [ TOP VIEW ] 7.62 ± 0.15 Function Vcon / NC GND Output VDD 12.8 ± 0.4 Recmmended soldering pattern ELECTRICAL SPECIFICATION Parameter Supply Voltage Variation (VDD) ±5% Frequency Range Frequency Tolerance* Frequency Stability Vs Supply Voltage (±5%) change Vs Load (±10%) change Vs Aging (@1st year) Supply Current 10 MHz Fo薹15 MHz 15 MHz Fo薹26 MHz 26 MHz Fo!!!52 MHz Output Level Supply Current 1.25 MHz Fo薹10 MHz 10 MHz Fo薹15 MHz 15 MHz Fo薹26 MHz 26 MHz Fo!!!52 MHz Output Level Output High (Logic"1") Clipped Sine Wave 3.3 V 2.8 V Min. Max. Min. Max. CMOS 3.3 V 2.8V Min. Max. Min. Max. 3.135 10 3.135 1.25 _ 3.465 52 ±2.0 _ _ _ _ _ _ 2.66 10 _ _ _ _ _ _ ±0.2 ±0.2 ±1.0 2.0 3.0 4.0 _ 0.8 2.94 52 ±2.0 _ ±0.2 ±0.2 ±1.0 2.0 3.0 4.0 0.8 _ 2.5 0.5 ±5.0 100 _ _ -115 -135 -148 _ 2 125 -55 -55 _ _ _ 2.66 1.25 2.94 52 ±2.0 _ _ _ _ ±0.2 ±0.2 ±1.0 ±0.2 ±0.2 ±1.0 2.5 _ _ -115 -135 -148 2 125 V MHz ppm ppm ppm mA Only for clipped sine wave Vp-p _ _ _ _ Output Low (Logic"0") 0.5 ±5.0 100 3.465 52 ±2.0 _ Only for CMOS Duty Control Voltage Range (VCTCXO) Pulling Range (VCTCXO) VC Input Impedance (VCTCXO) Phase noise @ 13.0 MHz 100 Hz 1 kHz 10 kHz Start Time Storage Temp. Range _ Unit _ _ _ _ 10 15 20 25 7 10 15 20 2.97 or 2.4 _ 2.52 or 2.4 _ _ 0.33 or 0.4 60 2.5 _ 0.28 or 0.4 60 2.5 40 0.5 ±5.0 100 _ _ _ 40 0.5 ±5.0 100 -115 -135 -148 -55 2 125 _ -55 _ _ -115 -135 -148 mA V % V ppm kΩ dBc/Hz 2 125 mSec °C Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. * Frequency at 25°C, 1 hour after reflow. FREQ. STABILITY vs. TEMP. RANGE Output Logic ppm Temp. (°C) -20 ~ +70 -40 ~ +85 Clipped sine wave ±0.5 " " ±1.0 CMOS ±0.5 " " ±1.0 * ż: Available Χ:Conditional X: Not available “ Pulling Range < 10 ppm available Note: not all combination of options are available. Other specifications may be available upon request. 6SHFL¿FDWLRQVVXEMHFWWRFKDQJHZLWKRXWQRWLFH www.taitien.com sales@taitien.com.tw Rev(15)11/2019 101
TFETBLJANF-19.440000 价格&库存
很抱歉,暂时无法提供与“TFETBLJANF-19.440000”相匹配的价格&库存,您可以联系我们找货
