TZKTADSANF-50.000000
    TAITIEN(泰艺)
    SIP4
    OSC TCXO 50.0MHZ 1.8V CLP SW SMD
TZKTADSANF-50.000000 数据手册
TZ Type 2.0 x 1.6 mm SMD Voltage Controlled Temperature Compensated Crystal Oscillator Actual Size FEATURE - Typical 2.0 x 1.6 x 0.7 mm ceramic SMD package. - For automatic assembly. - Compactness and lightweight. - VCTCXO available. - Miniature size and low profile. TYPICAL APPLICATION - GPS - WiMAX, WLAN - Mobile Phone - IoT, wearable Electronics. Actual Size OPTION A OPTION B RoHS Compliant RoHS Compliant OPTION A DIMENSION (mm) SOLDER PAD L AYOUT (mm) 2.05±0.10 #4 0.1μF 1.20 #2 [ SIDE VIEW ] Pin# Pin Function 1 GND   2 0.7±0.10 GND #1 #2 1.20 To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. GND 3  Output 4 +Vcc 0.80 1.65±0.10 #3 Marking #1 0.60 0.60 #3 #4 0.40 [ BOTTOM VIEW ] [ TOP VIEW ] OPTION B DIMENSION (mm) SOLDER PAD L AYOUT (mm) [ BOTTOM VIEW ] 1.45 1.2 #1 #2 0.70Max [ SIDE VIEW ] #3 #4 #2 #1 0.1 uF 1.20 #3 0.6 0.4 #4 1.15 1.65±0.10 2.05±0.10 Pin# Function 1 Vcon: VC-TCXO GND:TCXO 2 3 4   GND  Output VDD GND 1.20 0.8 [ TOP VIEW ] To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. Note: not all combination of options are available. Other specifications may be available upon request. 90 www.taitien.com sales@taitien.com.tw XO-0142 Rev(7) 10/2023 ELECTRICAL SPECIFICATION 3.3 / 3.0 / 2.8 V Min. Max. 2.66 3.465 10 52 Parameter Supply Voltage Variation (VDD) Frequency Range Standard Frequency Frequency Tolerance* Frequency stability Vs Supply Voltage (±5%) change Vs Load (±10%) change Vs Aging (@1st year) Supply Current 10 MHz Fo 26 MHz 26 MHz Fo 52 MHz Output Level (Clipped sine wave) Load Control Voltage Range (VCTCXO) Pulling Range (VCTCXO) Vc Input Impedance (VCTCXO) Phase Noise @ 19.2 MHz 100 Hz 1 kHz 10 kHz Start time Storage Temp. Range _ ±2.0 _ _ _ _ _ 2.5 V Min. Max. 2.375 2.625 10 52 16.369, 19.2, 26.0, 38.4 _ ±2.0 _ _ _ _ _ ±0.2 ±0.2 ±1.0 1.5 2.0 _ ±0.2 ±0.2 ±1.0 1.5 2.0 _ 0.8 0.8 10 KΩ // 10pF 10 KΩ // 10pF 0.5 2.5 0.4 2.4 _ _ ±5.0 ±5.0 _ _ 500 500 -115 -115 -135 -135 -148 -148 _ _ 2 2 -55 125 -55 125 Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. * Frequency at 25°C, 1 hour after reflow. 1.8 V Min. 1.71 10 _ _ _ _ _ _ Max. 1.89 52 ±2.0 ±0.2 ±0.2 ±1.0 1.5 2.0 _ 0.8 10 KΩ // 10pF 0.3 1.5 _ ±5.0 _ 500 -115 -135 -148 _ 2 -55 125 Unit V MHz ppm ppm ppm mA Vp-p V ppm kΩ dBc/Hz mSec °C FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) ppm ±0.5 ±1.0 ±1.5 ±2.0 ±2.5 -20 ~ +70 -30 ~ +85 -40 ~ +85 * ○: Available △:Conditional X: Not available Note: not all combination of options are available. Other specifications may be available upon request. www.taitien.com sales@taitien.com.tw XO-0142 Rev(7) 10/2023 91
TZKTADSANF-50.000000 价格&库存
很抱歉,暂时无法提供与“TZKTADSANF-50.000000”相匹配的价格&库存,您可以联系我们找货
  • 1000+21.307131000+2.76769
  • 2000+20.429302000+2.65367
  • 3000+19.933163000+2.58922
库存:2932
  • 1+32.453291+4.21552
  • 10+28.2044010+3.66361
  • 25+26.6699325+3.46429
  • 50+25.5673950+3.32108
  • 100+24.51072100+3.18382
  • 250+23.18080250+3.01107
  • 500+22.34544500+2.90256
库存:2932
