8NE-20.000MBM-T
8NE-20.000MBM-T
    TXC(台晶)
    4-SMD, No Lead
    XTAL OSC XO 20.000MHZ CMOS SMD
8NE-20.000MBM-T 数据手册
8NE Low EMI Oscillator Features Frequency range : 1MHz to 40MHz SMD seam sealing ceramic package Supply voltage : 1.8V ~ 3.3V CMOS output Phase modulation clock function selectable for EMI reduction External dimensions (mm) L : 2.0 x W : 1.6 x H : 0.76 RoHS compliant & Pb free Applications Imaging & Display Devices HD Camera, DVR HD Surveillance Camera Computer Peripherals Consumer products Electrical Characteristics Item 8NE Frequency Range (F 0) 1MHz ~ 40MHz Frequency Stability (F stab) ±50 ppm Operating Temperature Range (T OTR) -40°C ~ +85°C -40°C ~ +105°C -40°C ~ +125°C Supply Voltage (VDD) 1.8V, 2.5V, 3.3V Current Consumption (IDD) Note [1] & [2] VDD ± 5% 10 mA Max. Output Type CMOS Output Load (CL) 15 pF Output Voltage High (VOH) 80% VDD Min. Output Voltage Low (VOL) 20% VDD Max. Rise & Fall Time (Tr / Tf) 8 ns Max. Duty Cycle Start-up Time 45% ~ 55% 1 ms Max. Phase Jitter, RMS Phase Modulation Clock Mode Conditions 1 ps Max. Enable Disable Aging (F aging) Storage Temperature Range (T STR) 20% ~ 80% of VDD Note [2] Integrated 12kHz~5MHz. 30% VDD Max. (Logic "0") 70% VDD Min. (Logic "1") Input to Pin1; Note [3] ±3 ppm Max. at 25°C±3°C,first year -55°C ~ +125°C Notes: [1] Inclusive of frequency tolerance at 25°C, variations over operating temperature, supply voltage, load and 1st year aging at 25°C. [2] Phase modulation clock mode is disabled. [3] Phase modulation clock mode will be enabled if Pin1 is Logic "0"; Phase modulation clock mode will be disabled if Pin1 is Logic "1" or open (Internal pull-high resistor). Rev. 1.01 Page 1 www.txccrystal.com 8NE Low EMI Oscillator Phase Modulation Mode Deviation [4] Deviaton range (%) Frequency (MHz) VDD 1.8V VDD 2.5V VDD 3.3V 20 24 25 27 ± 0.54 ± 0.62 ± 0.65 ± 0.70 ± 0.36 ± 0.42 ± 0.45 ± 0.54 ± 0.29 ± 0.34 ± 0.35 ± 0.40 Notes: [4] Contact us for available frequencies and deviation range. Dimensions (Unit: mm) (Suggested Layout) Ordering Information 8NE - 27.000M B E - T Packaging Method Frequency in Hz T Please contact us for available frequencies Frequency Stability Supply Voltage B C D Rev. 1.01 Tape & Reel E J M 3.3 V 2.5 V 1.8 V Page 2 ± 50 ppm ( -40°C ~ +85°C ) ± 50 ppm ( -40°C ~ +105°C ) ± 50 ppm ( -40°C ~ +125°C ) www.txccrystal.com 8NE Low EMI Oscillator Packing (Unit: mm) (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.01 60 sec Page 3 Time (sec) www.txccrystal.com
8NE-20.000MBM-T
物料型号:8NE
器件简介:该振荡器适用于1MHz至40MHz的频率范围,采用SMD封装,适用于成像和显示设备、高清摄像机、DVR、监控摄像机、计算机外设和消费产品。
引脚分配:1号引脚为使能控制,2号引脚为地,3号引脚为输出,4号引脚为电源。
参数特性:包括频率稳定性、工作温度范围、供电电压、最大电流消耗、输出类型、输出负载、高低电平输出电压、上升和下降时间、占空比、启动时间、相位抖动、老化率和存储温度范围。
功能详解:具有相位调制时钟功能,可通过选择来减少电磁干扰。
应用信息:适用于需要低电磁干扰的电子设备,如高清摄像机、监控设备等。
封装信息:外部尺寸为长2.0mm、宽1.6mm、高0.76mm,符合RoHS标准,无铅。
8NE-20.000MBM-T 价格&库存
很抱歉,暂时无法提供与“8NE-20.000MBM-T”相匹配的价格&库存,您可以联系我们找货
8NE-20.000MBM-T
  • 3000+10.980083000+1.42170
  • 6000+10.527546000+1.36311
库存:1
8NE-20.000MBM-T
  • 1+17.844431+2.31049
  • 10+15.5392110+2.01201
  • 25+14.6959925+1.90283
  • 50+14.0876450+1.82407
  • 100+13.50576100+1.74872
  • 250+12.77198250+1.65371
  • 500+12.24410500+1.58537
  • 1000+11.738371000+1.51988
库存:1
