SIT9005AI-23H33EP12.000000 数据手册
SiT9005
1 to 141 MHz EMI Reduction Oscillator
Features
Applications
Spread spectrum for EMI reduction
▪ Wide spread % option
Center spread: from ±0.125% to ±2%, ±0.125%
step size
Down spread: -0.25% to -4% with -0.25%
step size
▪ Spread profile option: Triangular, Hershey-kiss
Programmable rise/fall time for EMI reduction:
8 options, 0.25 to 40 ns
Any frequency between 1 MHz and 141 MHz accurate to
6 decimal places
100% pin-to-pin drop-in replacement to quartz-based XO’s
Excellent total frequency stability as low as ±20 ppm
Operating temperature from -40°C to 85°C
Low power consumption of 4.0 mA typical at 1.8 V
Pin1 modes: Standby, output enable, or spread disable
Fast startup time of 5 ms
LVCMOS output
Industry-standard packages
▪ QFN: 2.0 x 1.6, 2.5 x 2.0, 3.2 x 2.5 mm2
▪ Contact SiTime for SOT23-5 (2.9 x 2.8 mm2)
RoHS and REACH compliant, Pb-free, Halogen-free
and Antimony-free
Surveillance camera
IP camera
Industrial motors
Flat panels
Multi function printers
PCI express
Electrical Specifications
Table 1. Electrical Characteristics
All Min and Max limits are specified over temperature and rated operating voltage with 15 pF output load unless otherwise stated.
Typical values are at 25°C and 3.3 V supply voltage.
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Frequency Range
Output Frequency Range
f
1
141
MHz
Frequency Stability and Aging
Frequency Stability
F_stab
-20
+20
ppm
-25
+25
ppm
+50
ppm
-50
Inclusive of initial tolerance at 25°C, 1st year aging at 25°C, and
variations over operating temperature, rated power supply
voltage. Spread = Off.
Operating Temperature Range
T_use
-20
+70
°C
Extended Commercial
-40
+85
°C
Industrial
Supply Voltage and Current Consumption
Supply Voltage
Current Consumption
Vdd
Idd
OE Disable Current
I_OD
Standby Current
I_std
Rev 1.01
1.62
1.8
1.98
V
2.25
2.5
2.75
V
2.52
2.8
3.08
V
2.7
3.0
3.3
V
2.97
3.3
3.63
V
2.25
3.63
V
5.6
6.5
mA
No load condition, f = 40 MHz, Vdd = 2.5 V to 3.3 V
5.0
5.5
mA
No load condition, f = 40 MHz, Vdd = 1.8 V
5.0
6.5
mA
f = 40 MHz, Vdd = 2.5 V to 3.3 V, OE = GND, Output in
high-Z state
4.6
5.2
mA
f = 40 MHz, Vdd = 1.8 V, OE = GND, Output in high-Z state
2.1
4.3
A
ST = GND, Vdd = 2.5 V to 3.3 V, Output is weakly pulled down
0.4
1.5
A
ST = GND, Vdd = 1.8 V, Output is weakly pulled down
11 March 2021
www.sitime.com
SiT9005 1 to 141 MHz EMI Reduction Oscillator
Table 1. Electrical Characteristics (continued)
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
LVCMOS Output Characteristics
Duty Cycle
Rise/Fall Time
DC
45
55
Tr, Tf
1
2
ns
Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V, 20% - 80%, default derive
strength
1.3
2.5
ns
Vdd =1.8 V, 20% - 80%, default derive strength
2
ns
Vdd = 2.25 V - 3.63 V, 20% - 80%, default derive strength
Output High Voltage
VOH
90%
Vdd
IOH = -4 mA (Vdd = 3.0 V or 3.3 V)
IOH = -3 mA (Vdd = 2.8 V and Vdd = 2.5 V)
IOH = -2 mA (Vdd = 1.8 V)
Output Low Voltage
VOL
10%
Vdd
IOL = 4 mA (Vdd = 3.0 V or 3.3 V)
IOL = 3 mA (Vdd = 2.8 V and Vdd = 2.5 V)
IOL = 2 mA (Vdd = 1.8 V)
Input High Voltage
VIH
70%
Vdd
Pin 1, OE or ST
Input Low Voltage
VIL
30%
Vdd
Pin 1, OE or ST
Input Pull-up Impedance
Z_in
50
87
150
k
Pin 1, OE logic high or logic low, or ST
̅ ̅ ̅ logic high
2
M
Pin 1, ST
̅ ̅ ̅ logic low
Input Characteristics
Startup and Resume Timing
T_start
5
ms
Measured from the time Vdd reaches its rated minimum value
T_oe
180
ns
f = 40 MHz. For other frequencies, T_oe = 100 ns + 3 * cycles
T_resume
5
ms
Measured from the time ST pin crosses 50% threshold
Spread Enable Time
T_sde
4
µs
Measured from the time SD pin crosses 50% threshold
Spread Disable Time
T_sdde
50
µs
Startup Time
Enable/Disable Time
Resume Time
Jitter
Cycle-to-cycle jitter
T_ccj
10.5
15
ps
f = 40 MHz, Vdd = 2.5 to 3.3V, Spread = ON( or OFF)
8.5
12
ps
f = 40 MHz, Vdd = 3.3V, Spread = ON( or OFF)
12.5
22
ps
f = 40 MHz, Vdd = 1.8V, Spread = ON( or OFF)
Table 2. Spread Spectrum % [1,2]
Table 3. Spread Profile
Ordering
Code
Center Spread
Down Spread
Spread Profile
A
±0.125
-0.25
Hershey-kiss
B
±0.250
-0.50
C
±0.390
-0.78
D
±0.515
-1.04
E
±0.640
-1.29
F
±0.765
-1.55
G
±0.905
-1.84
H
±1.030
-2.10
I
±1.155
-2.36
J
±1.280
-2.62
K
±1.420
-2.91
L
±1.545
-3.18
M
±1.670
-3.45
N
±1.795
-3.71
O
±1.935
-4.01
P
±2.060
-4.28
Triangular
Notes:
1. In both center spread and down spread modes, modulation rate is
employed with a frequency of ~31.25 kHz.
2. Contact SiTime for wider spread options
Rev 1.01
Page 2 of 10
www.sitime.com
Table 4. Pin Description
Pin
1
Symbol
OE / ST /
NC / SD
Top View
Functionality
Output
Enable
H[3]: specified frequency output
L: output is high impedance. Only output driver is disabled.
Standby
L: output is low (week pull down). Device goes to sleep mode.
Supply current reduced to I_std.
No
Connect
Pin1 has no function (Any voltage between 0 and Vdd or Open)
Spread
Disable
H: Spread = ON
L: Spread = OFF
2
GND
Power
Electrical ground
3
OUT
Output
Oscillator output
4
VDD
Power
Power supply voltage[4]
OE/ ST
NC/SD
1
4
VDD
GND
2
3
OUT
Figure 1. Pin Assignments
Notes:
3. In OE or ST mode, a pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven. If pin 1 needs to be left floating, use the NC option.
4. A capacitor of value 0.1 µF or higher between Vdd and GND is required.
Table 5. Absolute Maximum Limits
Attempted operation outside the absolute maximum ratings may cause permanent damage to the part.
Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings.
Parameter
Min.
Max.
Unit
Storage Temperature
-65
150
°C
Vdd
-0.5
4
V
Electrostatic Discharge
2000
V
Soldering Temperature (follow standard Pb free soldering guidelines)
260
°C
Junction Temperature[5]
150
°C
Note:
5. Exceeding this temperature for extended period of time may damage the device.
Table 6. Maximum Operating Junction Temperature[6]
Max Operating Temperature (ambient)
70°C
80°C
85°C
95°C
Note:
6. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature.
Table 7. Environmental Compliance
Parameter
Condition/Test Method
Mechanical Shock
MIL-STD-883F, Method 2002
Mechanical Vibration
MIL-STD-883F, Method 2007
Temperature Cycle
JESD22, Method A104
Solderability
MIL-STD-883F, Method 2003
Moisture Sensitivity Level
MSL1 @ 260°C
Rev 1.01
Page 3 of 10
www.sitime.com
Timing Diagrams
90% Vdd
Vdd
Vdd
50% Vdd
T_start
Pin 4 Voltage
[7]
No Glitch
during start up
T_resume
ST Voltage
CLK Output
HZ
CLK Output
HZ
T_resume: Time to resume from ST
T_start: Time to start from power-off
Figure 2. Startup Timing
Figure 3. Standby Resume Timing
(ST Mode Only)
Vdd
Vdd
50% Vdd
OE Voltage
50% Vdd
T_oe
OE Voltage
T_oe
CLK Output
CLK Output
HZ
HZ
T_oe: Time to put the output in High Z mode
T_oe: Time to re-enable the clock output
Figure 4. OE Enable Timing (OE Mode Only)
Figure 5. OE Disable Timing (OE Mode Only)
Vdd
50% Vdd
SD Voltage
Vdd
50% Vdd
T_sde
Frequency
Deviation (%)
T_sdde
Modulation period = 32µs (31.25kHz)
Frequency
Deviation (%)
SD Voltage
Time (s)
Time (s)
Figure 6. SD Enable Timing (SD Mode Only)
Figure 7. SD Diable Timing (SD Mode Only)
Note:
7. SiT9005 has “no runt” pulses and “no glitch” output during startup or resume.
Rev 1.01
Page 4 of 10
www.sitime.com
Programmable Drive Strength
High Output Load Capability
The SiT9005 includes a programmable drive strength
feature to provide a simple, flexible tool to optimize the
clock rise/fall time for specific applications. Benefits from the
programmable drive strength feature are:
The rise/fall time of the input clock varies as a function of
the actual capacitive load the clock drives. At any given
drive strength, the rise/fall time becomes slower as the
output load increases. As an example, for a 3.3V SiT9005
device with default drive strength setting, the typical rise/fall
time is 1.1 ns for 15 pF output load. The typical rise/fall time
slows down to 2.9 ns when the output load increases to
45 pF. One can choose to speed up the rise/fall time to
1.9 ns by then increasing the drive strength setting on
the SiT9005.
Improves system radiated electromagnetic interference
(EMI) by slowing down the clock rise/fall time
Improves the downstream clock receiver’s (RX) jitter by
decreasing (speeding up) the clock rise/fall time.
Ability to drive large capacitive loads while maintaining
full swing with sharp edge rates.
For more detailed information about rise/fall time control
and drive strength selection, see the SiTime Application
Notes section.
The SiT9005 can support up to 60 pF or higher in
maximum capacitive loads with up to 3 additional drive
strength settings. Refer to Table 8 through Table 12 to
determine the proper drive strength for the desired
combination of output load vs. rise/fall time
EMI Reduction by Slowing Rise/Fall Time
SiT9005 Drive Strength Selection
Figure 8 shows the harmonic power reduction as the
rise/fall times are increased (slowed down). The rise/fall
times are expressed as a ratio of the clock period. For the
ratio of 0.05, the signal is very close to a square wave. For
the ratio of 0.45, the rise/fall times are very close to neartriangular waveform. These results, for example, show that
the 11th clock harmonic can be reduced by 35 dB if the
rise/fall edge is increased from 5% of the period to 45% of
the period.
Table 8 through Table 12 define the rise/fall time for a given
capacitive load and supply voltage.
Select the table that matches the SiT9005 nominal
supply voltage (1.8 V, 2.5 V, 2.8 V, 3.3 V).
Select the capacitive load column that matches the
application requirement (15 pF to 60 pF)
Under the capacitive load column, select the desired
rise/fall times.
The left-most column represents the part number
code for the corresponding drive strength.
Add the drive strength code to the part number for
ordering purposes.
trise=0.05
trise=0.1
trise=0.15
trise=0.2
trise=0.25
trise=0.3
trise=0.35
trise=0.4
trise=0.45
10
Harmonic amplitude (dB)
-20
Calculating Maximum Frequency
Based on the rise and fall time data given in Table 8
through Table 12, the maximum frequency the oscillator
can operate with guaranteed full swing of the output voltage
over temperature as follows:
-30
-40
-50
-60
-70
-80
Max Frequency =
1
3
5
7
9
11
1
5 x Trf_20/80
Harmonic number
Figure 8. Harmonic EMI reduction as a Function
of Slower Rise/Fall Time
where Trf_20/80 is the typical rise/fall time at 20% to 80%
Vdd
Jitter Reduction with Faster Rise/Fall Time
Example 1
Power supply noise can be a source of jitter for the
downstream chipset. One way to reduce this jitter is to
increase rise/fall time (edge rate) of the input clock. Some
chipsets would require faster rise/fall time in order to
reduce their sensitivity to this type of jitter. The SiT9005
provides up to 3 additional high drive strength settings for
very fast rise/fall time. Refer to Table 8 through Table 12 to
determine the proper drive strength.
Calculate fMAX for the following condition:
Vdd = 3.3 V (Table 12)
Capacitive Load: 30 pF
Desired Tr/f time = 1.6 ns
(rise/fall time part number code = Z)
Part number for the above example:
SiT9005AIZ14-33EB-105.12345
Drive strength code is inserted here. Default setting is “-”
Rev 1.01
Page 5 of 10
www.sitime.com
Rise/Fall Time (20% to 80%) vs CLOAD Tables
Table 8. Vdd = 1.8 V Rise/Fall Times
for Specific CLOAD
Table 9. Vdd = 2.5 V Rise/Fall Times
for Specific CLOAD
Rise/Fall Time Typ (ns)
Drive Strength \ CLOAD
5 pF
15 pF
30 pF
45 pF
60 pF
5 pF
15 pF
30 pF
45 pF
60 pF
L
6.16
11.61
22.00
31.27
39.91
L
4.13
8.25
12.82
21.45
27.79
2.11
4.27
7.64
11.20
14.49
A
3.19
6.35
11.00
16.01
21.52
A
R
2.11
4.31
7.65
10.77
14.47
R
1.45
2.81
5.16
7.65
9.88
B
1.65
3.23
5.79
8.18
11.08
B
1.09
2.20
3.88
5.86
7.57
T
0.93
1.91
3.32
4.66
6.48
T
0.62
1.28
2.27
3.51
4.45
E
0.78
1.66
2.94
4.09
5.74
E or "‐": default
0.54
1.00
2.01
3.10
4.01
U
0.70
1.48
2.64
3.68
5.09
U
0.43
0.96
1.81
2.79
3.65
F or "‐": default
0.65
1.30
2.40
3.35
4.56
F
0.34
0.88
1.64
2.54
3.32
Table 10. Vdd = 2.8 V Rise/Fall Times
for Specific CLOAD
Table 11. Vdd = 3.0 V Rise/Fall Times
for Specific CLOAD
5 pF
15 pF
30 pF
45 pF
60 pF
5 pF
15 pF
30 pF
45 pF
60 pF
L
3.77
7.54
12.28
19.57
25.27
L
3.60
7.21
11.97
18.74
24.30
A
1.94
3.90
7.03
10.24
13.34
A
1.84
3.71
6.72
9.86
12.68
R
1.29
2.57
4.72
7.01
9.06
R
1.22
2.46
4.54
6.76
8.62
B
0.97
2.00
3.54
5.43
6.93
B
0.89
1.92
3.39
5.20
6.64
T
0.55
1.12
2.08
3.22
4.08
T or "‐": default
0.51
1.00
1.97
3.07
3.90
E or "‐": default
0.44
1.00
1.83
2.82
3.67
E
0.38
0.92
1.72
2.71
3.51
U
0.34
0.88
1.64
2.52
3.30
U
0.30
0.83
1.55
2.40
3.13
F
0.29
0.81
1.48
2.29
2.99
F
0.27
0.76
1.39
2.16
2.85
Table 12. Vdd = 3.3 V Rise/Fall Times
for Specific CLOAD
5 pF
15 pF
30 pF
45 pF
60 pF
L
3.39
6.88
11.63
17.56
23.59
A
R
B
1.74
1.16
0.81
3.50
2.33
1.82
6.38
4.29
3.22
8.98
6.04
4.52
12.19
8.34
6.33
T or "‐": default
0.46
1.00
1.86
2.60
3.84
E
U
0.33
0.28
0.87
0.79
1.64
1.46
2.30
2.05
3.35
2.93
F
0.25
0.72
1.31
1.83
2.61
Rev 1.01
Page 6 of 10
www.sitime.com
Dimensions and Patterns
Package Size – Dimensions (Unit: mm)[8]
Recommended Land Pattern (Unit: mm)[9]
2.0 x 1.6 x 0.75 mm
0.8
1.2
1.5
0.9
2.5 x 2.0 x 0.75 mm
1.0
1.5
1.9
1.1
Rev 1.01
Page 7 of 10
www.sitime.com
Dimensions and Patterns (continued)
3.2 x 2.5 x 0.75 mm
1.2
1.9
2.2
1.4
Notes:
8. Top marking: Y denotes manufacturing origin and XXXX denotes manufacturing lot number. The value of “Y” will depend on the assembly location of
the device.
9. A capacitor of value 0.1 µF or higher between Vdd and GND is required.
Rev 1.01
Page 8 of 10
www.sitime.com
Ordering Information
The Part No. Guide is for reference only.
To customize and build an exact part number, use the SiTime Part Number Generator.
SiT9005AI -71-18EA2 5 .000625D
Part Family
“SiT9005”
Packing Method
“D”: 8 mm Tape & Reel, 3ku reel
“E”: 8 mm Tape & Reel, 1ku reel
Blank for Bulk
Revision Letter
“A” is the revision
Frequency
Temperature Range
1.000000 to 141.000000 MHz
“C” Commercial -20ºC to 70ºC
“I” Industrial -40ºC to 85ºC
Spread Percentage
Center:
”A” for ±0.125,
“B” for ±0.250,
“C” for ±0.390,
“D” for ±0.515,
“E” for ±0.640,
“F” for ±0.765,
“G” for ±0.905,
“H” for ±1.030,
“I”
for ±1.155,
“J” for ±1.280,
“K” for ±1.420,
“L” for ±1.545,
“M” for ±1.670,
“N” for ±1.795,
“O” for ±1.935,
“P” for ±2.060,
Output Drive Strength
“–” Default (datasheet limits)
See Tables 7 to 11 for rise/fall times
“L”
“A”
“R”
“B”
“T”
“E”
“U”
“F”
Package Size
[10]
n1
2.0 x 1.6 mm
2.5 x 2.0 mm
“7”
“1”
“2” 3.2 x 2.5 mm
Frequency Stability
“1” for ±20 ppm
“2” for ±25 ppm
“3” for ±50 ppm
Down:
-0.25
-0.50
-0.78
-1.04
-1.29
-1.55
-1.84
-2.10
-2.36
-2.62
-2.91
-3.18
-3.45
-3.71
-4.01
-4.28
Feature Pin
“E” for Output Enable
“S” for Standby
“N” for No Connect
“D” for Spread Disablel
Spread Type and Profile
“-” Center spread & Triangular (Default)
“H” Center spread & Hershey Kiss
“D” Down spread & Triangular
“G” Down spread & Hershey Kiss
Supply Voltage
“18” for 1.8 V ±10%
“25” for 2.5 V ±10%
“28” for 2.8 V ±10%
“30” for 3.0 V ±10%
“33” for 3.3 V ±10%
“XX” for 2.5 V -10% to 3.3 V +10%
Note:
10. Contact SiTime for SOT23 (2.9 x 2.8 mm2) package.
Rev 1.01
Page 9 of 10
www.sitime.com
Table 13. Revision History
Revision
Release Date
Change Summary
1.0
25-Sep-2017
Final release
1.01
11-Mar-2021
Formatting layout issues, updated hyperlinks and changed rev table date format
Updated Dimensions and Patterns drawings
SiTime Corporation, 5451 Patrick Henry Drive, Santa Clara, CA 95054, USA | Phone: +1-408-328-4400 | Fax: +1-408-328-4439
© SiTime Corporation 2017-2021. The information contained herein is subject to change at any time without notice. SiTime assumes no responsibility or liability for any loss, damage
or defect of a Product which is caused in whole or in part by (i) use of any circuitry other than circuitry embodied in a SiTime product, (ii) misuse or abuse including static discharge, neglect
or accident, (iii) unauthorized modification or repairs which have been soldered or altered during assembly and are not capable of being tested by SiTime under its normal test conditions, or
(iv) improper installation, storage, handling, warehousing or transportation, or (v) being subjected to unusual physical, thermal, or electrical stress.
Disclaimer: SiTime makes no warranty of any kind, express or implied, with regard to this material, and specifically disclaims any and all express or implied warranties, either in fact or by
operation of law, statutory or otherwise, including the implied warranties of merchantability and fitness for use or a particular purpose, and any implied warranty arising from course of dealing or
usage of trade, as well as any common-law duties relating to accuracy or lack of negligence, with respect to this material, any SiTime product and any product documentation. Products sold by
SiTime are not suitable or intended to be used in a life support application or component, to operate nuclear facilities, or in other mission critical applications where human life may be involved
or at stake. All sales are made conditioned upon compliance with the critical uses policy set forth below.
CRITICAL USE EXCLUSION POLICY
BUYER AGREES NOT TO USE SITIME'S PRODUCTS FOR ANY APPLICATION OR IN ANY COMPONENTS USED IN LIFE SUPPORT DEVICES OR TO OPERATE NUCLEAR
FACILITIES OR FOR USE IN OTHER MISSION-CRITICAL APPLICATIONS OR COMPONENTS WHERE HUMAN LIFE OR PROPERTY MAY BE AT STAKE.
SiTime owns all rights, title and interest to the intellectual property related to SiTime's products, including any software, firmware, copyright, patent, or trademark. The sale of SiTime products does
not convey or imply any license under patent or other rights. SiTime retains the copyright and trademark rights in all documents, catalogs and plans supplied pursuant to or ancillary to the sale
of products or services by SiTime. Unless otherwise agreed to in writing by SiTime, any reproduction, modification, translation, compilation, or representation of this material shall be strictly
prohibited.
Rev 1.01
Page 10 of 10
www.sitime.com
