SIT8921BM-23-33E-125.000000
    SITIME(赛特时脉)
    SIP4
    MEMS OSC XO 125.0000MHZ LVCMOS
SIT8921BM-23-33E-125.000000 数据手册
SiT8921B High Frequency, -55°C to +125°C Oscillator Features ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ ◼ Applications Frequencies between 119.342001 MHz to 137 MHz accurate to 6 decimal places Operating temperature from -55°C to 125°C Supply voltage of 1.8 V or 2.5 V to 3.3 V Excellent total frequency stability as low as ±20 ppm Low power consumption of 4.9 mA typical at 1.8 V LVCMOS/LVTTL compatible output Industry-standard packages: 2.0 x 1.6, 2.5 x 2.0, 3.2 x 2.5, 5.0 x 3.2, 7.0 x 5.0 mm x mm Instant samples with Time Machine II and field programmable oscillators RoHS and REACH compliant, Pb-free, Halogen-free and Antimony-free ◼ Ruggedized equipment in harsh operating environment Related products for automotive applications. For aerospace and defense applications SiTime recommends using only Endura™ SiT8945. Table 1. Electrical Characteristics All Min and Max limits are specified over temperature and rated operating voltage with 15 pF output load unless otherwise stated. Typical values are at 25°C and nominal supply voltage. Parameters Symbol Min. Typ. Max. Unit Condition Frequency Range Output Frequency Range f 119.342001 – 137 MHz Refer to Table 13 for the exact list of supported frequencies Frequency Stability and Aging Frequency Stability F_stab -20 – +20 ppm -25 – +25 ppm -30 – +30 ppm -50 – +50 ppm Inclusive of Initial tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, rated power supply voltage and load (15 pF ± 10%). Operating Temperature Range Operating Temperature Range T_use -55 – +125 °C Supply Voltage and Current Consumption Supply Voltage Current Consumption OE Disable Current Standby Current Vdd Idd I_od I_std 1.62 1.8 1.98 V 2.25 2.5 2.75 V 2.52 2.8 3.08 V 2.7 3.0 3.3 V 2.97 3.3 3.63 V 2.25 – 3.63 V – 6.2 8 mA No load condition, f = 125 MHz, Vdd = 2.8 V, 3.0 V or 3.3 V – 5.4 7 mA No load condition, f = 125 MHz, Vdd = 2.5 V – 4.9 6 mA No load condition, f = 125 MHz, Vdd = 1.8 V – – 4.7 mA Vdd = 2.5 V to 3.3 V, OE = Low, Output in high Z state. – – 4.5 mA Vdd = 1.8 V, OE = Low, Output in high Z state. – 2.6 8.5 A Vdd = 2.8 V to 3.3V, ST = Low, Output is weakly pulled down – 1.4 5.5 A Vdd = 2.5 V, ST = Low, Output is weakly pulled down – 0.6 4.0 A Vdd = 1.8 V, ST = Low, Output is weakly pulled down LVCMOS Output Characteristics Duty Cycle Rise/Fall Time DC 45 – 55 % All Vdds Tr, Tf – 1.0 2.0 ns Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V, 20% - 80% – 1.3 2.5 ns Vdd =1.8 V, 20% - 80% – 1.0 3 ns Vdd = 2.25 V - 3.63 V, 20% - 80% Output High Voltage VOH 90% – – Vdd IOH = -4 mA (Vdd = 3.0 V or 3.3 V) IOH = -3 mA (Vdd = 2.8 V or 2.5 V) IOH = -2 mA (Vdd = 1.8 V) Output Low Voltage VOL – – 10% Vdd IOL = 4 mA (Vdd = 3.0 V or 3.3 V) IOL = 3 mA (Vdd = 2.8 V or 2.5 V) IOL = 2 mA (Vdd = 1.8 V) Rev 1.03 1 January 2023 www.sitime.com SiT8921B High Frequency, -55°C to +125°C Oscillator Table 1. Electrical Characteristics (continued) Parameters Symbol Min. Typ. Max. Unit Condition Input Characteristics Input High Voltage VIH 70% – – Vdd Pin 1, OE or ST Input Low Voltage VIL – – 30% Vdd Pin 1, OE or ST Input Pull-up Impedance Z_in 50 87 150 k Pin 1, OE logic high or logic low, or ST logic high 2 – – M Pin 1, ST logic low Startup and Resume Timing Startup Time T_start – – 5 ms Measured from the time Vdd reaches its rated minimum value T_oe – – 130 ns f = 119.342001 MHz. For other frequencies, T_oe = 100 ns + 3 * clock periods T_resume – – 5 ms Measured from the time ST pin crosses 50% threshold Enable/Disable Time Resume Time Jitter RMS Period Jitter T_jitt Peak-to-peak Period Jitter T_pk RMS Phase Jitter (random) T_phj – 1.6 2.5 ps f = 125 MHz, Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V – 1.8 3 ps f = 125 MHz, Vdd = 1.8 V – 12 20 ps f = 125 MHz, Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V – 14 25 ps f = 125 MHz, Vdd = 1.8 V – 0.5 0.8 ps f = 125 MHz, Integration bandwidth = 900 kHz to 7.5 MHz – 1.3 2 ps f = 125 MHz, Integration bandwidth = 12 kHz to 20 MHz Table 2. Pin Description Pin Symbol Output Enable 1 OE/ ST /NC Top View Functionality Standby No Connect H[1]: specified frequency output L: output is high impedance. Only output driver is disabled. H[1]: specified frequency output L: output is low (weak pull down). Device goes to sleep mode. Supply current reduces to I_std. Any voltage between 0 and Vdd or Open[1]: Specified frequency output. Pin 1 has no function. 2 GND Power Electrical ground 3 OUT Output Oscillator output 4 VDD Power Power supply voltage[2] OE/ST/NC 1 4 VDD GND 2 3 OUT Figure 1. Pin Assignments Notes: 1. 2. Rev 1.03 In OE or ST mode, a pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven. If pin 1 needs to be left floating, use the NC option. A capacitor of value 0.1 µF or higher between Vdd and GND is required. Page 2 of 18 www.sitime.com SiT8921B High Frequency, -55°C to +125°C Oscillator Table 3. Absolute Maximum Limits Attempted operation outside the absolute maximum ratings of the part may cause permanent damage to the part. Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings. Min. Max. Unit Storage Temperature Parameter -65 150 °C VDD V -0.5 4 Electrostatic Discharge – 2000 V Soldering Temperature (follow standard Pb free soldering guidelines) – 260 °C Junction Temperature[3] – 150 °C Note: 3. Exceeding this temperature for extended period of time may damage the device. Table 4. Thermal Consideration[4] JA, 4 Layer Board (°C/W) Package JA, 2 Layer Board (°C/W) JC, Bottom (°C/W) 7050 142 273 30 5032 97 199 24 3225 109 212 27 2520 117 222 26 2016 152 252 36 Note: 4. Refer to JESD51-7 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above table. Table 5. Maximum Operating Junction Temperature[5] Max Operating Temperature (ambient) Maximum Operating Junction Temperature 125°C 135°C Note: 5. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature. Table 6. Environmental Compliance Parameter Condition/Test Method Mechanical Shock MIL-STD-883F, Method 2002 Mechanical Vibration MIL-STD-883F, Method 2007 Temperature Cycle JESD22, Method A104 Solderability MIL-STD-883F, Method 2003 Moisture Sensitivity Level MSL1 @ 260°C Rev 1.03 Page 3 of 18 www.sitime.com SiT8921B High Frequency, -55°C to +125°C Oscillator Test Circuit and Waveform Vdd Vout 4 3 Test Point tr Power Supply tf 80% Vdd 0.1µF 1 15pF (including probe and fixture capacitance) 2 50% 20% Vdd High Pulse (TH) Low Pulse (TL) Period Vdd 1k OE/NC Function Figure 3. Waveform[6] Figure 2. Test Circuit[6] Note: 6. Duty Cycle is computed as Duty Cycle = TH/Period. Timing Diagram 90% Vdd Vdd Vdd 50% Vdd [7] T_start Pin 4 Voltage No Glitch during start up T_resume ST Voltage CLK Output CLK Output HZ HZ T_start: Time to start from power-off T_resume: Time to resume from ST Figure 5. Standby Resume Timing ( ST Mode Only) Figure 4. Startup Timing (OE/ ST Mode) Vdd Vdd 50% Vdd OE Voltage 50% Vdd T_oe OE Voltage T_oe CLK Output CLK Output HZ HZ T_oe: Time to re-enable the clock output T_oe: Time to put the output in High Z mode Figure 6. OE Enable Timing (OE Mode Only) Figure 7. OE Disable Timing (OE Mode Only) Note: 7. Rev 1.03 SiT8921 has “no runt” pulses and “no glitch” output during startup or resume. Page 4 of 18 www.sitime.com SiT8921B High Frequency, -55°C to +125°C Oscillator Performance Plots[8] Figure 8. Idd vs Frequency Figure 9. Frequency vs Temperature Figure 10. RMS Period Jitter vs Frequency Figure 11. Duty Cycle vs Frequency Figure 12. 20%-80% Rise Time vs Temperature (125 MHz Output) Figure 13. 20%-80% Fall Time vs Temperature (125 MHz Output) Rev 1.03 Page 5 of 18 www.sitime.com SiT8921B High Frequency, -55°C to +125°C Oscillator Performance Plots[8] (continued) Figure 14. RMS Integrated Phase Jitter Random (12 kHz to 20 MHz) vs Frequency[9] Figure 15. RMS Integrated Phase Jitter Random (900 kHz to 20 MHz) vs Frequency[9] Notes: 8. 9. Rev 1.03 All plots are measured with 15 pF load at room temperature, unless otherwise stated. Phase noise plots are measured with Agilent E5052B signal source analyzer. Page 6 of 18 www.sitime.com SiT8921B High Frequency, -55°C to +125°C Oscillator Programmable Drive Strength can choose to speed up the rise/fall time to 0.72 ns by then increasing the driven strength setting on the SiT8921 to “F”. The SiT8921 includes a programmable drive strength feature to provide a simple, flexible tool to optimize the clock rise/fall time for specific applications. Benefits from the programmable drive strength feature are: ◼ Improves system radiated electromagnetic interference (EMI) by slowing down the clock rise/fall time The SiT8921 can support up to 30 pF in maximum capacitive loads with up to 3 additional drive strength settings. Refer to the Rise/Tall Time Tables (Tables 7 to 11) to determine the proper drive strength for the desired combination of output load vs. rise/fall time. ◼ Improves the downstream clock receiver’s (RX) jitter by decreasing (speeding up) the clock rise/fall time. ◼ Ability to drive large capacitive loads while maintaining full swing with sharp edge rates. SiT8921 Drive Strength Selection Tables 7 through 11 define the rise/fall time for a given capacitive load and supply voltage. 1. Select the table that matches the SiT8921 nominal supply voltage (1.8 V, 2.5 V, 2.8 V, 3.0 V, 3.3 V). 2. Select the capacitive load column that matches the application requirement (5 pF to 30 pF) 3. Under the capacitive load column, select the desired rise/fall times. 4. The left-most column represents the part number code for the corresponding drive strength. 5. Add the drive strength code to the part number for ordering purposes. For more detailed information about rise/fall time control and drive strength selection, see the SiTime Application Notes section. EMI Reduction by Slowing Rise/Fall Time Figure 16 shows the harmonic power reduction as the rise/fall times are increased (slowed down). The rise/fall times are expressed as a ratio of the clock period. For the ratio of 0.05, the signal is very close to a square wave. For the ratio of 0.45, the rise/fall times are very close to neartriangular waveform. These results, for example, show that the 11th clock harmonic can be reduced by 35 dB if the rise/fall edge is increased from 5% of the period to 45% of the period. Based on the rise and fall time data given in Tables 7 through 11, the maximum frequency the oscillator can operate with guaranteed full swing of the output voltage over temperature as follows: trise=0.05 trise=0.1 trise=0.15 trise=0.2 trise=0.25 trise=0.3 trise=0.35 trise=0.4 trise=0.45 10 0 Harmonic amplitude (dB) Calculating Maximum Frequency -10 -20 Max Frequency = 5 x T rf_20/80 where Trf_20/80 is the typical value for 20%-80% rise/fall time. -30 -40 -50 Example 1 -60 -70 -80 1 1 3 5 7 9 11 Harmonic number Figure 16. Harmonic EMI reduction as a Function of Slower Rise/Fall Time Calculate fMAX for the following condition: ◼ Vdd = 3.3 V (Table 11) ◼ Capacitive Load: 30 pF ◼ Desired Tr/f time = 1.46 ns (rise/fall time part number code = U) Part number for the above example: SiT8921BMU12-33E-136.986300 Jitter Reduction with Faster Rise/Fall Time Power supply noise can be a source of jitter for the downstream chipset. One way to reduce this jitter is to speed up the rise/fall time of the input clock. Some chipsets may also require faster rise/fall time in order to reduce their sensitivity to this type of jitter. Refer to the Rise/Fall Time Tables (Table 7 to 11) to determine the proper drive strength. Drive strength code is inserted here. Default setting is “-”. High Output Load Capability The rise/fall time of the input clock varies as a function of the actual capacitive load the clock drives. At any given drive strength, the rise/fall time becomes slower as the output load increases. As an example, for a 3.3 V SiT8921 device with default drive strength setting, the typical rise/fall time is 0.46 ns for 5 pF output load. The typical rise/fall time slows down to 1 ns when the output load increases to 15 pF. One Rev 1.03 Page 7 of 18 www.sitime.com SiT8921B High Frequency, -55°C to +125°C Oscillator Rise/Fall Time (20% to 80%) vs CLOAD Tables Table 7. Vdd = 1.8 V Rise/Fall Times for Specific CLOAD Table 9. Vdd = 2.5 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Rise/Fall Time Typ (ns) Drive Strength \ CLOAD 5 pF 15 pF 30 pF Drive Strength \ CLOAD 5 pF 15 pF 30 pF T 0.93 n/a n/a R 1.45 n/a n/a E 0.78 n/a n/a U 0.70 1.48 n/a B T 1.09 0.62 n/a 1.28 n/a n/a F or "-": default 0.65 1.30 n/a E 0.54 1.00 n/a U or "-": default 0.43 0.96 n/a F 0.34 0.88 n/a Table 10. Vdd = 3.0 V Rise/Fall Times for Specific CLOAD Table 8. Vdd = 2.8 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Rise/Fall Time Typ (ns) Drive Strength \ CLOAD 5 pF 15 pF 30 pF Drive Strength \ CLOAD 5 pF 15 pF 30 pF R 1.29 n/a n/a R 1.22 n/a n/a B 0.97 n/a n/a 0.89 n/a n/a T E 0.55 1.12 n/a B T or "-": default 0.51 1.00 n/a 0.44 1.00 n/a E 0.38 0.92 n/a U or "-": default 0.34 0.88 n/a U 0.30 0.83 n/a F 0.29 0.81 1.48 F 0.27 0.76 1.39 Table 11. Vdd = 3.3 V Rise/Fall Times for Specific CLOAD Rise/Fall Time Typ (ns) Drive Strength \ CLOAD 5 pF 15 pF 30 pF R 1.16 n/a n/a B T or "-": default 0.81 n/a n/a 0.46 1.00 n/a E 0.33 0.87 n/a U 0.28 0.79 1.46 F 0.25 0.72 1.31 Note: 10. “n/a” in Table 7 to Table 11 indicates that the resulting rise/fall time from the respective combination of the drive str ength and output load does not provide rail-to-rail swing and is not available. Rev 1.03 Page 8 of 18 www.sitime.com SiT8921B High Frequency, -55°C to +125°C Oscillator Pin 1 Configuration Options (OE, ST , or NC) Vdd Pin 1 of the SiT8921 can be factory-programmed to support three modes: Output enable (OE), standby ( ST ̅ ̅ ̅ ) or No Connect (NC). These modes can also be programmed with the Time Machine using field programmable devices. Clock Output Output Enable (OE) Mode In the OE mode, applying logic Low to the OE pin only disables the output driver and puts it in Hi-Z mode. The core of the device continues to operate normally. Power consumption is reduced due to the inactivity of the output. When the OE pin is pulled High, the output is typically enabled in
SIT8921BM-23-33E-125.000000 价格&库存
很抱歉,暂时无法提供与“SIT8921BM-23-33E-125.000000”相匹配的价格&库存,您可以联系我们找货
