SIT1569AI-J3-33E-0000.010000 数据手册
SiT1569
µPower, Ultra-Small 1 Hz – 462.5 kHz ±50 ppm Oscillator
Features
Applications
µPower operating current: 3.3 µA (100 kHz)
Factory-programmable frequency from 1 Hz to 462.5 kHz[1]
±50 ppm max all-inclusive frequency stability
World’s smallest oscillator footprint: 1.2 mm2
1.5 mm x 0.8 mm CSP
0.6 mm max height
No external bypass capacitors required
Wide operating supply voltage range: 1.8 V to 3.3 V
LVCMOS compatible output
Pb-free, RoHS and REACH compliant
Smart stylus
Wearable biometric sensing
Wireless chargers
Portable medical
Note:
1. For higher frequency applications, consider the SiT1576 or the SiT8021.
Electrical Specifications
Table 1. DC Electrical Characteristics[2]
Conditions: Min/Max limits are over temperature, V DD = 1.8 V ±10%, unless otherwise stated. Typicals are at 25°C and VDD = 1.8 V.
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Frequency
Output Frequency Range
FOUT
1.0
462.5 k
Hz
Frequency Stability
Initial Tolerance
Frequency Stability
F_tol
-10
10
ppm
TA = 25°C. Includes 2x reflow.
F_stab
-50
50
ppm
All inclusive of over temperature, referenced to nominal
frequency at 25°C, inclusive of VDD, aging, and load
nsRMS
10,000 cycles, per JEDEC standard 65B,
tested at 100 kHz
Jitter
RMS Period Jitter
t_jitter
4
8.5
Power Supply
Power Supply Voltage
No Load Supply Current
Start-up Time
VDD
1.62
IDD
3.63
FOUT = 1 Hz
3
3.3
4.6
8
10
FOUT = 462.5 kHz
150
300
FOUT > 200 Hz, to first output pulse.
250 +
300 +
2.0 cycles 2.5 Cycles
500 +
2.5 Cycles
t_start
V
1.7
µA
ms
FOUT = 100 kHz
10 Hz < FOUT ≤ 200 Hz, to first output pulse.
1 Hz ≤ FOUT ≤ 10 Hz, to first output pulse.
Operating Temperature Range
Commercial Temperature
-20
Industrial Temperature
-40
70
°C
85
°C
LVCMOS Output
Rise-Fall Time
tR/tF
10
Output Clock Duty Cycle
DC
45
VOH - Output Voltage High
VOH
90%
VOL - Output Voltage Low
VOL
40
70
ns
55
20-80%, 15 pF load, VDD = 1.8 V ±10%
IOH = -50 µA, 15 pF load
10%
IOL = 50 µA, 15 pF load
Note:
2. For applications requiring lower jitter or improved frequency stability, consider the SiT1579, or contact SiTime for other product options.
Rev 1.2
25 March 2021
www.sitime.com
SiT1569 µPower, Ultra-Small 1 Hz – 462.5 kHz ±50 ppm Oscillator
Table 2. Pin Configuration
Pin
Symbol
I/O
1
NC
Internal Test Pin
2
CLK Out
Output
3
VDD
Power Supply
4
GND
Power Supply Ground
CSP Package (Top View)
Functionality
No Connect. Leave floating. Pin 1 is for internal testing and is
designed to be left floating.
NC
1
4
GND
CLK Out
2
3
Vdd
Oscillator clock output, LVCMOS compatible
Connect to power supply between 1.8 V and 3.3 V ±10%.
Under normal operating conditions, Vdd does not require external
bypass/decoupling capacitor(s).
The SiT1569 includes on-chip Vdd filtering.
Connect to GND
Figure 1. Pin Assignments
Table 3. Absolute Maximum Ratings
Attempted operation outside the absolute maximum ratings may cause permanent damage to the part.
Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings.
Parameters
Test Conditions
Value
Continuous Power Supply Voltage Range (VDD)
Continuous Maximum Operating Temperature Range
Unit
-0.5 to 4.0
V
105
°C
≤ 30 minutes
125
°C
Human Body Model (HBM) ESD Protection
JESD22-A114
2000
V
Charge-Device Model (CDM) ESD Protection
JESD22-C101
750
V
Machine Model (MM) ESD Protection
JESD22-A115
200
V
g
Short Duration Maximum Operating Temperature Range
Latch-up Tolerance
JESD78 Compliant
Mechanical Shock Resistance
Mil 883, Method 2002
20,000
Mechanical Vibration Resistance
Mil 883, Method 2007
70
g
150
°C
-65 to 150
°C
1508 CSP Junction Temperature
Storage Temperature
System Block Diagram
VDD
GND
NVM
Driver
NC
CLK Out
Figure 2. SiT1569 Block Diagram
Rev 1.2
Page 2 of 7
www.sitime.com
Detailed Description
Frequency Stability
The SiT1569 is the first ULP, factory-programmable oscillator in
an ultra-small 1.5mm x 0.8mm (1508) chip-scale package (CSP),
and part of a new family of ULP, ultra-small oscillators from
SiTime. This device can be programmed for any frequency
between 1 Hz and 462.5 kHz. The silicon MEMS technology
makes it possible to produce the world's smallest, programmable
reference clock in a chip-scale package.
The SiT1569 oscillator is Factory trimmed to 32.768 kHz at
room temperature. The result is a very accurate oscillator at
room temperature and over temperature. Unlike quartz crystals
that have a classic tuning fork parabola temperature curve
with a 25°C turnover point with a 0.04 to 0.06 ppm/°C2
temperature coefficient (TCF), the SiT1569 temperature
coefficient is calibrated at room temperature and corrected over
temperature with an active temperature correction circuit. The
result is 100 ms. Shorter gate times may lead to
inaccurate measurements.
Page 3 of 7
www.sitime.com
Typical Operating Curves
(TA = 25°C, VDD = 1.8 V, supply current plots are no load, unless otherwise stated)
No Vdd bypass
10 nF Vdd bypass
Figure 3. LVCMOS Output Swing
(VDD = 1.8 V)
Figure 4. Power Supply Noise Rejection (PSNR)
2.5
2.4
2.4
2.3
2.3
2.2
2.2
2.1
VDD = 3.3 V
1.9
2
Current (µA)
Current (µA)
VDD = 3.3 V
2.1
2
1.8
VDD = 1.8 V
1.7
1.6
1.5
1.9
VDD = 1.8 V
1.8
1.7
1.6
1.5
1.4
1.4
1.3
1.3
1.2
1.2
1.1
1.1
1
1
-40
-20
60
80
-40
100
-20
60
80
100
Temperature (°C)
Temperature (°C)
Figure 6. Supply Current vs Temperature
(FOUT = 100 Hz)
Figure 5. Supply Current vs Temperature
(FOUT = 1 Hz)
5
13.5
4.75
12.75
4.5
11.25
10.5
Current (µA)
Current (µA)
4
3.75
3.5
3.25
VDD = 1.8 V
3
9.75
9
8.25
2.75
7.5
2.5
VDD = 1.8 V
6.75
2.25
2
6
-40
-20
60
80
100
-40
Temperature (°C)
-20
60
80
100
Temperature (°C)
Figure 8. Supply Current vs Temperature
(FOUT = 440 kHz)
Figure 7. Supply Current vs Temperature
(FOUT = 100 kHz)
Rev 1.2
VDD = 3.3 V
12
VDD = 3.3 V
4.25
Page 4 of 7
www.sitime.com
Dimensions and Patterns
Package Size – Dimensions (Unit: mm)
Recommended Land Pattern (Unit: mm)
#4
#3
#2
#1
(soldermask openings shown with
dashed line around NSMD pad)
Recommended 4-mil (0.1mm) stencil thickness
4) The SiT1569 CSP includes a protective, opaque
Manufacturing Guidelines
1) No Ultrasonic or Megasonic cleaning: Do not
subject the SiT1569 to an ultrasonic or megasonic
cleaning environment. Permanent damage or long
term reliability issues may occur.
2) Applying board-level underfill and overmold is
acceptable and will not impact the reliability of the
device.
3) Reflow profile, per JESD22-A113D.
Rev 1.2
Page 5 of 7
polymer top-coat. If the SiT1569 will see intense
light, especially in the 1.0-1.2µm IR spectrum, we
recommend a protective “glob-top” epoxy or other
cover to keep the light from negatively impacting the
frequency stability.
5) For additional manufacturing guidelines and
marking/tape-reel instructions, refer to SiTime
Manufacturing Notes.
www.sitime.com
Ordering Information
SiT1569AC -J3-33E-0000.000000Q
Packaging
Part Family
“S”: 8 mm Tape & Reel, 10 ku reel
“Q”: 8 mm Tape & Reel, 5 ku reel
“D”: 8 mm Tape & Reel, 3 ku reel
“E”: 8 mm Tape & Reel, 1 ku reel
Samples in cut Tape
“SiT1569”
Revision Letter
“A” is the revision
Output Frequency
Continuous frequency options
Temperature Range
“C”: Commercial, -20 to 70ºC
“I”: Industrial, -40 to 85ºC
Enter your desired frequency
as shown below:
0462.500000 = 462.5 kHz
0100.000000 = 100.0 kHz
0010.000000 = 10.0 kHz
0001.000000 = 1.0 kHz
0000.100000 = 100.0 Hz
0000.010000 = 10.0 Hz
0000.001000 = 1.0 Hz
0000.001100 = 1.10 Hz
0000.005123 = 5.123 Hz
Package Size
“J”: 1.5 x 0.8 mm CSP
Frequency Stability
“3”: ±50 ppm
Supply Voltage (Vdd):
18E: 1.8 V ±10%
25E: 2.5 V ±10%
30E: 3.0 V ±10%
33E: 3.3 V ±10%
For applications that require
operation over wide range,
enter the option that corresponds
to the highest supply voltage.
Rev 1.2
Page 6 of 7
www.sitime.com
Table 4. Revision History
Version
Release Date
Change Summary
0.25
13-Jan-2016
Initial Preliminary
0.5
28-Apr-2016
Updated max operating frequency
Updated part number ordering
0.7
8-Jul-2016
0.9
28-Apr-2017
Updated min/max frequency stability, added RMS period jitter
Update part numbering code
Update min/max frequency stability
Updated CSP package outline drawing (POD)
Updated Supply Current max limits
Updated logo and company address, other page layout changes
1.0
10-May-2017
Final Release
1.1
17-May-2018
Added additional typical operating curves
Updated typical No Load Supply Current (Table 1)
Corrected frequency range from ‘1 HZ – 460 KHz’ to ‘1 HZ – 462.5 KHz’
1.2
25-Mar-2021
Added Option “D” for 3ku reels to the Ordering Information
Updated hyperlinks, trademarks, date format and layout formatting
SiTime Corporation, 5451 Patrick Henry Drive, Santa Clara, CA 95054, USA | Phone: +1-408-328-4400 | Fax: +1-408-328-4439
© SiTime Corporation 2018-2021. The information contained herein is subject to change at any time without notice. SiTime assumes no responsibility or liability for any loss, damage
or defect of a Product which is caused in whole or in part by (i) use of any circuitry other than circuitry embodied in a SiTime product, (ii) misuse or abuse including static discharge, neglect
or accident, (iii) unauthorized modification or repairs which have been soldered or altered during assembly and are not capable of being tested by SiTime under its normal test conditions, or
(iv) improper installation, storage, handling, warehousing or transportation, or (v) being subjected to unusual physical, thermal, or electrical stress.
Disclaimer: SiTime makes no warranty of any kind, express or implied, with regard to this material, and specifically disclaims any and all express or implied warranties, either in fact or by
operation of law, statutory or otherwise, including the implied warranties of merchantability and fitness for use or a particular purpose, and any implied warranty arising from course of dealing or
usage of trade, as well as any common-law duties relating to accuracy or lack of negligence, with respect to this material, any SiTime product and any product documentation. Products sold by
SiTime are not suitable or intended to be used in a life support application or component, to operate nuclear facilities, or in other mission critical applications where human life may be involved
or at stake. All sales are made conditioned upon compliance with the critical uses policy set forth below.
CRITICAL USE EXCLUSION POLICY
BUYER AGREES NOT TO USE SITIME'S PRODUCTS FOR ANY APPLICATION OR IN ANY COMPONENTS USED IN LIFE SUPPORT DEVICES OR TO OPERATE NUCLEAR
FACILITIES OR FOR USE IN OTHER MISSION-CRITICAL APPLICATIONS OR COMPONENTS WHERE HUMAN LIFE OR PROPERTY MAY BE AT STAKE.
SiTime owns all rights, title and interest to the intellectual property related to SiTime's products, including any software, firmware, copyright, patent, or trademark. The sale of SiTime products does
not convey or imply any license under patent or other rights. SiTime retains the copyright and trademark rights in all documents, catalogs and plans supplied pursuant to or ancillary to the sale
of products or services by SiTime. Unless otherwise agreed to in writing by SiTime, any reproduction, modification, translation, compilation, or representation of this material shall be strictly
prohibited.
Rev 1.2
Page 7 of 7
www.sitime.com
