QTM750-100.000MBE-T
QTM750-100.000MBE-T
    QST(矽睿)
    SIP4
    XTAL OSC XO 100.0000MHZ CMOS SMD
QTM750-100.000MBE-T 数据手册
QTM750 MHz CMOS Oscillator Fuel The Digital World Features ● ● ● ● ● ● ● Applications Frequency range : 1MHz to 170MHz SMD seam sealing ceramic package Supply voltage : 1.8V, 2.5V, 3.3V, 5V CMOS output Tri-state function available External dimensions (mm) L : 7.0 x W : 5.0 x H : 1.3 RoHS compliant & Pb free ● ● ● ● ● Networking, Server, Storage Wireless communications Fibre channel, Ethernet, SATA, SAS, PCI-E, USB, WLAN, xDSL, xPON PC mainboard, Notebook, HDD, SSD, Graphics card, Computer peripherals Audio, Video, Gaming, Printer, DSC, IP CAM, Consumer products Electrical Characteristics Item Frequency Range (F0) QTM750 Conditions 1MHz ~ 170MHz ±50ppm, ±25ppm -10°C ~ +70°C; Note [1] ±50ppm, ±30ppm, ±25ppm -40°C ~ +85°C; Note [1] Frequency Stability (Fstab) Operating Temperature Range (T OTR) Supply Voltage (VDD) -10°C ~ +70°C -40°C ~ +85°C 1.8V, 2.5V, 3.3V, 5.0V VDD ± 10% 10 mA Max. 1MHz ~ 75MHz 20 mA Max. 75MHz ~ 170MHz Current Consumption (IDD) Output Type CMOS Output Load (CL) 15 pF Output Voltage High (VOH) Output Voltage Low (VOL) Rise & Fall Time (Tr / Tf) Duty Cycle Start-up Time 90% VDD Min. 10% VDD Max. 8 ns Max. 40% ~ 60% 5 ms Max. Enable Voltage High, Logic "1" 70% VDD Min. Enable Voltage Low, Logic "0" 30% VDD Max. Phase Jitter, RMS Aging (Faging) Storage Temperature Range (T STR) 10% ~ 90% of VDD 1 ps Max. ±3 ppm Max. Input to Pin1 Note [2] Note [3] at 25°C±3°C,first year -55°C ~ +125°C Notes: [1] Inclusive of frequency tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, supply voltage, and load. [2] Output will be enabled if Pin1 is Logic "1" or open; Output will be disabled if Pin1 is Logic "0". [3] Freq. 10MHz~40MHz, integrated 12kHz~5MHz; Freq. >40MHz, integrated 12kHz~20MHz. Rev. 1.04 Page 1 www.qstproducts.com QTM750 MHz CMOS Oscillator Fuel The Digital World Dimensions (Unit: mm) Ordering Information QTM750 - 30.000M B E - T Frequency in Hz Packaging Method T Please contact us for available frequencies Frequency Stability Supply Voltage A B C D Rev. 1.04 Tape & Reel A B D E G 5.0 V 3.3 V 2.5 V 1.8 V Page 2 ± 25 ppm ± 50 ppm ± 25 ppm ± 50 ppm ± 30 ppm ( -10°C ~ +70°C ) ( -10°C ~ +70°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) ( -40°C ~ +85°C ) www.qstproducts.com QTM750 MHz CMOS Oscillator Fuel The Digital World Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.04 60 sec Page 3 Time (sec) www.qstproducts.com
QTM750-100.000MBE-T 价格&库存
很抱歉,暂时无法提供与“QTM750-100.000MBE-T”相匹配的价格&库存,您可以联系我们找货
QTM750-100.000MBE-T
  • 1+15.098881+1.95241
  • 10+13.1394410+1.69904
  • 25+12.4259325+1.60678
  • 50+11.9103950+1.54011
  • 100+11.41855100+1.47652
  • 250+10.79815250+1.39629
  • 500+10.35185500+1.33858
库存:1050
QTM750-100.000MBE-T
  • 1000+9.924111000+1.28327
  • 2000+9.514392000+1.23029
  • 3000+9.282793000+1.20034
  • 5000+8.999065000+1.16366
  • 7000+8.817087000+1.14012
  • 10000+8.6283110000+1.11571
库存:1050
