SIT8920BME11-XXE-64.000000 数据手册
SiT8920B
-55°C to +125°C Oscillator
Features
Applications
Frequencies between 1 MHz and 110 MHz accurate
to 6 decimal places
Operating temperature from -55°C to 125°C
Supply voltage of 1.8 V or 2.5 V to 3.3 V
Excellent total frequency stability as low as ±20 ppm
Low power consumption of 3.5 mA typical at 1.8 V
LVCMOS/LVTTL compatible output
Industry-standard packages: 2.0 x 1.6, 2.5 x 2.0,
3.2 x 2.5, 5.0 x 3.2, 7.0 x 5.0 mm x mm
Instant samples with Time Machine II and field
programmable oscillators
RoHS and REACH compliant, Pb-free, Halogen-free
and Antimony-free
Ruggedized equipment in harsh operating environment
Related products for automotive applications.
For aerospace and defense applications SiTime recommends
using only Endura™ SiT8944.
Table 1. Electrical Characteristics
All Min and Max limits are specified over temperature and rated operating voltage with 15 pF output load unless otherwise stated.
Typical values are at 25°C and nominal supply voltage.
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Frequency Range
Output Frequency Range
f
1
110
MHz
F_stab
-20
+20
ppm
-25
+25
ppm
-30
+30
ppm
-50
+50
ppm
Refer to Table 13 for the exact list of supported frequencies list
Frequency Stability and Aging
Frequency Stability
Inclusive of Initial tolerance at 25°C, 1st year aging at 25°C,
and variations over operating temperature, rated power
supply voltage and load (15 pF ±10%).
Operating Temperature Range
T_use
-55
+125
°C
Supply Voltage and Current Consumption
Supply Voltage
Current Consumption
OE Disable Current
Standby Current
Vdd
Idd
I_od
I_std
1.62
1.8
1.98
V
2.25
2.5
2.75
V
2.52
2.8
3.08
V
2.7
3.0
3.3
V
2.97
3.3
3.63
V
2.25
3.63
V
3.8
4.7
mA
No load condition, f = 20 MHz, Vdd = 2.8 V, 3.0 V or 3.3 V
3.6
4.5
mA
No load condition, f = 20 MHz, Vdd = 2.5 V
3.5
4.5
mA
No load condition, f = 20 MHz, Vdd = 1.8 V
4.5
mA
Vdd = 2.5 V to 3.3 V, OE = Low, Output in high Z state.
4.3
mA
Vdd = 1.8 V, OE = Low, Output in high Z state.
2.6
8.5
A
Vdd = 2.8 V to 3.3 V, ST = Low, Output is weakly pulled down
1.4
5.5
A
Vdd = 2.5 V, ST = Low, Output is weakly pulled down
0.6
4.0
A
Vdd = 1.8 V, ST = Low, Output is weakly pulled down
LVCMOS Output Characteristics
Duty Cycle
Rise/Fall Time
Output High Voltage
Output Low Voltage
Rev 1.03
DC
45
55
All Vdds
Tr, Tf
1.0
2.0
ns
Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V, 20% - 80%
1.3
2.5
ns
Vdd = 1.8 V, 20% - 80%
1.0
3
ns
Vdd = 2.25 V - 3.63 V, 20% - 80%
90%
Vdd
IOH = -4 mA (Vdd = 3.0 V or 3.3 V)
IOH = -3 mA (Vdd = 2.8 V or 2.5 V)
IOH = -2 mA (Vdd = 1.8 V)
10%
Vdd
IOL = 4 mA (Vdd = 3.0 V or 3.3 V)
IOL = 3 mA (Vdd = 2.8 V or 2.5 V)
IOL = 2 mA (Vdd = 1.8 V)
VOH
VOL
1 January 2023
www.sitime.com
SiT8920B -55°C to +125°C Oscillator
Table 1. Electrical Characteristics (continued)
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Input Characteristics
Input High Voltage
VIH
70%
Vdd
Pin 1, OE or ST
Input Low Voltage
VIL
30%
Vdd
Pin 1, OE or ST
Input Pull-up Impedance
Z_in
50
87
150
k
Pin 1, OE logic high or logic low, or ST logic high
M
Pin 1, ST logic low
2
Startup and Resume Timing
T_start
5
ms
Measured from the time Vdd reaches its rated minimum value
T_oe
130
ns
f = 110 MHz. For other frequencies, T_oe = 100 ns + 3 * clock
periods
T_resume
5
ms
Measured from the time ST pin crosses 50% threshold
T_jitt
1.6
2.5
ps
f = 75 MHz, Vdd = 2.5 V, 2.8 V, 3.0 V or 3.3 V
1.9
3
ps
f = 75 MHz, Vdd = 1.8 V
12
ps
14
25
ps
0.5
0.8
ps
f = 75 MHz, Integration bandwidth = 900 kHz to 7.5 MHz
1.3
2
ps
f = 75 MHz, Integration bandwidth = 12 kHz to 20 MHz
Startup Time
Enable/Disable Time
Resume Time
Jitter
RMS Period Jitter
Peak-to-peak Period Jitter
T_pk
RMS Phase Jitter (random)
T_phj
Table 2. Pin Description
Pin
Symbol
Output Enable
1
OE/ST/NC
Top View
Functionality
Standby
No Connect
H[1]: specified frequency output
L: output is high impedance. Only output driver is disabled.
L: output is low (weak pull down). Device goes to sleep mode.
Supply current reduces to I_std.
Any voltage between 0 and Vdd or Open[1]: Specified
frequency output. Pin 1 has no function.
2
GND
Power
Electrical ground
3
OUT
Output
Oscillator output
4
VDD
Power
Power supply voltage[2]
OE/ST/NC
1
4
VDD
GND
2
3
OUT
Figure 1. Pin Assignments
Notes:
1. In OE or ST mode, a pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven. If pin 1 needs to be left floating, use the
NC option.
2. A capacitor of value 0.1 µF or higher between Vdd and GND is required.
Rev 1.03
Page 2 of 18
www.sitime.com
Table 3. Absolute Maximum Limits
Attempted operation outside the absolute maximum ratings of the part may cause permanent damage to the part.
Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings.
Min.
Max.
Unit
Storage Temperature
Parameter
-65
150
°C
VDD
-0.5
4
V
Electrostatic Discharge
2000
V
Soldering Temperature (follow standard Pb free soldering guidelines)
260
°C
Junction Temperature[3]
150
°C
Note:
3. Exceeding this temperature for extended period of time may damage the device.
Table 4. Thermal Consideration[4]
JA, 4 Layer Board (°C/W)
Package
JA, 2 Layer Board (°C/W)
JC, Bottom (°C/W)
7050
142
273
30
5032
97
199
24
3225
109
212
27
2520
117
222
26
2016
152
252
36
Note:
4. Refer to JESD51-7 for JA and JC definitions, and reference layout used to determine the JA and JC values in the above table.
Table 5. Maximum Operating Junction Temperature[5]
Max Operating Temperature (ambient)
125°C
135°C
Note:
5. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature.
Table 6. Environmental Compliance
Parameter
Condition/Test Method
Mechanical Shock
MIL-STD-883F, Method 2002
Mechanical Vibration
MIL-STD-883F, Method 2007
Temperature Cycle
JESD22, Method A104
Solderability
MIL-STD-883F, Method 2003
Moisture Sensitivity Level
MSL1 @ 260°C
Rev 1.03
Page 3 of 18
www.sitime.com
Test Circuit and Waveform
Vdd
Vout
4
3
Test
Point
tr
Power
Supply
tf
80% Vdd
0.1µF
1
15pF
(including probe
and fixture
capacitance)
2
50%
20% Vdd
High Pulse
(TH)
Low Pulse
(TL)
Period
Vdd
1k
OE/NC Function
Figure 3. Waveform[6]
Figure 2. Test Circuit[6]
Notes:
6. Duty Cycle is computed as Duty Cycle = TH/Period.
Timing Diagram
90% Vdd
Vdd
Vdd
50% Vdd
[7]
T_start
Pin 4 Voltage
No Glitch
during start up
T_resume
ST Voltage
CLK Output
CLK Output
HZ
HZ
T_start: Time to start from power-off
Figure 4. Startup Timing (OE/ ST Mode)
T_resume: Time to resume from ST
Figure 5. Standby Resume Timing ( ST Mode Only)
Vdd
Vdd
50% Vdd
OE Voltage
50% Vdd
T_oe
OE Voltage
T_oe
CLK Output
CLK Output
HZ
HZ
T_oe: Time to re-enable the clock output
T_oe: Time to put the output in High Z mode
Figure 6. OE Enable Timing (OE Mode Only)
Figure 7. OE Disable Timing (OE Mode Only)
Note:
7. SiT8920 has “no runt” pulses and “no glitch” output during startup or resume.
Rev 1.03
Page 4 of 18
www.sitime.com
Performance Plots[8]
1.8 V
2.5 V
2.8 V
3V
3.3 V
6.0
5.5
Frequency (ppm)
Idd (mA)
5.0
4.5
4.0
3.5
3.0
60
80
100
Frequency (MHz)
Figure 9. Frequency vs Temperature
Duty cycle (%)
RMS period jitter (ps)
Figure 8. Idd vs Frequency
Figure 10. RMS Period Jitter vs Frequency
Figure 11. Duty Cycle vs Frequency
1.8 V
2.5 V
2.8 V
3.0 V
3.3 V
2.5
Fall time (ns)
Rise time (ns)
2.0
1.5
1.0
0.5
0.0
-40
Figure 12. 20%-80% Rise Time vs Temperature
Rev 1.03
-20
60
80
100
120
Figure 13. 20%-80% Fall Time vs Temperature
Page 5 of 18
www.sitime.com
IPJ (ps)
IPJ (ps)
Figure 14. RMS Integrated Phase Jitter Random
(12k to 20 MHz) vs Frequency[9]
Figure 15. RMS Integrated Phase Jitter Random
(900 kHz to 20 MHz) vs Frequency[9]
Notes:
8. All plots are measured with 15 pF load at room temperature, unless otherwise stated.
9. Phase noise plots are measured with Agilent E5052B signal source analyzer. Integration range is 12 kHz to 5 MHz for carrier f requencies up
to 40 MHz.
Rev 1.03
Page 6 of 18
www.sitime.com
Programmable Drive Strength
The SiT8920 includes a programmable drive strength feature
to provide a simple, flexible tool to optimize the clock rise/fall
time for specific applications. Benefits from the programmable
drive strength feature are:
Improves system radiated electromagnetic
interference (EMI) by slowing down the clock
rise/fall time
Improves the downstream clock receiver’s (RX)
jitter by decreasing (speeding up) the clock rise/fall
time.
Ability to drive large capacitive loads while
maintaining
full swing with sharp edge rates.
For more detailed information about rise/fall time control and
drive strength selection, see the SiTime Application Notes
section.
EMI Reduction by Slowing Rise/Fall Time
Figure 16 shows the harmonic power reduction as the rise/fall
times are increased (slowed down). The rise/fall times are
expressed as a ratio of the clock period. For the ratio of 0.05,
the signal is very close to a square wave. For the ratio of 0.45,
the rise/fall times are very close to near-triangular waveform.
These results, for example, show that the 11th clock harmonic
can be reduced by 35 dB if the rise/fall edge is increased from
5% of the period to 45% of the period.
trise=0.05
trise=0.1
trise=0.15
trise=0.2
trise=0.25
trise=0.3
trise=0.35
trise=0.4
trise=0.45
10
Harmonic amplitude (dB)
-20
2.6 ns when the output load increases to 45 pF. One can
choose to speed up the rise/fall time to 1.83 ns by then
increasing the drive strength setting on the SiT8920.
The SiT8920 can support up to 60 pF or higher in maximum
capacitive loads with drive strength settings. Refer to the
Rise/Tall Time Tables (Tables 7 to 11) to determine the
proper drive strength for the desired combination of output
load vs. rise/fall time.
SiT8920 Drive Strength Selection
Tables 7 through 11 define the rise/fall time for a given
capacitive load and supply voltage.
1. Select the table that matches the SiT8920 nominal
supply voltage (1.8 V, 2.5 V, 2.8 V, 3.0 V, 3.3 V).
2. Select the capacitive load column that matches the
application requirement (5 pF to 60 pF)
3. Under the capacitive load column, select the desired
rise/fall times.
4. The left-most column represents the part number
code for the corresponding drive strength.
5. Add the drive strength code to the part number for
ordering purposes.
Calculating Maximum Frequency
Based on the rise and fall time data given in Tables 7
through 11, the maximum frequency the oscillator can
operate with guaranteed full swing of the output voltage over
temperature as follows:
Max Frequency =
1
5 x T rf_20/80
where Trf_20/80 is the typical value for 20%-80% rise/fall
time.
-30
-40
Example 1
-50
Calculate fMAX for the following condition:
Vdd = 1.8 V (Table 7)
Capacitive Load: 30 pF
Desired Tr/f time = 3 ns (rise/fall time part
number
code = E)
Part number for the above example:
SiT8920BME12-18E-66.666660
-60
-70
-80
1
3
5
7
9
11
Harmonic number
Figure 16. Harmonic EMI reduction as a Function
of Slower Rise/Fall Time
Jitter Reduction with Faster Rise/Fall Time
Power supply noise can be a source of jitter for the
downstream chipset. One way to reduce this jitter is to speed
up the rise/fall time of the input clock. Some chipsets may
also require faster rise/fall time in order to reduce their
sensitivity to this type of jitter. Refer to the Rise/Fall Time
Tables (Table 7 to 11) to determine the proper drive
strength.
Drive strength code is inserted here. Default setting is “-”
High Output Load Capability
The rise/fall time of the input clock varies as a function of the
actual capacitive load the clock drives. At any given drive
strength, the rise/fall time becomes slower as the output load
increases. As an example, for a 3.3 V SiT8920 device with
default drive strength setting, the typical rise/fall time is 1ns for
15 pF output load. The typical rise/fall time slows down to
Rev 1.03
Page 7 of 18
www.sitime.com
Rise/Fall Time (20% to 80%) vs CLOAD Tables
Table 7. Vdd = 1.8 V Rise/Fall Times
for Specific CLOAD
Table 9. Vdd = 2.5 V Rise/Fall Times
for Specific CLOAD
Rise/Fall Time Typ (ns)
Drive Strength \ CLOAD
5 pF
15 pF
30 pF
45 pF
60 pF
5 pF
15 pF
30 pF
45 pF
60 pF
L
6.16
11.61
22.00
31.27
39.91
L
4.13
8.25
12.82
21.45
27.79
A
3.19
6.35
11.00
16.01
21.52
A
2.11
4.27
7.64
11.20
14.49
R
2.11
4.31
7.65
10.77
14.47
R
1.45
2.81
5.16
7.65
9.88
B
1.65
3.23
5.79
8.18
11.08
B
1.09
2.20
3.88
5.86
7.57
T
0.93
1.91
3.32
4.66
6.48
T
0.62
1.28
2.27
3.51
4.45
E
0.78
1.66
2.94
4.09
5.74
U
0.70
1.48
2.64
3.68
5.09
0.54
0.43
1.00
0.96
2.01
1.81
3.10
2.79
4.01
3.65
F or "‐": default
0.65
1.30
2.40
3.35
4.56
E or "‐": default
U
F
0.34
0.88
1.64
2.54
3.32
Table 8. Vdd = 2.8 V Rise/Fall Times
for Specific CLOAD
Table 10. Vdd = 3.0 V Rise/Fall Times
for Specific CLOAD
5 pF
15 pF
30 pF
45 pF
60 pF
5 pF
15 pF
30 pF
45 pF
60 pF
L
3.77
7.54
12.28
19.57
25.27
L
3.60
7.21
11.97
18.74
24.30
A
1.94
3.90
7.03
10.24
13.34
A
1.84
3.71
6.72
9.86
12.68
R
1.29
2.57
4.72
7.01
9.06
R
1.22
2.46
4.54
6.76
8.62
B
0.97
2.00
3.54
5.43
6.93
B
0.89
1.92
3.39
5.20
6.64
T
0.55
1.12
2.08
3.22
4.08
T or "‐": default
E or "‐": default
U
F
0.44
0.34
1.00
0.88
1.83
1.64
2.82
2.52
3.67
3.30
E
0.51
0.38
1.00
0.92
1.97
1.72
3.07
2.71
3.90
3.51
0.30
0.83
1.55
2.40
3.13
0.29
0.81
1.48
2.29
2.99
0.27
0.76
1.39
2.16
2.85
U
F
Table 11. Vdd = 3.3 V Rise/Fall Times
for Specific CLOAD
5 pF
15 pF
30 pF
45 pF
60 pF
L
3.39
6.88
11.63
17.56
23.59
A
1.74
3.50
6.38
8.98
12.19
R
1.16
2.33
4.29
6.04
8.34
B
0.81
1.82
3.22
4.52
6.33
T or "‐": default
E
0.46
0.33
1.00
0.87
1.86
1.64
2.60
2.30
3.84
3.35
U
F
0.28
0.79
1.46
2.05
2.93
0.25
0.72
1.31
1.83
2.61
Rev 1.03
Page 8 of 18
www.sitime.com
Pin 1 Configuration Options
(OE, ST
̅ ̅ ̅ , or NC)
Pin 1 of the SiT8920 can be factory-programmed to support
three modes: Output enable (OE), standby (ST
̅ ̅ ̅ ) or No
Connect (NC). These modes can also be programmed with
the Time Machine using field programmable devices.
Output Enable (OE) Mode
In the OE mode, applying logic Low to the OE pin only
disables the output driver and puts it in Hi-Z mode. The core
of the device continues to operate normally. Power
consumption is reduced due to the inactivity of the output.
When the OE pin is pulled High, the output is typically
enabled in
