Transient Voltage Suppressors for ESD Protection
SE03N2C01HL
Features
Working voltage : 3.3V
Low capacitance: 0.4pF (Typical)
Low leakage current: 1.0μA @ VRWM
Low clamping voltage
Response Time is < 1 ns
DFN0603
Applications
Functional Diagram
Cell Phone Handsets and Accessories
Portable Instrumentation
Notebooks, Desktops, and Servers
Digital CamerasMDDI Ports
Mechanical Characteristics
DFN0603-2L Package
Molding Compound Flammability Rating : UL 94V-0
Quantity Per Reel : 10,000pcs
Reel Size : 7 inch
Absolute Maximum Rating
Symbol
Parameter
Value
Units
TLST
Lead Soldering Temperature
260 (10 sec.)
TSTG
Storage Temperature Range
-55 to +150
TOPT
Operating Temperature Range
-55 to +125
VESD
Revision January 14, 2019
ESD per IEC 61000-4-2(Air)
±20
ESD per IEC 61000-4-2 (Contact)
±15
1/4
KV
SE03N2C01HL
I-V Curve Characteristics
Symbol
Parameter
IPP
Maximum Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
Working Peak Reverse Voltage
IR
Maximum Reverse Leakage Current @ VRWM
Vt1
Trigger Voltage
It1
Trigger Current @ Vt1
Vh
Holding Voltage
Ih
Holding Current @ Vh
Electrical Characteristics (@ TA=25℃ Unless Otherwise Specified )
Symbol
Test Condition
Minimum
Typical
Maximum
Units
VRWM
3.3
V
IR
VRWM=3.3V, T=25℃
1.0
μA
VBR
IT = 1mA
4.1
7.0
V
VC
IPP=1A, tp=8/20μs
12
V
VC
IPP=4A, tp=8/20μs
27
V
CJ
VR=0V, f=1MHz
0.4
pF
Characteristic Curves
Fig1. 8/20μs Pulse Waveform
Fig2. ESD Pulse Waveform (according to IEC61000-4-2)
tr
100
Peak Value IPP
80
100%
TEST
WAVEFORM
PARAMETERS
tr=8μs
td=20μs
Percent of Peak Pulse Current %
IPP - Peak Pulse Current - % of IPP
120
60
40
td=t IPP/2
10
15
30
10%
tr = 0.7~1ns
30ns
60ns
t - Time (μs)
90%
2/4
Time (ns)
SE03N2C01HL
Characteristic Curves (Continue)
Fig3. Clamped +8 kV ESD Voltage Waveform
Fig4. Clamped -8 kV ESD Voltage Waveform
DFN0603-2LPackage Outline & Dimensions
Plastic surface mounted package;
Unit
mm
2 leads DFN0603
A
A1
b
D
E
Min.
0.27
0.000
0.21
0.57
0.28
Max.
0.33
0.025
0.29
0.65
0.35
3/4
e
0.355
L
0.14
0.22
SE03N2C01HL
Recommended Soldering Footprint (Unit: mm)
Tape and Reel Specification (Unit: mm)
A0
0.37 +/- 0.03
B0
0.67 +/- 0.03
4/4
K0
0.32 +/- 0.02
很抱歉,暂时无法提供与“SE03N2C01HL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.15181
- 100+0.13801
- 500+0.12881
- 1000+0.11961
- 5000+0.10857
- 10000+0.10397
