SQ2361EES-T1-GE3-VB
SQ2361EES-T1-GE3-VB
    VBSEMI(微碧)
    SOT-23
    MOSFETs P-沟道 60V 5.2A SOT-23
SQ2361EES-T1-GE3-VB 数据手册
SQ2361EES-T1-GE3-VB www.VBsemi.com SQ2361EES-T1-GE3-VB Datasheet P-Channel 60-V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS (V) • Isolated Package • High Voltage Isolation = 2.5 kVRMS (t = 60 s; f = 60 Hz) • Sink to Lead Creepage Distance = 4.8 mm • P-Channel • 175 °C Operating Temperature • Dynamic dV/dt Rating • Low Thermal Resistance • Lead (Pb)-free Available - 60 RDS(on) (Ω) 0.05 VGS = - 10 V Qg (Max.) (nC) 12 Qgs (nC) 3.8 Qgd (nC) 5.1 Configuration Single Available RoHS* COMPLIANT S TO-236 (SOT-23) G G 1 3 S D 2 D P-Channel MOSFET Top View ABSOLUTE MAXIMUM RATINGS TC = 25 °C, unless otherwise noted PARAMETER Drain-Source Voltage Gate-Source Voltage Continuous Drain Current Pulsed Drain Currenta Linear Derating Factor Single Pulse Avalanche Energyb Repetitive Avalanche Currenta Repetitive Avalanche Energya Maximum Power Dissipation Peak Diode Recovery dV/dtc Operating Junction and Storage Temperature Range Soldering Recommendations (Peak Temperature) Mounting Torque VGS at - 10 V TC = 25 °C TC = 100 °C SYMBOL LIMIT VDS VGS - 60 ± 20 - 5.2 - 3.8 - 21 0.18 120 - 5.2 2.7 27 - 4.5 - 55 to + 175 300d 10 1.1 ID IDM TC = 25 °C for 10 s 6-32 or M3 screw EAS IAR EAR PD dV/dt TJ, Tstg UNIT V A W/°C mJ A mJ W V/ns °C lbf · in N·m Notes a. b. c. d. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). VDD = - 25 V, starting TJ = 25 °C, L = 5.0 mH, RG = 25 Ω, IAS = - 5.3 A (see fig. 12). ISD ≤ - 6.7 A, dI/dt ≤ 90 A/µs, VDD ≤ VDS, TJ ≤ 175 °C. 1.6 mm from case. 服务热线:400-655-8788 1 SQ2361EES-T1-GE3-VB www.VBsemi.com THERMAL RESISTANCE RATINGS SYMBOL TYP. MAX. Maximum Junction-to-Ambient RthJA - 65 Maximum Junction-to-Case (Drain) RthJC - 5.5 PARAMETER UNIT °C/W SPECIFICATIONS TJ = 25 °C, unless otherwise noted PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Static Drain-Source Breakdown Voltage VDS Temperature Coefficient Gate-Source Threshold Voltage VDS VGS = 0 V, ID = - 250 µA - 60 - - V ΔVDS/TJ Reference to 25 °C, ID = - 1 mA - - 0.060 - V/°C VGS(th) VDS = VGS, ID = - 250 µA - 1.0 - - 2.5 V Gate-Source Leakage IGSS VGS = ± 20 V - - ± 100 nA Zero Gate Voltage Drain Current IDSS Drain-Source On-State Resistance Forward Transconductance RDS(on) gfs VDS = - 60 V, VGS = 0 V - - - 100 VDS = - 48 VGS = 0 V, TJ = 150 °C - - - 500 - 0.05 - Ω 1.6 - - S - 270 - - 170 - - 31 - - 12 - ID = - 3.2 Ab VGS = - 10 V VDS = - 25 V, ID = - 3.2 Ab µA Dynamic Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss Drain to Sink Capacitance VGS = 0 V, VDS = - 25 V, f = 1.0 MHz, see fig. 5 C Total Gate Charge Qg Gate-Source Charge Qgs f = 1.0 MHz VGS = - 10 V ID = - 4.7 A, VDS = - 48 V, see fig. 6 and 13b - - 12 - - 3.8 Gate-Drain Charge Qgd - - 5.1 Turn-On Delay Time td(on) - 11 - - 63 - - 9.6 - - 31 - - 4.5 - - 7.5 - - - - 5.2 - - - 21 - - - 5 .5 Rise Time Turn-Off Delay Time Fall Time tr td(off) VDD = - 30 V, ID = - 4.7 A, RG = 24 Ω, RD= 4.0 Ω, see fig. 10b tf Internal Drain Inductance LD Internal Source Inductance LS Between lead, 6 mm (0.25") from package and center of die contact D pF nC ns nH G S Drain-Source Body Diode Characteristics Continuous Source-Drain Diode Current IS Pulsed Diode Forward Currenta ISM Body Diode Voltage VSD Body Diode Reverse Recovery Time trr Body Diode Reverse Recovery Charge Qrr Forward Turn-On Time ton MOSFET symbol showing the integral reverse p - n junction diode D A G S TJ = 25 °C, IS = - 5.2 A, VGS = 0 Vb TJ = 25 °C, IF = - 4.7 A, dI/dt = 100 A/µsb V - 80 160 ns - 0.096 0.19 µC Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD) Notes a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11). b. Pulse width ≤ 300 µs; duty cycle ≤ 2 %. 服务热线:400-655-8788 2 SQ2361EES-T1-GE3-VB www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted Fig. 1 - Typical Output Characteristics, TC= 25 °C Fig. 3 - Typical Transfer Characteristics Fig. 2 - Typical Output Characteristics, TC= 175 °C Fig. 4 - Normalized On-Resistance vs. Temperature 服务热线:400-655-8788 3 SQ2361EES-T1-GE3-VB www.VBsemi.com Fig. 5 - Typical Capacitance vs. Drain-to-Source Voltage Fig. 6 - Typical Gate Charge vs. Gate-to-Source Voltage Fig. 7 - Typical Source-Drain Diode Forward Voltage Fig. 8 - Maximum Safe Operating Area 服务热线:400-655-8788 4 SQ2361EES-T1-GE3-VB www.VBsemi.com RD VDS VGS D.U.T. RG +VDD - 10 V Pulse width ≤ 1 µs Duty factor ≤ 0.1 % Fig. 10a - Switching Time Test Circuit td(on) td(off) tf tr VGS 10 % 90 % VDS Fig. 9 - Maximum Drain Current vs. Case Temperature Fig. 10b - Switching Time Waveforms Fig. 11 - Maximum Effective Transient Thermal Impedance, Junction-to-Case L Vary tp to obtain required IAS IAS VDS D.U.T. RG VDS + V DD VDD IAS tp - 10 V tp 0.01 Ω VDS Fig. 12a - Unclamped Inductive Test Circuit Fig. 12b - Unclamped Inductive Waveforms 服务热线:400-655-8788 5 SQ2361EES-T1-GE3-VB www.VBsemi.com Fig. 12c - Maximum Avalanche Energy vs. Drain Current Current regulator Same type as D.U.T. 50 kΩ QG - 10 V 12 V 0.2 µF 0.3 µF QGS - QGD D.U.T. VG + VDS VGS - 3 mA Charge IG ID Current sampling resistors Fig. 13a - Basic Gate Charge Waveform Fig. 13b - Gate Charge Test Circuit 服务热线:400-655-8788 6 SQ2361EES-T1-GE3-VB www.VBsemi.com Peak Diode Recovery dV/dt Test Circuit D.U.T. + Circuit layout considerations • Low stray inductance • Ground plane • Low leakage inductance current transformer + - - RG + • dV/dt controlled by RG • ISD controlled by duty factor "D" • D.U.T. - device under test + - VDD Compliment N-Channel of D.U.T. for driver Driver gate drive P.W. Period D= P.W. Period VGS = - 10 V* D.U.T. ISD waveform Reverse recovery current Body diode forward current dI/dt D.U.T. VDS waveform Diode recovery dV/dt Re-applied voltage VDD Body diode forward drop Inductor current Ripple ≤ 5 % * ISD VGS = - 5 V for logic level and - 3 V drive devices Fig. 14 - For P-Channel 服务热线:400-655-8788 7 SQ2361EES-T1-GE3-VB www.VBsemi.com SOT-23 (TO-236): 3-LEAD b 3 E1 1 E 2 e S e1 D 0.10 mm C 0.004" A2 A C 0.25 mm q Gauge Plane Seating Plane Seating Plane C A1 Dim L L1 MILLIMETERS INCHES Min Max Min Max A 0.89 1.12 0.035 0.044 A1 0.01 0.10 0.0004 0.004 A2 0.88 1.02 0.0346 0.040 b 0.35 0.50 0.014 0.020 c 0.085 0.18 0.003 0.007 D 2.80 3.04 0.110 0.120 E 2.10 2.64 0.083 0.104 E1 1.20 1.40 0.047 e 0.95 BSC e1 L 1.90 BSC 0.40 L1 q 0.0748 Ref 0.60 0.016 0.64 Ref S 0.024 0.025 Ref 0.50 Ref 3° 0.055 0.0374 Ref 0.020 Ref 8° 3° 8° ECN: S-03946-Rev. K, 09-Jul-01 DWG: 5479 8 服务热线:400-655-8788 SQ2361EES-T1-GE3-VB www.VBsemi.com 0.049 (1.245) 0.029 0.022 (0.559) (0.724) 0.037 (0.950) (2.692) 0.106 RECOMMENDED MINIMUM PADS FOR SOT-23 0.053 (1.341) 0.097 (2.459) Recommended Minimum Pads Dimensions in Inches/(mm) 服务热线:400-655-8788 9 SQ2361EES-T1-GE3-VB www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be RoHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
SQ2361EES-T1-GE3-VB 价格&库存
很抱歉,暂时无法提供与“SQ2361EES-T1-GE3-VB”相匹配的价格&库存,您可以联系我们找货
