SPD06N80C3-VB
www.VBsemi.com
SPD06N80C3-VB Datasheet
N-Channel 800V (D-S) Super Junction Power MOSFET
FEATURES
PRODUCT SUMMARY
800
VDS (V) at TJ max.
Qg max. (nC)
Qgs (nC)
4
11
Qgd (nC)
Configuration
0.85
VGS = 10 V
RDS(on) at 25 °C (Ω)
Low figure-of-merit (FOM) Ron x Qg
Low input capacitance (Ciss)
Reduced switching and conduction losses
Ultra low gate charge (Qg)
Avalanche energy rated (UIS)
APPLICATIONS
Single
Server and telecom power supplies
Switch mode power supplies (SMPS)
Power factor correction power supplies (PFC)
Lighting
- High-intensity discharge (HID)
- Fluorescent ballast lighting
• Industrial
TO-252
D
G
G
D
S
S
Top View
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted)
PARAMETER
Drain-Source Voltage
VDS
LIMIT
800
Gate-Source Voltage
VGS
± 30
Continuous Drain Current (TJ = 150 °C)
SYMBOL
VGS at 10 V
TC = 25 °C
TC = 100 °C
Pulsed Drain Current a
ID
IDM
UNIT
V
5.9
A
1
8964
W/°C
Single Pulse Avalanche Energy b
EAS
mJ
Maximum Power Dissipation
PD
999746
W
TJ, Tstg
-55 to +150
°C
Linear Derating Factor
Operating Junction and Storage Temperature Range
Drain-Source Voltage Slope
TJ = 125 °C
Reverse Diode dV/dt d
Soldering Recommendations (Peak Temperature) c
for 10 s
dV/dt
32
300
V/ns
°C
Notes
a. Repetitive rating; pulse width limited by maximum junction temperature.
b. VDD = 50 V, starting TJ = 25 °C, L = 28.2 mH, Rg = 25 Ω, IAS = 3.5 A.
c. 1.6 mm from case.
d. ISD ≤ ID, dI/dt = 100 A/μs, starting TJ = 25 °C.
服务热线:400-655-8788
SPD06N80C3-VB
www.VBsemi.com
THERMAL RESISTANCE RATINGS
SYMBOL
TYP.
MAX.
Maximum Junction-to-Ambient
PARAMETER
RthJA
72
Maximum Junction-to-Case (Drain)
RthJC
0.7
UNIT
°C/W
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
PARAMETER
SYMBOL
TEST CONDITIONS
MIN.
TYP.
MAX.
UNIT
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
Gate-Source Threshold Voltage (N)
VDS
VGS = 0 V, ID = 250 μA
800
V
ΔVDS/TJ
Reference to 25 °C, ID = 1 mA
0.65
V/°C
VGS(th)
VDS = VGS, ID = 250 μA
2
4
V
VGS = ± 20 V
± 100
nA
VGS = ± 30 V
±1
μA
VDS = 800 V, VGS = 0 V
1
VDS = 520 V, VGS = 0 V, TJ = 125 °C
10
0.85
Ω
S
Gate-Source Leakage
IGSS
Zero Gate Voltage Drain Current
IDSS
Drain-Source On-State Resistance
RDS(on)
VGS = 10 V
ID = 4 A
gfs
VDS = 30 V, ID = 4 A
9
Input Capacitance
Ciss
73
Coss
Crss
6
14
Reverse Transfer Capacitance
VGS = 0 V,
VDS = 100 V,
f = 1 MHz
Output Capacitance
Effective Output Capacitance, Energy
Related a
Co(er)
46
Effective Output Capacitance, Time
Related b
Co(tr)
64
26
2.1
2.8
Forward Transconductance
μA
Dynamic
pF
VDS = 0 V to 520 V, VGS = 0 V
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Turn-On Delay Time
td(on)
VDD = 520 V, ID = 4 A,
VGS = 10 V, Rg = 9.1 Ω
26
55.7
tr
71
41
f = 1 MHz, open drain
3.5
7
18
TJ = 25 °C, IS = 4 A, VGS = 0 V
1.4
192
ns
TJ = 25 °C, IF = IS = 4 A,
dI/dt = 100 A/μs, VR = 400 V
2.4
μC
11
A
Rise Time
Turn-Off Delay Time
td(off)
Fall Time
tf
Gate Input Resistance
Rg
VGS = 10 V
ID = 4 A, VDS = 520 V
nC
ns
Ω
Drain-Source Body Diode Characteristics
Continuous Source-Drain Diode Current
IS
Pulsed Diode Forward Current
ISM
Diode Forward Voltage
VSD
Reverse Recovery Time
trr
Reverse Recovery Charge
Qrr
Reverse Recovery Current
IRRM
MOSFET symbol
showing the
integral reverse
p - n junction diode
D
A
G
S
V
Notes
a. Coss(er) is a fixed capacitance that gives the same energy as Coss while VDS is rising from 0 % to 80 % VDSS.
b. Coss(tr) is a fixed capacitance that gives the same charging time as Coss while VDS is rising from 0 % to 80 % VDSS.
服务热线:400-655-8788
SPD06N80C3-VB
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
3
TOP
15 V
14 V
13 V
12 V
11 V
10 V
9V
8V
7V
6V
BOTTOM 5 V
40
30
ID = 4 A
TJ = 25 °C
RDS(on), Drain-to-Source
On Resistance (Normalized)
ID, Drain-to-Source Current (A)
50
2.5
2
1.5
1
VGS = 10 V
0.5
10
15
30
TJ, Junction Temperature (°C)
Fig. 1 - Typical Output Characteristics
Fig. 4 - Normalized On-Resistance vs. Temperature
1000
30
15 V
14 V
13 V
12 V
11 V
10 V
9V
8V
7V
BOTTOM 6 V
TJ = 150 °C
Ciss
Capacitance (pF)
TOP
25
20 40 60 80 100 120 140 160
VDS, Drain-to-Source Voltage (V)
15
10
300
VGS = 0 V, f = 1 MHz
Ciss = Cgs + Cgd, Cds Shorted
Crss = Cgd
Coss = Cds + Cgd
Coss
200
ġ
Crss
10
ġ
5
5V
1
5
15
30
400
300
500
600
Fig. 5 - Typical Capacitance vs. Drain-to-Source Voltage
48
24
VGS, Gate-to-Source Voltage (V)
200
Fig. 2 - Typical Output Characteristics
40
32
16
TJ = 25 °C
8
TJ = 150 °C
VDS = 30.8 V
VDS = 520 V
VDS = 325 V
VDS = 130 V
12
8
4
5
10
15
60
80
100
Qg, Total Gate Charge (nC)
Fig. 3 - Typical Transfer Characteristics
Fig. 6 - Typical Gate Charge vs. Gate-to-Source Voltage
服务热线:400-655-8788
SPD06N80C3-VB
www.VBsemi.com
ISD, Reverse Drain Current (A)
100
ID, Drain Current (A)
TJ = 150 °C
TJ = 25 °C
10
1
15
10
5
VGS = 0 V
0.2
0.4
0.6
0.8
1
1.2
1.4
25
1.6
VSD, Source-Drain Voltage (V)
75
100
125
150
TJ, Case Temperature (°C)
Fig. 7 - Typical Source-Drain Diode Forward Voltage
Fig. 9 - Maximum Drain Current vs. Case Temperature
800
1000
Operation in this Area
Limited by RDS(on)
10
100 μs
Limited by RDS(on)*
1
1 ms
0.1
TC = 25 °C
TJ = 150 °C
Single Pulse
BVDSS Limited
10 ms
Breakdown Voltage (V)
775
IDM = Limited
100
50
725
700
675
650
625
0.01
600
- 60 - 40 - 20 0
1
10
100
1000
VDS - Drain -to-Source Voltage (V)
* VGS > minimum V GS at which R DS(on) is specified
Fig. 8 - Maximum Safe Operating Area
Normalized Effective Transient
Thermal Impedance
750
Fig. 10 - Temperature vs. Drain-to-Source Voltage
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
0.0001
0.001
0.01
0.1
1
Pulse Time (s)
Fig. 11 - Normalized Thermal Transient Impedance, Junction-to-Case
服务热线:400-655-8788
4
SPD06N80C3-VB
www.VBsemi.com
RD
VDS
QG
10 V
VGS
D.U.T.
RG
QGS
- VDD
QGD
VG
10 V
Pulse width ≤ 1 μs
Duty factor ≤ 0.1 %
Charge
Fig. 12 - Switching Time Test Circuit
Fig. 16 - Basic Gate Charge Waveform
Current regulator
Same type as D.U.T.
VDS
90 %
50 kΩ
12 V
0.2 μF
0.3 μF
10 %
VGS
D.U.T.
td(on)
td(off) tf
tr
VDS
VGS
3 mA
Fig. 13 - Switching Time Waveforms
IG
ID
Current sampling resistors
L
Vary tp to obtain
required IAS
Fig. 17 - Gate Charge Test Circuit
VDS
D.U.T
RG
IAS
V DD
10 V
0.01 Ω
tp
Fig. 14 - Unclamped Inductive Test Circuit
VDS
tp
VDD
VDS
IAS
Fig. 15 - Unclamped Inductive Waveforms
服务热线:400-655-8788
SPD06N80C3-VB
www.VBsemi.com
Peak Diode Recovery dV/dt Test Circuit
Circuit layout considerations
• Low stray inductance
• Ground plane
• Low leakage inductance
current transformer
D.U.T.
Rg
dV/dt controlled by Rg
Driver same type as D.U.T.
ISD controlled by duty factor “D”
D.U.T. - device under test
VDD
Driver gate drive
P.W.
Period
D=
P.W.
Period
VGS = 10 Va
D.U.T. lSD waveform
Reverse
recovery
current
Body diode forward
current
dI/dt
D.U.T. VDS waveform
Diode recovery
dV/dt
Re-applied
voltage
Inductor current
VDD
Body diode forward drop
Ripple ≤ 5 %
ISD
Note
a. VGS = 5 V for logic level devices
Fig. 18 - For N-Channel
服务热线:400-655-8788
SPD06N80C3-VB
www.VBsemi.com
TO-252AA CASE OUTLINE
E
MILLIMETERS
A
C2
e
b2
D1
e1
E1
L
gage plane height (0.5 mm)
L4
b
L5
H
D
L3
b3
C
A1
INCHES
DIM.
MIN.
MAX.
MIN.
MAX.
A
2.18
2.38
0.086
0.094
A1
0.127
0.005
b
0.64
0.88
0.025
0.035
b2
0.76
1.14
0.030
0.045
b3
4.95
5.46
0.195
0.215
C
0.46
0.61
0.018
0.024
C2
0.46
0.89
0.018
0.035
D
5.97
6.22
0.235
0.245
D1
5.21
0.205
0.265
E
6.35
6.73
0.250
E1
4.32
0.170
H
9.40
10.41
0.370
0.410
e
2.28 BSC
0.090 BSC
e1
4.56 BSC
0.180 BSC
L
1.40
1.78
0.055
0.070
L3
0.89
1.27
0.035
0.050
L4
1.02
0.040
L5
1.14
1.52
0.045
0.060
ECN: X12-0247-Rev. M, 24-Dec-12
DWG: 5347
Note
• Dimension L3 is for reference only.
服务热线:400-655-8788
7
SPD06N80C3-VB
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
