IRLML5103GTRPBF-VB
www.VBsemi.com
IRLML5103GTRPBF-VB Datasheet
P-Channel 30 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
- 30
RDS(on) () Typ.
ID (A)a
0.046 at VGS = - 10 V
- 5.6
0.049 at VGS = - 6 V
-5
0.054 at VGS = - 4.5 V
-4.5
• Trench Power MOSFET
• 100 % Rg Tested
Qg (Typ.)
11.4 nC
APPLICATIONS
• For Mobile Computing
- Load Switch
- Notebook Adaptor Switch
- DC/DC Converter
S
(SOT-23)
TO-236
G
G
1
3
S
D
2
D
Top View
P-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TA = 25 °C, unless otherwise noted)
Parameter
Symbol
Limit
Drain-Source Voltage
VDS
- 30
Gate-Source Voltage
VGS
± 20
TC = 70 °C
- 5.1
ID
TA = 25 °C
- 5.4b,c
- 4.3b,c
TA = 70 °C
Pulsed Drain Current (t = 100 µs)
Continous Source-Drain Diode Current
Maximum Power Dissipation
IDM
TC = 25 °C
- 2.1
- 1b,c
TC = 25 °C
2.5
TC = 70 °C
1.6
PD
TA = 25 °C
A
- 18
IS
TA = 25 °C
W
1.25b,c
0.8b,c
TA = 70 °C
Operating Junction and Storage Temperature Range
V
- 5.6
TC = 25 °C
Continuous Drain Current (TJ = 150 °C)
Unit
TJ, Tstg
°C
- 55 to 150
THERMAL RESISTANCE RATINGS
Symbol
Typical
Maximum
t5s
RthJA
75
100
Steady State
RthJF
40
50
Parameter
b,d
Maximum Junction-to-Ambient
Maximum Junction-to-Foot (Drain)
Unit
°C/W
Notes:
a. Based on TC = 25 °C.
b. Surface mounted on 1" x 1" FR4 board.
c. t = 5 s.
d. Maximum under steady state conditions is 166 °C/W.
服务热线:400-655-8788
1
IRLML5103GTRPBF-VB
www.VBsemi.com
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = - 250 µA
- 30
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
VDS/TJ
V
- 19
ID = - 250 µA
mV/°C
VGS(th) Temperature Coefficient
VGS(th)/TJ
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS , ID = - 250 µA
- 2.0
V
IGSS
VDS = 0 V, VGS = ± 20 V
± 100
nA
VDS = - 30 V, VGS = 0 V
-1
VDS = - 30 V, VGS = 0 V, TJ = 55 °C
-5
Gate-Source Leakage
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currenta
ID(on)
Drain-Source On-State Resistancea
Forward Transconductancea
RDS(on)
gfs
VDS - 5 V, VGS = - 10 V
4
- 0.5
µA
A
- 2.5
VGS =- 10 V, ID = - 4.4 A
0.046
VGS =- 6 V, ID = - 4 A
0.049
VGS =- 4.5 V, ID = - 3.6 A
0.054
VDS = - 15 V, ID = - 3.4 A
18
S
Dynamicb
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Rg
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
1295
VDS = - 15 V, VGS = 0 V, f = 1 MHz
pF
130
VDS = - 15 V, VGS = - 10 V, ID = - 5.4 A
24
36
11.4
17
3.4
VDS = - 15 V, VGS = - 4.5 V, ID = - 5.4 A
VDD = - 15 V, RL = 3.5
ID - 4.3 A, VGEN = - 10 V, Rg = 1
1.5
7.7
15.4
13
8
38
57
tf
6
12
td(on)
28
42
td(off)
tr
td(off)
nC
3.8
f = 1 MHz
td(on)
tr
150
ID - 4.3 A, VGEN = - 4.5 V, Rg = 1
tf
16
24
30
45
10
ns
Drain-Source Body Diode Characteristics
Continuous Source-Drain Diode Current
IS
Pulse Diode Forward Current (t = 100 µs)
ISM
Body Diode Voltage
VSD
TC = 25 °C
- 2.1
- 80
IS = - 4.3 A, VGS 0 V
- 0.8
- 1.2
A
V
Body Diode Reverse Recovery Time
trr
15
23
ns
Body Diode Reverse Recovery Charge
Qrr
7
14
nC
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
IF = - 4.3 A, dI/dt = 100 A/µs, TJ = 25 °C
8
7
ns
Notes:
a. Pulse test; pulse width 300 µs, duty cycle 2 %.
b. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
2
IRLML5103GTRPBF-VB
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C, unless otherwise noted)
2
50
VGS = 10 V thru 5 V
40
ID - Drain Current (A)
1.5
VGS = 4.5 V
30
VGS = 4 V
TC = 25 °C
0.5
10
TC = 125 °C
VGS = 3 V
TC = - 55 °C
1
1.5
VDS - Drain-to-Source Voltage (V)
Output Characteristics
2.4
3
Transfer Characteristics
1800
0.08
0.06
VGS = 4.5 V
1350
VGS = 6 V
C - Capacitance (pF)
RDS(on) - On-Resistance (Ω)
1.8
1.2
VGS - Gate-to-Source Voltage (V)
VGS = 10 V
0.04
Ciss
900
450
0.02
Coss
Crss
40
18
24
On-Resistance vs. Drain Current
Capacitance
30
1.5
10
ID = 5.4 A
ID = 5.4 A
VDS = 8 V
RDS(on) - On-Resistance (Normalized)
12
6
8
VDS = 15 V
6
4
VDS = 24 V
2
5
15
VGS = 10 V, 6 V
1.3
VGS = 4.5 V
1.1
0.9
0.7
- 50
- 25
50
75
100
125
150
Qg - Total Gate Charge (nC)
TJ - Junction Temperature (°C)
Gate Charge
On-Resistance vs. Junction Temperature
服务热线:400-655-8788
3
IRLML5103GTRPBF-VB
www.VBsemi.com
100
0.080
IS - Source Current (A)
ID = 5.4 A
10
TJ = 150 °C
TJ = 25 °C
1
0.1
0.060
TJ = 125 °C
0.040
TJ = 25 °C
0.020
0.000
0.0
0.3
0.6
0.9
1.2
2
4
6
8
10
VSD - Source-to-Drain Voltage (V)
Source-Drain Diode Forward Voltage
On-Resistance vs. Gate-to-Source Voltage
10
2
ID = 250 μA
8
Power (W)
VGS(th) (V)
1.75
1.5
6
4
1.25
2
1
- 50
- 25
50
75
100
125
150
TA = 25 °C
0.1
1
10
100
1000
TJ - Temperature (°C)
Time (s)
Threshold Voltage
Single Pulse Power (Junction-to-Ambient)
10
5
Limited by RDS(on)*
100 μs
1 ms
1
10 ms
100 ms
0.1
10s, 1 s
DC
0.01
TA = 25 °C
Single Pulse
BVDSS Limited
0.001
0.1
1
10
100
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area, Junction-to-Ambient
服务热线:400-655-8788
4
IRLML5103GTRPBF-VB
www.VBsemi.com
5.8
4.6
3.4
2.2
25
75
100
125
150
TC - Case Temperature (°C)
Current Derating*
1.0
3.1
2.48
1.86
Power (W)
Power (W)
0.8
1.24
0.5
0.3
0.62
0.0
50
75
100
Power, Junction-to-Foot
125
150
50
75
100
125
150
TA - Ambient Temperature (°C)
Power, Junction-to-Ambient
* The power dissipation PD is based on TJ(max.) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
服务热线:400-655-8788
5
IRLML5103GTRPBF-VB
www.VBsemi.com
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
Notes:
0.1
PDM
0.05
t1
0.02
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = RthJA = 166 °C/W
3. TJM - TA = PDMZthJA(t)
4. Surface Mounted
Single Pulse
0.01
10 -4
10 -3
10 -2
10 -1
1
100
10
1000
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Ambient
1
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
0.1
0.05
0.02
Single Pulse
0.01
10 -4
10 -3
10 -2
10 -1
1
10
Normalized Thermal Transient Impedance, Junction-to-Foot
服务热线:400-655-8788
6
IRLML5103GTRPBF-VB
www.VBsemi.com
SOT-23 (TO-236): 3-LEAD
b
3
E1
1
E
2
e
S
e1
D
0.10 mm
C
0.004"
A2
A
C
q
Gauge Plane
Seating Plane
Seating Plane
C
A1
Dim
0.25 mm
L
L1
MILLIMETERS
INCHES
Min
Max
Min
Max
A
0.89
1.12
0.035
0.044
A1
0.01
0.10
0.0004
0.004
A2
0.88
1.02
0.0346
0.040
b
0.35
0.50
0.014
0.020
c
0.085
0.18
0.003
0.007
D
2.80
3.04
0.110
0.120
E
2.10
2.64
0.083
0.104
E1
1.20
1.40
0.047
e
e1
L
1.90 BSC
0.40
L1
q
0.0748 Ref
0.60
0.016
0.64 Ref
S
0.024
0.025 Ref
0.50 Ref
3°
0.055
0.0374 Ref
0.95 BSC
0.020 Ref
8°
3°
8°
ECN: S-03946-Rev. K, 09-Jul-01
DWG: 5479
服务热线:400-655-8788
7
IRLML5103GTRPBF-VB
www.VBsemi.com
0.049
(1.245)
0.029
0.022
(0.559)
(0.724)
0.037
(0.950)
(2.692)
0.106
RECOMMENDED MINIMUM PADS FOR SOT-23
0.053
(1.341)
0.097
(2.459)
Recommended Minimum Pads
Dimensions in Inches/(mm)
服务热线:400-655-8788
8
IRLML5103GTRPBF-VB
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
RoHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
