MMSZ5221B-MMSZ5259B
Product specification
MMSZ5221B-MMSZ5259B
Reference News
FEATURES
PACKAGE OUTLINE
Planar Die Construction
Ultra-Small Surface Mount Package
General purpose, Medium Current
Ideally Suited for Automated Assembly Processes
PIN CONFIGURATION
SOD-123
Maximum Ratings(Ta=25 ℃ unless otherwise specified)
Characteristic
Value
Unit
VF
0.9
V
Power Dissipation(Note 1)
Pd
500
mW
Thermal Resistance, Junction to Ambient Air
Operation Junction and Storage Temperature
Range
RθJA
357
℃/W
TJ,Tstg
-55~+150
Forward Voltage (Note 2)
@ IF = 10mA
Symbol
Notes:1. Device mounted on ceramic PCB; 7.6 mm x 9.4 mm x 0.87 mm with pad areas 25 mm2 .
2. Tested with pulses, Tp≤1.0ms.
Copyright© Msksemi Incorporated
www.msksemi.com
MMSZ5221B-MMSZ5259B
ELECTRICAL CHARACTERISTICS
Ta=25
Type
Number
Maximum Zener Impedance
Zener Voltage Range (Note 2)
(Note 4)
Code
VZ@ IZT
IZT
Nom(V)
Min(V)
Max(V)
mA
Z ZT @I ZT
Z ZK @I ZK
Ω
Maximum
Reverse
Current
IZK
IR
VR
mA
uA
V
MMSZ5221B
C1
2.4
2.28
2.52
1200
0.25
100
1.0
MMSZ5223B
C3
2.7
2.57
2.84
1300
0.25
75
1.0
MMSZ5225B
C5
3.0
2.85
3.15
1600
0.25
50
1.0
MMSZ5226B
G1
3.3
3.14
3.47
1600
0.25
25
1.0
MMSZ5227B
G2
3.6
3.42
3.78
1700
0.25
15
1.0
MMSZ5228B
G3
3.9
3.71
4.10
1900
0.25
10
1.0
MMSZ5229B
G4
4.3
4.09
4.52
2000
0.25
5
1.0
MMSZ5230B
G5
4.7
4.47
4.94
1900
0.25
5
2.0
MMSZ5231B
E1
5.1
4.85
5.36
1600
0.25
5
2.0
MMSZ5232B
E2
5.6
5.32
5.88
1600
0.25
5
3.0
MMSZ5233B
E3
6.0
5.70
6.30
1600
0.25
5
3.5
MMSZ5234B
E4
6.2
5.89
6.51
1000
0.25
5
4.0
MMSZ5235B
E5
6.8
6.46
7.14
750
0.25
3
5.0
MMSZ5236B
F1
7.5
7.13
7.88
500
0.25
3
6.0
MMSZ5237B
F2
8.2
7.79
8.61
500
0.25
3
6.5
MMSZ5238B
F3
8.7
8.27
9.14
600
0.25
3
6.5
MMSZ5239B
F4
9.1
8.65
9.56
600
0.25
3
7.0
MMSZ5240B
F5
10
9.50
10.50
600
0.25
3
8.0
MMSZ5241B
H1
11
10.45
11.55
600
0.25
2.0
8.4
MMSZ5242B
H2
12
11.40
12.60
600
0.25
1.0
9.1
MMSZ5243B
H3
13
12.35
13.65
9.5
13
600
0.25
0.5
9.9
MMSZ5244B
H4
14
13.30
14.70
9.0
15
600
0.25
0.1
10
MMSZ5245B
H5
15
14.25
15.75
8.5
16
600
0.25
0.1
11
MMSZ5246B
J1
16
15.20
16.80
7.8
17
600
0.25
0.1
12
MMSZ5248B
J3
18
17.10
18.90
7.0
21
600
0.25
0.1
14
MMSZ5250B
J5
21.00
6.2
25
600
0.25
0.1
15
MMSZ5251B
K1
22
20.90
23.10
5.6
29
600
0.25
0.1
17
MMSZ5252B
K2
24
22.80
25.20
5.2
33
600
0.25
0.1
18
MMSZ5253B
K3
25
23.75
26.25
5.0
35
600
0.25
0.1
19
MMSZ5254B
K4
27
25.65
28.35
5.0
41
600
0.25
0.1
21
MMSZ5255B
K5
28
26.60
29.40
4.5
44
600
0.25
0.1
21
MMSZ5256B
M1
30
28.50
31.50
4.2
49
600
0.25
0.1
23
MMSZ5257B
M2
33
31.35
34.65
3.8
58
700
0.25
0.1
25
MMSZ5258B
M3
36
34.20
37.80
3.4
70
700
0.25
0.1
27
MMSZ5259B
M4
39
37.05
40.95
3.2
80
800
0.25
0.1
30
MMSZ5266B
P1
68
64.6
71.4
1.8
230
1600
0.25
0.1
52
www.msksemi.com
MMSZ5221B-MMSZ5259B
Zener Characteristics(VZ Up to 10 V)
Pulsed
10
1
0.5
PD =350mW
1
2
3
4
5
6
7
8
9
10
0.5
10
11
15
33
28
30
24
25
27
36
40
45
Typical Leakage Current
Pulsed
FOR MMSZ52XXB SERIES
10
30
IR, LEAKAGE CURRENT (uA)
θVZ, TEMPERATURE COEFFICIENT (mV/℃)
35
TYPICAL Ta VALUES
35
25
VZ @ IZT
15
10
5
1
0.1
0.01
Ta=100℃
1E-3
Ta=25℃
8
12
16
28
32
36
40
1E-4
44
10
25
30
35
40
45
Effect of Zener Voltage on Zener Impedance
Ta=25℃
f=1MHz
ZZT, DYNAMIC IMPEDANCE(Ω)
1000
0V BIAS
1V BIAS
10
BIAS AT
50% OF VZ NOM
1
Ta=25℃
100
15
VZ, NOMINAL ZENER VOLTAGE (V)
Typical Capacitance
1000
C, CAPACITANCE (pF)
30
100
10
100
IZ(AC)=0.1IZ(DC)
IZ=0.25mA
f=1kHz
100
IZT
10
1
1
10
100
Power Derating Curve
800
700
600
POWER DISSIPATION
PD
(mW)
25
VZ, ZENER VOLTAGE (V)
Temperature Coefficients
40
1
22
1
-5
11
12
13
14
15
16
9.1
8.7
8.2
7.5
6.2
6.8
5.1
5.6
6.0
4.3
4.7
10
3.0
IZ, ZENER CURRENT (mA)
Ta =25℃
PD =350mW
Pulsed
18
Ta =25℃
Zener Characteristics(11 V to 39 V)
100
100
500
400
300
200
100
50
75
AMBIENT TEMPERATURE
100
Ta
125
150
www.msksemi.com
MMSZ5221B-MMSZ5259B
PACKAGE MECHANICAL DATA
Symbol
A
A1
A2
b
c
D
E
E1
L
L1
θ
Dimensions In Millimeters
Max
Min
1.050
1.250
0.000
0.100
1.050
1.150
0.450
0.650
0.080
0.150
1.500
1.700
2.600
2.800
3.550
3.850
0.500 REF
0.250
0.450
0°
8°
Dimensions In Inches
Min
Max
0.041
0.049
0.000
0.004
0.041
0.045
0.018
0.026
0.003
0.006
0.059
0.067
0.102
0.110
0.140
0.152
0.020 REF
0.010
0.018
0°
8°
Note:
1.Controllng dlmenslon:in mlllmeters.
2.General tolerance:± 0.05mm.
3.The pad layout Is for reference purposes only.
REEL SPECIFICATION
P/N
PKG
QTY
MMSZ5221B-MMSZ5259B
SOD-123
3000
www.msksemi.com
MMSZ5221B-MMSZ5259B
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not
handle applications that require extremely high levels of reliability, such as life-support
have specifications
that can
systems, aircraft's control systems, or
other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with
your MSKSEMI Semiconductor representative
nearest
you before using any MSKSEMI Semiconductor products described
or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that
exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in
products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the
performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To
verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test
devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor
products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could
endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing
equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are
not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained
herein are controlled under any of applicable local export control laws and regulations, such products must not be exported
without obtaining the export license from theauthorities
concerned
in accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior
written permission of MSKSEMI Semiconductor.
Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume
production. MSKSEMI Semiconductor believes information herein is accurate and
reliable, but no guarantees are made or
implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties.
Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI
Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“MMSZ5255B”相匹配的价格&库存,您可以联系我们找货
