Plastic-Encapsulate MOSFETs
Dual N-channel MOSFET
V(BR)DSS
SOT-363
ID
RDS(on)MAX
6
50 V
3.5Ω@10V
220mA
6Ω@4.5V
5
4
1
2
3
APPLICATION
z Load Switch for Portable Devices
z DC/DC Converter
FEATURE
High density cell design for low RDS(ON)
z
Voltage controlled small signal switch
z
Rugged and reliable
z
High saturation current capability
z
Equivalent Circuit
MARKING
Maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Drain-Source Voltage
VDS
50
Continuous Gate-Source Voltage
VGSS
±20
Continuous Drain Current
ID
0.22
A
Power Dissipation
PD
0.3
W
RθJA
417
℃/W
Tj
150
Tstg
-55 ~+150
Thermal Resistance from Junction to Ambient
Operating Temperature
Storage Temperature
1 of 4
Copyright © All right reserved: Heyuan China Base Electronics Technology Co., Ltd.
V
MOSFET ELECTRICAL CHARACTERISTICS
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
Units
Off characteristics
Drain-source breakdown voltage
V(BR)DSS
VGS = 0V, ID =250µA
Gate-body leakage
IGSS
VDS =0V, VGS =±20V
±500
nA
Zero gate voltage drain current
IDSS
VDS =50V, VGS =0V
0.5
µA
VDS =30V, VGS =0V
100
nA
1.50
V
50
V
On characteristics
Gate-threshold voltage (note 1)
VGS(th)
Static drain-source on-resistance (note 1)
RDS(on)
Forward transconductance (note 1)
gFS
VDS =VGS, ID =1mA
0.80
VGS =10V, ID =0.22A
3.50
VGS =4.5V, ID =0.22A
6
VDS =10V, ID =0.22A
0.12
Ω
S
Dynamic characteristics (note 2)
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitance
Crss
27
VDS =25V,VGS =0V, f=1MHz
pF
13
6
Switching characteristics
Turn-on delay time (note 1,2)
Rise time (note 1,2)
Turn-off delay time (note 1,2)
Fall time (note 1,2)
td(on)
5
tr
VDD=30V, VDS=10V,
18
td(off)
ID =0.29A,RGEN=6Ω
36
tf
ns
14
Drain-source body diode characteristics
Body diode forward voltage (note 1)
VSD
IS=0.44A, VGS = 0V
Notes:
1.
Pulse Test ; Pulse Width ≤300µs, Duty Cycle ≤2%.
2.
These parameters have no way to verify.
2 of 4
1.4
V
Typical Characteristics
Output Characteristics
Transfer Characteristics
1.2
2.0
Ta=25℃
VDS=3V
VGS=3V,4V,5V,6V
Pulsed
VGS=10V
(A)
(A)
1.5
ID
VGS=5V
1.0
DRAIN CURRENT
ID
DRAIN CURRENT
Pulsed
1.0
VGS=4V
VGS=3V
0.5
Ta=25℃
0.8
Ta=100℃
0.6
0.4
0.2
VGS=2V
0.0
2
3
4
DRAIN TO SOURCE VOLTAGE
VDS
0.0
5
2
Pulsed
Ta=25℃
Pulsed
ID=500mA
5
1.2
1.1
1.0
0.9
VGS=10V
0.8
RDS(ON)
VGS=4.5V
4
ON-RESISTANCE
RDS(ON)
ON-RESISTANCE
5
(V)
6
1.3
3
0.7
Ta=100℃
2
1
0.6
0.5
4
VGS
RDS(ON) —— VGS
RDS(ON) —— ID
1.5
1.4
3
GATE TO SOURCE VOLTAGE
(V)
Ta=25℃
0.2
0.4
0.6
DRAIN CURRENT
0.8
ID
4
6
(A)
8
VGS
10
(V)
Threshold Voltage
IS —— VSD
1
2.0
Ta=100℃
Ta=25℃
0.01
1E-3
0.2
0.4
0.6
1.5
VTH
0.1
THRESHOLD VOLTAGE
SOURCE CURRENT
IS (A)
(V)
Pulsed
0.8
1.0
SOURCE TO DRAIN VOLTAGE
1.2
ID=250uA
1.0
0.5
0.0
25
1.4
50
75
JUNCTION TEMPERATURE
VSD (V)
100
Tj
3 of 4
125
SOT-363 Package Outline Dimensions
Dimension in Millimeters
Symbol
Min
Max
A
0.90
1.00
A1
0.010
0.100
B
1.20
1.40
bp
0.25
0.45
C
0.09
0.15
D
2.00
2.20
E
1.15
1.35
HE
2.15
2.55
Lp
0.25
0.46
θ
0º
6º
4 of 4
很抱歉,暂时无法提供与“BSS138DW”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.27786
- 100+0.21968
- 600+0.19054
- 1200+0.18768
- 3000+0.16873
- 国内价格
- 10+0.31925
- 100+0.25240
- 300+0.21892
- 3000+0.19386
- 6000+0.17378
- 9000+0.16373
