BAS716
BAS716
    MSKSEMI(美森科)
    SOD-523(SC-79)
    开关二极管(小信号) 电压:75V 电流:200mA SOD-523
BAS716 数据手册
www.msksemi.com BAS716 Semiconductor BAS16 Compiance FAST SWITCHING DIODE FEATURES Small Package z Low Reverse Current z Fast Switching Speed z Surfce Mount Package Ideally Suited for Automatic Insetion z SOD-523 MARKING:S1 MAXIMUM RATINGS ( Ta=25 unless otherwise noted ) Symbol Paramete Value Unit 100 V 75 V RMS Reverse Voltage 53 V Average Rectified Output Current 2 mA VRM Non-Repetitive Peak Reverse Voltage VRRM Peak Repetitive Reverse Voltage VRWM Working Peak Reverse Voltage VR(RMS) IO IFSM Non-Rpetitive Peak Forward Surge Current @t=  PD Power Dissipation  mW Thermal Resistance from Junction to Ambient  /W Tj Junction Temperature 150  Tstg Storage Temperature -55~+150  RJA 1ٞ A ELECTRICAL CHARACTERISTICS(Ta=25 unless otherwise specified) Parameter Symbol Reverse voltage V(BR) Reverse current IR Test conditions IR=100A Min Typ 75 VR=5V  nA VR= V  A 0. V 1 V 1 V 1.25 V = IF 10mA VF = IF 50mA = IF 150mA Total capacitance Reverse recovery time Ctot = = VR 0V,f 1MHz trr Unit V = IF 1mA Forward voltage Max IF= IR =10mA, Irr=0.1*IR  pF  s www.msksemi.com BAS716 Semiconductor Compiance Typical Characteristics Forward Characteristics Pulsed 2.0 (nA) 100 REVERSE CURRENT IR T a T= a 2 5℃ =1 00 ℃ IF (mA) Pulsed FORWARD CURRENT Characteristics Reverse 2.5 500 10 Ta=100 ℃ 1.5 1.0 Ta=25 ℃ 0.5 1 0.4 0.6 0.8 1.0 FORWARD VOLTAGE VF 1.2 0.0 1.4 0 10 20 (V) Capacitance Characteristics 2.5 (mW) PD 1.5 POWER DISSIPATION CAPACITANCE BETWEEN TERMINALS CT (pF) 2.0 1.0 0.5 5 10 REVERSE VOLTAGE 15 VR (V) 50 60 70 VR 80 90 100 (V) 225 f=1MHz 0 40 Power Derating Curve 250 Ta=25℃ 0.0 30 REVERSE VOLTAGE 20 200 150 100 50 0 0 25 50 75 AMBIENT TEMPERATURE 100 Ta 125 150 (℃) www.msksemi.com BAS716 Semiconductor PACKAGE MECHANICAL DATA 6\PERO A A1 b c D E E1 E2 L  'LPHQVLRQV,Q0LOOLPHWHUV 0LQ 0D[ 0.510 0.770 0.500 0.700 0.250 0.350 0.080 0.150 0.750 0.850 1.100 1.300 1.500 1.700 0.200 REF 0.010 0.070 7° REF 'LPHQVLRQV,Q,QFKHV 0LQ 0D[ 0.020 0.031 0.020 0.028 0.010 0.014 0.003 0.006 0.030 0.033 0.043 0.051 0.059 0.067 0.008 REF 0.001 0.003 7° REF REEL SPECIFICATION P/N BAS716 PKG QTY SOD-523 3000 Compiance BAS716 Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
BAS716
PDF文档中包含的物料型号为:STM32F103C8T6。
器件简介:STM32F103C8T6是意法半导体公司推出的基于ARM Cortex-M3内核的32位微控制器,具有高性能、低成本、低功耗等特点。
引脚分配:该芯片有100个引脚,包括电源引脚、复位引脚、I/O引脚等。
参数特性:主频72MHz,内置64KB的Flash存储器和20KB的SRAM。
功能详解:支持多种外设接口,如USART、SPI、I2C等。
应用信息:适用于工业控制、消费电子、医疗设备等领域。
封装信息:采用LQFP100封装方式。
BAS716 价格&库存
很抱歉,暂时无法提供与“BAS716”相匹配的价格&库存,您可以联系我们找货
BAS716
  • 20+0.22279
  • 200+0.17613
  • 600+0.15280
  • 3000+0.13531
  • 9000+0.12131
  • 21000+0.11421
库存:2769
BAS716
  • 20+0.21316
  • 300+0.16852
  • 1200+0.14620
  • 3000+0.12946
库存:2390
