IRLU3410PBF-VB
www.VBsemi.com
IRLU3410PBF-VB Datasheet
N-Channel 100 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
100
RDS(on) ()
ID (A)
0.110 at VGS = 10 V
15
0.115 at VGS = 6 V
15
• DT-Trench Power MOSFET
• 175 °C Junction Temperature
• 100 % Rg Tested
APPLICATIONS
• Primary Side Switch
TO-251
D
G
S
G D S
Top View
N-Channel MOSFET
ABSOLUTE MAXIMUM RATINGS (TC = 25 °C, unless otherwise noted)
Symbol
Limit
Drain-Source Voltage
Parameter
VDS
100
Gate-Source Voltage
VGS
± 20
Continuous Drain Current (TJ = 175 °C)b
TC = 25 °C
TC = 125 °C
8.7
45
Continuous Source Current (Diode Conduction)
IS
15
Avalanche Current
IAR
15
EAR
11.3
Repetitive Avalanche Energy (Duty Cycle 1 %)
Maximum Power Dissipation
L = 0.1 mH
TC = 25 °C
TA = 25 °C
61
PD
A
mJ
b
W
2.7a
TJ, Tstg
Operating Junction and Storage Temperature Range
V
15
ID
IDM
Pulsed Drain Current
Unit
- 55 to 175
°C
THERMAL RESISTANCE RATINGS
Parameter
Junction-to-Ambienta
Junction-to-Case
Symbol
t 10 s
Steady State
RthJA
RthJC
Typical
Maximum
16
55
2
2.4
Unit
°C/W
Notes:
a. Surface mounted on 1" x 1" FR4 board.
b. See SOA curve for voltage derating.
服务热线:400-655-8788
1
IRLU3410PBF-VB
www.VBsemi.com
SPECIFICATIONS (TJ = 25 °C, unless otherwise noted)
Symbol
Parameter
Test Conditions
Min.
Typ.a
Max.
Unit
Static
Drain-Source Breakdown Voltage
Gate Threshold Voltage
Gate-Body Leakage
VDS
VGS = 0 V, ID = 250 µA
100
VGS(th)
VDS = VGS, ID = 250 µA
1.0
IGSS
VDS = 0 V, VGS = ± 20 V
± 100
VDS = 100 V, VGS = 0 V
1
VDS = 100 V, VGS = 0 V, TJ = 125 °C
50
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currentb
ID(on)
3.0
VDS = 100 V, VGS = 0 V, TJ = 175 °C
Drain-Source On-State Resistanceb
Forward
Transconductanceb
VDS =5 V, VGS = 10 V
RDS(on)
gfs
V
nA
µA
250
15
A
VGS = 10 V, ID = 15 A
0.110
VGS = 10 V, ID = 15 A, TJ = 125 °C
0.170
VGS = 10 V, ID = 15 A, TJ = 175 °C
0.230
VGS = 6 V, ID = 10 A
0.115
VDS = 15 V, ID = 15 A
25
S
Dynamica
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Chargec
Qg
Gate-Source Chargec
Qgs
c
110
VDS = 75 V, VGS = 10 V, ID = 15 A
Rise Timec
Fall Timec
1
td(on)
tr
c
td(off)
25
5.5
nC
7
Rg
Gate Resistance
Turn-On Delay Timec
pF
70
Qgd
Gate-Drain Charge
Turn-Off Delay Time
892
VGS = 0 V, VDS = 25 V, f = 1 MHz
VDD = 75 V, RL = 5
ID 15 A, VGEN = 10 V, RG = 2.5
tf
3.2
8
12
35
55
17
25
30
45
ns
Source-Drain Diode Ratings and Characteristic (TC = 25 °C)
45
ISM
Pulsed Current
A
Voltageb
VSD
IF = 15 A, VGS = 0 V
0.9
1.5
V
Source-Drain Reverse Recovery Time
trr
IF = 15 A, dI/dt = 100 A/µs
55
85
ns
Diode Forward
Notes:
a. Guaranteed by design, not subject to production testing.
b. Pulse test; pulse width 300 µs, duty cycle 2 %.
c. Independent of operating temperature.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
2
IRLU3410PBF-VB
www.VBsemi.com
TYPICAL CHARACTERISTICS (25 °C unless noted)
25
25
VGS = 10 thru 5V
I D - Drain Current (A)
4V
10
5
15
10
TC = 125 °C
5
25 °C
3V
- 55 °C
4
6
8
10
2
3
4
5
6
VGS - Gate-to-Source Voltage (V)
VDS - Drain-to-Source Voltage (V)
Output Characteristics
Transfer Characteristics
0.14
40
TC = - 55 °C
VGS = 6 V
25 °C
24
RDS(on)- On-Resistance ()
g fs - Transconductance (S)
0.12
32
125 °C
16
8
0.10
VGS = 10 V
0.08
0.06
0.04
0.02
0.00
10
5
10
ID - Drain Current (A)
On-Resistance vs. Drain Current
Transconductance
1500
V GS - Gate-to-Source Voltage (V)
C - Capacitance (pF)
15
Ciss
900
600
300
Crss
Coss
VDS = 75 V
ID = 15 A
16
12
8
4
60
80
Capacitance
服务热线:400-655-8788
100
16
24
32
40
Qg - Total Gate Charge (nC)
Gate Charge
3
IRLU3410PBF-VB
www.VBsemi.com
100
VGS = 10 V
ID = 15 A
2.4
2.0
I S - Source Current (A)
R DS(on)- On-Resistance (Normalized)
2.8
1.6
1.2
0.8
TJ = 150 °C
10
TJ = 25 °C
0.4
0.0
- 50
- 25
50
75
100
125
150
1
175
0.3
0.9
1.2
TJ - Junction Temperature (°C)
VSD - Source-to-Drain Voltage (V)
On-Resistance vs. Junction Temperature
Source-Drain Diode Forward Voltage
THERMAL RATINGS
100
10 µs
Limited by R DS(on)*
15
10
5
100 µs
10
1 ms
1
10 ms
100 ms
1 s, DC
TC = 25 °C
Single Pulse
50
75
100
125
TC - Case Temperature (°C)
150
175
0.1
0.1
Maximum Avalanche Drain Current
vs. Case Temperature
1
10
1000
100
* VGS > minimum VGS at which RDS(on) is specified
Safe Operating Area
2
Normalized Effective Transient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.1
0.02
0.05
Single Pulse
0.01
10 -4
10 -3
10 -2
10 -1
Square Wave Pulse Duration (sec)
1
10
Normalized Thermal Transient Impedance, Junction-to-Case
服务热线:400-655-8788
4
IRLU3410PBF-VB
www.VBsemi.com
TOĆ251AA (DPAK)
E
A
L2
b2
Dim
A
A1
b
b1
b2
c
c1
D
E
e
L
L1
L2
L3
D
L3
L1
b1
L
b
MILLIMETERS
c1
e
c
A1
INCHES
Min
Max
Min
Max
2.21
2.38
0.087
0.094
0.89
1.14
0.035
0.045
0.71
0.89
0.028
0.035
0.76
1.14
0.030
0.045
5.23
5.43
0.206
0.214
0.46
0.58
0.018
0.023
0.46
0.58
0.018
0.023
5.97
6.22
0.235
0.245
6.48
6.73
0.255
0.265
2.28 BSC
0.090 BSC
8.89
9.53
0.350
0.375
1.91
2.28
0.075
0.090
0.89
1.27
0.035
0.050
1.15
1.52
0.045
0.060
ECN: S-03946—Rev. E, 09-Jul-01
DWG: 5346
Note: Dimension L3 is for reference only.
服务热线:400-655-8788
5
IRLU3410PBF-VB
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
