ES1BAL – ES1JAL
Taiwan Semiconductor
1A, 100V - 600V Super Fast Surface Mount Rectifier
FEATURES
KEY PARAMETERS
Glass passivated chip junction
Ideal for automated placement
Low power loss, high efficiency
Low profile package
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
IF
1
A
VRRM
100 - 600
V
IFSM
30
A
TJ MAX
150
°C
Package
Thin SMA
Configuration
Single die
● DC to DC converter
● Switching mode converters and inverters
● Freewheeling application
MECHANICAL DATA
Case: Thin SMA
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.029g (approximately)
Thin SMA
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL ES1BAL ES1DAL ES1GAL ES1JAL UNIT
Marking code on the device
ES1BAL
ES1DAL
ES1GAL
ES1JAL
Repetitive peak reverse voltage
VRRM
100
200
400
600
V
Reverse voltage, total rms value
VR(RMS)
70
140
280
420
V
Forward current
Surge peak forward current single
half sine wave superimposed on
rated load
Junction temperature
Storage temperature
IF
t = 8.3ms
t = 1.0ms
1
A
30
A
60
A
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
IFSM
1
Version: C2103
ES1BAL – ES1JAL
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
28
°C/W
Junction-to-ambient thermal resistance
RӨJA
67
°C/W
Junction-to-case thermal resistance
RӨJC
°C/W
Thermal Performance Note: Units mounted on PCB (5mm x 5mm Cu pad test board)
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
TYP
MAX
UNIT
0.80
V
ES1BAL IF = 1.0A, TJ = 25°C
ES1DAL IF = 0.5A, TJ = 125°C
0.85
0.95
V
0.58
V
IF = 1.0A, TJ = 125°C
0.71
0.81
V
IF = 0.5A, TJ = 25°C
0.86
V
0.93
1.30
V
0.69
V
0.77
0.89
V
1.04
V
1.15
1.70
V
0.80
V
0.93
1.06
V
1
µA
µA
35
ns
18
pF
16
pF
15
pF
Forward voltage
(1)
ES1GAL
ES1JAL
Reverse current @ rated VR
TJ = 25°C
(2)
TJ = 125°C
IF = 0.5A, IR = 1.0A,
Irr = 0.25A
Reverse recovery time
Junction capacitance
ES1BAL
ES1DAL
ES1GAL 1MHz, VR = 4.0V
ES1JAL
VF
IR
trr
CJ
Notes:
1. Pulse test with PW = 0.3ms
2. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
ES1xAL
Thin SMA
14,000 / Tape & Reel
Notes:
1. "x" defines voltage from 100V(ES1BAL) to 600V(ES1JAL)
2
Version: C2103
ES1BAL – ES1JAL
CHARACTERISTICS CURVES
Fig.1 Forward Current Derating Curve
Fig.2 Typical Junction Capacitance
100
CAPACITANCE (pF)
AVERAGE FORWARD CURRENT (A)
2
1
ES1BAL - ES1DAL
ES1GAL
ES1JAL
10
f=1.0MHz
Vsig=50mVp-p
50
75
100
125
1
150
1
10
LEAD TEMPERATURE (°C)
ES1BAL – ES1DAL
TJ=150°C
1
TJ=125°C
0.1
0.01
0.001
TJ=25°C
0.0001
40
50
60
70
80
90 100
10
10
ES1BAL – ES1DAL
UF1DLW
1
0.1
1
TJ=150°C
TJ=125°C
TJ=125°C
TJ=25°C
TJ=25°C
(A)
INSTANTANEOUS FORWARD CURRENT (A)
100
10
0.01
TJ=-55°C
0.001
0.1
0.3
0.4
width
Pulse widthPulse
300μs
1% duty cycle
0.4
0.6
0.5
0.6
0.8
0.7
1
0.8
0.9
1.2
1
1.4
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
FORWARD VOLTAGE (V)
Fig.5 Typical Reverse Characteristics
Fig.6 Typical Forward Characteristics
10
TJ=150°C
ES1GAL
1
TJ=125°C
0.1
0.01
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
90 100
10
1.1
1.2
1.1
1.2
10
ES1GAL
1
UF1DLW
T =150°C
J
TJ=125°C
T =125°C
J
TJ=25°C
0.1
1
TJ=-55°C
0.01
0.001
0.1
0.3
0.4
TJ=25°C
(A)
INSTANTANEOUS REVERSE CURRENT (μA)
Fig.4 Typical Forward Characteristics
Fig.3 Typical Reverse Characteristics
10
100
REVERSE VOLTAGE (V)
Pulse widthPulse
300μs
width
1% duty cycle
0.4
0.6
0.5
0.8
0.6
1
0.7
0.8
1.2
0.9
1.4
1
1.6
FORWARD VOLTAGE (V)
3
Version: C2103
ES1BAL – ES1JAL
Fig.8 Typical Forward Characteristics
ES1JAL
10
TJ=150°C
1
TJ=125°C
0.1
0.01
0.001
TJ=25°C
0.0001
10
40
50
60
70
80
90 100
10
10
ES1JAL
UF1DLW
TJ=150°C
1
TJ=125°C
TJ=125°C
0.1
1
TJ=25°C
0.01
TJ=25°C
(A)
100
TJ=-55°C
0.001
0.1
0.3
0.4
0.5
0.3 0.5 0.7 0.9
Pulse widthPulse
300μs
width
1% duty cycle
0.6
1.1
0.7
0.8
0.9
1.3 1.5 1.7 1.9
1
2.1
1.1
FORWARD VOLTAGE (V)
Fig.9 Typical Transient Thermal Impedance
100
TRANSIENT THERMAL IMPEDANCE (°C/W)
Fig.7 Typical Reverse Characteristics
10
1
0.1
0.01
0.001
0.000001
0.00001
0.0001
0.001
0.01
0.1
1
10
100
PULSE DURATION (s)
4
Version: C2103
1.2
ES1BAL – ES1JAL
PACKAGE OUTLINE DIMENSIONS
Thin SMA
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
P/N = Marking Code
YW
= Date Code
F
= Factory Code
5
Version: C2103
ES1BAL – ES1JAL
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: C2103
很抱歉,暂时无法提供与“ES1GAL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.988931+0.51867
- 10+2.4159510+0.31414
- 100+1.50345100+0.19549
- 500+1.12976500+0.14690
- 1000+1.025481000+0.13334
- 2500+0.973342500+0.12656
- 国内价格 香港价格
- 1+4.499921+0.58512
- 10+2.7863310+0.36230
- 50+2.0140950+0.26189
- 100+1.76276100+0.22921
- 500+1.32025500+0.17167
- 国内价格
- 1+3.70480
- 10+2.24348
- 100+1.39663
- 500+1.05167
- 1000+0.94986
- 2500+0.90314
- 国内价格 香港价格
- 14000+0.8109414000+0.10545
- 42000+0.7166242000+0.09318
