SSH210H
SSH210H
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMB(DO-214AA)
    二极管 100 V 2A 表面贴装型 DO-214AA(SMB)
SSH210H 数据手册
SSH210H Taiwan Semiconductor 2A, 100V Schottky Barrier Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified Low power loss, high efficiency Ideal for automated placement Guard ring for overvoltage protection High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 2 A VRRM 100 V IFSM 75 A TJ MAX 175 °C Package DO-214AA (SMB) Configuration Single die APPLICATIONS ● ● ● ● ● Low voltage, high freq. inverter DC/DC converter Freewheeling diodes Reverse battery protection Car lighting MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.090g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device SSH210H UNIT SSH210 Repetitive peak reverse voltage VRRM 100 V Reverse voltage, total rms value VR(RMS) 70 V Forward current Surge peak forward current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 2 A IFSM 75 A TJ - 55 to +175 °C Storage temperature TSTG - 55 to +175 °C 1 Version: A2102 SSH210H Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-lead thermal resistance SYMBOL TYP UNIT RӨJL 24 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage CONDITIONS IF = 2A, TJ = 25°C (1) Reverse current @ rated VR IF = 2A, TJ = 125°C (2) TJ = 25°C SYMBOL VF IR TJ = 125°C TYP MAX UNIT - 0.79 V - 0.65 V - 1 µA - 1 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING SSH210H DO-214AA (SMB) 3,000 / Tape & Reel 2 Version: A2102 SSH210H Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 2 CAPACITANCE (pF) 1.5 1 100 0.5 f=1.0MHz Vslg=50mVp-p 10 0 50 75 100 125 LEAD TEMPERATURE 150 0.1 175 1000 100 TJ=125oC 1 0.1 TJ=25oC 0.01 0 20 40 60 80 100 Fig.4 Typical Forward Characteristics INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.3 Typical Reverse Characteristics 10 1 10 REVERSE VOLTAGE (V) (oC) 100 10 10 TJ=125oC TJ=125°C 1 TJ=25°C 0.1 TJ=25oC 0.01 Pulse width 0.001 0.3 0.1 0 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) UF1DLW 1 (A) AVERAGE FORWARD CURRENT (A) 2.5 0.2 0.4 0.4 0.5 0.6 0.6 0.7 0.8 0.8 1 0.9 1.2 1 1.1 1.4 1.6 FORWARD VOLTAGE (V) 3 Version: A2102 1.2 SSH210H Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Maximum Non-repetitive Forward Surge Current PEAK FORWARD SURGE CURRENT (A) 80 70 8.3ms single half sine wave 60 50 40 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 4 Version: A2102 SSH210H Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: A2102 SSH210H Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: A2102
SSH210H 价格&库存
很抱歉,暂时无法提供与“SSH210H”相匹配的价格&库存,您可以联系我们找货
SSH210H
  • 3000+1.549403000+0.20109
  • 9000+1.350509000+0.17527
库存:7356
SSH210H
  • 1+6.689371+0.86816
  • 10+4.1308010+0.53611
  • 50+3.0159750+0.39142
  • 100+2.65402100+0.34445
  • 500+2.01664500+0.26173
库存:7356
