S5QB
S5QB
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMB(DO-214AA)
    二极管 1200 V 5A 表面贴装型 DO-214AA(SMB)
S5QB 数据手册
S5QB Taiwan Semiconductor 5A, 1200V Standard Surface Mount Rectifier FEATURES ● ● ● ● ● ● KEY PARAMETERS Glass passivated chip junction Ideal for automated placement Low reverse leakage Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS ● Switch Mode Power Supply ● Inverters and Converters ● Freewheeling diode PARAMETER VALUE UNIT IF 5 A VRRM 1200 V IFSM 170 A TJ MAX 150 °C Package DO-214AA (SMB) Configuration Single die MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 1 whisker test Polarity: Indicated by cathode band Weight: 0.090g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device S5QB UNIT S5QB Repetitive peak reverse voltage VRRM 1200 V Reverse voltage, total rms value VR(RMS) 840 V IF 5 A 170 A 430 A Forward current Surge peak forward current single half sine-wave superimposed on rated load t = 8.3ms IFSM t = 1.0ms Junction temperature TJ -55 to +150 °C Storage temperature TSTG -55 to +150 °C 1 Version: B2102 S5QB Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 28 °C/W Junction-to-ambient thermal resistance RӨJA 49 °C/W Junction-to-case thermal resistance RӨJC 16 °C/W Thermal Performance Note: Units mounted on PCB (10mm x 10mm Cu pad test board) ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL IF = 2.5A, TJ = 25°C Forward voltage IF = 5.0A, TJ = 25°C (1) IF = 2.5A, TJ = 125°C VF IF = 5.0A, TJ = 125°C Reverse current @ rated VR (2) Junction capacitance TJ = 25°C IR TJ = 125°C 1MHz, VR = 4.0V CJ TYP MAX UNIT 0.89 - V 0.94 1.1 V 0.76 - V 0.83 0.95 V - 10 µA - 75 µA 36 - pF Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE PACKAGE PACKING S5QB DO-214AA (SMB) 3,000 / Tape & Reel 2 Version: B2102 S5QB Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 6 100 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 5 4 3 2 10 1 0 f=1.0MHz Vsig=50mVp-p 1 25 50 75 100 125 150 1 10 LEAD TEMPERATURE (°C) Fig.4 Typical Forward Characteristics TJ=150°C TJ=125°C 1 0.1 TJ=25°C 0.01 10 20 30 40 50 60 70 80 90 100 10 10 UF1DLW TJ=150°C 1 TJ=125°C TJ=125°C 0.1 1 TJ=25°C TJ=25°C (A) INSTANTANEOUS FORWARD CURRENT (A) 100 0.01 TJ=-55°C 0.001 0.1 0.3 0.4 Pulse widthPulse 300µs width 1% duty cycle 0.4 0.6 0.5 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 0.6 0.8 0.7 1 0.8 0.9 1.2 1 1.4 1.1 FORWARD VOLTAGE (V) Fig.5 Typical Transient Thermal Impedance 100 TRANSIENT THERMAL IMPEDANCE (°C/W) INSTANTANEOUS REVERSE CURRENT (μA) Fig.3 Typical Reverse Characteristics 10 100 REVERSE VOLTAGE (V) 10 1 0.1 0.01 0.001 0.0001 0.000001 0.00001 0.0001 0.001 0.01 0.1 1 10 100 PULSE DURATION (s) 3 Version: B2102 1.2 S5QB Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: B2102 S5QB Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: B2102
很抱歉,暂时无法提供与“S5QB”相匹配的价格&库存,您可以联系我们找货
