CSTP0740-700
CSTP0740-700
    CODACA(科达嘉)
    SMD,7.3x6mm
    共模电感
CSTP0740-700 数据手册
Common Mode Choke CSTP0740 Series Outline: 产品概要 Excellent impedance characteristics, making it great for suppressing common mode noise. Low profile design makes it optimal for surface mounting. Measures against common mode noise in power lines for various DC power lines, multimedia devices, and various electronic devices, including automotive power trains. Operating temperature : -40 +125 (Including coil’s temperature rise) 1 Appearance and Dimensions (mm) (mm) 7.3±0.3 3.5±0.3 3.5±0.3 2 3 1.6Typ. 6.0±0.3 Marking 3.0±0.3 1 1.7Typ. 2 Marking 3 Reference Land Pattern (mm) (mm) 4 4 Schematic 7.6 6.1 Marking 6.3 1.9 2 3 1 4 3.0 2.9 SHENZHEN CODACA ELECTRONIC CO., LTD This product is not authorized for use in any application related to safety. Specification subject to change without notice. Please check web site for latest information. TEL: +86 755 89585372 http://www.codaca.com FAX: +86 755 89585280 E-mail: info@codaca.com Revised: 12/11/2023 1/8 Common Mode Choke CSTP0740 Series 5 Electrical Characteristics Inductance (μH) Part No. Impedance (Ω) D.C.R. (mΩ) Rated Current (A) Rated Voltage (V) Insulation Resistance (MΩ) Min. Typical Min. Typical Typical Max. Max. Max. Min. CSTP0740-700 0.25 0.51 40 70 2.95 5.00 15.00 80.0 10.0 CSTP0740-141 0.40 1.10 100 140 4.10 5.00 9.00 80.0 10.0 CSTP0740-301 1.10 2.20 230 300 6.60 8.00 5.20 80.0 10.0 CSTP0740-501 1.50 3.00 300 500 8.80 10.0 5.00 80.0 10.0 CSTP0740-701 1.70 3.50 500 700 9.00 11.0 4.30 80.0 10.0 CSTP0740-102 2.50 5.00 800 1,000 12.0 14.5 3.60 80.0 10.0 CSTP0740-132 3.60 7.20 910 1,300 15.5 21.0 2.50 80.0 10.0 CSTP0740-272 6.50 13.5 2,000 2,700 43.5 55.0 1.00 80.0 10.0 CSTP0740-302 9.00 18.5 2,500 3,000 63.0 75.0 0.90 80.0 10.0 All data is tested based on 25 ambient temperature. 25 1 Inductance measure condition at 100KHz,0.1V. 100KHz,0.1V 2 Impedance measure condition at 100MHz,0.5V. 100MHz,0.5V 3 Rated current the value of DC current when the temperature rise is ΔT40 (Ta=25 ). ΔT40 (Ta=25 ) Special remind Circuit design, component placement, PCB size and thickness, cooling system and etc. all will affect the product temperature. Please verify the product temperature in the final application. (PCB) SHENZHEN CODACA ELECTRONIC CO., LTD This product is not authorized for use in any application related to safety. Specification subject to change without notice. Please check web site for latest information. TEL: +86 755 89585372 http://www.codaca.com FAX: +86 755 89585280 E-mail: info@codaca.com Revised: 12/11/2023 2/8 Common Mode Choke CSTP0740 Series 6 Impedance vs Frequency Curve 141 B-302 700 B-302 10,000 Impedance (Ω) 10,000 Impedance (Ω) 1,000 Common mode 100 Differential mode 10 Common mode 1,000 100 Differential mode 10 1 1 1 10 100 1,000 1 10 Frequency (MHz) 301 B-302 Impedance (Ω) 1,000 100.00 1,000.00 100.00 1,000.00 501 B-302 10,000 10,000 1,000 Common mode Impedance (Ω) 1,000 100 Differential mode Common mode 100 Differential mode 10 10 1 1 10 100 1,000 1.00 10.00 Frequency (MHz) Frequency (MHz) 701 B-302 102 B-302 10,000 Impedance (Ω) 100 Frequency (MHz) 10,000 1,000 Common mode Impedance (Ω) 1,000 Differential mode 100 Common mode 100 Differential mode 10 10 1 1 10 100 1,000 1.00 10.00 Frequency (MHz) Frequency (MHz) 272 B-302 132 B-302 10,000 10,000 Impedance (Ω) Impedance (Ω) Common mode 1,000 Common mode 100 Differential mode 10 1,000 Differential mode 100 10 1 1 1 10 100 1,000 Frequency (MHz) SHENZHEN CODACA ELECTRONIC CO., LTD This product is not authorized for use in any application related to safety. Specification subject to change without notice. Please check web site for latest information. 1 10 100 1,000 Frequency (MHz) TEL: +86 755 89585372 http://www.codaca.com FAX: +86 755 89585280 E-mail: info@codaca.com Revised: 12/11/2023 3/8 Common Mode Choke CSTP0740 Series 302 B-302 10,000 Common mode Impedance (Ω) 1,000 100 Differential mode 10 1 1.00 10.00 100.00 1,000.00 Frequency (MHz) SHENZHEN CODACA ELECTRONIC CO., LTD This product is not authorized for use in any application related to safety. Specification subject to change without notice. Please check web site for latest information. TEL: +86 755 89585372 http://www.codaca.com FAX: +86 755 89585280 E-mail: info@codaca.com Revised: 12/11/2023 4/8 Common Mode Choke CSTP0740 Series 7 Packing Specification 7.1 Carrier Tape Dimensions (mm) 4.4±0.1 4.2±0.1 4.0±0.1 2.0±0.1 +0.1 Φ1.5 -0 A 1.75±0.1 7.5±0.1 16.0±0.3 7.75±0.1 B A 0.4±0.05 (6.75) B 12.0±0.1 A-A 6.45±0.1 B-B Packing is referred to the international standard IEC 60286-3. IEC 60286-3 7.2 Tape Direction No component Cover tape Marking Start Marking Marking Marking End Carrier tape Sprocket hole Feeding direction Component No component 100mm Min. Cover tape 400mm Min. 160mm Min. 7.3 Cover Tape Peel Off Condition Cover tape Cover tape peel force shall be 0.1 to 1.3N. 0.1 1.3N Reference peel speed 300±10mm/min. 300±10mm/ 165°~180° Unreeling direction Pull direction Carrier tape SHENZHEN CODACA ELECTRONIC CO., LTD This product is not authorized for use in any application related to safety. Specification subject to change without notice. Please check web site for latest information. TEL: +86 755 89585372 http://www.codaca.com FAX: +86 755 89585280 E-mail: info@codaca.com Revised: 12/11/2023 5/8 Common Mode Choke CSTP0740 Series 7.4 Reel Dimensions (mm) (mm) W2 22.40 Max. W1 +2.0 16.4 -0 Label Cover tape 13.0±0.5 21.0±0.8 330±2.0 2.0±0.5 Sprocket hole 100 Min. Unreeling direction 15.90 Min. W3 7.5 Carton Dimensions and Packing Quantity ■ Inner Carton 340 340 95mm ■ Out Carton 360 360 370mm Product Series Quantity / Reel / Inner Carton Quantity Out Carton Quantity CSTP0740 1000pcs (1000 3) = 3000pcs (3000 3) = 9000pcs 7.6 Label Making The following items will be marked on the tray of product label and shipping label. Production Label Shipping Label ■ Packing No. ■ Packing No. ■ Quantity ■ Quantity ■Shipment Date ■Shipment Date ■ Part No. ■ Part No. ■Customer Part No. ■Customer Part No. ■ Customer Po No. ■ Customer Po No. SHENZHEN CODACA ELECTRONIC CO., LTD This product is not authorized for use in any application related to safety. Specification subject to change without notice. Please check web site for latest information. TEL: +86 755 89585372 http://www.codaca.com FAX: +86 755 89585280 E-mail: info@codaca.com Revised: 12/11/2023 6/8 Common Mode Choke CSTP0740 Series 8 Soldering Specification 8.1 Reflow Profile for SMT Components SMT T( ) TP Max. Ramp Up Rate = 3 /s Max. Ramp Down Rate = 6 /s TL 217 TS Max. 200 tP 20~30s TC -5 tL 60~150s Preheat Area Temperature TS Min. 150 tS 60~120s 25 t(s) 480s Max. (Time of 25℃ to peak temperature) Time 8.2 Classification of Peak Package Body Temperature (TP) (TP) Package Volume Package Thickness 2000 mm3
CSTP0740-700 价格&库存
很抱歉,暂时无法提供与“CSTP0740-700”相匹配的价格&库存,您可以联系我们找货
